Мерцание либо пульсация RGB ленты, устранение.
Добрый день уважаемые специалисты!
Собрал фоновую подстветку аналог ambilight по инструкции mysku. ru/blog/aliexpress/28820.html
использовал Arduino nano, БП 8A - https://ru.aliexpress.com/item/5V-2A-3A-4A-5A-8A-10A-12A-20A-30A-40A-60A-Switch-LED-Power-Supply/32670505021.html и ленту https://ru.aliexpress.com/item/1m-4m-5m-WS2812B-Smart-led-pixel-strip-Bl... 60LED/1м
Использовал данный скетч-
// Slightly modified Adalight protocol implementation that uses FastLED // library (http://fastled.io) for driving WS2811/WS2812 led stripe // Was tested only with Prismatik software from Lightpack project #include "FastLED.h" #define NUM_LEDS 110 // Max LED count #define LED_PIN 8 // arduino output pin #define GROUND_PIN 10 #define BRIGHTNESS 255 // maximum brightness #define SPEED 115200 // virtual serial port speed, must be the same in boblight_config CRGB leds[NUM_LEDS]; uint8_t * ledsRaw = (uint8_t *)leds; // A 'magic word' (along with LED count & checksum) precedes each block // of LED data; this assists the microcontroller in syncing up with the // host-side software and properly issuing the latch (host I/O is // likely buffered, making usleep() unreliable for latch). You may see // an initial glitchy frame or two until the two come into alignment. // The magic word can be whatever sequence you like, but each character // should be unique, and frequent pixel values like 0 and 255 are // avoided -- fewer false positives. The host software will need to // generate a compatible header: immediately following the magic word // are three bytes: a 16-bit count of the number of LEDs (high byte // first) followed by a simple checksum value (high byte XOR low byte // XOR 0x55). LED data follows, 3 bytes per LED, in order R, G, B, // where 0 = off and 255 = max brightness. static const uint8_t magic[] = { 'A','d','a'}; #define MAGICSIZE sizeof(magic) #define HEADERSIZE (MAGICSIZE + 3) #define MODE_HEADER 0 #define MODE_DATA 2 // If no serial data is received for a while, the LEDs are shut off // automatically. This avoids the annoying "stuck pixel" look when // quitting LED display programs on the host computer. static const unsigned long serialTimeout = 150000; // 150 seconds void setup() { pinMode(GROUND_PIN, OUTPUT); digitalWrite(GROUND_PIN, LOW); FastLED.addLeds<WS2812B, LED_PIN, GRB>(leds, NUM_LEDS); // Dirty trick: the circular buffer for serial data is 256 bytes, // and the "in" and "out" indices are unsigned 8-bit types -- this // much simplifies the cases where in/out need to "wrap around" the // beginning/end of the buffer. Otherwise there'd be a ton of bit- // masking and/or conditional code every time one of these indices // needs to change, slowing things down tremendously. uint8_t buffer[256], indexIn = 0, indexOut = 0, mode = MODE_HEADER, hi, lo, chk, i, spiFlag; int16_t bytesBuffered = 0, hold = 0, c; int32_t bytesRemaining; unsigned long startTime, lastByteTime, lastAckTime, t; int32_t outPos = 0; Serial.begin(SPEED); // Teensy/32u4 disregards baud rate; is OK! Serial.print("Ada\n"); // Send ACK string to host startTime = micros(); lastByteTime = lastAckTime = millis(); // loop() is avoided as even that small bit of function overhead // has a measurable impact on this code's overall throughput. for(;;) { // Implementation is a simple finite-state machine. // Regardless of mode, check for serial input each time: t = millis(); if((bytesBuffered < 256) && ((c = Serial.read()) >= 0)) { buffer[indexIn++] = c; bytesBuffered++; lastByteTime = lastAckTime = t; // Reset timeout counters } else { // No data received. If this persists, send an ACK packet // to host once every second to alert it to our presence. if((t - lastAckTime) > 1000) { Serial.print("Ada\n"); // Send ACK string to host lastAckTime = t; // Reset counter } // If no data received for an extended time, turn off all LEDs. if((t - lastByteTime) > serialTimeout) { memset(leds, 0, NUM_LEDS * sizeof(struct CRGB)); //filling Led array by zeroes FastLED.show(); lastByteTime = t; // Reset counter } } switch(mode) { case MODE_HEADER: // In header-seeking mode. Is there enough data to check? if(bytesBuffered >= HEADERSIZE) { // Indeed. Check for a 'magic word' match. for(i=0; (i<MAGICSIZE) && (buffer[indexOut++] == magic[i++]);); if(i == MAGICSIZE) { // Magic word matches. Now how about the checksum? hi = buffer[indexOut++]; lo = buffer[indexOut++]; chk = buffer[indexOut++]; if(chk == (hi ^ lo ^ 0x55)) { // Checksum looks valid. Get 16-bit LED count, add 1 // (# LEDs is always > 0) and multiply by 3 for R,G,B. bytesRemaining = 3L * (256L * (long)hi + (long)lo + 1L); bytesBuffered -= 3; outPos = 0; memset(leds, 0, NUM_LEDS * sizeof(struct CRGB)); mode = MODE_DATA; // Proceed to latch wait mode } else { // Checksum didn't match; search resumes after magic word. indexOut -= 3; // Rewind } } // else no header match. Resume at first mismatched byte. bytesBuffered -= i; } break; case MODE_DATA: if(bytesRemaining > 0) { if(bytesBuffered > 0) { if (outPos < sizeof(leds)) ledsRaw[outPos++] = buffer[indexOut++]; // Issue next byte bytesBuffered--; bytesRemaining--; } // If serial buffer is threatening to underrun, start // introducing progressively longer pauses to allow more // data to arrive (up to a point). } else { // End of data -- issue latch: startTime = micros(); mode = MODE_HEADER; // Begin next header search FastLED.show(); } } // end switch } // end for(;;) } void loop() { // Not used. See note in setup() function. }
Всё получилось хорошо, 110 диодов лента подключена только с одной стороны, но есть мерцание глазу не заметно, видит камера смартфона
Ну и соответствено после длительного включения есть легкая усталость глаз. Как сглать ток, либо поднять частоту, подскажите пожалуста?
Я в этом деле новичек, но буду всеми силами вникать в кажды ваш совет.
Заранее спасибо!
Вот схема подключения
Только у меня Arduino nano
Наверное с этой лентой вы уже ничего не сделать лучше не сможете. Мерцание из-за того, что яркость светодиода регулируется ШИМом. Т.е. чтобы меньше мерцало нужно ограничивать диапазон регулировки яркости.
https://www.youtube.com/watch?v=flEm-wQpx90
Вот мой пример именно на этой ленте, разворачивать рисунок на врашающемся колесе. Чем меньше яркость я ставил, тем больше было видно дискретность включения светодиодов.
Спасибо Вам за ответ!
Заменял ногу Ардуино, тоже не помогло... и тогда до меня дошло, прочита дадашит на контроллер WS2812, действительно ничего не сделать, единственн вариант замены ленты на WS2811 хотя по данным там тоже в пределах 400герц.
Я так понимаю, ambilight хороший выйдет не на ардуино, а на отрезках светодиодных RGB лент, без контролеров на них, управление которым берёт на себя микросхема более продвинутая...
В общем сложно всё это) особенно мне, единственное буду ждать может кто-нибудь на этом форуме собирал нечто подобное и поделится советом)
Я правильно понял, у ленты https://cdn-shop.adafruit.com/datasheets/WS2801.pdf ШИМ на частоте 2.5 Кгц?
А может пульсации от источника питания?
Я бы поробовал запитать Ардуино и ленту через небольшой фильтр на дросселе и конденсаторе с низким ESR
Мне нужно будет схему показать специалисту) А пока может есть готовое решение на Али? (если можно - ссылку) по данной схеме.
Arduino питается от USB, а вот на ленту можно поставить.
Первым делом, чтобы исключить пульсацию, я запитывал ленту от АКБ, ситуация абсолютно такая же, так что наличие фильтра хорошо, но ситуацию координально не исправит.
kasper007 - согласен. Замена ленты на ws2801 пока идея одна.
