контроллер автоматического полива
Втр, 26/07/2016 - 22:32
Необходимо довести до ума контроллер автополива на Arduino Nano(ATmega328).
Есть скетч, фунционал которго меня устраивает, за исключением управления(нивигации в меню).
* "THE BEER-WARE LICENSE" (Revision 42):
* <adi@clepcea.ro> wrote this file. As long as you retain this notice you
* can do whatever you want with this stuff. If we meet some day, and you think
* this stuff is worth it, you can buy me a beer in return. Adi Clepcea
#include "Wire.h"
#include "LiquidCrystal.h"
#include "math.h"
#include "EEPROM.h"
#define DS1307_I2C_ADDRESS 0x68
#define PIN_STG 12
#define PIN_MENU 11
#define PIN_DR 10
#define PIN_COMMAND_A A1 //releu A
#define PIN_COMMAND_B A2 //releu B
#define PIN_COMMAND_C A3 //releu C
#define PIN_COMMAND_D A0 //releu D
#define PIN_COMMAND_E 7 //releu E
#define PIN_COMMAND_F 9 //releu F
#define PIN_COMMAND_G 13 //releu G
#define DESCHIS LOW
#define INCHIS HIGH
#define NR_ALARME 6
#define MAX_MENU_POS NR_ALARME*4+3 //trebuie sa fie NR_ALARME*4+3
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
byte menuPos=0;
byte subMenuPos = 0;
byte cursorPos = -1;
char linia1[17];
char linia2[17];
char linia[17];
boolean dataDirthy = false;
boolean oraDirthy = false;
long lastMillis=0;
boolean bAlarma = false;
typedef struct alarm{
byte hour;
byte minute;
byte days;
byte duration;
byte relee;
byte unitAlarma;
typedef struct ds1307_time{
byte second;
byte minute;
byte hour;
byte dayOfWeek;
byte dayOfMonth;
byte month;
byte year;
struct ds1307_time time;
alarm* alarme = (alarm*) malloc(sizeof(alarm) * NR_ALARME);
byte relee[]={PIN_COMMAND_G, PIN_COMMAND_F,PIN_COMMAND_E,PIN_COMMAND_D,PIN_COMMAND_C,PIN_COMMAND_B,PIN_COMMAND_A};
byte decToBcd(byte val){
return ((val/10*16)+(val%10));
byte bcdToDec(byte val){
return ((val/16*10)+(val%16));
void setDateDs1307(struct ds1307_time time)
Wire.beginTransmission(DS1307_I2C_ADDRESS);
Wire.write(0);
Wire.write(decToBcd(time.second));
Wire.write(decToBcd(time.minute));
Wire.write(decToBcd(time.hour));
Wire.write(decToBcd(time.dayOfWeek));
Wire.write(decToBcd(time.dayOfMonth));
Wire.write(decToBcd(time.month));
Wire.write(decToBcd(time.year));
Wire.endTransmission();
void getDateDs1307(struct ds1307_time *time)
Wire.write(0);
Wire.requestFrom(DS1307_I2C_ADDRESS,7);
(*time).second = bcdToDec(Wire.read() & 0x7f);
(*time).minute = bcdToDec(Wire.read());
(*time).hour = bcdToDec(Wire.read() & 0x3f);
(*time).dayOfWeek = bcdToDec(Wire.read());
(*time).dayOfMonth = bcdToDec(Wire.read());
(*time).month = bcdToDec(Wire.read());
(*time).year = bcdToDec(Wire.read());
void showMenu(){
char *zile[7];
zile[0]="L\0";
zile[1]="M\0";
zile[2]="M\0";
zile[3]="J\0";
zile[4]="V\0";
zile[5]="S\0";
zile[6]="D\0";
if(menuPos==1){
strcpy(linia1,"Data\0");
strcpy(linia2,getDate(time));
strcat(linia2," ");
strcat(linia2,getZiuaSaptamaniiShort(time.dayOfWeek));
}else if(menuPos==2){
strcpy(linia1,"Ora\0");
strcpy(linia2,getTime(time));
}else if((menuPos+1)%4==0){ //incepand cu 3, din 4 in 4 avem ora alarmei
strcpy(linia1,"Alarma ");
linia1[7] = 48+(byte)((menuPos+1)/4)/10;
linia1[8] = 48+(byte)(((menuPos+1)/4)-((menuPos+1)/4)/10*10);
linia1[9]='\0';
strcat(linia1," ora\0");
strcpy(linia2,getFmt2Char((alarme[(menuPos+1)/4-1]).hour));
strcat(linia2,":");
strcat(linia2,getFmt2Char((alarme[(menuPos+1)/4-1]).minute));
strcat(linia2," ");
}else if((menuPos)%4==0){ //incepand cu 4, din 4 in 4 avem zielele alarmei
linia1[7] = 48+(byte)((menuPos)/4)/10;
linia1[8] = 48+(byte)((menuPos)/4-(menuPos)/4/10*10);
linia1[9]='\0';
strcat(linia1," zile\0");
strcpy(linia2,"L");
for(int i=6;i>=0;i--){
if((alarme[(menuPos)/4-1]).days & (byte)ceil(pow(2,i))){
strcat(linia2,"X");
}else{
strcat(linia2," ");
if(i>0)strcat(linia2,zile[7-i]);
}else if((menuPos-1)%4==0){ //incepand cu 5, din 4 in 4 avem durata alarmei
linia1[7] = 48+(byte)((menuPos-1)/4)/10;
linia1[8] = 48+(byte)((menuPos-1)/4-(menuPos-1)/4/10*10);
linia1[9]='\0';
strcat(linia1," durata\0");
itoa(alarme[(menuPos-1)/4-1].duration,linia2,10);
if(alarme[(menuPos-1)/4-1].unitAlarma){
strcat(linia2," min");
}else{
strcat(linia2," sec");
}else if((menuPos-2)%4==0){ //incepand cu 6 din 4 in 4 avem releele activate de alarma
strcpy(linia1,"Relee alarma ");
linia1[13]= 48+(byte)((menuPos-2)/4)/10;
linia1[14]= 48+(byte)((menuPos-2)/4-(menuPos-2)/4/10*10);
linia1[15]='\0';
strcpy(linia2,"");
char chBuff[2];
chBuff[0]=6-i+65;
chBuff[1]='\0';
strcat(linia2,chBuff);
if((alarme[(menuPos-2)/4-1]).relee & (byte)ceil(pow(2,i))){
strcat(linia2,"X");
}else{
strcat(linia2," ");
//if(i>0)strcat(linia2,zile[7-i]);
//punem cursorul in functie de locatia noastra in sumbeniu
void showSubMenu(){
if(menuPos==1 || menuPos==2){ //data sau ora
switch(subMenuPos){
case 1://zile
cursorPos = 1;
case 2://luni
cursorPos = 4;
case 3://ani
cursorPos = 7;
case 4://ziua saptamanii
if(menuPos==1){//doar in cazul datei avem si ziua saptamanii
cursorPos=12;
default:
subMenuPos = 0;
cursorPos = -1;
}else if((menuPos+1)%4==0){ //ora alarmelor
switch(subMenuPos){
case 1: //ora
cursorPos = 1;
case 2: //minutul
cursorPos = 4;
default:
subMenuPos = 0;
cursorPos = -1;
}else if((menuPos)%4==0){ //zilele alarmelor
if(subMenuPos>0 && subMenuPos<8){
cursorPos = subMenuPos*2-1;
}else{
subMenuPos = 0;
cursorPos = -1;
}else if((menuPos-1)%4==0){ //durata alarmelor
if(subMenuPos==1){
cursorPos = 0;
}else if(subMenuPos==2){
cursorPos=4;
}else{
subMenuPos=0;
cursorPos = -1;
}else if((menuPos-2)%4==0){ //releele alarmelor
}else{
subMenuPos = 0;
cursorPos = -1;
void menu(){
if((millis()-lastMillis)>150){
if(digitalRead(PIN_MENU)==LOW && menuPos==0){
menuPos=(menuPos+1)%(MAX_MENU_POS);
showMenu();
}else if(digitalRead(PIN_MENU)==LOW){
subMenuPos++;
showSubMenu();
lastMillis=millis();
void readValues(){
//citim valorile initiale din eeprom.
//daca nu exista nimic scris in eeprom, consideram si orele si durata ca fiind 0 si scriem in EEPROM
for(int i=0;i<NR_ALARME;i++){
byte b = EEPROM.read(i*5+1);
if(b==0xFF){
b = 0;
EEPROM.write(i*5+1,b);
(alarme[i]).hour = b & 31; //pozitiile 1, 6, 11 etc.
(alarme[i]).unitAlarma = b >> 6;
b = EEPROM.read(i*5+2);
if(b==0xFF){
b = 0;
EEPROM.write(i*5+2,b);
(alarme[i]).minute = b; //pozitiile 2, 7, 12 etc.
b = EEPROM.read(i*5+3);
if(b==0xFF){
b = 0;
EEPROM.write(i*5+3,b);
(alarme[i]).days = b; //pozitiile 3, 8, 13 etc.
b = EEPROM.read(i*5+4);
if(b==0xFF){
b = 0;
EEPROM.write(i*5+4,b);
(alarme[i]).duration = b; //pozitiile 4, 9, 14 etc.
b = EEPROM.read(i*5+5);
if(b==0xFF){
b = 0;
EEPROM.write(i*5+5,b);
(alarme[i]).relee = b; //pozitiile 5, 10, 15 etc.
void setup(){
pinMode(PIN_MENU,INPUT); //btn stg
pinMode(PIN_DR,INPUT); //meniu
pinMode(PIN_STG,INPUT); //btnDr
for(int i=0;i<7;i++){
pinMode(relee[i],OUTPUT);
digitalWrite(relee[i],DESCHIS);
digitalWrite(PIN_MENU,HIGH);
digitalWrite(PIN_STG,HIGH);
digitalWrite(PIN_DR,HIGH);
attachInterrupt(0,menu,CHANGE);
//alarmele
readValues();
//initializam DS_1307
Wire.begin();
lcd.begin(16, 2);
time.second = 15;
time.minute = 55;
time.hour = 11;
time.dayOfWeek = 5;
time.dayOfMonth = 14;
time.month = 3;
time.year = 14;
//setDateDs1307(time);
char* getFmt2Char(byte val){
char *buf = "00\0";
buf[0] = 48+val/10;
buf[1] = 48+val%10;
return buf;
char* getDate(struct ds1307_time time){
char *buf=" \0";
buf[0]=48+time.dayOfMonth/10;
buf[1]=48+time.dayOfMonth%10;
buf[2]='.';
buf[3]=48+time.month/10;
buf[4]=48+time.month%10;
buf[5]='.';
buf[6]=48+time.year/10;
buf[7]=48+time.year%10;
return buf;
char* getTime(struct ds1307_time time){
char *buf=" \0";
buf[0]=48+time.hour/10;
buf[1]=48+time.hour%10;
buf[2]=':';
buf[3]=48+time.minute/10;
buf[4]=48+time.minute%10;
buf[5]=':';
buf[6]=48+time.second/10;
buf[7]=48+time.second%10;
return buf;
char* getZiuaSaptamaniiShort(byte val){
switch(val){
case 1:
return "Lun\0"; //Mon
case 2:
return "Mar\0"; //Tue
case 3:
return "Mie\0"; //Wen
case 4:
return "Joi\0"; //Thu
case 5:
return "Vin\0"; //Fri
case 6:
return "Sam\0"; //Sat
case 7:
return "Dum\0"; //Sun
default:
return "?\0";
char* getZiuaSaptamanii(byte val){
switch(val){
case 1:
return "Luni\0"; //replace with Monday if you want
case 2:
return "Marti\0"; //replace with Tuesday if you want
case 3:
return "Miercuri\0"; //replace with Wednesday if you want
case 4:
return "Joi\0"; //replace with Thursday if you want
case 5:
return "Vineri\0"; //replace with Friday if you want
case 6:
return "Sambata\0"; //replace with Saturday if you want
case 7:
return "Duminica\0"; //replace with Sunday if you want
default:
return "?\0";
void minusData(){
if(subMenuPos==1 && time.dayOfMonth>1){ //zilele
time.dayOfMonth--;
}else if(subMenuPos==2 && time.month>1){
time.month--;
}else if(subMenuPos==3 && time.year>1){
time.year--;
}else if(subMenuPos==4 && time.dayOfWeek>1){
time.dayOfWeek--;
dataDirthy=true;
showMenu();
void plusData(){
if(subMenuPos==1){ //zilele aici utilizatorul trebuie sa aiba grija sa nu puna mai multe zile dact are luna, eu am limitat doar la 31
time.dayOfMonth=(time.dayOfMonth+1)%32;
if(time.dayOfMonth==0){
time.dayOfMonth=1;
time.month=(time.month+1)%13;
if(time.month==0){
time.month=1;
}else if(subMenuPos==3){
time.year=(time.year+1)%99;
}else if(subMenuPos==4){
time.dayOfWeek=(time.dayOfWeek+1)%8;
if(time.dayOfWeek==0){
time.dayOfWeek=1;
dataDirthy=true;
showMenu();
void minusOra(){
if(subMenuPos==1 && time.hour>0){ //zilele
time.hour=time.hour-1;
}else if(subMenuPos==2 && time.minute>0){
time.minute=time.minute-1;
}else if(subMenuPos==3 && time.second>1){
time.second=time.second-1;
oraDirthy = true;
showMenu();
void plusOra(){
time.hour=(time.hour+1)%24;
time.minute=(time.minute+1)%60;
time.second=(time.second+1)%60;
oraDirthy = true;
showMenu();
void minusAlarma(int pos){
alarme[pos-1];
if(subMenuPos==1 && alarme[pos-1].hour>0){ //zilele
alarme[pos-1].hour--;
}else if(subMenuPos==2 && alarme[pos-1].minute>0){
alarme[pos-1].minute--;
showMenu();
void plusAlarma(byte pos){
alarme[pos-1].hour=(alarme[pos-1].hour+1)%24;
alarme[pos-1].minute=(alarme[pos-1].minute+1)%60;
showMenu();
void minusZileAlarma(byte pos){
Serial.println(alarme[pos-1].days);
alarme[pos-1].days =alarme[pos-1].days ^ (byte)ceil(pow(2,(7-subMenuPos)));
showMenu();
void plusReleeAlarma(byte pos){
minusReleeAlarma(pos);
void minusReleeAlarma(byte pos){
Serial.println(alarme[pos-1].relee);
alarme[pos-1].relee = alarme[pos-1].relee ^ (byte)ceil(pow(2,(7-subMenuPos)));
showMenu();
void plusZileAlarma(byte pos){
minusZileAlarma(pos);
void minusUnitAlarma(byte pos){
plusUnitAlarma(pos);
void plusUnitAlarma(byte pos){
if(subMenuPos==2){
alarme[pos-1].unitAlarma=(alarme[pos-1].unitAlarma+1)%2;
void minusDurataAlarma(byte pos){
if(alarme[pos-1].duration>0 && subMenuPos==1){
alarme[pos-1].duration--;
minusUnitAlarma(pos);
showMenu();
void plusDurataAlarma(byte pos){
if(subMenuPos==1){
alarme[pos-1].duration=(alarme[pos-1].duration+1)%240;
showMenu();
void saveValues(){
EEPROM.write(i*5+1,(alarme[i]).hour | (alarme[i].unitAlarma << 6));
EEPROM.write(i*5+2,(alarme[i]).minute);
EEPROM.write(i*5+3,(alarme[i]).days);
EEPROM.write(i*5+4,(alarme[i]).duration);
EEPROM.write(i*5+5,(alarme[i]).relee);
void applyNewDateHour(){
if(dataDirthy || oraDirthy){
if(oraDirthy){
Serial.println("Cu ora");
}else{ //daca ora nu s-a modificat o lasam si noi cum este
Serial.println("Fara ora");
struct ds1307_time tmp;
getDateDs1307(&tmp);
tmp.dayOfMonth = time.dayOfMonth;
tmp.dayOfWeek = time.dayOfWeek;
tmp.month = time.month;
tmp.year = time.year;
setDateDs1307(tmp);
dataDirthy=false;
oraDirthy = false;
saveValues();
int valAlarmaMin(byte index){
return (alarme[index]).hour*3600+(alarme[index]).minute*60;
int valAlarmaMax(byte index){
byte multipl = (alarme[index]).unitAlarma?60:1;
return (alarme[index]).hour*3600+(alarme[index]).minute*60+multipl*(alarme[index]).duration;
void checkAlarms(){
int valComp = time.hour*3600+time.minute*60+time.second;
bAlarma=false;
strcpy(linia,getTime(time));
strcat(linia,";A");
char cAl[4];
int timeToFinish=0,vAlMax=0;
boolean tipTimp=0;
byte statusRelee[7];
statusRelee[i]=0;
struct alarm alarma = alarme[i];
vAlMax=valAlarmaMax(i);
if(valComp>=valAlarmaMin(i) && valComp<=vAlMax){ //comparam valorile minime si maxime ale fiecarei alarme cu timpul actual
if((byte)ceil(pow(2,7-time.dayOfWeek)) & (alarma).days){
bAlarma=true;
if((timeToFinish==0 && vAlMax-valComp>timeToFinish) || (vAlMax-valComp<timeToFinish)){//setam durata pana la sf primei alarme
tipTimp = alarma.unitAlarma;
if(tipTimp && vAlMax-valComp>=60){
timeToFinish=(vAlMax-valComp)/60;
}else{
timeToFinish=vAlMax-valComp;
tipTimp=0;
for(int j=6;j>=0;j--){
if((alarma).relee & (byte)(ceil(pow(2,j)))){
statusRelee[j]=1;
itoa((i+1),cAl,10);
if(strlen(linia)<11){
strcat(linia,cAl);
if(statusRelee[i]){
digitalWrite(relee[i],INCHIS);
}else{
if(bAlarma){
itoa(timeToFinish,cAl,10);
strcat(linia," ");
strcat(linia,cAl);
if(tipTimp){
strcat(linia,"m");
}else{
strcat(linia,"s");
void loop(){
//daca avem meniul apasat aratam ceea ce ne trebuie si nu mai aratam data si ora curente
if(menuPos>0){
lcd.clear();
lcd.setCursor(0,0);
lcd.print(linia1);
lcd.setCursor(0,1);
lcd.print(linia2);
if(digitalRead(PIN_STG)==LOW && menuPos){ //avem apasat minus
delay(100);
if(subMenuPos){
if(menuPos==1){ //data
minusData();
minusOra();
minusAlarma((menuPos+1)/4);
}else if((menuPos)%4==0){ //zile alarma
minusZileAlarma((menuPos)/4);
}else if((menuPos-1)%4==0){ //durata alarma
minusDurataAlarma((menuPos-1)/4);
}else if((menuPos-2)%4==0){ //relee alarma
minusReleeAlarma((menuPos-2)/4);
else{
if(menuPos==1){
applyNewDateHour();
menuPos--;
showMenu();
}else if(digitalRead(PIN_DR)==LOW && menuPos){ //avem apasat plus
delay(200);
if(subMenuPos){
plusData();
plusOra();
}else if((menuPos+1)%4==0){ //ora alarma
plusAlarma((menuPos+1)/4);
plusZileAlarma((menuPos)/4);
plusDurataAlarma((menuPos-1)/4);
}else if((menuPos-2)%4==0){ //durata alarma
plusReleeAlarma((menuPos-2)/4);
else if(menuPos<MAX_MENU_POS-1){
++menuPos;
Serial.print("Menu pos: ");
Serial.print(menuPos);
showMenu();
}else{
applyNewDateHour();
menuPos=0;
}else if(subMenuPos>0 && cursorPos>-1){
// Serial.println(cursorPos);
lcd.cursor();
lcd.setCursor(cursorPos,1);
}else{
lcd.noCursor();
delay(100);
return;
lcd.clear();
char buf[3];
getDateDs1307(&time);
Serial.print(getTime(time));
Serial.print(" ");
Serial.print(getDate(time));
Serial.print(":");
Serial.print("Ziua saptamanii: ");
Serial.println(time.dayOfWeek, DEC);
lcd.setCursor(0, 0);
lcd.print(getZiuaSaptamanii(time.dayOfWeek));
lcd.setCursor(8,0);
lcd.print(getDate(time));
if(bAlarma){
lcd.setCursor(0,1);
lcd.print(linia);
}else{
lcd.setCursor(4,1);
lcd.print(getTime(time));
lcd.setCursor(12,1);
lcd.print(" ");
lcd.noCursor();
checkAlarms();
Нужно сделать удобную навигацию пятью конпками(вверх, вниз, влево, вправо, меню) и еще изменить колличество релле, которыми контроллер управляет. сейчас их 7, а нужно сделать 8.
Комментарии в коде на румынском языке)
Подробности - на почту.
Ex3mGamer@mail.ru
Бюджет какой?
Сроки?
Сроки - быстро) до конца месяца нужно сделать.
Бюджет - "расскажите, почему это стоит дорого, и я вам заплачу" - пишите ваши расценки на почту.
А можно подробнее про этот контроллер? Как он выгдядит аппаратно? Какой функционал?
Просто ищу для себя :)
https://www.drive2.ru/b/1394538/
