Возможно ли по коду определить монтажную схему?
Ср, 03/01/2018 - 22:27
Приветствую.
Предосталяю для анализа всю имеющуюся информацию по этому вопросу.
https://www.youtube.com/watch?v=OW-Bf3yjUyE
Wiring diagrams:
Код:
/* Start button is Digital Pin 7, SyRen S1 is connected to Arduino Digital Pin 1 (TX), Proximities are Digital Pins 2 and 3, Pots are Analog Pins 1 and 2 */
#include <SyRenSimplified.h>
const int StopButton = 7;
const int ForwardButton = 3;
const int ReverseButton = 2;
const int ForwardSpeedPin = A1;
const int ReverseSpeedPin = A2;
int ForwardState = 0;
int ReverseState = 0;
int StopState = 0;
int ForwardSpeed = 0;
int ReverseSpeed = 0;
int CurrentState = 0; // 0 is stopped, 1 is forward, 2 is reverse
SyRenSimplified ST; // Simplified Serial Mode. Baud rate of 9600. Arduino TX->1 -> Sabertooth S1 Arduino GND -> Sabertooth 0V [ST.motor(1, X); X of 0 is full reverse, 128 is stop, 255 full forward] <--- WRONG! -127 full reverse, 0 stop, 127 full forward
SyRenTXPinSerial.begin(9600); // This is the baud rate you chose with the DIP switches.
ST.motor(1, 0);
ForwardState = digitalRead(ForwardButton);
ReverseState = digitalRead(ReverseButton);
ForwardSpeed = analogRead(ForwardSpeedPin);
ReverseSpeed = analogRead(ReverseSpeedPin);
ForwardSpeed = map(ForwardSpeed,0,1023,60,1);
ReverseSpeed = map(ReverseSpeed,0,1023,-60,-1);
StopState = digitalRead(StopButton);
//SET THREE DIFFERENT STATES (FORWARD, REVERSE, STOP)
if (ForwardState == LOW)
{ //up state
CurrentState = 1;
if (ReverseState == LOW)
{ // down state
CurrentState = 2;
if (StopState == LOW)
CurrentState = 0;
ST.motor(1, 0);
//FINISHED WITH "SET THREE DIFFERENT STATES (FORWARD, REVERSE, STOP)"
if (CurrentState == 0)
ST.motor(1, 0);
delay(2000);
if (CurrentState == 1)
{ //Forward
delay(2000);
ST.motor(1,ForwardSpeed);
if (CurrentState == 2)
{ //Reverse
delay(2000);
ST.motor(1, ReverseSpeed);
Да.
СПС
