Rfid антенна - arduino
Пт, 22/01/2021 - 19:14
Есть антенна
и скетч
/* Crazy People
* By Mike Cook April 2009
* Three RFID readers outputing 26 bit Wiegand code to pins:-
* Reader A (Head) Pins 2 & 3
* Interrupt service routine gathers Wiegand pulses (zero or one) until 26 have been recieved
* Then a sting is sent to processing
volatile long reader1 = 0;
volatile int reader1Count = 0;
void reader1One(void) {
reader1Count++;
reader1 = reader1 << 1;
reader1 |= 1;
void reader1Zero(void) {
reader1Count++;
// Attach pin change interrupt service routines from the Wiegand RFID readers
attachInterrupt(0, reader1Zero, RISING);//DATA0 to pin 2
attachInterrupt(1, reader1One, RISING); //DATA1 to pin 3
delay(10);
// the interrupt in the Atmel processor mises out the first negitave pulse as the inputs are already high,
// so this gives a pulse to each reader input line to get the interrupts working properly.
// Then clear out the reader variables.
// The readers are open collector sitting normally at a one so this is OK
for(int i = 2; i<4; i++){
pinMode(i, OUTPUT);
digitalWrite(i, HIGH); // enable internal pull up causing a one
digitalWrite(i, LOW); // disable internal pull up causing zero and thus an interrupt
pinMode(i, INPUT);
delay(10);
// put the reader input variables to zero
reader1 = 0;
reader1Count = 0;
//digitalWrite(13, HIGH); // show Arduino has finished initilisation
if(reader1Count >=26){
//Serial.print(" Reader 1 ");
//Serial.println(reader1,HEX);
// Serial.println("A");
//Serial.println(reader1& 0xfffffff);
int serialNumber=(reader1 >> 1) & 0x3fff;
int siteCode= (reader1 >> 17) & 0x3ff;
Serial.print(siteCode);
Serial.print(" ");
Serial.println(serialNumber);
reader1 = 0;
reader1Count = 0;
digitalWrite(13,HIGH);
delay(2000);
digitalWrite(13,LOW);
по результатам получаю данные:
Wiegand HEX = 1140BE, DECIMAL = 1130686, Type W26
считывает только часть кода ключа.
полный код
56 5A 11 40 BE
помогите считать полностью ключ
не бесплатно)
Полный код получишь только на Wiegand 34
Тот считыватель который у вас, нельзя перевести на 34 по этому меняйте RFID. Правда данная антенна (как вы её называете), одна из дальнобойных. С 3-4 метров ловит специальные карты легко. По этому, у вас есть выбор, либо полный код, либо дальнобойность.
Сделаю полный код.
