DHT22. Неверные показания.
fid
DHT22 работал около года нормально. Переставил на др.проект и начал прказывать 1.0 С темп и 1% влажность. Умер датчик ?
vodyanov
А арресс по которому от отзывется, правильно в шилде указали?
Воспользуйтесь сканером и проверте, отзывается датчик или нет, и по тому-ли адрессу...
// i2c_scanner
// Version 1
//    This program (or code that looks like it)
//    can be found in many places.
//    For example on the Arduino.cc forum.
//    The original author is not know.
// Version 2, Juni 2012, Using Arduino 1.0.1
//     Adapted to be as simple as possible by Arduino.cc user Krodal
// Version 3, Feb 26  2013
//    V3 by louarnold
// Version 4, March 3, 2013, Using Arduino 1.0.3
//    by Arduino.cc user Krodal.
//    Changes by louarnold removed.
//    Scanning addresses changed from 0...127 to 1...119,
//    according to the i2c scanner by Nick Gammon
//    http://www.gammon.com.au/forum/?id=10896
// Version 5, March 28, 2013
//    As version 4, but address scans now to 127.
//    A sensor seems to use address 120.
// This sketch tests the standard 7-bit addresses
// Devices with higher bit address might not be seen properly.
#include <Wire.h>
  Wire.begin();
  Serial.println("\nI2C Scanner");
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for(address = 1; address < 127; address++ )
    // The i2c_scanner uses the return value of
    // the Write.endTransmisstion to see if
    // a device did acknowledge to the address.
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.print(address,HEX);
      Serial.println("  !");
      nDevices++;
    else if (error==4)
      Serial.print("Unknow error at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.println(address,HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
    Serial.println("done\n");
  delay(5000);           // wait 5 seconds for next scan
MaksMS
DHT22 не по i2c работает...
Датчик да, может и помер, а может питание не нравиться
vodyanov
MaksMS пишет:
Блин... мои глубочайшие извинения, он ведь действительно по 1-wire трудится. Как так перепутал ума не приложу.
А подтягивающий резистор, правильного наминала? Если есть осцилограф, посмотрите что на Vcc & Data творится, уровень шумов, ну и сам сигнал есть или нет.
MaksMS
тут не 1-wire, а свой протокол, а резистор вообще ниразу не ставил..
vodyanov
Да нет как раз 1-ware... просто НЕ совместимая с привычной нам Dallas 1-wire bus.
fid
Резисторы разные пробовал,результат одинаково. если подуть на датчик влажность 2.0% прказывает.
vodyanov
Ну тогда все шансы на похороны датчика, раз показывает все-таки данные, но не верные. Сам датчик не пробовали вскрыть, может механически повредили?
gena
 Если вскроете, то выложите фото. Интересно, как там внутри сделано.
vodyanov
Ага... всем интерестно!
trembo
trembo аватар
