Arduino Mega 2560 R3 не работает с шилдом Motor Shield Wenzhou L293D
Dmti
Dmti аватар
Запустил пример Steper Test выпала ошибка с библиотекой WProgram, поменял на Arduino.h. Стала выподать ошибка множественная декларация (что такое слабо понимаю), закоментировал стоку AFMotorController::AFMotorController(void) { } и добавил строку
||   defined(__AVR_ATmega2560__)
к строке
#elif efined(__AVR_ATmega1280__)
стла опять писать множественная декларация latch_tx()
полный код ошибки:
AFMotor\AFMotor.cpp.o: In function `AFMotorController::latch_tx()':
C:\Users\Dimitri\Documents\Arduino\libraries\AFMotor/AFMotor.cpp:36: multiple definition of `AFMotorController::latch_tx()'
AFMotor.cpp.o:C:\Users\Dimitri\AppData\Local\Temp\build3060534936635475779.tmp/AFMotor.cpp:35: first defined here
c:/program files/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
AFMotor\AFMotor.cpp.o: In function `AF_Stepper::onestep(unsigned char, unsigned char)':
C:\Users\Dimitri\Documents\Arduino\libraries\AFMotor/AFMotor.cpp:393: multiple definition of `AF_Stepper::onestep(unsigned char, unsigned char)'
AFMotor.cpp.o:C:\Users\Dimitri\AppData\Local\Temp\build3060534936635475779.tmp/AFMotor.cpp:400: first defined here
AFMotor\AFMotor.cpp.o: In function `AF_Stepper::step(unsigned int, unsigned char, unsigned char)':
C:\Users\Dimitri\Documents\Arduino\libraries\AFMotor/AFMotor.cpp:350: multiple definition of `AF_Stepper::step(unsigned int, unsigned char, unsigned char)'
AFMotor.cpp.o:C:\Users\Dimitri\AppData\Local\Temp\build3060534936635475779.tmp/AFMotor.cpp:357: first defined here
AFMotor\AFMotor.cpp.o: In function `AF_Stepper::release()':
C:\Users\Dimitri\Documents\Arduino\libraries\AFMotor/AFMotor.cpp:339: multiple definition of `AF_Stepper::release()'
AFMotor.cpp.o:C:\Users\Dimitri\AppData\Local\Temp\build3060534936635475779.tmp/AFMotor.cpp:346: first defined here
AFMotor\AFMotor.cpp.o: In function `AFMotorController::enable()':
C:\Users\Dimitri\Documents\Arduino\libraries\AFMotor/AFMotor.cpp:14: multiple definition of `AFMotorController::enable()'
AFMotor.cpp.o:C:\Users\Dimitri\AppData\Local\Temp\build3060534936635475779.tmp/AFMotor.cpp:22: first defined here
AFMotor\AFMotor.cpp.o: In function `AF_Stepper':
C:\Users\Dimitri\Documents\Arduino\libraries\AFMotor/AFMotor.cpp:286: multiple definition of `AF_Stepper::AF_Stepper(unsigned int, unsigned char)'
AFMotor.cpp.o:C:\Users\Dimitri\AppData\Local\Temp\build3060534936635475779.tmp/AFMotor.cpp:293: first defined here
Скажите для этой дуны есть работающий пример к этому шилду.
Dmti
Dmti аватар
Все библиотеки вернул в исходное. В файле AFMotor.cpp в место
 #include "WProgram.h"
написал
#if defined(ARDUINO) && ARDUINO >= 100
      #include "Arduino.h"
    #else
    #endif
списал на какомто сайте
в секторе MOTORS все строки
#elif defined(__AVR_ATmega1280__)
дополнил до
#elif defined(__AVR_ATmega1280__)  || \
не чиго лудшего не придумал. После всех манипуляций стал получать ошибку:
AFMotor.cpp:222: error: 'AF_DCMotor' has not been declared
AFMotor.cpp:222: error: ISO C++ forbids declaration of 'AF_DCMotor' with no type
AFMotor.cpp: In function 'int AF_DCMotor(uint8_t, uint8_t)':
DCMotor часть мне не нужна надо только STEP поэтому всю DC часть закоментировал и стал получать ошибку:
C:\Users\Dimitri\Documents\Arduino\libraries\AFMotor\AFMotor.cpp:7:22: error: WProgram.h: No such file or directory
C:\Users\Dimitri\Documents\Arduino\libraries\AFMotor\AFMotor.cpp: In member function 'void AFMotorController::enable()':
хотя до того пока не закоментировал файл WProgram.h виделся .
Подскажите где копать или рабочий примерчик под этот модуль или как воздействодать на микруху 74HCT595D чтобы она заработала или кто видел толковое описание.
maksim
1. Что за библиотека? Откуда качали?
2. Какая версия IDE ?
maksim
В общем делаете следуещее:
1. Перестаете извращаться над либой.
2. Качаете эту либу.
3. Качаете Arduino 1.0.4 (Windows?)
4. Распаковываете архив с либой в \arduino-1.0.4\libraries.
5. Запускаете IDE и пользуетесь.
Dmti
Dmti аватар
Версия IDE  1.5.4. Откуда качал библиотеки уже не помню у меня их уже штук 6 и Мотор Мастер и AFMotor и AccelStepper разные версии и все не работают часть не видит WProgram другая часть видет но выдаёт ошибку типа множественной декларации внутри файла WProgram.c. Поэтому и полез разбираться в библиотеки.
Переустановил IDE 1.0.4. Скачал библиотеку по сылке разорхивировал в мои документы запустил AFMotor_MultiStepper, получил ошибку на названия переименовал удалив все тире. Получил ошибку нет библиотеки,  error: 'AccelStepper' does not name a type. Добавил недостающую из старых скачиваний. Откомпилировалась и загрузилась без ошибки. Шаговые движки один просто гудит и не крутит второй гудит и валом трясёт и тоже крутить не хочет. Думаю, что катушки перепутаны один снял с принтера Samsung нет ни каких данных, подключается по 5 проводной схеме относительно средней точки везде 22 ома второй вообще, хрен знает где снял, тоже 5 проводов. Буду пробовать методом перебора, или есть, какая ни будь метода, скиньте ссылку если знаете
Спасибо за ответы.
vvadim
Скачал библиотеку по сылке разорхивировал в мои документы - установите правильно библиотеку и будет вам счастье.
