Семисегментный led и Arduino mega
EUS
Семисегментный led индикатор и Arduino mega. Снят с убитого контроллера низвестного оборудования, подключить к Arduino mega 2560 удалось с помощью этого кода, немного подправил сегменты пины и все заработало
 6-13-2011
 Spark Fun Electronics 2011
 Nathan Seidle
 This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
 4 digit 7 segment display:
 http://www.sparkfun.com/products/9483
 Datasheet:
 http://www.sparkfun.com/datasheets/Components/LED/7-Segment/YSD-439AR6B-...
 This is an example of how to drive a 7 segment LED display from an ATmega without the use of current limiting resistors.
 This technique is very common but requires some knowledge of electronics - you do run the risk of dumping too
 much current through the segments and burning out parts of the display. If you use the stock code you should be ok, but
 be careful editing the brightness values.
 This code should work with all colors (red, blue, yellow, green) but the brightness will vary from one color to the next
 because the forward voltage drop of each color is different. This code was written and calibrated for the red color.
 This code will work with most Arduinos but you may want to re-route some of the pins.
 7 segments
 4 digits
 1 colon
 12 pins required for full control
//int digit1 = 8; //PWM Display pin 1
int digit2 = 9; //PWM Display pin 2
int digit3 = 10; //PWM Display pin 6
int digit4 = 11; //PWM Display pin 8
//Pin mapping from Arduino to the ATmega DIP28 if you need it
//http://www.arduino.cc/en/Hacking/PinMapping
int segA = 1; //Display pin 14
int segB = 2; //Display pin 16
int segC = 3; //Display pin 13
int segD = 4; //Display pin 3
int segE = 5; //Display pin 5
int segF = 6; //Display pin 11
int segG = 7; //Display pin 15
  pinMode(segA, OUTPUT);
  pinMode(segB, OUTPUT);
  pinMode(segC, OUTPUT);
  pinMode(segD, OUTPUT);
  pinMode(segE, OUTPUT);
  pinMode(segF, OUTPUT);
  pinMode(segG, OUTPUT);
 // pinMode(digit1, OUTPUT);
  pinMode(digit2, OUTPUT);
  pinMode(digit3, OUTPUT);
  pinMode(digit4, OUTPUT);
  //pinMode(13, OUTPUT);
  //long startTime = millis();
  displayNumber(millis()/1000);
  //while( (millis() - startTime) < 2000) {
  //displayNumber(1217);
  //delay(1000);
//Given a number, we display 10:22
//After running through the 4 numbers, the display is left turned off
//Display brightness
//Each digit is on for a certain amount of microseconds
//Then it is off until we have reached a total of 20ms for the function call
//Let's assume each digit is on for 1000us
//If each digit is on for 1ms, there are 4 digits, so the display is off for 16ms.
//That's a ratio of 1ms to 16ms or 6.25% on time (PWM).
//Let's define a variable called brightness that varies from:
//5000 blindingly bright (15.7mA current draw per digit)
//2000 shockingly bright (11.4mA current draw per digit)
//1000 pretty bright (5.9mA)
//500 normal (3mA)
//200 dim but readable (1.4mA)
//50 dim but readable (0.56mA)
//5 dim but readable (0.31mA)
//1 dim but readable in dark (0.28mA)
void displayNumber(int toDisplay) {
#define DISPLAY_BRIGHTNESS  500
#define DIGIT_ON  HIGH
#define DIGIT_OFF  LOW
  long beginTime = millis();
  for(int digit = 4 ; digit > 0 ; digit--) {
    //Turn on a digit for a short amount of time
    switch(digit) {
    case 1:
     // digitalWrite(digit1, DIGIT_ON);
    case 2:
      digitalWrite(digit2, DIGIT_ON);
    case 3:
      digitalWrite(digit3, DIGIT_ON);
    case 4:
    digitalWrite(digit4, DIGIT_ON);
//  Turn on the right segments for this digit
    lightNumber(toDisplay % 10);
    toDisplay /= 10;
    delayMicroseconds(DISPLAY_BRIGHTNESS); //Display this digit for a fraction of a second (between 1us and 5000us, 500 is pretty good)
    //Turn off all segments
    lightNumber(10);
    //Turn off all digits
  //  digitalWrite(digit1, DIGIT_OFF);
    digitalWrite(digit2, DIGIT_OFF);
    digitalWrite(digit3, DIGIT_OFF);
    digitalWrite(digit4, DIGIT_OFF);
  while( (millis() - beginTime) < 10) ; //Wait for 20ms to pass before we paint the display again
//Given a number, turns on those segments
//If number == 10, then turn off number
void lightNumber(int numberToDisplay) {
#define SEGMENT_ON  LOW
#define SEGMENT_OFF HIGH
  switch (numberToDisplay){
  case 0:
    digitalWrite(segA, SEGMENT_ON);
    digitalWrite(segB, SEGMENT_ON);
    digitalWrite(segC, SEGMENT_ON);
    digitalWrite(segD, SEGMENT_ON);
    digitalWrite(segE, SEGMENT_ON);
    digitalWrite(segF, SEGMENT_OFF);
    digitalWrite(segG, SEGMENT_ON);
  case 1:
    digitalWrite(segA, SEGMENT_OFF);
    digitalWrite(segB, SEGMENT_OFF);
    digitalWrite(segC, SEGMENT_OFF);
    digitalWrite(segG, SEGMENT_OFF);
  case 2:
    digitalWrite(segD, SEGMENT_OFF);
    digitalWrite(segF, SEGMENT_ON);
  case 3:
  case 4:
  case 5:
    digitalWrite(segE, SEGMENT_OFF);
  case 6:
  case 7:
  case 8:
  case 9:
  case 10:
 интерес в том что програмно меняется яркость, в связи с чем не нужны доп. резисторы. собственно подключал напрямую пины свои подправил за день играний ничего не сгорело.
Так вот вопрос как,  заставить его высвечивать данные датчика температуры, примера найти не удалось, тем более что Led не стандартный
bwn
EUS пишет:
Возможно все еще впереди.
EUS
Благодарю за юмор, но все же, направте точечно ссылкой, где почитать , чтобы заставить этот код выводить информацию с простейшего датчика.
int x = A0;
void setup() // процедура setup
  pinMode(12, OUTPUT);
  pinMode(A0, INPUT);
void loop() // процедура loop
int reading = analogRead(A0);
float voltage = reading * 5.0;
voltage /= 1024.0;
Serial.print(voltage); Serial.println(" volts");
P.S Прошу не ругать за простыню в первом посте, не сразу разобрался с форумом.
bwn
Не направлю, ибо и сам не знаю. Вам надо связать case с цифрами и дальше осуществлять вывод.
EUS
displayNumber(ЗНАЧЕНИЕ ИЛИ ПЕРЕМЕННАЯ); все заработало, нельзя использовать, с выводом в порт или я незнаю как. Влюбом случае с командой сериал LCD начинал мерцать. Может кому пригодиться.
