Ошибка кампиляции для платы Arduino/Genelino Uno
Вс, 19/03/2017 - 13:21
Arduino: 1.8.1 (Windows 7), Плата:"Arduino/Genuino Uno"
C:\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Arduino\hardware -tools C:\Arduino\tools-builder -tools C:\Arduino\hardware\tools\avr -built-in-libraries C:\Arduino\libraries -libraries C:\Users\Hp\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10801 -build-path C:\Users\Hp\AppData\Local\Temp\arduino_build_945211 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Arduino\hardware\tools\avr -verbose C:\Users\Hp\Documents\Arduino\sketch_mar18a\sketch_mar18a.ino
C:\Arduino\arduino-builder -compile -logger=machine -hardware C:\Arduino\hardware -tools C:\Arduino\tools-builder -tools C:\Arduino\hardware\tools\avr -built-in-libraries C:\Arduino\libraries -libraries C:\Users\Hp\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10801 -build-path C:\Users\Hp\AppData\Local\Temp\arduino_build_945211 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Arduino\hardware\tools\avr -verbose C:\Users\Hp\Documents\Arduino\sketch_mar18a\sketch_mar18a.ino
Using board 'uno' from platform in folder: C:\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\sketch\sketch_mar18a.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\sketch\sketch_mar18a.ino.cpp" -o "C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\preproc\ctags_target_for_gcc_minus_e.cpp"
Компиляция скетча...
"C:\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\sketch\sketch_mar18a.ino.cpp" -o "C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\sketch\sketch_mar18a.ino.cpp.o"
Compiling libraries...
Compiling core...
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\wiring_pulse.S.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\WInterrupts.c.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\hooks.c.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\wiring.c.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\wiring_analog.c.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\wiring_digital.c.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\wiring_pulse.c.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\wiring_shift.c.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\CDC.cpp.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\HardwareSerial.cpp.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\HardwareSerial0.cpp.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\HardwareSerial1.cpp.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\HardwareSerial2.cpp.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\HardwareSerial3.cpp.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\IPAddress.cpp.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\PluggableUSB.cpp.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\Print.cpp.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\Stream.cpp.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\Tone.cpp.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\USBCore.cpp.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\WMath.cpp.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\WString.cpp.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\abi.cpp.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\main.cpp.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\new.cpp.o
Используем предварительно скомпилированный файл: C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\core\core.a
Linking everything together...
"C:\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\Hp\AppData\Local\Temp\arduino_build_945211/sketch_mar18a.ino.elf" "C:\Users\Hp\AppData\Local\Temp\arduino_build_945211\sketch\sketch_mar18a.ino.cpp.o" "C:\Users\Hp\AppData\Local\Temp\arduino_build_945211/core\core.a" "-LC:\Users\Hp\AppData\Local\Temp\arduino_build_945211" -lm
c:/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/lib/avr5/crtatmega328p.o:(.init9+0x0): undefined reference to `main'
collect2.exe: error: ld returned 1 exit status
exit status 1
Ошибка компиляции для платы Arduino/Genuino Uno.
Только купил не знаю как исправить , помогите .
у меня такая проблема была когда я свежие версии IDE на XP устанавливал . в моем случае было 3 варианта.
1) поставить систему выше xp например win 7
2) поставить на XP старую версию IDE
3) на XP на свежей IDE заменить один файлик взяв его от старой IDE
Уточню название файлика - ld.exe
saftik, в приведенном ТС протоколе явно значится Windows 7.
также рекомендуеться чтоб в пути к папке установки небыло русских букв
andriano, простите незаметил
