управление реле
Пнд, 15/03/2021 - 17:24
Добрый день. Прошу помощи. Не могу до конца склеить в работоспособном состоянии два скетча.
Один из примеров в ide называется OTAWebUpdater для платы esp32 (у меня devkitv1)
и любой скотч для управления реле (достаточно одним).
Идея такова. Заливать прошивку через web.
#include <WiFi.h>
#include <WiFiClient.h>
#include <WebServer.h>
#include <ESPmDNS.h>
#include <Update.h>
const char* host = "esp32";
const char* ssid = "xxx";
const char* password = "xxxx";
WebServer server(80);
* Login page
const char* loginIndex =
"<form name='loginForm'>"
"<table width='20%' bgcolor='A09F9F' align='center'>"
"<tr>"
"<td colspan=2>"
"<center><font size=4><b>ESP32 Login Page</b></font></center>"
"<br>"
"</td>"
"<br>"
"<br>"
"</tr>"
"<tr>"
"<td>Username:</td>"
"<td><input type='text' size=25 name='userid'><br></td>"
"</tr>"
"<br>"
"<br>"
"<tr>"
"<td>Password:</td>"
"<td><input type='Password' size=25 name='pwd'><br></td>"
"<br>"
"<br>"
"</tr>"
"<tr>"
"<td><input type='submit' onclick='check(this.form)' value='Login'></td>"
"</tr>"
"</table>"
"</form>"
"<script>"
"function check(form)"
"if(form.userid.value=='admin' && form.pwd.value=='admin')"
"window.open('/serverIndex')"
"else"
" alert('Error Password or Username')/*displays error message*/"
"</script>";
* Server Index Page
const char* serverIndex =
"<script src='https://ajax.googleapis.com/ajax/libs/jquery/3.2.1/jquery.min.js'></script>"
"<form method='POST' action='#' enctype='multipart/form-data' id='upload_form'>"
"<input type='file' name='update'>"
"<input type='submit' value='Update'>"
"</form>"
"<div id='prg'>progress: 0%</div>"
"<script>"
"$('form').submit(function(e){"
"e.preventDefault();"
"var form = $('#upload_form')[0];"
"var data = new FormData(form);"
" $.ajax({"
"url: '/update',"
"type: 'POST',"
"data: data,"
"contentType: false,"
"processData:false,"
"xhr: function() {"
"var xhr = new window.XMLHttpRequest();"
"xhr.upload.addEventListener('progress', function(evt) {"
"if (evt.lengthComputable) {"
"var per = evt.loaded / evt.total;"
"$('#prg').html('progress: ' + Math.round(per*100) + '%');"
"}, false);"
"return xhr;"
"success:function(d, s) {"
"console.log('success!')"
"error: function (a, b, c) {"
"</script>";
* setup function
void setup(void) {
Serial.begin(115200);
// Connect to WiFi network
WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
delay(500);
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
Serial.println(WiFi.localIP());
/*use mdns for host name resolution*/
if (!MDNS.begin(host)) { //http://esp32.local
Serial.println("Error setting up MDNS responder!");
while (1) {
Serial.println("mDNS responder started");
/*return index page which is stored in serverIndex */
server.on("/", HTTP_GET, []() {
server.sendHeader("Connection", "close");
server.send(200, "text/html", loginIndex);
server.on("/serverIndex", HTTP_GET, []() {
server.send(200, "text/html", serverIndex);
/*handling uploading firmware file */
server.on("/update", HTTP_POST, []() {
server.send(200, "text/plain", (Update.hasError()) ? "FAIL" : "OK");
ESP.restart();
HTTPUpload& upload = server.upload();
if (upload.status == UPLOAD_FILE_START) {
Serial.printf("Update: %s\n", upload.filename.c_str());
if (!Update.begin(UPDATE_SIZE_UNKNOWN)) { //start with max available size
Update.printError(Serial);
} else if (upload.status == UPLOAD_FILE_WRITE) {
/* flashing firmware to ESP*/
if (Update.write(upload.buf, upload.currentSize) != upload.currentSize) {
} else if (upload.status == UPLOAD_FILE_END) {
if (Update.end(true)) { //true to set the size to the current progress
Serial.printf("Update Success: %u\nRebooting...\n", upload.totalSize);
} else {
server.begin();
void loop(void) {
server.handleClient();
delay(1);
... и одновременно вклюючать свет в туалете?
Любой скотч тут не подойдет. Нужен прозрачный, 3М.
Только синяя изолента, никаких скотчей
Спасибо за юмор. Оценил.
Но хотелось бы по существу.
А может с таким кто склеит -Te Bheag Blended Scotch 0.7 л.? Это же платный раздел.
Ответов по существу на вопрос "не могу склеить два скетча" быть не может. Тем более что выложили только один. А второй надо самому придумать?
И не написали. сколько готовы платить за это.
В этом слове ошибка или нет ?
Прозрачный не очень для управления реле годится. Может ёбом токнуть. Тут у автора явный аппаратный просчет. Изолента в самый раз, если я ТЗ правильно прочитал
Ну побольше намотать, не ?
Как вариант. А если намотать на палец, то можно несколькими реле управлять. И не только реле. Нагрев конденсаторов проверять, например
я сам люблю пошутить, но тут похоже уже перебор. с каждой новой темой ветка форума "ищу исполнителя" превращается в дом мумий-троллей(не ошибка, именно мумий).
Вот это было обидно. Тут, понимаешь, стараешься, тратишь драгоценное время чтобы совершенно бесплатно оказать ТСу (обычно, заметьте, платную) услугу, так еще и вместо благодарности одни оскорбления в ответ
Любишь - шути. Это не заказчик и не заказ. Почему не повеселиться? Или ты хотел заработать на "склеивании скетчей"?
Не скетчей, а скотчей... вроде...
Кстати, че за намек на мумий, мне еще до пенсии 15 лет топтаться, так что молокососы обязаны фильтровать выражения !
да мы уже сами устали, живот болит от смеха... Но что поделаешь, если уже который день сюда заходят сплошные клоуны?
