NT-R02BL Datasheet
gpa_76@mail.ru
Есть ли у кого-нибудь пример подключения сего беспроводного приёмника? Хочу получать данные с беспроводного датчика температуры Oregon
Если есть пример скетча, буду рад
http://dx.com/p/nt-r02bl-wireless-high-frequency-receiving-module-150634
4ishops
// Oregon V2 decoder added - Dominique Pierre
// Oregon V3 decoder revisited - Dominique Pierre
// New code to decode OOK signals from weather sensors, etc.
// 2010-04-11 <jcw@equi4.com> <a data-cke-saved-href="http://opensource.org/licenses/mit-license.php" href="http://opensource.org/licenses/mit-license.php" rel="nofollow">http://opensource.org/licenses/mit-license.php</a>
// $Id: ookDecoder.pde 5331 2010-04-17 10:45:17Z jcw $
class DecodeOOK {
protected:
    byte total_bits, bits, flip, state, pos, data[25];
    virtual char decode (word width) =0;
public:
    enum { UNKNOWN, T0, T1, T2, T3, OK, DONE };
    DecodeOOK () { resetDecoder(); }
    bool nextPulse (word width) {
        if (state != DONE)
            switch (decode(width)) {
                case -1: resetDecoder(); break;
                case 1:  done(); break;
        return isDone();
    bool isDone () const { return state == DONE; }
    const byte* getData (byte& count) const {
        count = pos;
        return data;
    void resetDecoder () {
        total_bits = bits = pos = flip = 0;
        state = UNKNOWN;
    // add one bit to the packet data buffer
    virtual void gotBit (char value) {
        total_bits++;
        byte *ptr = data + pos;
        *ptr = (*ptr >> 1) | (value << 7);
        if (++bits >= 8) {
            bits = 0;
            if (++pos >= sizeof data) {
                resetDecoder();
                return;
        state = OK;
    // store a bit using Manchester encoding
    void manchester (char value) {
        flip ^= value; // manchester code, long pulse flips the bit
        gotBit(flip);
    // move bits to the front so that all the bits are aligned to the end
    void alignTail (byte max =0) {
        // align bits
        if (bits != 0) {
            data[pos] >>= 8 - bits;
            for (byte i = 0; i < pos; ++i)
                data[i] = (data[i] >> bits) | (data[i+1] << (8 - bits));
            bits = 0;
        // optionally shift bytes down if there are too many of 'em
        if (max > 0 && pos > max) {
            byte n = pos - max;
            pos = max;
                data[i] = data[i+n];
    void reverseBits () {
        for (byte i = 0; i < pos; ++i) {
            byte b = data[i];
            for (byte j = 0; j < 8; ++j) {
                data[i] = (data[i] << 1) | (b & 1);
                b >>= 1;
    void reverseNibbles () {
            data[i] = (data[i] << 4) | (data[i] >> 4);
    void done () {
        while (bits)
            gotBit(0); // padding
        state = DONE;
// 433 MHz decoders
class OregonDecoderV2 : public DecodeOOK {
public:
    OregonDecoderV2() {}
        if(!(total_bits & 0x01))
            data[pos] = (data[pos] >> 1) | (value ? 0x80 : 00);
        total_bits++;
        pos = total_bits >> 4;
        if (pos >= sizeof data) {
            resetDecoder();
            return;
        state = OK;
    virtual char decode (word width) {
        if (200 <= width && width < 1200) {
            byte w = width >= 700;
            switch (state) {
                case UNKNOWN:
                    if (w != 0) {
                        // Long pulse
                        ++flip;
                    } else if (32 <= flip) {
                        // Short pulse, start bit
                        flip = 0;
                        state = T0;
                    } else {
                      // Reset decoder
                        return -1;
                case OK:
                    if (w == 0) {
                        // Short pulse
                        state = T0;
                    } else {
                        // Long pulse
                        manchester(1);
                case T0:
                    if (w == 0) {
                      // Second short pulse
                        manchester(0);
                    } else {
                        // Reset decoder
                        return -1;
        } else {
            return -1;
        return total_bits == 160 ? 1: 0;
class OregonDecoderV3 : public DecodeOOK {
public:
    OregonDecoderV3() {}
        total_bits++;
        pos = total_bits >> 3;
            resetDecoder();
            return;
        state = OK;
            switch (state) {
                case UNKNOWN:
                    if (w == 0)
                        ++flip;
                        flip = 1;
                        manchester(1);
                    } else
                        return -1;
                case OK:
                    if (w == 0)
                        state = T0;
                        manchester(1);
                case T0:
                    if (w == 0)
                        manchester(0);
                        return -1;
        } else {
            return -1;
        return  total_bits == 80 ? 1: 0;
class CrestaDecoder : public DecodeOOK {
public:
    CrestaDecoder () {}
        if (200 <= width && width < 1300) {
            byte w = width >= 750;
            switch (state) {
                case UNKNOWN:
                    if (w == 1)
                        ++flip;
                    else if (2 <= flip && flip <= 10)
                        state = T0;
                        return -1;
                case OK:
                    if (w == 0)
                        state = T0;
                        gotBit(1);
                case T0:
                    if (w == 0)
                        gotBit(0);
                        return -1;
        } else if (width >= 2500 && pos >= 7)
            return 1;
            return -1;
        return 0;
class KakuDecoder : public DecodeOOK {
public:
    KakuDecoder () {}
        if (180 <= width && width < 450 || 950 <= width && width < 1250) {
            switch (state) {
                case UNKNOWN:
                case OK:
                    if (w == 0)
                        state = T0;
                        return -1;
                case T0:
                    if (w)
                        state = T1;
                        return -1;
                case T1:
                    state += w + 1;
                case T2:
                    if (w)
                        gotBit(0);
                        return -1;
                case T3:
                    if (w == 0)
                        gotBit(1);
                        return -1;
        } else if (width >= 2500 && 8 * pos + bits == 12) {
            for (byte i = 0; i < 4; ++i)
                gotBit(0);
            alignTail(2);
            return 1;
        } else
            return -1;
        return 0;
class XrfDecoder : public DecodeOOK {
public:
    XrfDecoder () {}
    // see also <a data-cke-saved-href="http://davehouston.net/rf.htm" href="http://davehouston.net/rf.htm" rel="nofollow">http://davehouston.net/rf.htm</a>
        if (width > 2000 && pos >= 4)
            return 1;
        if (width > 5000)
            return -1;
        if (width > 4000 && state == UNKNOWN)
            state = OK;
        else if (350 <= width && width < 1800) {
            byte w = width >= 720;
            switch (state) {
                case OK:
                    if (w == 0)
                        state = T0;
                        return -1;
                case T0:
                    gotBit(w);
        } else
            return -1;
        return 0;
class HezDecoder : public DecodeOOK {
public:
    HezDecoder () {}
    // see also <a data-cke-saved-href="http://homeeasyhacking.wikia.com/wiki/Home_Easy_Hacking_Wiki" href="http://homeeasyhacking.wikia.com/wiki/Home_Easy_Hacking_Wiki" rel="nofollow">http://homeeasyhacking.wikia.com/wiki/Home_Easy_Hacking_Wiki</a>
            byte w = width >= 600;
            gotBit(w);
        } else if (width >= 5000 && pos >= 5 /*&& 8 * pos + bits == 50*/) {
            for (byte i = 0; i < 6; ++i)
                gotBit(0);
            alignTail(7); // keep last 56 bits
            return 1;
        } else
            return -1;
        return 0;
// 868 MHz decoders
class VisonicDecoder : public DecodeOOK {
public:
    VisonicDecoder () {}
        if (200 <= width && width < 1000) {
            switch (state) {
                case UNKNOWN:
                case OK:
                    state = w == 0 ? T0 : T1;
                case T0:
                    gotBit(!w);
                    if (w)
                        return 0;
                case T1:
                    gotBit(!w);
                    if (!w)
                        return 0;
            // sync error, flip all the preceding bits to resync
            for (byte i = 0; i <= pos; ++i)
                data[i] ^= 0xFF;
        } else if (width >= 2500 && 8 * pos + bits >= 36 && state == OK) {
                gotBit(0);
            alignTail(5); // keep last 40 bits
            // only report valid packets
            byte b = data[0] ^ data[1] ^ data[2] ^ data[3] ^ data[4];
            if ((b & 0xF) == (b >> 4))
                return 1;
        } else
            return -1;
        return 0;
class EMxDecoder : public DecodeOOK {
public:
    EMxDecoder () {}
    // see also <a data-cke-saved-href="http://fhz4linux.info/tiki-index.php?page=EM+Protocol" href="http://fhz4linux.info/tiki-index.php?page=EM+Protocol" rel="nofollow">http://fhz4linux.info/tiki-index.php?page=EM+Protocol</a>
            switch (state) {
                case UNKNOWN:
                    if (w == 0)
                        ++flip;
                    else if (flip > 20)
                        state = OK;
                        return -1;
                case OK:
                    if (w == 0)
                        state = T0;
                        return -1;
                case T0:
                    gotBit(w);
        } else if (width >= 1500 && pos >= 9)
            return 1;
            return -1;
        return 0;
class KSxDecoder : public DecodeOOK {
public:
    KSxDecoder () {}
    // see also <a data-cke-saved-href="http://www.dc3yc.homepage.t-online.de/protocol.htm" href="http://www.dc3yc.homepage.t-online.de/protocol.htm" rel="nofollow">http://www.dc3yc.homepage.t-online.de/protocol.htm</a>
            switch (state) {
                case UNKNOWN:
                    gotBit(w);
                    bits = pos = 0;
                    if (data[0] != 0x95)
                        state = UNKNOWN;
                case OK:
                case T0:
                    gotBit(1);
                    if (!w)
                        return -1;
                case T1:
                    gotBit(0);
                    if (w)
                        return -1;
        } else if (width >= 1500 && pos >= 6)
            return 1;
            return -1;
        return 0;
class FSxDecoder : public DecodeOOK {
public:
    FSxDecoder () {}
    // see also <a data-cke-saved-href="http://fhz4linux.info/tiki-index.php?page=FS20%20Protocol" href="http://fhz4linux.info/tiki-index.php?page=FS20%20Protocol" rel="nofollow">http://fhz4linux.info/tiki-index.php?page=FS20%20Protocol</a>
        if (300 <= width && width < 775) {
            byte w = width >= 500;
            switch (state) {
                case UNKNOWN:
                    if (w == 0)
                        ++flip;
                    else if (flip > 20)
                        state = T1;
                        return -1;
                case OK:
                case T0:
                    gotBit(0);
                    if (w)
                        return -1;
                case T1:
                    gotBit(1);
                    if (!w)
                        return -1;
        } else if (width >= 1500 && pos >= 5)
            return 1;
            return -1;
        return 0;
OregonDecoderV2 orscV2;
OregonDecoderV3 orscV3;
CrestaDecoder cres;
KakuDecoder kaku;
XrfDecoder xrf;
HezDecoder hez;
VisonicDecoder viso;
EMxDecoder emx;
KSxDecoder ksx;
FSxDecoder fsx;
#define PORT 2
volatile word pulse;
#if defined(__AVR_ATmega1280__)
void ext_int_1(void) {
#else
ISR(ANALOG_COMP_vect) {
#endif
    static word last;
    // determine the pulse length in microseconds, for either polarity
    pulse = micros() - last;
    last += pulse;
void reportSerial (const char* s, class DecodeOOK& decoder) {
    byte pos;
    const byte* data = decoder.getData(pos);
    Serial.print(s);
    Serial.print(' ');
        Serial.print(data[i] >> 4, HEX);
        Serial.print(data[i] & 0x0F, HEX);
    // Serial.print(' ');
    // Serial.print(millis() / 1000);
    Serial.println();
    decoder.resetDecoder();
void setup () {
    Serial.begin(115200);
    Serial.println("\n[ookDecoder]");
#if !defined(__AVR_ATmega1280__)
    pinMode(13 + PORT, INPUT);  // use the AIO pin
    digitalWrite(13 + PORT, 1); // enable pull-up
    // use analog comparator to switch at 1.1V bandgap transition
    ACSR = _BV(ACBG) | _BV(ACI) | _BV(ACIE);
    // set ADC mux to the proper port
    ADCSRA &= ~ bit(ADEN);
    ADCSRB |= bit(ACME);
    ADMUX = PORT - 1;
#else
   attachInterrupt(1, ext_int_1, CHANGE);
   DDRE  &= ~_BV(PE5);
   PORTE &= ~_BV(PE5);
#endif
void loop () {
    static int i = 0;
    cli();
    word p = pulse;
    pulse = 0;
    sei();
    //if (p != 0){ Serial.print(++i); Serial.print('\n');}
    if (p != 0) {
        if (orscV2.nextPulse(p))
            reportSerial("OSV2", orscV2);
        if (orscV3.nextPulse(p))
            reportSerial("OSV3", orscV3);
        if (cres.nextPulse(p))
            reportSerial("CRES", cres);
        if (kaku.nextPulse(p))
            reportSerial("KAKU", kaku);
        if (xrf.nextPulse(p))
            reportSerial("XRF", xrf);
        if (hez.nextPulse(p))
            reportSerial("HEZ", hez);
    if (p != 0) {
        if (viso.nextPulse(p))
            reportSerial("VISO", viso);
        if (emx.nextPulse(p))
            reportSerial("EMX", emx);
        if (ksx.nextPulse(p))
            reportSerial("KSX", ksx);
        if (fsx.nextPulse(p))
            reportSerial("FSX", fsx);
