Подключение гироскопа GY-521 на базе MPU 6050
Чт, 14/07/2016 - 22:28
Доброго времени суток! Пытаюсь подключить гироскоп Gy-521 на базе MPU 6050. Нашел вот такой код:
#include <Wire.h>
#include "Kalman.h"
Kalman kalmanX;
Kalman kalmanY;
uint8_t IMUAddress = 0x68;
/* IMU Data */
int16_t accX;
int16_t accY;
int16_t accZ;
int16_t tempRaw;
int16_t gyroX;
int16_t gyroY;
int16_t gyroZ;
double accXangle; // Angle calculate using the accelerometer
double accYangle;
double temp;
double gyroXangle = 180; // Angle calculate using the gyro
double gyroYangle = 180;
double compAngleX = 180; // Calculate the angle using a Kalman filter
double compAngleY = 180;
double kalAngleX; // Calculate the angle using a Kalman filter
double kalAngleY;
uint32_t timer;
Wire.begin();
i2cWrite(0x6B,0x00); // Disable sleep mode
kalmanX.setAngle(180); // Set starting angle
kalmanY.setAngle(180);
timer = micros();
/* Update all the values */
uint8_t* data = i2cRead(0x3B,14);
accX = ((data[0] << 8) | data[1]);
accY = ((data[2] << 8) | data[3]);
accZ = ((data[4] << 8) | data[5]);
tempRaw = ((data[6] << 8) | data[7]);
gyroX = ((data[8] << 8) | data[9]);
gyroY = ((data[10] << 8) | data[11]);
gyroZ = ((data[12] << 8) | data[13]);
/* Calculate the angls based on the different sensors and algorithm */
accYangle = (atan2(accX,accZ)+PI)*RAD_TO_DEG;
accXangle = (atan2(accY,accZ)+PI)*RAD_TO_DEG;
double gyroXrate = (double)gyroX/131.0;
double gyroYrate = -((double)gyroY/131.0);
gyroXangle += kalmanX.getRate()*((double)(micros()-timer)/1000000); // Calculate gyro angle using the unbiased rate
gyroYangle += kalmanY.getRate()*((double)(micros()-timer)/1000000);
kalAngleX = kalmanX.getAngle(accXangle, gyroXrate, (double)(micros()-timer)/1000000); // Calculate the angle using a Kalman filter
kalAngleY = kalmanY.getAngle(accYangle, gyroYrate, (double)(micros()-timer)/1000000);
timer = micros();
Serial.println();
Serial.print("X:");
Serial.print(kalAngleX,0);
Serial.print(" ");
Serial.print("Y:");
Serial.print(kalAngleY,0);
Serial.println(" ");
// The accelerometer's maximum samples rate is 1kHz
void i2cWrite(uint8_t registerAddress, uint8_t data){
Wire.beginTransmission(IMUAddress);
Wire.write(registerAddress);
Wire.write(data);
Wire.endTransmission(); // Send stop
uint8_t* i2cRead(uint8_t registerAddress, uint8_t nbytes) {
uint8_t data[nbytes];
Wire.endTransmission(false); // Don't release the bus
Wire.requestFrom(IMUAddress, nbytes); // Send a repeated start and then release the bus after reading
for(uint8_t i = 0; i < nbytes; i++)
data [i]= Wire.read();
return data;
При компиляции ругается: Ошибка компиляции для платы arduino/genuino uno. Compilation terminated. exit status 1. В чем может быть проблема? Помогите, пожалуйста, новичку!
1. Вставьте код как положено.
2. Скопируйте текст сообщения об ошибке полностью, ничего не опуская и опубликуйте.
Вот.
fatal error: Kalman.h: No such file or directory
Сие означает, что среда не может найти указанный файл. Проверяйте, установлена ли у вас библиотека нужная, или лежит ли указанный файл рядом со скетчем - вам виднее, чего там за Kalman.h у вас в скетче во второй строке подключается.
Библиотеку Kalman можно скачать здесь http://lesson.iarduino.ru/page/urok-11-podklyuchenie-giroskopa-gy-521-mpu-6050-k-arduio/ Это там же где вы брали код
Вот еще вопросик к этому же примеру. Если интересует узнать еще отклонения по оси Z, кто-нибудь дописывал код, как он будет выглядеть?
А то появилась потребность именно в этом значении, но почитать еще ничего по гироскопам и акселерометрам не успел.
Погуглите по слову DMP MPU 6051.
Z будет в нулевой точке в зависимости от положения гироскопа в момент включения. Для нормального отслеживания нужен еще компас(магнитометр.)
