Помогите с запуском экрана
garfiik
Есть ардуино мега
Экран: https://ru.aliexpress.com/item/Free-shipping-LCD-Display-Module-TFT-3-95-inch-TFT-LCD-screen-for-Arduino-UNO-R3/32588903711.html?spm=a2g0s.9042311.0.0.EDnnfU
НЕ является ILI9488 480X240 ЭКРАН. товар поставляется в ST7793 400x240
продовец дал вот это
//st7793
Lcd_Write_Com(0x0001);Lcd_Write_Data(0x0100);
 Lcd_Write_Com(0x0003);Lcd_Write_Data(0x1030); //9030
 Lcd_Write_Com(0x0008);Lcd_Write_Data(0x0808);
 Lcd_Write_Com(0x0090);Lcd_Write_Data(0x8000);
 Lcd_Write_Com(0x0400);Lcd_Write_Data(0x6200);
 Lcd_Write_Com(0x0401);Lcd_Write_Data(0x0001);
 //-----------------------------------End Display Control setting-----------------------------------------//
 //-------------------------------- Power Control Registers Initial --------------------------------------//
 Lcd_Write_Com(0x00ff);Lcd_Write_Data(0x0001);
 Lcd_Write_Com(0x0102);Lcd_Write_Data(0x01b0);
 Lcd_Write_Com(0x0710);Lcd_Write_Data(0x0016);
 Lcd_Write_Com(0x0712);Lcd_Write_Data(0x000f);
 Lcd_Write_Com(0x0752);Lcd_Write_Data(0x002f);
 Lcd_Write_Com(0x0724);Lcd_Write_Data(0x001a);
 Lcd_Write_Com(0x0754);Lcd_Write_Data(0x002a);
 //---------------------------------End Power Control Registers Initial -------------------------------//
 delay(100);
 //----------------------------------Display Windows 240 X 400----------------------------------------//
 Lcd_Write_Com(0x0210);Lcd_Write_Data(0x0000);
 Lcd_Write_Com(0x0211);Lcd_Write_Data(0x00ef);
 Lcd_Write_Com(0x0212);Lcd_Write_Data(0x0000);
 Lcd_Write_Com(0x0213);Lcd_Write_Data(0x018f);
 //----------------------------------End Display Windows 240 X 400----------------------------------//
 delay(10);
 //-------------------------------------Gamma Cluster Setting-------------------------------------------//
 Lcd_Write_Com(0x0380);Lcd_Write_Data(0x0000);
 Lcd_Write_Com(0x0381);Lcd_Write_Data(0x5f10);
 Lcd_Write_Com(0x0382);Lcd_Write_Data(0x0b02);
 Lcd_Write_Com(0x0383);Lcd_Write_Data(0x0614);
 Lcd_Write_Com(0x0384);Lcd_Write_Data(0x0111);
 Lcd_Write_Com(0x0385);Lcd_Write_Data(0x0000);
 Lcd_Write_Com(0x0386);Lcd_Write_Data(0xa90b);
 Lcd_Write_Com(0x0387);Lcd_Write_Data(0x0606);
 Lcd_Write_Com(0x0388);Lcd_Write_Data(0x0612);
 Lcd_Write_Com(0x0389);Lcd_Write_Data(0x0111);
 //---------------------------------------End Gamma Setting---------------------------------------------//
 //---------------------------------------Vcom Setting---------------------------------------------//
 Lcd_Write_Com(0x0702);Lcd_Write_Data(0x003b);
 Lcd_Write_Com(0x00ff);Lcd_Write_Data(0x0000);
 //---------------------------------------End Vcom Setting---------------------------------------------//
 Lcd_Write_Com(0x0007);Lcd_Write_Data(0x0100);
 delay(200); //Delay 200ms
 Lcd_Write_Com(0x0200);Lcd_Write_Data(0x0000);
 Lcd_Write_Com(0x0201);Lcd_Write_Data(0x0000);
как с этим работать
Обсуждение и решение проблемы с бибилиотекой - https://forum.arduino.cc/index.php?topic=418569.0 (вроед всё решилось)
Даташит - http://orientdisplay.com/pdf/ST7793.pdf
MaksVV
может попробовать библиотеку mcuFriend ?
garfiik
я так понял это под уно, а у меня мега.
у меня остаются еще вопросы о правильности подключения
garfiik
Спасибо помогло
garfiik
разобрался с выводом информации
получилось запустить тач
теперь новый вопрос как организовать программу чтобы была быстрая реакция на нажатие на тач.
как сделать прерывание программы при нажатии на тач
uint8_t YP = A1;  // must be an analog pin, use "An" notation!
uint8_t XM = A2;  // must be an analog pin, use "An" notation!
uint8_t YM = 7;   // can be a digital pin
uint8_t XP = 6;   // can be a digital pin
у меги прерывания на других пинах
garfiik пишет:
Ну, так поменяйте пины. Кто-то или что-то мешает? Или они там в граните отлиты?
garfiik
Ну если единственный способ использовать прерывание с пинов пока что не буду этим заморачиватся только если будут проблемы с торможением тача
