Программный i2c 1 МГц (для 16 МГц устройств) для AVR.
Пт, 04/12/2020 - 14:49
Размер кода 138 байт.
Можно назначить SCL и SDA на любые выводы.
Для ASM:
Для C++:
#define SCLPORT PORTC #define SCLPIN PORTC5 #define SDAPORT PORTC #define SDAPIN PORTC4 void __attribute__ ((noinline)) i2c_init() { asm volatile( "CBI %0-1,%1\n\t" "CBI %2-1,%3\n\t" "CBI %2,%3\n\t" "CBI %0,%1\n\t" ::"I" (_SFR_IO_ADDR(SCLPORT)), "I" (SCLPIN), "I" (_SFR_IO_ADDR(SDAPORT)), "I" (SDAPIN) ); } void __attribute__ ((noinline)) i2c_start() { asm volatile( "SBI %0-1,%1\n\t" ::"I" (_SFR_IO_ADDR(SDAPORT)), "I" (SDAPIN) ); } void __attribute__ ((noinline)) i2c_restart() { asm volatile( "CBI %0-1,%1\n\t" "CBI %0-1,%1\n\t" //replacement for two NOP // "NOP\n\t" // "NOP\n\t" "SBI %2-1,%3\n\t" ::"I" (_SFR_IO_ADDR(SCLPORT)), "I" (SCLPIN), "I" (_SFR_IO_ADDR(SDAPORT)), "I" (SDAPIN) ); } uint8_t __attribute__ ((noinline)) i2c_write(uint8_t data) { uint8_t result; uint8_t i=8; asm volatile( "i2c_write_loop:" "SBI %1-1,%2\n\t" "SBRC %5,7\n\t" "CBI %3-1,%4\n\t" "SBRS %5,7\n\t" "SBI %3-1,%4\n\t" "ROL %5\n\t" "CBI %1-1,%2\n\t" "i2c_write_loop1:" "SBIS %1-2,%2\n\t" "RJMP i2c_write_loop1\n\t" "NOP\n\t" "DEC %6\n\t" "BRNE i2c_write_loop\n\t" "NOP\n\t" "SBI %1-1,%2\n\t" "CBI %3-1,%4\n\t" "CBI %3-1,%4\n\t" //replacement for two NOP "CBI %3-1,%4\n\t" //replacement for two NOP // "NOP\n\t" // "NOP\n\t" // "NOP\n\t" // "NOP\n\t" "CBI %1-1,%2\n\t" "CLR %0\n\t" "SBIS %3-2,%4\n\t" "INC %0\n\t" "CBI %1-1,%2\n\t" //replacement for two NOP // "NOP\n\t" // "NOP\n\t" "NOP\n\t" "SBI %1-1,%2\n\t" : "=r" (result) : "I" (_SFR_IO_ADDR(SCLPORT)), "I" (SCLPIN), "I" (_SFR_IO_ADDR(SDAPORT)), "I" (SDAPIN), "r" (data), "r" (i) ); return result; } uint8_t __attribute__ ((noinline)) i2c_read(uint8_t last=false) { uint8_t result; uint8_t i=8; asm volatile( "BST %0,0\n\t" "i2c_read_loop:\n\t" "SBI %1-1,%2\n\t" "SBI %1-1,%2\n\t" //replacement for two NOP "SBI %1-1,%2\n\t" //replacement for two NOP // "NOP\n\t" // "NOP\n\t" // "NOP\n\t" // "NOP\n\t" "BLD %0,0\n\t" "LSL %0\n\t" "CBI %1-1,%2\n\t" "SET\n\t" "SBIS %3-2,%4\n\t" "CLT\n\t" "DEC %6\n\t" "BRNE i2c_read_loop\n\t" "BLD %0,0\n\t" "SBI %1-1,%2\n\t" "ROL %6\n\t" "SBRS %6,0\n\t" "SBI %3-1,%4\n\t" "SBRC %6,0\n\t" "CBI %3-1,%4\n\t" "CBI %1-1,%2\n\t" "CBI %1-1,%2\n\t" //replacement for two NOP "CBI %1-1,%2\n\t" //replacement for two NOP "CBI %1-1,%2\n\t" //replacement for two NOP // "NOP\n\t" // "NOP\n\t" // "NOP\n\t" // "NOP\n\t" // "NOP\n\t" // "NOP\n\t" "SBI %1-1,%2\n\t" "CBI %3-1,%4\n\t" : "=r" (result) : "I" (_SFR_IO_ADDR(SCLPORT)), "I" (SCLPIN), "I" (_SFR_IO_ADDR(SDAPORT)), "I" (SDAPIN), "r" (last), "r" (i) ); return result; } void __attribute__ ((noinline)) i2c_stop() { asm volatile( "SBI %2-1,%3\n\t" "CBI %0-1,%1\n\t" "CBI %0-1,%1\n\t" //replacement for two NOP // "NOP\n\t" // "NOP\n\t" "CBI %2-1,%3\n\t" ::"I" (_SFR_IO_ADDR(SCLPORT)), "I" (SCLPIN), "I" (_SFR_IO_ADDR(SDAPORT)), "I" (SDAPIN) ); } void setup() { Serial.begin(9600); i2c_init(); } void loop() { uint8_t b,b1; i2c_start(); i2c_write(0x40<<1); i2c_write(0x03); i2c_write(0x11); i2c_stop(); do { i2c_start(); i2c_write(0x40<<1); i2c_write(0x00); i2c_restart(); i2c_write(0x40<<1 | 0x01); b=i2c_read(true); i2c_stop(); } while (b & 0x01); i2c_start(); i2c_write(0x40<<1); i2c_write(0x01); i2c_restart(); i2c_write(0x40<<1 | 0x01); b=i2c_read(false); b1=i2c_read(true); i2c_stop(); Serial.print(b, HEX); Serial.print(" "); Serial.println(b1, HEX); delay(1000); delay(100); }Помимо самих функций для интерфейса i2c - код содержит примеры, для схемы:
В железе тестировал на OLED 128x32 SSD1306. Код для него ещё короче, так как не нужны функции i2c_restart и i2c_read.
192 кадра в секунду !!!
1 000 000 / 1024 / 192 = 5,0862630208333333333333333333333
Т.е. Вы передаете байт за 5 тактов?
Можно привести исходник, который можно было бы "пощупать"?
Прошу прощения, не обратил внимания, что х32, а не х64, тогда 96 кадров для х64 - все сходится.
Но просьба насчет исходника остается.
Вот код для для SSD1306 128x32:
#define SCLPORT PORTC #define SCLPIN PORTC5 #define SDAPORT PORTC #define SDAPIN PORTC4 #include <avr/pgmspace.h> void __attribute__ ((noinline)) i2c_init() { asm volatile( "CBI %0-1,%1\n\t" "CBI %2-1,%3\n\t" "CBI %2,%3\n\t" "CBI %0,%1\n\t" ::"I" (_SFR_IO_ADDR(SCLPORT)), "I" (SCLPIN), "I" (_SFR_IO_ADDR(SDAPORT)), "I" (SDAPIN) ); } void __attribute__ ((noinline)) i2c_start() { asm volatile( "SBI %0-1,%1\n\t" ::"I" (_SFR_IO_ADDR(SDAPORT)), "I" (SDAPIN) ); } uint8_t __attribute__ ((noinline)) i2c_write(uint8_t data) { uint8_t result; uint8_t i=8; asm volatile( "i2c_write_loop:" "SBI %1-1,%2\n\t" "SBRC %5,7\n\t" "CBI %3-1,%4\n\t" "SBRS %5,7\n\t" "SBI %3-1,%4\n\t" "ROL %5\n\t" "CBI %1-1,%2\n\t" "i2c_write_loop1:" "SBIS %1-2,%2\n\t" "RJMP i2c_write_loop1\n\t" "NOP\n\t" "DEC %6\n\t" "BRNE i2c_write_loop\n\t" "NOP\n\t" "SBI %1-1,%2\n\t" "CBI %3-1,%4\n\t" "CBI %3-1,%4\n\t" //replacement for two NOP "CBI %3-1,%4\n\t" //replacement for two NOP // "NOP\n\t" // "NOP\n\t" // "NOP\n\t" // "NOP\n\t" "CBI %1-1,%2\n\t" "CLR %0\n\t" "SBIS %3-2,%4\n\t" "INC %0\n\t" "CBI %1-1,%2\n\t" //replacement for two NOP // "NOP\n\t" // "NOP\n\t" "NOP\n\t" "SBI %1-1,%2\n\t" : "=r" (result) : "I" (_SFR_IO_ADDR(SCLPORT)), "I" (SCLPIN), "I" (_SFR_IO_ADDR(SDAPORT)), "I" (SDAPIN), "r" (data), "r" (i) ); return result; } void __attribute__ ((noinline)) i2c_stop() { asm volatile( "SBI %2-1,%3\n\t" "CBI %0-1,%1\n\t" "CBI %0-1,%1\n\t" //replacement for two NOP // "NOP\n\t" // "NOP\n\t" "CBI %2-1,%3\n\t" ::"I" (_SFR_IO_ADDR(SCLPORT)), "I" (SCLPIN), "I" (_SFR_IO_ADDR(SDAPORT)), "I" (SDAPIN) ); } static const uint8_t PROGMEM init_bytes[]={0x3C<<1,0x00,0xAE,0xD5,0x80,0xA8,0x1F,0xD3,0x00,0x40,0x8D,0x14,0x20,0x00,0xA0,0xC0, 0xDA,0x02,0xD9,0xF1,0xDB,0x40,0x21,0x00,0x7f,0x22,0x00,0x03,0xA4,0xA6,0xAF}; static const uint8_t PROGMEM impreza[] = { 0xF8, 0xF8, 0x00, 0x00, 0xF8, 0xF8, 0x38, 0x70, 0xE0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xE0, 0x70, 0x38, 0xF8, 0xF8, 0x00, 0x00, 0xF8, 0xF8, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x38, 0xF0, 0xE0, 0x00, 0x00, 0xF8, 0xF8, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x38, 0xF0, 0xE0, 0x00, 0x00, 0xE0, 0xF0, 0x38, 0x18, 0x98, 0x98, 0x98, 0x98, 0x98, 0x98, 0x98, 0x98, 0x98, 0x98, 0x98, 0x98, 0x98, 0x98, 0x98, 0x00, 0x00, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x98, 0x98, 0xD8, 0xD8, 0x78, 0x78, 0x38, 0x38, 0x18, 0x18, 0x00, 0x00, 0xE0, 0xF0, 0x38, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x38, 0xF0, 0xE0, 0x1F, 0x1F, 0x00, 0x00, 0x1F, 0x1F, 0x00, 0x00, 0x00, 0x01, 0x03, 0x07, 0x0E, 0x1C, 0x0E, 0x07, 0x03, 0x01, 0x00, 0x00, 0x00, 0x1F, 0x1F, 0x00, 0x00, 0x1F, 0x1F, 0x00, 0x00, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x07, 0x03, 0x01, 0x00, 0x00, 0x1F, 0x1F, 0x00, 0x00, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x0E, 0x1F, 0x1B, 0x11, 0x00, 0x00, 0x07, 0x0F, 0x1C, 0x18, 0x19, 0x19, 0x19, 0x19, 0x19, 0x19, 0x19, 0x19, 0x19, 0x19, 0x19, 0x19, 0x19, 0x19, 0x19, 0x00, 0x00, 0x18, 0x18, 0x1C, 0x1C, 0x1E, 0x1E, 0x1B, 0x1B, 0x19, 0x19, 0x19, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x00, 0x00, 0x1F, 0x1F, 0x00, 0x00, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x06, 0x1F, 0x1F}; void setup() { i2c_init(); i2c_start(); for(uint8_t i=0;i<sizeof(init_bytes);i++) i2c_write(pgm_read_byte(init_bytes+i)); i2c_stop(); i2c_start(); i2c_write(0x3C<<1); i2c_write(0x40); } void loop() { for(uint8_t i=0;i<=127;i++) i2c_write(0x00); for(uint16_t i=0;i<=255;i++) i2c_write(pgm_read_byte(impreza+i)); for(uint8_t i=0;i<=127;i++) i2c_write(0x00); while (1) {}; }Это софтверный I2C на стандартных хардверных ногах?
Для ASM:
Снимаю шляпу. :-)
Ноги можно прописать любые в самом начале ...
1.equ SCLPORT=PORTC2.equ SCLPIN=PORTC53.equ SDAPORT=PORTC.equ SDAPIN=PORTC4А как это работает???
Пропишите те порты и пины, где у Вас живет i2c девайс и компилируйте/заливайте/тестируйте ...
Эти alias-ы реально переключают порт(ы) со входа на выход и наоборот???
Просто я не понимаю, как это работает.
Нет. Они используются дальше в командах - пример CBI SCLPORT-1,SCLPIN
Макроподстановка однако ...
Нижнюю строчку поправь, а то галиматья получается
.equ SDAPIN=PORTC4Нижнюю строчку поправь, а то галиматья получается
.equ SDAPIN=PORTC4У меня то вроде всё четко ...
SBI - поставим бит в порту
CBI - сбросим (абнулим) бит в порту.
Это понятно, зачем ЧЕТЫРЕ алиаса?????????????
Две пары ПОРТ + ПИН
Есть возможность выложить РАЗДЭЗ ассемблерного кода? Реально не понятно, как софт работает с портами.
Ну или скомпиль в объектник, я сам раздезю и гляну.
AVRASM ver. 2.1.42 ..\main.asm Fri Dec 04 20:24:30 2020 [builtin](2): Including file 'C:\Program Files (x86)\Labcenter Electronics\Proteus 8 Professional\Tools\AVRASM\appnotes\m328Pdef.inc' .equ SCLPORT=PORTC ;***** Created: 2010-02-25 11:46 ******* Source: ATmega328P.xml ********** ;************************************************************************* ;* A P P L I C A T I O N N O T E F O R T H E A V R F A M I L Y ;* ;* Number : AVR000 ;* File Name : "m328Pdef.inc" ;* Title : Register/Bit Definitions for the ATmega328P ;* Date : 2010-02-25 ;* Version : 2.35 ;* Support E-mail : avr@atmel.com ;* Target MCU : ATmega328P ;* ;* DESCRIPTION ;* When including this file in the assembly program file, all I/O register ;* names and I/O register bit names appearing in the data book can be used. ;* In addition, the six registers forming the three data pointers X, Y and ;* Z have been assigned names XL - ZH. Highest RAM address for Internal ;* SRAM is also defined ;* ;* The Register names are represented by their hexadecimal address. ;* ;* The Register Bit names are represented by their bit number (0-7). ;* ;* Please observe the difference in using the bit names with instructions ;* such as "sbr"/"cbr" (set/clear bit in register) and "sbrs"/"sbrc" ;* (skip if bit in register set/cleared). The following example illustrates ;* this: ;* ;* in r16,PORTB ;read PORTB latch ;* sbr r16,(1<<PB6)+(1<<PB5) ;set PB6 and PB5 (use masks, not bit#) ;* out PORTB,r16 ;output to PORTB ;* ;* in r16,TIFR ;read the Timer Interrupt Flag Register ;* sbrc r16,TOV0 ;test the overflow flag (use bit#) ;* rjmp TOV0_is_set ;jump if set ;* ... ;otherwise do something else ;************************************************************************* #ifndef _M328PDEF_INC_ #define _M328PDEF_INC_ #pragma partinc 0 ; ***** SPECIFY DEVICE *************************************************** .device ATmega328P #pragma AVRPART ADMIN PART_NAME ATmega328P .equ SIGNATURE_000 = 0x1e .equ SIGNATURE_001 = 0x95 .equ SIGNATURE_002 = 0x0f #pragma AVRPART CORE CORE_VERSION V2E ; ***** I/O REGISTER DEFINITIONS ***************************************** ; NOTE: ; Definitions marked "MEMORY MAPPED"are extended I/O ports ; and cannot be used with IN/OUT instructions .equ UDR0 = 0xc6 ; MEMORY MAPPED .equ UBRR0L = 0xc4 ; MEMORY MAPPED .equ UBRR0H = 0xc5 ; MEMORY MAPPED .equ UCSR0C = 0xc2 ; MEMORY MAPPED .equ UCSR0B = 0xc1 ; MEMORY MAPPED .equ UCSR0A = 0xc0 ; MEMORY MAPPED .equ TWAMR = 0xbd ; MEMORY MAPPED .equ TWCR = 0xbc ; MEMORY MAPPED .equ TWDR = 0xbb ; MEMORY MAPPED .equ TWAR = 0xba ; MEMORY MAPPED .equ TWSR = 0xb9 ; MEMORY MAPPED .equ TWBR = 0xb8 ; MEMORY MAPPED .equ ASSR = 0xb6 ; MEMORY MAPPED .equ OCR2B = 0xb4 ; MEMORY MAPPED .equ OCR2A = 0xb3 ; MEMORY MAPPED .equ TCNT2 = 0xb2 ; MEMORY MAPPED .equ TCCR2B = 0xb1 ; MEMORY MAPPED .equ TCCR2A = 0xb0 ; MEMORY MAPPED .equ OCR1BL = 0x8a ; MEMORY MAPPED .equ OCR1BH = 0x8b ; MEMORY MAPPED .equ OCR1AL = 0x88 ; MEMORY MAPPED .equ OCR1AH = 0x89 ; MEMORY MAPPED .equ ICR1L = 0x86 ; MEMORY MAPPED .equ ICR1H = 0x87 ; MEMORY MAPPED .equ TCNT1L = 0x84 ; MEMORY MAPPED .equ TCNT1H = 0x85 ; MEMORY MAPPED .equ TCCR1C = 0x82 ; MEMORY MAPPED .equ TCCR1B = 0x81 ; MEMORY MAPPED .equ TCCR1A = 0x80 ; MEMORY MAPPED .equ DIDR1 = 0x7f ; MEMORY MAPPED .equ DIDR0 = 0x7e ; MEMORY MAPPED .equ ADMUX = 0x7c ; MEMORY MAPPED .equ ADCSRB = 0x7b ; MEMORY MAPPED .equ ADCSRA = 0x7a ; MEMORY MAPPED .equ ADCH = 0x79 ; MEMORY MAPPED .equ ADCL = 0x78 ; MEMORY MAPPED .equ TIMSK2 = 0x70 ; MEMORY MAPPED .equ TIMSK1 = 0x6f ; MEMORY MAPPED .equ TIMSK0 = 0x6e ; MEMORY MAPPED .equ PCMSK1 = 0x6c ; MEMORY MAPPED .equ PCMSK2 = 0x6d ; MEMORY MAPPED .equ PCMSK0 = 0x6b ; MEMORY MAPPED .equ EICRA = 0x69 ; MEMORY MAPPED .equ PCICR = 0x68 ; MEMORY MAPPED .equ OSCCAL = 0x66 ; MEMORY MAPPED .equ PRR = 0x64 ; MEMORY MAPPED .equ CLKPR = 0x61 ; MEMORY MAPPED .equ WDTCSR = 0x60 ; MEMORY MAPPED .equ SREG = 0x3f .equ SPL = 0x3d .equ SPH = 0x3e .equ SPMCSR = 0x37 .equ MCUCR = 0x35 .equ MCUSR = 0x34 .equ SMCR = 0x33 .equ ACSR = 0x30 .equ SPDR = 0x2e .equ SPSR = 0x2d .equ SPCR = 0x2c .equ GPIOR2 = 0x2b .equ GPIOR1 = 0x2a .equ OCR0B = 0x28 .equ OCR0A = 0x27 .equ TCNT0 = 0x26 .equ TCCR0B = 0x25 .equ TCCR0A = 0x24 .equ GTCCR = 0x23 .equ EEARH = 0x22 .equ EEARL = 0x21 .equ EEDR = 0x20 .equ EECR = 0x1f .equ GPIOR0 = 0x1e .equ EIMSK = 0x1d .equ EIFR = 0x1c .equ PCIFR = 0x1b .equ TIFR2 = 0x17 .equ TIFR1 = 0x16 .equ TIFR0 = 0x15 .equ PORTD = 0x0b .equ DDRD = 0x0a .equ PIND = 0x09 .equ PORTC = 0x08 .equ DDRC = 0x07 .equ PINC = 0x06 .equ PORTB = 0x05 .equ DDRB = 0x04 .equ PINB = 0x03 ; ***** BIT DEFINITIONS ************************************************** ; ***** USART0 *********************** ; UDR0 - USART I/O Data Register .equ UDR0_0 = 0 ; USART I/O Data Register bit 0 .equ UDR0_1 = 1 ; USART I/O Data Register bit 1 .equ UDR0_2 = 2 ; USART I/O Data Register bit 2 .equ UDR0_3 = 3 ; USART I/O Data Register bit 3 .equ UDR0_4 = 4 ; USART I/O Data Register bit 4 .equ UDR0_5 = 5 ; USART I/O Data Register bit 5 .equ UDR0_6 = 6 ; USART I/O Data Register bit 6 .equ UDR0_7 = 7 ; USART I/O Data Register bit 7 ; UCSR0A - USART Control and Status Register A .equ MPCM0 = 0 ; Multi-processor Communication Mode .equ U2X0 = 1 ; Double the USART transmission speed .equ UPE0 = 2 ; Parity Error .equ DOR0 = 3 ; Data overRun .equ FE0 = 4 ; Framing Error .equ UDRE0 = 5 ; USART Data Register Empty .equ TXC0 = 6 ; USART Transmitt Complete .equ RXC0 = 7 ; USART Receive Complete ; UCSR0B - USART Control and Status Register B .equ TXB80 = 0 ; Transmit Data Bit 8 .equ RXB80 = 1 ; Receive Data Bit 8 .equ UCSZ02 = 2 ; Character Size .equ TXEN0 = 3 ; Transmitter Enable .equ RXEN0 = 4 ; Receiver Enable .equ UDRIE0 = 5 ; USART Data register Empty Interrupt Enable .equ TXCIE0 = 6 ; TX Complete Interrupt Enable .equ RXCIE0 = 7 ; RX Complete Interrupt Enable ; UCSR0C - USART Control and Status Register C .equ UCPOL0 = 0 ; Clock Polarity .equ UCSZ00 = 1 ; Character Size .equ UCPHA0 = UCSZ00 ; For compatibility .equ UCSZ01 = 2 ; Character Size .equ UDORD0 = UCSZ01 ; For compatibility .equ USBS0 = 3 ; Stop Bit Select .equ UPM00 = 4 ; Parity Mode Bit 0 .equ UPM01 = 5 ; Parity Mode Bit 1 .equ UMSEL00 = 6 ; USART Mode Select .equ UMSEL0 = UMSEL00 ; For compatibility .equ UMSEL01 = 7 ; USART Mode Select .equ UMSEL1 = UMSEL01 ; For compatibility ; UBRR0H - USART Baud Rate Register High Byte .equ UBRR8 = 0 ; USART Baud Rate Register bit 8 .equ UBRR9 = 1 ; USART Baud Rate Register bit 9 .equ UBRR10 = 2 ; USART Baud Rate Register bit 10 .equ UBRR11 = 3 ; USART Baud Rate Register bit 11 ; UBRR0L - USART Baud Rate Register Low Byte .equ _UBRR0 = 0 ; USART Baud Rate Register bit 0 .equ _UBRR1 = 1 ; USART Baud Rate Register bit 1 .equ UBRR2 = 2 ; USART Baud Rate Register bit 2 .equ UBRR3 = 3 ; USART Baud Rate Register bit 3 .equ UBRR4 = 4 ; USART Baud Rate Register bit 4 .equ UBRR5 = 5 ; USART Baud Rate Register bit 5 .equ UBRR6 = 6 ; USART Baud Rate Register bit 6 .equ UBRR7 = 7 ; USART Baud Rate Register bit 7 ; ***** TWI ************************** ; TWAMR - TWI (Slave) Address Mask Register .equ TWAM0 = 1 ; .equ TWAMR0 = TWAM0 ; For compatibility .equ TWAM1 = 2 ; .equ TWAMR1 = TWAM1 ; For compatibility .equ TWAM2 = 3 ; .equ TWAMR2 = TWAM2 ; For compatibility .equ TWAM3 = 4 ; .equ TWAMR3 = TWAM3 ; For compatibility .equ TWAM4 = 5 ; .equ TWAMR4 = TWAM4 ; For compatibility .equ TWAM5 = 6 ; .equ TWAMR5 = TWAM5 ; For compatibility .equ TWAM6 = 7 ; .equ TWAMR6 = TWAM6 ; For compatibility ; TWBR - TWI Bit Rate register .equ TWBR0 = 0 ; .equ TWBR1 = 1 ; .equ TWBR2 = 2 ; .equ TWBR3 = 3 ; .equ TWBR4 = 4 ; .equ TWBR5 = 5 ; .equ TWBR6 = 6 ; .equ TWBR7 = 7 ; ; TWCR - TWI Control Register .equ TWIE = 0 ; TWI Interrupt Enable .equ TWEN = 2 ; TWI Enable Bit .equ TWWC = 3 ; TWI Write Collition Flag .equ TWSTO = 4 ; TWI Stop Condition Bit .equ TWSTA = 5 ; TWI Start Condition Bit .equ TWEA = 6 ; TWI Enable Acknowledge Bit .equ TWINT = 7 ; TWI Interrupt Flag ; TWSR - TWI Status Register .equ TWPS0 = 0 ; TWI Prescaler .equ TWPS1 = 1 ; TWI Prescaler .equ TWS3 = 3 ; TWI Status .equ TWS4 = 4 ; TWI Status .equ TWS5 = 5 ; TWI Status .equ TWS6 = 6 ; TWI Status .equ TWS7 = 7 ; TWI Status ; TWDR - TWI Data register .equ TWD0 = 0 ; TWI Data Register Bit 0 .equ TWD1 = 1 ; TWI Data Register Bit 1 .equ TWD2 = 2 ; TWI Data Register Bit 2 .equ TWD3 = 3 ; TWI Data Register Bit 3 .equ TWD4 = 4 ; TWI Data Register Bit 4 .equ TWD5 = 5 ; TWI Data Register Bit 5 .equ TWD6 = 6 ; TWI Data Register Bit 6 .equ TWD7 = 7 ; TWI Data Register Bit 7 ; TWAR - TWI (Slave) Address register .equ TWGCE = 0 ; TWI General Call Recognition Enable Bit .equ TWA0 = 1 ; TWI (Slave) Address register Bit 0 .equ TWA1 = 2 ; TWI (Slave) Address register Bit 1 .equ TWA2 = 3 ; TWI (Slave) Address register Bit 2 .equ TWA3 = 4 ; TWI (Slave) Address register Bit 3 .equ TWA4 = 5 ; TWI (Slave) Address register Bit 4 .equ TWA5 = 6 ; TWI (Slave) Address register Bit 5 .equ TWA6 = 7 ; TWI (Slave) Address register Bit 6 ; ***** TIMER_COUNTER_1 ************** ; TIMSK1 - Timer/Counter Interrupt Mask Register .equ TOIE1 = 0 ; Timer/Counter1 Overflow Interrupt Enable .equ OCIE1A = 1 ; Timer/Counter1 Output CompareA Match Interrupt Enable .equ OCIE1B = 2 ; Timer/Counter1 Output CompareB Match Interrupt Enable .equ ICIE1 = 5 ; Timer/Counter1 Input Capture Interrupt Enable ; TIFR1 - Timer/Counter Interrupt Flag register .equ TOV1 = 0 ; Timer/Counter1 Overflow Flag .equ OCF1A = 1 ; Output Compare Flag 1A .equ OCF1B = 2 ; Output Compare Flag 1B .equ ICF1 = 5 ; Input Capture Flag 1 ; TCCR1A - Timer/Counter1 Control Register A .equ WGM10 = 0 ; Waveform Generation Mode .equ WGM11 = 1 ; Waveform Generation Mode .equ COM1B0 = 4 ; Compare Output Mode 1B, bit 0 .equ COM1B1 = 5 ; Compare Output Mode 1B, bit 1 .equ COM1A0 = 6 ; Comparet Ouput Mode 1A, bit 0 .equ COM1A1 = 7 ; Compare Output Mode 1A, bit 1 ; TCCR1B - Timer/Counter1 Control Register B .equ CS10 = 0 ; Prescaler source of Timer/Counter 1 .equ CS11 = 1 ; Prescaler source of Timer/Counter 1 .equ CS12 = 2 ; Prescaler source of Timer/Counter 1 .equ WGM12 = 3 ; Waveform Generation Mode .equ WGM13 = 4 ; Waveform Generation Mode .equ ICES1 = 6 ; Input Capture 1 Edge Select .equ ICNC1 = 7 ; Input Capture 1 Noise Canceler ; TCCR1C - Timer/Counter1 Control Register C .equ FOC1B = 6 ; .equ FOC1A = 7 ; ; GTCCR - General Timer/Counter Control Register .equ PSRSYNC = 0 ; Prescaler Reset Timer/Counter1 and Timer/Counter0 .equ TSM = 7 ; Timer/Counter Synchronization Mode ; ***** TIMER_COUNTER_2 ************** ; TIMSK2 - Timer/Counter Interrupt Mask register .equ TOIE2 = 0 ; Timer/Counter2 Overflow Interrupt Enable .equ TOIE2A = TOIE2 ; For compatibility .equ OCIE2A = 1 ; Timer/Counter2 Output Compare Match A Interrupt Enable .equ OCIE2B = 2 ; Timer/Counter2 Output Compare Match B Interrupt Enable ; TIFR2 - Timer/Counter Interrupt Flag Register .equ TOV2 = 0 ; Timer/Counter2 Overflow Flag .equ OCF2A = 1 ; Output Compare Flag 2A .equ OCF2B = 2 ; Output Compare Flag 2B ; TCCR2A - Timer/Counter2 Control Register A .equ WGM20 = 0 ; Waveform Genration Mode .equ WGM21 = 1 ; Waveform Genration Mode .equ COM2B0 = 4 ; Compare Output Mode bit 0 .equ COM2B1 = 5 ; Compare Output Mode bit 1 .equ COM2A0 = 6 ; Compare Output Mode bit 1 .equ COM2A1 = 7 ; Compare Output Mode bit 1 ; TCCR2B - Timer/Counter2 Control Register B .equ CS20 = 0 ; Clock Select bit 0 .equ CS21 = 1 ; Clock Select bit 1 .equ CS22 = 2 ; Clock Select bit 2 .equ WGM22 = 3 ; Waveform Generation Mode .equ FOC2B = 6 ; Force Output Compare B .equ FOC2A = 7 ; Force Output Compare A ; TCNT2 - Timer/Counter2 .equ TCNT2_0 = 0 ; Timer/Counter 2 bit 0 .equ TCNT2_1 = 1 ; Timer/Counter 2 bit 1 .equ TCNT2_2 = 2 ; Timer/Counter 2 bit 2 .equ TCNT2_3 = 3 ; Timer/Counter 2 bit 3 .equ TCNT2_4 = 4 ; Timer/Counter 2 bit 4 .equ TCNT2_5 = 5 ; Timer/Counter 2 bit 5 .equ TCNT2_6 = 6 ; Timer/Counter 2 bit 6 .equ TCNT2_7 = 7 ; Timer/Counter 2 bit 7 ; OCR2A - Timer/Counter2 Output Compare Register A .equ OCR2A_0 = 0 ; Timer/Counter2 Output Compare Register Bit 0 .equ OCR2A_1 = 1 ; Timer/Counter2 Output Compare Register Bit 1 .equ OCR2A_2 = 2 ; Timer/Counter2 Output Compare Register Bit 2 .equ OCR2A_3 = 3 ; Timer/Counter2 Output Compare Register Bit 3 .equ OCR2A_4 = 4 ; Timer/Counter2 Output Compare Register Bit 4 .equ OCR2A_5 = 5 ; Timer/Counter2 Output Compare Register Bit 5 .equ OCR2A_6 = 6 ; Timer/Counter2 Output Compare Register Bit 6 .equ OCR2A_7 = 7 ; Timer/Counter2 Output Compare Register Bit 7 ; OCR2B - Timer/Counter2 Output Compare Register B .equ OCR2B_0 = 0 ; Timer/Counter2 Output Compare Register Bit 0 .equ OCR2B_1 = 1 ; Timer/Counter2 Output Compare Register Bit 1 .equ OCR2B_2 = 2 ; Timer/Counter2 Output Compare Register Bit 2 .equ OCR2B_3 = 3 ; Timer/Counter2 Output Compare Register Bit 3 .equ OCR2B_4 = 4 ; Timer/Counter2 Output Compare Register Bit 4 .equ OCR2B_5 = 5 ; Timer/Counter2 Output Compare Register Bit 5 .equ OCR2B_6 = 6 ; Timer/Counter2 Output Compare Register Bit 6 .equ OCR2B_7 = 7 ; Timer/Counter2 Output Compare Register Bit 7 ; ASSR - Asynchronous Status Register .equ TCR2BUB = 0 ; Timer/Counter Control Register2 Update Busy .equ TCR2AUB = 1 ; Timer/Counter Control Register2 Update Busy .equ OCR2BUB = 2 ; Output Compare Register 2 Update Busy .equ OCR2AUB = 3 ; Output Compare Register2 Update Busy .equ TCN2UB = 4 ; Timer/Counter2 Update Busy .equ AS2 = 5 ; Asynchronous Timer/Counter2 .equ EXCLK = 6 ; Enable External Clock Input ; GTCCR - General Timer Counter Control register .equ PSRASY = 1 ; Prescaler Reset Timer/Counter2 .equ PSR2 = PSRASY ; For compatibility ;.equ TSM = 7 ; Timer/Counter Synchronization Mode ; ***** AD_CONVERTER ***************** ; ADMUX - The ADC multiplexer Selection Register .equ MUX0 = 0 ; Analog Channel and Gain Selection Bits .equ MUX1 = 1 ; Analog Channel and Gain Selection Bits .equ MUX2 = 2 ; Analog Channel and Gain Selection Bits .equ MUX3 = 3 ; Analog Channel and Gain Selection Bits .equ ADLAR = 5 ; Left Adjust Result .equ REFS0 = 6 ; Reference Selection Bit 0 .equ REFS1 = 7 ; Reference Selection Bit 1 ; ADCSRA - The ADC Control and Status register A .equ ADPS0 = 0 ; ADC Prescaler Select Bits .equ ADPS1 = 1 ; ADC Prescaler Select Bits .equ ADPS2 = 2 ; ADC Prescaler Select Bits .equ ADIE = 3 ; ADC Interrupt Enable .equ ADIF = 4 ; ADC Interrupt Flag .equ ADATE = 5 ; ADC Auto Trigger Enable .equ ADSC = 6 ; ADC Start Conversion .equ ADEN = 7 ; ADC Enable ; ADCSRB - The ADC Control and Status register B .equ ADTS0 = 0 ; ADC Auto Trigger Source bit 0 .equ ADTS1 = 1 ; ADC Auto Trigger Source bit 1 .equ ADTS2 = 2 ; ADC Auto Trigger Source bit 2 .equ ACME = 6 ; ; ADCH - ADC Data Register High Byte .equ ADCH0 = 0 ; ADC Data Register High Byte Bit 0 .equ ADCH1 = 1 ; ADC Data Register High Byte Bit 1 .equ ADCH2 = 2 ; ADC Data Register High Byte Bit 2 .equ ADCH3 = 3 ; ADC Data Register High Byte Bit 3 .equ ADCH4 = 4 ; ADC Data Register High Byte Bit 4 .equ ADCH5 = 5 ; ADC Data Register High Byte Bit 5 .equ ADCH6 = 6 ; ADC Data Register High Byte Bit 6 .equ ADCH7 = 7 ; ADC Data Register High Byte Bit 7 ; ADCL - ADC Data Register Low Byte .equ ADCL0 = 0 ; ADC Data Register Low Byte Bit 0 .equ ADCL1 = 1 ; ADC Data Register Low Byte Bit 1 .equ ADCL2 = 2 ; ADC Data Register Low Byte Bit 2 .equ ADCL3 = 3 ; ADC Data Register Low Byte Bit 3 .equ ADCL4 = 4 ; ADC Data Register Low Byte Bit 4 .equ ADCL5 = 5 ; ADC Data Register Low Byte Bit 5 .equ ADCL6 = 6 ; ADC Data Register Low Byte Bit 6 .equ ADCL7 = 7 ; ADC Data Register Low Byte Bit 7 ; DIDR0 - Digital Input Disable Register .equ ADC0D = 0 ; .equ ADC1D = 1 ; .equ ADC2D = 2 ; .equ ADC3D = 3 ; .equ ADC4D = 4 ; .equ ADC5D = 5 ; ; ***** ANALOG_COMPARATOR ************ ; ACSR - Analog Comparator Control And Status Register .equ ACIS0 = 0 ; Analog Comparator Interrupt Mode Select bit 0 .equ ACIS1 = 1 ; Analog Comparator Interrupt Mode Select bit 1 .equ ACIC = 2 ; Analog Comparator Input Capture Enable .equ ACIE = 3 ; Analog Comparator Interrupt Enable .equ ACI = 4 ; Analog Comparator Interrupt Flag .equ ACO = 5 ; Analog Compare Output .equ ACBG = 6 ; Analog Comparator Bandgap Select .equ ACD = 7 ; Analog Comparator Disable ; DIDR1 - Digital Input Disable Register 1 .equ AIN0D = 0 ; AIN0 Digital Input Disable .equ AIN1D = 1 ; AIN1 Digital Input Disable ; ***** PORTB ************************ ; PORTB - Port B Data Register .equ PORTB0 = 0 ; Port B Data Register bit 0 .equ PB0 = 0 ; For compatibility .equ PORTB1 = 1 ; Port B Data Register bit 1 .equ PB1 = 1 ; For compatibility .equ PORTB2 = 2 ; Port B Data Register bit 2 .equ PB2 = 2 ; For compatibility .equ PORTB3 = 3 ; Port B Data Register bit 3 .equ PB3 = 3 ; For compatibility .equ PORTB4 = 4 ; Port B Data Register bit 4 .equ PB4 = 4 ; For compatibility .equ PORTB5 = 5 ; Port B Data Register bit 5 .equ PB5 = 5 ; For compatibility .equ PORTB6 = 6 ; Port B Data Register bit 6 .equ PB6 = 6 ; For compatibility .equ PORTB7 = 7 ; Port B Data Register bit 7 .equ PB7 = 7 ; For compatibility ; DDRB - Port B Data Direction Register .equ DDB0 = 0 ; Port B Data Direction Register bit 0 .equ DDB1 = 1 ; Port B Data Direction Register bit 1 .equ DDB2 = 2 ; Port B Data Direction Register bit 2 .equ DDB3 = 3 ; Port B Data Direction Register bit 3 .equ DDB4 = 4 ; Port B Data Direction Register bit 4 .equ DDB5 = 5 ; Port B Data Direction Register bit 5 .equ DDB6 = 6 ; Port B Data Direction Register bit 6 .equ DDB7 = 7 ; Port B Data Direction Register bit 7 ; PINB - Port B Input Pins .equ PINB0 = 0 ; Port B Input Pins bit 0 .equ PINB1 = 1 ; Port B Input Pins bit 1 .equ PINB2 = 2 ; Port B Input Pins bit 2 .equ PINB3 = 3 ; Port B Input Pins bit 3 .equ PINB4 = 4 ; Port B Input Pins bit 4 .equ PINB5 = 5 ; Port B Input Pins bit 5 .equ PINB6 = 6 ; Port B Input Pins bit 6 .equ PINB7 = 7 ; Port B Input Pins bit 7 ; ***** PORTC ************************ ; PORTC - Port C Data Register .equ PORTC0 = 0 ; Port C Data Register bit 0 .equ PC0 = 0 ; For compatibility .equ PORTC1 = 1 ; Port C Data Register bit 1 .equ PC1 = 1 ; For compatibility .equ PORTC2 = 2 ; Port C Data Register bit 2 .equ PC2 = 2 ; For compatibility .equ PORTC3 = 3 ; Port C Data Register bit 3 .equ PC3 = 3 ; For compatibility .equ PORTC4 = 4 ; Port C Data Register bit 4 .equ PC4 = 4 ; For compatibility .equ PORTC5 = 5 ; Port C Data Register bit 5 .equ PC5 = 5 ; For compatibility .equ PORTC6 = 6 ; Port C Data Register bit 6 .equ PC6 = 6 ; For compatibility ; DDRC - Port C Data Direction Register .equ DDC0 = 0 ; Port C Data Direction Register bit 0 .equ DDC1 = 1 ; Port C Data Direction Register bit 1 .equ DDC2 = 2 ; Port C Data Direction Register bit 2 .equ DDC3 = 3 ; Port C Data Direction Register bit 3 .equ DDC4 = 4 ; Port C Data Direction Register bit 4 .equ DDC5 = 5 ; Port C Data Direction Register bit 5 .equ DDC6 = 6 ; Port C Data Direction Register bit 6 ; PINC - Port C Input Pins .equ PINC0 = 0 ; Port C Input Pins bit 0 .equ PINC1 = 1 ; Port C Input Pins bit 1 .equ PINC2 = 2 ; Port C Input Pins bit 2 .equ PINC3 = 3 ; Port C Input Pins bit 3 .equ PINC4 = 4 ; Port C Input Pins bit 4 .equ PINC5 = 5 ; Port C Input Pins bit 5 .equ PINC6 = 6 ; Port C Input Pins bit 6 ; ***** PORTD ************************ ; PORTD - Port D Data Register .equ PORTD0 = 0 ; Port D Data Register bit 0 .equ PD0 = 0 ; For compatibility .equ PORTD1 = 1 ; Port D Data Register bit 1 .equ PD1 = 1 ; For compatibility .equ PORTD2 = 2 ; Port D Data Register bit 2 .equ PD2 = 2 ; For compatibility .equ PORTD3 = 3 ; Port D Data Register bit 3 .equ PD3 = 3 ; For compatibility .equ PORTD4 = 4 ; Port D Data Register bit 4 .equ PD4 = 4 ; For compatibility .equ PORTD5 = 5 ; Port D Data Register bit 5 .equ PD5 = 5 ; For compatibility .equ PORTD6 = 6 ; Port D Data Register bit 6 .equ PD6 = 6 ; For compatibility .equ PORTD7 = 7 ; Port D Data Register bit 7 .equ PD7 = 7 ; For compatibility ; DDRD - Port D Data Direction Register .equ DDD0 = 0 ; Port D Data Direction Register bit 0 .equ DDD1 = 1 ; Port D Data Direction Register bit 1 .equ DDD2 = 2 ; Port D Data Direction Register bit 2 .equ DDD3 = 3 ; Port D Data Direction Register bit 3 .equ DDD4 = 4 ; Port D Data Direction Register bit 4 .equ DDD5 = 5 ; Port D Data Direction Register bit 5 .equ DDD6 = 6 ; Port D Data Direction Register bit 6 .equ DDD7 = 7 ; Port D Data Direction Register bit 7 ; PIND - Port D Input Pins .equ PIND0 = 0 ; Port D Input Pins bit 0 .equ PIND1 = 1 ; Port D Input Pins bit 1 .equ PIND2 = 2 ; Port D Input Pins bit 2 .equ PIND3 = 3 ; Port D Input Pins bit 3 .equ PIND4 = 4 ; Port D Input Pins bit 4 .equ PIND5 = 5 ; Port D Input Pins bit 5 .equ PIND6 = 6 ; Port D Input Pins bit 6 .equ PIND7 = 7 ; Port D Input Pins bit 7 ; ***** TIMER_COUNTER_0 ************** ; TIMSK0 - Timer/Counter0 Interrupt Mask Register .equ TOIE0 = 0 ; Timer/Counter0 Overflow Interrupt Enable .equ OCIE0A = 1 ; Timer/Counter0 Output Compare Match A Interrupt Enable .equ OCIE0B = 2 ; Timer/Counter0 Output Compare Match B Interrupt Enable ; TIFR0 - Timer/Counter0 Interrupt Flag register .equ TOV0 = 0 ; Timer/Counter0 Overflow Flag .equ OCF0A = 1 ; Timer/Counter0 Output Compare Flag 0A .equ OCF0B = 2 ; Timer/Counter0 Output Compare Flag 0B ; TCCR0A - Timer/Counter Control Register A .equ WGM00 = 0 ; Waveform Generation Mode .equ WGM01 = 1 ; Waveform Generation Mode .equ COM0B0 = 4 ; Compare Output Mode, Fast PWm .equ COM0B1 = 5 ; Compare Output Mode, Fast PWm .equ COM0A0 = 6 ; Compare Output Mode, Phase Correct PWM Mode .equ COM0A1 = 7 ; Compare Output Mode, Phase Correct PWM Mode ; TCCR0B - Timer/Counter Control Register B .equ CS00 = 0 ; Clock Select .equ CS01 = 1 ; Clock Select .equ CS02 = 2 ; Clock Select .equ WGM02 = 3 ; .equ FOC0B = 6 ; Force Output Compare B .equ FOC0A = 7 ; Force Output Compare A ; TCNT0 - Timer/Counter0 .equ TCNT0_0 = 0 ; .equ TCNT0_1 = 1 ; .equ TCNT0_2 = 2 ; .equ TCNT0_3 = 3 ; .equ TCNT0_4 = 4 ; .equ TCNT0_5 = 5 ; .equ TCNT0_6 = 6 ; .equ TCNT0_7 = 7 ; ; OCR0A - Timer/Counter0 Output Compare Register .equ OCR0A_0 = 0 ; .equ OCR0A_1 = 1 ; .equ OCR0A_2 = 2 ; .equ OCR0A_3 = 3 ; .equ OCR0A_4 = 4 ; .equ OCR0A_5 = 5 ; .equ OCR0A_6 = 6 ; .equ OCR0A_7 = 7 ; ; OCR0B - Timer/Counter0 Output Compare Register .equ OCR0B_0 = 0 ; .equ OCR0B_1 = 1 ; .equ OCR0B_2 = 2 ; .equ OCR0B_3 = 3 ; .equ OCR0B_4 = 4 ; .equ OCR0B_5 = 5 ; .equ OCR0B_6 = 6 ; .equ OCR0B_7 = 7 ; ; GTCCR - General Timer/Counter Control Register ;.equ PSRSYNC = 0 ; Prescaler Reset Timer/Counter1 and Timer/Counter0 .equ PSR10 = PSRSYNC ; For compatibility ;.equ TSM = 7 ; Timer/Counter Synchronization Mode ; ***** EXTERNAL_INTERRUPT *********** ; EICRA - External Interrupt Control Register .equ ISC00 = 0 ; External Interrupt Sense Control 0 Bit 0 .equ ISC01 = 1 ; External Interrupt Sense Control 0 Bit 1 .equ ISC10 = 2 ; External Interrupt Sense Control 1 Bit 0 .equ ISC11 = 3 ; External Interrupt Sense Control 1 Bit 1 ; EIMSK - External Interrupt Mask Register .equ INT0 = 0 ; External Interrupt Request 0 Enable .equ INT1 = 1 ; External Interrupt Request 1 Enable ; EIFR - External Interrupt Flag Register .equ INTF0 = 0 ; External Interrupt Flag 0 .equ INTF1 = 1 ; External Interrupt Flag 1 ; PCICR - Pin Change Interrupt Control Register .equ PCIE0 = 0 ; Pin Change Interrupt Enable 0 .equ PCIE1 = 1 ; Pin Change Interrupt Enable 1 .equ PCIE2 = 2 ; Pin Change Interrupt Enable 2 ; PCMSK2 - Pin Change Mask Register 2 .equ PCINT16 = 0 ; Pin Change Enable Mask 16 .equ PCINT17 = 1 ; Pin Change Enable Mask 17 .equ PCINT18 = 2 ; Pin Change Enable Mask 18 .equ PCINT19 = 3 ; Pin Change Enable Mask 19 .equ PCINT20 = 4 ; Pin Change Enable Mask 20 .equ PCINT21 = 5 ; Pin Change Enable Mask 21 .equ PCINT22 = 6 ; Pin Change Enable Mask 22 .equ PCINT23 = 7 ; Pin Change Enable Mask 23 ; PCMSK1 - Pin Change Mask Register 1 .equ PCINT8 = 0 ; Pin Change Enable Mask 8 .equ PCINT9 = 1 ; Pin Change Enable Mask 9 .equ PCINT10 = 2 ; Pin Change Enable Mask 10 .equ PCINT11 = 3 ; Pin Change Enable Mask 11 .equ PCINT12 = 4 ; Pin Change Enable Mask 12 .equ PCINT13 = 5 ; Pin Change Enable Mask 13 .equ PCINT14 = 6 ; Pin Change Enable Mask 14 ; PCMSK0 - Pin Change Mask Register 0 .equ PCINT0 = 0 ; Pin Change Enable Mask 0 .equ PCINT1 = 1 ; Pin Change Enable Mask 1 .equ PCINT2 = 2 ; Pin Change Enable Mask 2 .equ PCINT3 = 3 ; Pin Change Enable Mask 3 .equ PCINT4 = 4 ; Pin Change Enable Mask 4 .equ PCINT5 = 5 ; Pin Change Enable Mask 5 .equ PCINT6 = 6 ; Pin Change Enable Mask 6 .equ PCINT7 = 7 ; Pin Change Enable Mask 7 ; PCIFR - Pin Change Interrupt Flag Register .equ PCIF0 = 0 ; Pin Change Interrupt Flag 0 .equ PCIF1 = 1 ; Pin Change Interrupt Flag 1 .equ PCIF2 = 2 ; Pin Change Interrupt Flag 2 ; ***** SPI ************************** ; SPDR - SPI Data Register .equ SPDR0 = 0 ; SPI Data Register bit 0 .equ SPDR1 = 1 ; SPI Data Register bit 1 .equ SPDR2 = 2 ; SPI Data Register bit 2 .equ SPDR3 = 3 ; SPI Data Register bit 3 .equ SPDR4 = 4 ; SPI Data Register bit 4 .equ SPDR5 = 5 ; SPI Data Register bit 5 .equ SPDR6 = 6 ; SPI Data Register bit 6 .equ SPDR7 = 7 ; SPI Data Register bit 7 ; SPSR - SPI Status Register .equ SPI2X = 0 ; Double SPI Speed Bit .equ WCOL = 6 ; Write Collision Flag .equ SPIF = 7 ; SPI Interrupt Flag ; SPCR - SPI Control Register .equ SPR0 = 0 ; SPI Clock Rate Select 0 .equ SPR1 = 1 ; SPI Clock Rate Select 1 .equ CPHA = 2 ; Clock Phase .equ CPOL = 3 ; Clock polarity .equ MSTR = 4 ; Master/Slave Select .equ DORD = 5 ; Data Order .equ SPE = 6 ; SPI Enable .equ SPIE = 7 ; SPI Interrupt Enable ; ***** WATCHDOG ********************* ; WDTCSR - Watchdog Timer Control Register .equ WDP0 = 0 ; Watch Dog Timer Prescaler bit 0 .equ WDP1 = 1 ; Watch Dog Timer Prescaler bit 1 .equ WDP2 = 2 ; Watch Dog Timer Prescaler bit 2 .equ WDE = 3 ; Watch Dog Enable .equ WDCE = 4 ; Watchdog Change Enable .equ WDP3 = 5 ; Watchdog Timer Prescaler Bit 3 .equ WDIE = 6 ; Watchdog Timeout Interrupt Enable .equ WDIF = 7 ; Watchdog Timeout Interrupt Flag ; ***** CPU ************************** ; SREG - Status Register .equ SREG_C = 0 ; Carry Flag .equ SREG_Z = 1 ; Zero Flag .equ SREG_N = 2 ; Negative Flag .equ SREG_V = 3 ; Two's Complement Overflow Flag .equ SREG_S = 4 ; Sign Bit .equ SREG_H = 5 ; Half Carry Flag .equ SREG_T = 6 ; Bit Copy Storage .equ SREG_I = 7 ; Global Interrupt Enable ; OSCCAL - Oscillator Calibration Value .equ CAL0 = 0 ; Oscillator Calibration Value Bit0 .equ CAL1 = 1 ; Oscillator Calibration Value Bit1 .equ CAL2 = 2 ; Oscillator Calibration Value Bit2 .equ CAL3 = 3 ; Oscillator Calibration Value Bit3 .equ CAL4 = 4 ; Oscillator Calibration Value Bit4 .equ CAL5 = 5 ; Oscillator Calibration Value Bit5 .equ CAL6 = 6 ; Oscillator Calibration Value Bit6 .equ CAL7 = 7 ; Oscillator Calibration Value Bit7 ; CLKPR - Clock Prescale Register .equ CLKPS0 = 0 ; Clock Prescaler Select Bit 0 .equ CLKPS1 = 1 ; Clock Prescaler Select Bit 1 .equ CLKPS2 = 2 ; Clock Prescaler Select Bit 2 .equ CLKPS3 = 3 ; Clock Prescaler Select Bit 3 .equ CLKPCE = 7 ; Clock Prescaler Change Enable ; SPMCSR - Store Program Memory Control and Status Register .equ SELFPRGEN = 0 ; Self Programming Enable .equ PGERS = 1 ; Page Erase .equ PGWRT = 2 ; Page Write .equ BLBSET = 3 ; Boot Lock Bit Set .equ RWWSRE = 4 ; Read-While-Write section read enable .equ RWWSB = 6 ; Read-While-Write Section Busy .equ SPMIE = 7 ; SPM Interrupt Enable ; MCUCR - MCU Control Register .equ IVCE = 0 ; .equ IVSEL = 1 ; .equ PUD = 4 ; .equ BODSE = 5 ; BOD Sleep Enable .equ BODS = 6 ; BOD Sleep ; MCUSR - MCU Status Register .equ PORF = 0 ; Power-on reset flag .equ EXTRF = 1 ; External Reset Flag .equ EXTREF = EXTRF ; For compatibility .equ BORF = 2 ; Brown-out Reset Flag .equ WDRF = 3 ; Watchdog Reset Flag ; SMCR - Sleep Mode Control Register .equ SE = 0 ; Sleep Enable .equ SM0 = 1 ; Sleep Mode Select Bit 0 .equ SM1 = 2 ; Sleep Mode Select Bit 1 .equ SM2 = 3 ; Sleep Mode Select Bit 2 ; GPIOR2 - General Purpose I/O Register 2 .equ GPIOR20 = 0 ; .equ GPIOR21 = 1 ; .equ GPIOR22 = 2 ; .equ GPIOR23 = 3 ; .equ GPIOR24 = 4 ; .equ GPIOR25 = 5 ; .equ GPIOR26 = 6 ; .equ GPIOR27 = 7 ; ; GPIOR1 - General Purpose I/O Register 1 .equ GPIOR10 = 0 ; .equ GPIOR11 = 1 ; .equ GPIOR12 = 2 ; .equ GPIOR13 = 3 ; .equ GPIOR14 = 4 ; .equ GPIOR15 = 5 ; .equ GPIOR16 = 6 ; .equ GPIOR17 = 7 ; ; GPIOR0 - General Purpose I/O Register 0 .equ GPIOR00 = 0 ; .equ GPIOR01 = 1 ; .equ GPIOR02 = 2 ; .equ GPIOR03 = 3 ; .equ GPIOR04 = 4 ; .equ GPIOR05 = 5 ; .equ GPIOR06 = 6 ; .equ GPIOR07 = 7 ; ; PRR - Power Reduction Register .equ PRADC = 0 ; Power Reduction ADC .equ PRUSART0 = 1 ; Power Reduction USART .equ PRSPI = 2 ; Power Reduction Serial Peripheral Interface .equ PRTIM1 = 3 ; Power Reduction Timer/Counter1 .equ PRTIM0 = 5 ; Power Reduction Timer/Counter0 .equ PRTIM2 = 6 ; Power Reduction Timer/Counter2 .equ PRTWI = 7 ; Power Reduction TWI ; ***** EEPROM *********************** ; EEARL - EEPROM Address Register Low Byte .equ EEAR0 = 0 ; EEPROM Read/Write Access Bit 0 .equ EEAR1 = 1 ; EEPROM Read/Write Access Bit 1 .equ EEAR2 = 2 ; EEPROM Read/Write Access Bit 2 .equ EEAR3 = 3 ; EEPROM Read/Write Access Bit 3 .equ EEAR4 = 4 ; EEPROM Read/Write Access Bit 4 .equ EEAR5 = 5 ; EEPROM Read/Write Access Bit 5 .equ EEAR6 = 6 ; EEPROM Read/Write Access Bit 6 .equ EEAR7 = 7 ; EEPROM Read/Write Access Bit 7 ; EEARH - EEPROM Address Register High Byte .equ EEAR8 = 0 ; EEPROM Read/Write Access Bit 8 .equ EEAR9 = 1 ; EEPROM Read/Write Access Bit 9 ; EEDR - EEPROM Data Register .equ EEDR0 = 0 ; EEPROM Data Register bit 0 .equ EEDR1 = 1 ; EEPROM Data Register bit 1 .equ EEDR2 = 2 ; EEPROM Data Register bit 2 .equ EEDR3 = 3 ; EEPROM Data Register bit 3 .equ EEDR4 = 4 ; EEPROM Data Register bit 4 .equ EEDR5 = 5 ; EEPROM Data Register bit 5 .equ EEDR6 = 6 ; EEPROM Data Register bit 6 .equ EEDR7 = 7 ; EEPROM Data Register bit 7 ; EECR - EEPROM Control Register .equ EERE = 0 ; EEPROM Read Enable .equ EEPE = 1 ; EEPROM Write Enable .equ EEMPE = 2 ; EEPROM Master Write Enable .equ EERIE = 3 ; EEPROM Ready Interrupt Enable .equ EEPM0 = 4 ; EEPROM Programming Mode Bit 0 .equ EEPM1 = 5 ; EEPROM Programming Mode Bit 1 ; ***** LOCKSBITS ******************************************************** .equ LB1 = 0 ; Lock bit .equ LB2 = 1 ; Lock bit .equ BLB01 = 2 ; Boot Lock bit .equ BLB02 = 3 ; Boot Lock bit .equ BLB11 = 4 ; Boot lock bit .equ BLB12 = 5 ; Boot lock bit ; ***** FUSES ************************************************************ ; LOW fuse bits .equ CKSEL0 = 0 ; Select Clock Source .equ CKSEL1 = 1 ; Select Clock Source .equ CKSEL2 = 2 ; Select Clock Source .equ CKSEL3 = 3 ; Select Clock Source .equ SUT0 = 4 ; Select start-up time .equ SUT1 = 5 ; Select start-up time .equ CKOUT = 6 ; Clock output .equ CKDIV8 = 7 ; Divide clock by 8 ; HIGH fuse bits .equ BOOTRST = 0 ; Select reset vector .equ BOOTSZ0 = 1 ; Select boot size .equ BOOTSZ1 = 2 ; Select boot size .equ EESAVE = 3 ; EEPROM memory is preserved through chip erase .equ WDTON = 4 ; Watchdog Timer Always On .equ SPIEN = 5 ; Enable Serial programming and Data Downloading .equ DWEN = 6 ; debugWIRE Enable .equ RSTDISBL = 7 ; External reset disable ; EXTENDED fuse bits .equ BODLEVEL0 = 0 ; Brown-out Detector trigger level .equ BODLEVEL1 = 1 ; Brown-out Detector trigger level .equ BODLEVEL2 = 2 ; Brown-out Detector trigger level ; ***** CPU REGISTER DEFINITIONS ***************************************** .def XH = r27 .def XL = r26 .def YH = r29 .def YL = r28 .def ZH = r31 .def ZL = r30 ; ***** DATA MEMORY DECLARATIONS ***************************************** .equ FLASHEND = 0x3fff ; Note: Word address .equ IOEND = 0x00ff .equ SRAM_START = 0x0100 .equ SRAM_SIZE = 2048 .equ RAMEND = 0x08ff .equ XRAMEND = 0x0000 .equ E2END = 0x03ff .equ EEPROMEND = 0x03ff .equ EEADRBITS = 10 #pragma AVRPART MEMORY PROG_FLASH 32768 #pragma AVRPART MEMORY EEPROM 1024 #pragma AVRPART MEMORY INT_SRAM SIZE 2048 #pragma AVRPART MEMORY INT_SRAM START_ADDR 0x100 ; ***** BOOTLOADER DECLARATIONS ****************************************** .equ NRWW_START_ADDR = 0x3800 .equ NRWW_STOP_ADDR = 0x3fff .equ RWW_START_ADDR = 0x0 .equ RWW_STOP_ADDR = 0x37ff .equ PAGESIZE = 64 .equ FIRSTBOOTSTART = 0x3f00 .equ SECONDBOOTSTART = 0x3e00 .equ THIRDBOOTSTART = 0x3c00 .equ FOURTHBOOTSTART = 0x3800 .equ SMALLBOOTSTART = FIRSTBOOTSTART .equ LARGEBOOTSTART = FOURTHBOOTSTART ; ***** INTERRUPT VECTORS ************************************************ .equ INT0addr = 0x0002 ; External Interrupt Request 0 .equ INT1addr = 0x0004 ; External Interrupt Request 1 .equ PCI0addr = 0x0006 ; Pin Change Interrupt Request 0 .equ PCI1addr = 0x0008 ; Pin Change Interrupt Request 0 .equ PCI2addr = 0x000a ; Pin Change Interrupt Request 1 .equ WDTaddr = 0x000c ; Watchdog Time-out Interrupt .equ OC2Aaddr = 0x000e ; Timer/Counter2 Compare Match A .equ OC2Baddr = 0x0010 ; Timer/Counter2 Compare Match A .equ OVF2addr = 0x0012 ; Timer/Counter2 Overflow .equ ICP1addr = 0x0014 ; Timer/Counter1 Capture Event .equ OC1Aaddr = 0x0016 ; Timer/Counter1 Compare Match A .equ OC1Baddr = 0x0018 ; Timer/Counter1 Compare Match B .equ OVF1addr = 0x001a ; Timer/Counter1 Overflow .equ OC0Aaddr = 0x001c ; TimerCounter0 Compare Match A .equ OC0Baddr = 0x001e ; TimerCounter0 Compare Match B .equ OVF0addr = 0x0020 ; Timer/Couner0 Overflow .equ SPIaddr = 0x0022 ; SPI Serial Transfer Complete .equ URXCaddr = 0x0024 ; USART Rx Complete .equ UDREaddr = 0x0026 ; USART, Data Register Empty .equ UTXCaddr = 0x0028 ; USART Tx Complete .equ ADCCaddr = 0x002a ; ADC Conversion Complete .equ ERDYaddr = 0x002c ; EEPROM Ready .equ ACIaddr = 0x002e ; Analog Comparator .equ TWIaddr = 0x0030 ; Two-wire Serial Interface .equ SPMRaddr = 0x0032 ; Store Program Memory Read .equ INT_VECTORS_SIZE = 52 ; size in words #endif /* _M328PDEF_INC_ */ ; ***** END OF FILE ****************************************************** .equ SCLPIN=PORTC5 .equ SDAPORT=PORTC .equ SDAPIN=PORTC4 .CSEG .ORG $0 000000 c078 RJMP Start .ORG INT_VECTORS_SIZE ;------------------------------ i2c_init: 000034 983d CBI SCLPORT-1,SCLPIN 000035 983c CBI SDAPORT-1,SDAPIN 000036 9844 CBI SDAPORT,SDAPIN 000037 9845 CBI SCLPORT,SCLPIN 000038 9508 RET ;------------------------------ i2c_start: 000039 9a3c SBI SDAPORT-1,SDAPIN 00003a 9508 RET ;------------------------------ i2c_restart: 00003b 983d CBI SCLPORT-1,SCLPIN 00003c 983d CBI SCLPORT-1,SCLPIN 00003d 9a3c SBI SDAPORT-1,SDAPIN 00003e 9508 RET ;------------------------------ i2c_write: 00003f e098 LDI R25,8 i2c_write_loop: 000040 9a3d SBI SCLPORT-1,SCLPIN 000041 fd87 SBRC R24,7 000042 983c CBI SDAPORT-1,SDAPIN 000043 ff87 SBRS R24,7 000044 9a3c SBI SDAPORT-1,SDAPIN 000045 1f88 ROL R24 000046 983d CBI SCLPORT-1,SCLPIN i2c_write_loop1: 000047 9b35 SBIS SCLPORT-2,SCLPIN 000048 cffe RJMP i2c_write_loop1 000049 0000 NOP 00004a 959a DEC R25 00004b f7a1 BRNE i2c_write_loop 00004c 0000 NOP 00004d 9a3d SBI SCLPORT-1,SCLPIN 00004e 983c CBI SDAPORT-1,SDAPIN 00004f 983c CBI SDAPORT-1,SDAPIN 000050 983c CBI SDAPORT-1,SDAPIN 000051 983d CBI SCLPORT-1,SCLPIN 000052 2788 CLR R24 000053 9b34 SBIS SDAPORT-2,SDAPIN 000054 9583 INC R24 000055 983d CBI SCLPORT-1,SCLPIN 000056 0000 NOP 000057 9a3d SBI SCLPORT-1,SCLPIN 000058 9508 RET ;------------------------------ i2c_read: 000059 e098 LDI R25,8 00005a fb80 BST R24,0 i2c_read_loop: 00005b 9a3d SBI SCLPORT-1,SCLPIN 00005c 9a3d SBI SCLPORT-1,SCLPIN 00005d 9a3d SBI SCLPORT-1,SCLPIN 00005e f980 BLD R24,0 00005f 0f88 LSL R24 000060 983d CBI SCLPORT-1,SCLPIN 000061 9468 SET 000062 9b34 SBIS SDAPORT-2,SDAPIN 000063 94e8 CLT 000064 959a DEC R25 000065 f7a9 BRNE i2c_read_loop 000066 f980 BLD R24,0 000067 9a3d SBI SCLPORT-1,SCLPIN 000068 1f99 ROL R25 000069 ff90 SBRS R25,0 00006a 9a3c SBI SDAPORT-1,SDAPIN 00006b fd90 SBRC R25,0 00006c 983c CBI SDAPORT-1,SDAPIN 00006d 983d CBI SCLPORT-1,SCLPIN 00006e 983d CBI SCLPORT-1,SCLPIN 00006f 983d CBI SCLPORT-1,SCLPIN 000070 983d CBI SCLPORT-1,SCLPIN 000071 9a3d SBI SCLPORT-1,SCLPIN 000072 983c CBI SDAPORT-1,SDAPIN 000073 9508 RET ;------------------------------ i2c_stop: 000074 9a3c SBI SDAPORT-1,SDAPIN 000075 983d CBI SCLPORT-1,SCLPIN 000076 983d CBI SCLPORT-1,SCLPIN 000077 983c CBI SDAPORT-1,SDAPIN 000078 9508 RET ;------------------------------ Start: 000079 ef0f LDI R16,Low(RAMEND) 00007a bf0d OUT SPL,R16 00007b e008 LDI R16,High(RAMEND) 00007c bf0e OUT SPH,R16 00007d 940e 0034 CALL i2c_init Loop: 00007f 940e 0039 CALL i2c_start 000081 ec80 LDI R24,$C0 000082 940e 003f CALL i2c_write 000084 e087 LDI R24,$07 000085 940e 003f CALL i2c_write 000087 ef8f LDI R24,$FF 000088 940e 003f CALL i2c_write 00008a 940e 0074 CALL i2c_stop 00008c 940e 0039 CALL i2c_start 00008e e880 LDI R24,$80 00008f 940e 003f CALL i2c_write 000091 e083 LDI R24,$03 000092 940e 003f CALL i2c_write 000094 e181 LDI R24,$11 000095 940e 003f CALL i2c_write 000097 940e 0074 CALL i2c_stop Loop1: 000099 940e 0039 CALL i2c_start 00009b e880 LDI R24,$80 00009c 940e 003f CALL i2c_write 00009e e080 LDI R24,$00 00009f 940e 003f CALL i2c_write 0000a1 940e 003b CALL i2c_restart 0000a3 e881 LDI R24,$81 0000a4 940e 003f CALL i2c_write 0000a6 e081 LDI R24,$01 0000a7 940e 0059 CALL i2c_read 0000a9 940e 0074 CALL i2c_stop 0000ab 7081 ANDI R24,$01 0000ac f761 BRNE Loop1 0000ad 940e 0039 CALL i2c_start 0000af e880 LDI R24,$80 0000b0 940e 003f CALL i2c_write 0000b2 e081 LDI R24,$01 0000b3 940e 003f CALL i2c_write 0000b5 940e 003b CALL i2c_restart 0000b7 e881 LDI R24,$81 0000b8 940e 003f CALL i2c_write 0000ba e080 LDI R24,$00 0000bb 940e 0059 CALL i2c_read 0000bd e081 LDI R24,$01 0000be 940e 0059 CALL i2c_read 0000c0 940e 0074 CALL i2c_stop 0000c2 cfbc RJMP Loop RESOURCE USE INFORMATION ------------------------ Notice: The register and instruction counts are symbol table hit counts, and hence implicitly used resources are not counted, eg, the 'lpm' instruction without operands implicitly uses r0 and z, none of which are counted. x,y,z are separate entities in the symbol table and are counted separately from r26..r31 here. .dseg memory usage only counts static data declared with .byte ATmega328P register use summary: r0 : 0 r1 : 0 r2 : 0 r3 : 0 r4 : 0 r5 : 0 r6 : 0 r7 : 0 r8 : 0 r9 : 0 r10: 0 r11: 0 r12: 0 r13: 0 r14: 0 r15: 0 r16: 4 r17: 0 r18: 0 r19: 0 r20: 0 r21: 0 r22: 0 r23: 0 r24: 25 r25: 7 r26: 0 r27: 0 r28: 0 r29: 0 r30: 0 r31: 0 x : 0 y : 0 z : 0 Registers used: 3 out of 35 (8.6%) ATmega328P instruction use summary: .lds : 0 .sts : 0 adc : 0 add : 0 adiw : 0 and : 0 andi : 1 asr : 0 bclr : 0 bld : 2 brbc : 0 brbs : 0 brcc : 0 brcs : 0 break : 0 breq : 0 brge : 0 brhc : 0 brhs : 0 brid : 0 brie : 0 brlo : 0 brlt : 0 brmi : 0 brne : 3 brpl : 0 brsh : 0 brtc : 0 brts : 0 brvc : 0 brvs : 0 bset : 0 bst : 1 call : 26 cbi : 23 cbr : 0 clc : 0 clh : 0 cli : 0 cln : 0 clr : 1 cls : 0 clt : 1 clv : 0 clz : 0 com : 0 cp : 0 cpc : 0 cpi : 0 cpse : 0 dec : 2 eor : 0 fmul : 0 fmuls : 0 fmulsu: 0 icall : 0 ijmp : 0 in : 0 inc : 1 jmp : 0 ld : 0 ldd : 0 ldi : 19 lds : 0 lpm : 0 lsl : 1 lsr : 0 mov : 0 movw : 0 mul : 0 muls : 0 mulsu : 0 neg : 0 nop : 3 or : 0 ori : 0 out : 2 pop : 0 push : 0 rcall : 0 ret : 6 reti : 0 rjmp : 3 rol : 2 ror : 0 sbc : 0 sbci : 0 sbi : 13 sbic : 0 sbis : 3 sbiw : 0 sbr : 0 sbrc : 2 sbrs : 2 sec : 0 seh : 0 sei : 0 sen : 0 ser : 0 ses : 0 set : 1 sev : 0 sez : 0 sleep : 0 spm : 0 st : 0 std : 0 sts : 0 sub : 0 subi : 0 swap : 0 tst : 0 wdr : 0 Instructions used: 22 out of 113 (19.5%) ATmega328P memory use summary [bytes]: Segment Begin End Code Data Used Size Use% --------------------------------------------------------------- [.cseg] 0x000000 0x000186 288 0 288 32768 0.9% [.dseg] 0x000100 0x000100 0 0 0 2048 0.0% [.eseg] 0x000000 0x000000 0 0 0 1024 0.0% Assembly complete, 0 errors, 0 warningsЭто просто константы. Они прописаны в ...inc и заменяются реальными номерами портов и константами пинов для портов ...
Надо деда просить, чтобы пояснил.
Вот тут видно:
Зафаворитил :-)
Опоздал ты с идеей на пяток лет. ))) Поищи, это ещё с Архатом и ещё кем-то тогда со всех сторон обгрызли идею. И юзаю так, даже прямо сейчас. И нету там 1МГц. Говориш 192 ФПС. Считаем192*512*9=884КГц Девять тактов на байт - потому что АСК.. Все верно, дето так и у нас получалось.
АСМ там не нужен совсем. Пиши просто на Си, соберется считай так же.
Теперь о плохом.
Жаль что ТС так и не понял как работает I2C )))) Уровень 1 на SDA контроллер не выводит никогда. Нужно просто отпустить шину, а к 1 ее подтягивают резюки. Их там вообще 2, сказанное относится и к SCL по большому счету, но мультимастер - экзотика.Отпустить шины - это на ввод настроить.
АСК контролировать обязательно! Как только перейдеш от примера на ssd1306, на пример, к примеру на 24c512 - поймеш зачем.
Но именно вот такую реализацию, без резюков подтяжки, без контроля АСК, но на Си и с нормальной задачей пинов ( ну просто их номером) я таки храню. Чтоб по быстряку ОЛЕД покинуть на любые ноги для отладки. Да и в проектах иногда подтяжки память влом ))) Пошарся по форуму, тут даже видео его работы лето валяется, там и осцилограф и ДПФ и диаграмки отрисовывает.
Нарочно жопой крутишь? Это мой код софт И2С был, его и трахали по разному. До Миллиона довести нельзя. Но если всё увести в ассемблер, конечно не так, как тут, то может быть получится. Если родная softI2C на arduino.cc очень грамотная. Которую можно ускорить, зная протокол (убрав проверки на "медленный слейв").
Явился не прошенный, ещё и с претензией, не понятно на что. У меня моя реализация. А что у тебя там с Ахатом общее - сами решайте, главное не на людях ;)
Теперь о плохом.
Ну что тут сказать ...
Ты мальчик еще мал и глуп и не видал больших за...п !!!
Про скорость - скорость шины измеряется периодом следования сигналов на линии SCL !!!
Где ты тут нашел выставление 1 ? Тут ВЕЗДЕ подтяжка к нулю или отпускание !!! И на схеме R1 R2 для красоты что ли ???
Тут есть не только контроль ASK, но даже есть контроль удержания ведомым линии SCL в низком состоянии для паузы на обработку !!!
Разуй глаза ...
Вау! К нам спец по за..там пожаловал!
Ну раздвигайся, принимай первую. Если за 1 сек на SCL 884тысячи импульсов прошло, то какая частота на SCL?
9 тактов SCL за 9 микросекунд - это какая частота ?
Аппаратный i2c:
на 100 КГц выдает 9 тактов SCL за 90 микросекунд
на 400 КГц выдает 9 тактов SCL за 22,5 микросекунды
следовательно:
на 1000 КГц 9 тактов SCL должны генерироваться именно за 9 микросекунд !!!
Спать уже ушел. С тилипона сложно... Логик! Шаббат шалом! Прочитай "Шма Исраэль" и ложись спать. Хорош тут лысого гонять на форумах. Не круто;)))
9 тактов SCL за 9 микросекунд - это какая частота ?/p>
Такс, отвечаем вопросом на вопрос.... Ну ясно, спец по за..пам должен быть обрезаным.
Про 9 мкс на 9 тактов. Ты видно таки решил что тут самый обрезаный ))) И пропустил что любые 9 тактов за 9 мксек в течении сеанса обмена. А не некоторые, избранные. Вот если сделаеш так и продемонстрируеш опытным путём, по ФПС экрана, что хотя бы в среднем 9мксек на 9 тактов - добро пожаловать. А пока наслаждайся за..пой.
Повторяю вопрос. Какая частота шины при измеренных 192 фПС? В мои годы студентов, не отвечающих на такой вопрос отправляли применять сапоги и шинель. У замдекана спецом комплект хранился. Ты пишеш командир...из таких похоже.
И тебе шалом, православный.
Та тут же лысый со знанием асма подвергался. Часто ль такое было!
Пс. Сам с планшета набирать замучался.
Если обратиться к первоисточнику:
Это генерирует мой код:
А тупых преподавателей везде хватает ! У нас в МЭИ был один похожий ... оценивал код на вес бумаги, на которой его распечатывали.
Logik это не ты в МЭИ преподавал нам ???
С частотой SCL ты жидко обделался !!!
Перейдём ко второму вопросу..
В какой строке я выставил "1" в порту для SCL или SDA, а не отпустил линию (перевел её в состояние входа) ?
Komandir, разворошили :-)
Говорили ж мудрые англичане: "Let sleeping dogs lie" :-)
Вдогонку - аппаратная передача на 100 КГц:
и аппаратная передача на 400 КГц:
ЕвгенийП кто кого разбудил то ?
Ligik всё уже объяснил выше.
В таком случае нам понадобятся две команды, одна из них CBI х,у для прижатия шины к земле, вторая DDRх,у для перевода пина на вход/выход для "отпускания" шины, т.е. выставления лог. 1 на ней.
-NMi- Ещё один знаток ассемблера AVR ? А как выглядит DDR x,y ? Раскройте мне глаза ?
Что па Вашему делают следующие команды, если SCLPORT=SDAPORT=PORTC=0x08 ?
смахивает на битву одного против трёх мушкетёров )))
ua6em воспитателя и детсадовцев ...
Зачем так агрессировать? Просто мне не понятна одна вещь: для того, чтобы прижать пин к земле сколько нужно команд? Одна или две? Вот в чём вопрос..
Как по мне, нужно:
1 - сделать пин выходом
2 - сбросить бит в регистре пина, чтобы он вывел на пин "0"
И наоборот:
1 - сделать пин входом
2 - выставить бит пина в "1"
Или же просто манипулировать DDRх пинами без изменения битов регистра порта? Вот в чём вопрос...
Ваша тема разбудила застарелый срач, который тихо дремал себе до поры :-)
Всё, вЪехал. Это просто для универсальности пользования сделано. Т.е. есть порт и есть пин в качестве констант или алиаса а дальше мы уже вычисляем те порты (регистры ввода-вывода), шо нужны нам.
))) с тилипона то не всё видно то... ))) вчерасЪ )))
ЕвгенийП Вот Вы лично как считаете ? Частота SCL определяет скорость работы сдвигового регистра при выводе одного байта, или же надо учесть кто и какой лопатой загружает эти байты в сдвиговый регистр.
Komandir, в i2c_read() всё красиво? Мне кажется на last никто не обращает внимания.
Green В ассемблерном коде обратите внимание на стоки 148 и 150, в Сишном коде на строки 155 и 156.
