Error: "setTime" was not declared in this area. Plotclock arduino uno
Пнд, 30/11/2020 - 18:43
//#include <Time.h> // Plotclock // cc - by Johannes Heberlein 2014 // v 1.02 // thingiverse.com/joo wiki.fablab-nuernberg.de // units: mm; microseconds; radians // origin: bottom left of drawing surface // time library see http://playground.arduino.cc/Code/time // RTC library see http://playground.arduino.cc/Code/time // or http://www.pjrc.com/teensy/td_libs_DS1307RTC.html // Change log: // 1.01 Release by joo at https://github.com/9a/plotclock // 1.02 Additional features implemented by Dave (https://github.com/Dave1001/): // - added ability to calibrate servofaktor seperately for left and right servos // - added code to support DS1307, DS1337 and DS3231 real time clock chips // - see http://www.pjrc.com/teensy/td_libs_DS1307RTC.html for how to hook up the real time clock // 1.03 Fixed the length bug at the servo2 angle calculation, other fixups #include <Time.h> // see http://playground.arduino.cc/Code/time #include <Servo.h> // delete or mark the next line as comment if you don't need these #define CALIBRATION // enable calibration mode //#define REALTIMECLOCK // enable real time clock #define WISHY 3 // Offset of the Y coordinats of the plate-wisher // When in calibration mode, adjust the following factors until the servos move exactly 90 degrees #define SERVOFAKTORLEFT 600 #define SERVOFAKTORRIGHT 600 // Zero-position of left and right servo // When in calibration mode, adjust the NULL-values so that the servo arms are at all times parallel // either to the X or Y axis #define SERVOLEFTNULL 1950 #define SERVORIGHTNULL 815 #define SERVOPINLIFT 2 #define SERVOPINLEFT 3 #define SERVOPINRIGHT 4 #define ZOFF 90 // lift positions of lifting servo #define LIFT0 1110+ZOFF // on drawing surface #define LIFT1 995+ZOFF // between numbers #define LIFT2 735+ZOFF // going towards sweeper // speed of liftimg arm, higher is slower #define LIFTSPEED 2000 // length of arms #define L1 35 #define L2 55.1 #define L3 13.2 #define L4 45 // origin points of left and right servo #define O1X 24//22 #define O1Y -25 #define O2X 49//47 #define O2Y -25 #ifdef REALTIMECLOCK // for instructions on how to hook up a real time clock, // see here -> http://www.pjrc.com/teensy/td_libs_DS1307RTC.html // DS1307RTC works with the DS1307, DS1337 and DS3231 real time clock chips. // Please run the SetTime example to initialize the time on new RTC chips and begin running. #include <Wire.h> #include <DS1307RTC.h> // see http://playground.arduino.cc/Code/time #endif int servoLift = 1500; Servo servo1; // Servo servo2; // Servo servo3; // volatile double lastX = 75; volatile double lastY = 47.5; int last_min = 0; void setup() { pinMode(7, INPUT_PULLUP); #ifdef REALTIMECLOCK Serial.begin(9600); //while (!Serial) { ; } // wait for serial port to connect. Needed for Leonardo only // Set current time only the first to values, hh,mm are needed tmElements_t tm; if (RTC.read(tm)) { setTime(tm.Hour,tm.Minute,tm.Second,tm.Day,tm.Month,tm.Year); Serial.println("DS1307 time is set OK."); } else { if (RTC.chipPresent()) { Serial.println("DS1307 is stopped. Please run the SetTime example to initialize the time and begin running."); } else { Serial.println("DS1307 read error! Please check the circuitry."); } // Set current time only the first to values, hh,mm are needed setTime(13,25,0,0,0,0); } #else // Set current time only the first to values, hh,mm are needed setTime(17,30,0,30,11,0); #endif drawTo(75.2, 47); lift(0); //servo1.attach(SERVOPINLIFT); // lifting servo //servo2.attach(SERVOPINLEFT); // left servo //servo3.attach(SERVOPINRIGHT); // right servo delay(1000); } void loop() { #ifdef CALIBRATION if (!servo1.attached()) servo1.attach(SERVOPINLIFT); if (!servo2.attached()) servo2.attach(SERVOPINLEFT); if (!servo3.attached()) servo3.attach(SERVOPINRIGHT); // Servohorns will have 90° between movements, parallel to x and y axis drawTo(-3, 29.2); delay(500); drawTo(74.1, 28); delay(500); #else int i = 0; if (last_min != minute()) { if (!servo1.attached()) servo1.attach(SERVOPINLIFT); if (!servo2.attached()) servo2.attach(SERVOPINLEFT); if (!servo3.attached()) servo3.attach(SERVOPINRIGHT); lift(0); hour(); while ((i+1)*10 <= hour()) { i++; } number(3, 3, 111, 1); number(5, 25, i, 0.9); number(19, 25, (hour()-i*10), 0.9); number(28, 25, 11, 0.9); i=0; while ((i+1)*10 <= minute()) { i++; } number(34, 25, i, 0.9); number(48, 25, (minute()-i*10), 0.9); lift(2); drawTo(71.0, 47.2); lift(1); last_min = minute(); delay(580); servo1.detach(); servo2.detach(); servo3.detach(); } #endif } // Writing numeral with bx by being the bottom left originpoint. Scale 1 equals a 20 mm high font. // The structure follows this principle: move to first startpoint of the numeral, lift down, draw numeral, lift up void number(float bx, float by, int num, float scale) { switch (num) { case 0: drawTo(bx + 12 * scale, by + 6 * scale); lift(0); bogenGZS(bx + 7 * scale, by + 10 * scale, 10 * scale, -0.8, 6.7, 0.5); lift(1); break; case 1: drawTo(bx + 3 * scale, by + 15 * scale); lift(0); drawTo(bx + 10 * scale, by + 20 * scale); drawTo(bx + 10 * scale, by + 0 * scale); lift(1); break; case 2: drawTo(bx + 2 * scale, by + 12 * scale); lift(0); bogenUZS(bx + 8 * scale, by + 14 * scale, 6 * scale, 3, -0.8, 1); drawTo(bx + 1 * scale, by + 0 * scale); drawTo(bx + 12 * scale, by + 0 * scale); lift(1); break; case 3: drawTo(bx + 2 * scale, by + 17 * scale); lift(0); bogenUZS(bx + 5 * scale, by + 15 * scale, 5 * scale, 3, -2, 1); bogenUZS(bx + 5 * scale, by + 5 * scale, 5 * scale, 1.57, -3, 1); lift(1); break; case 4: drawTo(bx + 10 * scale, by + 0 * scale); lift(0); drawTo(bx + 10 * scale, by + 20 * scale); drawTo(bx + 2 * scale, by + 6 * scale); drawTo(bx + 12 * scale, by + 6 * scale); lift(1); break; case 5: drawTo(bx + 2 * scale, by + 5 * scale); lift(0); bogenGZS(bx + 5 * scale, by + 6 * scale, 6 * scale, -2.5, 2, 1); drawTo(bx + 5 * scale, by + 20 * scale); drawTo(bx + 12 * scale, by + 20 * scale); lift(1); break; case 6: drawTo(bx + 2 * scale, by + 10 * scale); lift(0); bogenUZS(bx + 7 * scale, by + 6 * scale, 6 * scale, 2, -4.4, 1); drawTo(bx + 11 * scale, by + 20 * scale); lift(1); break; case 7: drawTo(bx + 2 * scale, by + 20 * scale); lift(0); drawTo(bx + 12 * scale, by + 20 * scale); drawTo(bx + 2 * scale, by + 0); lift(1); break; case 8: drawTo(bx + 5 * scale, by + 10 * scale); lift(0); bogenUZS(bx + 5 * scale, by + 15 * scale, 5 * scale, 4.7, -1.6, 1); bogenGZS(bx + 5 * scale, by + 5 * scale, 5 * scale, -4.7, 2, 1); lift(1); break; case 9: drawTo(bx + 9 * scale, by + 11 * scale); lift(0); bogenUZS(bx + 7 * scale, by + 15 * scale, 5 * scale, 4, -0.5, 1); drawTo(bx + 5 * scale, by + 0); lift(1); break; case 111: lift(0); drawTo(70, 45); drawTo(65-WISHY, 43); drawTo(65-WISHY, 46); drawTo(5, 49); drawTo(5, 46); drawTo(63-WISHY, 46); drawTo(63-WISHY, 42); drawTo(5, 42); drawTo(5, 38); drawTo(63-WISHY, 38); drawTo(63-WISHY, 34); drawTo(5, 34); drawTo(5, 29); drawTo(6, 29); drawTo(65-WISHY, 26); drawTo(5, 26); drawTo(60-WISHY, 40); drawTo(73.2, 44.0); lift(2); break; case 11: drawTo(bx + 5 * scale, by + 15 * scale); lift(0); bogenGZS(bx + 5 * scale, by + 15 * scale, 0.1 * scale, 1, -1, 1); delay(10); lift(1); drawTo(bx + 5 * scale, by + 5 * scale); lift(0); bogenGZS(bx + 5 * scale, by + 5 * scale, 0.1 * scale, 1, -1, 1); delay(10); lift(1); break; } } void lift(char lift) { switch (lift) { // room to optimize ! case 0: //850 if (servoLift >= LIFT0) { while (servoLift >= LIFT0) { servoLift--; servo1.writeMicroseconds(servoLift); delayMicroseconds(LIFTSPEED); } } else { while (servoLift <= LIFT0) { servoLift++; servo1.writeMicroseconds(servoLift); delayMicroseconds(LIFTSPEED); } } break; case 1: //150 if (servoLift >= LIFT1) { while (servoLift >= LIFT1) { servoLift--; servo1.writeMicroseconds(servoLift); delayMicroseconds(LIFTSPEED); } } else { while (servoLift <= LIFT1) { servoLift++; servo1.writeMicroseconds(servoLift); delayMicroseconds(LIFTSPEED); } } break; case 2: if (servoLift >= LIFT2) { while (servoLift >= LIFT2) { servoLift--; servo1.writeMicroseconds(servoLift); delayMicroseconds(LIFTSPEED); } } else { while (servoLift <= LIFT2) { servoLift++; servo1.writeMicroseconds(servoLift); delayMicroseconds(LIFTSPEED); } } break; } } void bogenUZS(float bx, float by, float radius, int start, int ende, float sqee) { float inkr = -0.05; float count = 0; do { drawTo(sqee * radius * cos(start + count) + bx, radius * sin(start + count) + by); count += inkr; } while ((start + count) > ende); } void bogenGZS(float bx, float by, float radius, int start, int ende, float sqee) { float inkr = 0.05; float count = 0; do { drawTo(sqee * radius * cos(start + count) + bx, radius * sin(start + count) + by); count += inkr; } while ((start + count) <= ende); } void drawTo(double pX, double pY) { double dx, dy, c; int i; // dx dy of new point dx = pX - lastX; dy = pY - lastY; //path lenght in mm, times 4 equals 4 steps per mm c = floor(7 * sqrt(dx * dx + dy * dy)); if (c < 1) c = 1; for (i = 0; i <= c; i++) { // draw line point by point set_XY(lastX + (i * dx / c), lastY + (i * dy / c)); } lastX = pX; lastY = pY; } double return_angle(double a, double b, double c) { // cosine rule for angle between c and a return acos((a * a + c * c - b * b) / (2 * a * c)); } void set_XY(double Tx, double Ty) { delay(1); double dx, dy, c, a1, a2, Hx, Hy; // calculate triangle between pen, servoLeft and arm joint // cartesian dx/dy dx = Tx - O1X; dy = Ty - O1Y; // polar lemgth (c) and angle (a1) c = sqrt(dx * dx + dy * dy); // a1 = atan2(dy, dx); // a2 = return_angle(L1, L2, c); servo2.writeMicroseconds(floor(((a2 + a1 - M_PI) * SERVOFAKTORLEFT) + SERVOLEFTNULL)); // calculate joinr arm point for triangle of the right servo arm a2 = return_angle(L2, L1, c); Hx = Tx + L3 * cos((a1 - a2 + 0.621) + M_PI); //36,5° Hy = Ty + L3 * sin((a1 - a2 + 0.621) + M_PI); // calculate triangle between pen joint, servoRight and arm joint dx = Hx - O2X; dy = Hy - O2Y; c = sqrt(dx * dx + dy * dy); a1 = atan2(dy, dx); a2 = return_angle(L1, L4, c); servo3.writeMicroseconds(floor(((a1 - a2) * SERVOFAKTORRIGHT) + SERVORIGHTNULL)); }
Hi, I'm new to arduino and I'm making a PlotClock project on arduino (I apologize in advance for the grammar, I'm Russian and I'm writing from a translator) (https://www.thingiverse.com/thing:248009), and when I turn on the calibration mode I get an error Arduino: 1.8.14 Hourly Build 2020/10/09 12:33 (Windows 10), Board: "Arduino Uno". C: \ Users \ Acer \ Downloads \ Plotclock \ plotclock_v1_03 \ plotclock_v1_03.ino: In function 'void setup ()':
plotclock_v1_03: 120: 3: error: 'setTime' was not declared in this scope
setTime (17,30,0,30,11,0);
C: \ Users \ Acer \ Downloads \ Plotclock \ plotclock_v1_03 \ plotclock_v1_03.ino: 120: 3: note: suggested alternative: 'isotime'
isotime
exit status 1
This report will have more information from
enabled option File -> Settings ->
Show verbose output at compile time
I am very worried that I do not understand anything, and therefore I want to learn how not to ask such possibly easy questions. Thanks in advance!
что это было?
Часы реального времени
Видимо библиотека Time.h не та
