Замена магнитометра HMC5883L на QMC5883L в скетче
Пнд, 08/08/2022 - 03:30
Прошу помощи в замене библиотеки магнитометра HMC5883L на QMC5883L в скетче
Необходимая библиотека: https://github.com/mprograms/QMC5883LCompass
//self driving car
#include "HMC5883L.h"
#include <I2Cdev.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include <TinyGPS.h>
#include <Servo.h>
#include <NewPing.h>
int mo1 = 2, mo2 = 3, mo3 = 4, mo4 = 5;
int vcc = 13;
#define trig1 9
#define echo1 8
#define MAX_DISTANCE 200
//int trig2 = 11;
//int echo2 = 10;
//int gnd = 4;
long cm1;//,cm2;
int i = 0;
NewPing sonar(trig1, echo1, MAX_DISTANCE);
//NewPing sonar2(trig2,echo2,250);
int f1 = 0;
float heading;
TinyGPS gps;
SoftwareSerial ss(11, 12);
void gpshead();
void stopp();
void rightturn();
void gostraight();
void leftturn();
void turn();
//Servo myservo;
float x2lon = radians(00000000), x2lat = radians(000000000); //enter ur final location here as lon and lat
HMC5883L mag;
int16_t mx, my, mz;
float head, distance = 0.0;
Wire.begin();
mag.initialize();
ss.begin(9600);
pinMode (vcc, OUTPUT);
// pinMode (gnd,OUTPUT);
pinMode(mo1, OUTPUT);
pinMode(mo2, OUTPUT);
pinMode(mo3, OUTPUT);
pinMode(mo4, OUTPUT);
//myservo.attach(7);
digitalWrite(vcc, HIGH);
if (f1 != 0)
gostraight();
cm1 = sonar.ping_cm();
delay(50);
Serial.print("cm");
Serial.print(cm1);
if (cm1 < 20 && cm1 > 0)
mag.getHeading(&mx, &my, &mz);
heading = atan2(my, mx);
if (heading < 0)
heading += 2 * M_PI;
heading = heading * 180 / M_PI;
if ((i % 2) == 0)
{ head = heading + 100;
if (head > 360)
head = head - 360;
leftturn();
/*myservo.write(180);
delay(2000);*/
//myservo.write(180);
//i++;
{ head = heading - 100;
if (head < 0)
head = head + 360;
rightturn();
/*myservo.write(0);
delay(1000);*/
// myservo.write(0);
//i++;
while ((heading > head + 8) || (heading < head - 8)) // this loop turns the bot till its facing (head)degrees east of north
turn();
delay(5);
if (heading < 0)
stopp();
delay(100);
else {
/*cm2=sonar2.ping_cm();
delay(50);
cm2+=sonar2.ping_cm();
cm2=cm2/2;*/
//while((cm1<50)&&(cm1>0))
gostraight();
delay(50);
//cm2=sonar2.ping_cm();
//delay(50);
//cm2+=sonar2.ping_cm();
//cm2=cm2/2;}
delay(500);
stopp();
do {
gpshead();
} while (distance == 0.0);
if (distance < 15)
while (1)
stopp();
if (f1 == 0)
{ mag.getHeading(&mx, &my, &mz);
if (heading < 0)
turn();
delay(5);
if (heading < 0)
f1 = 4;
f1--;
void turn()
{ float tur = heading - head;
//if (tur < 0.0 && tur > -180 )
// { //if (tur > -180.0)
//rightturn();
// else {
//leftturn();
if (tur < 0.0)
{ if (tur > -180.0)
rightturn();
leftturn();
{ if (tur < 180.0)
leftturn();
else rightturn();
void leftturn()
{ digitalWrite(mo1, LOW);
digitalWrite(mo2, LOW);
digitalWrite(mo3, HIGH);
digitalWrite(mo4, LOW);
delay(10);
void stopp()
digitalWrite(mo3, LOW);
void rightturn()
digitalWrite(mo2, HIGH);
void gostraight()
void gpshead()
bool newData = false;
for (unsigned long start = millis(); millis() - start < 1000;)
while (ss.available())
char c = ss.read();
// Serial.write(c); // uncomment this line if you want to see the GPS data flowing
if (gps.encode(c)) // Did a new valid sentence come in?
newData = true;
if (newData)
float flat1, flon1;
unsigned long age;
gps.f_get_position(&flat1, &flon1, &age);
flon1 = radians(flon1); //also must be done in radians
flat1 = radians(flat1); //also must be done in radians
head = atan2(sin(x2lon - flon1) * cos(x2lat), cos(flat1) * sin(x2lat) - sin(flat1) * cos(x2lat) * cos(x2lon - flon1));
head = head * 180 / 3.1415926535; // convert from radians to degrees
float dist_calc = 0;
float diflat = 0;
float diflon = 0;
diflat = x2lat - flat1; //notice it must be done in radians
diflon = (x2lon) - (flon1); //subtract and convert longitudes to radians
distance = (sin(diflat / 2.0) * sin(diflat / 2.0));
dist_calc = cos(flat1);
dist_calc *= cos(x2lat);
dist_calc *= sin(diflon / 2.0);
distance += dist_calc;
distance = (2 * atan2(sqrt(distance), sqrt(1.0 - distance)));
distance *= 6371000.0; //Converting to meters
if (head < 0) {
head += 360; //if the heading is negative then add 360 to make it positive
head = 0.0;
distance = 0.0;
3000р
2500р
интересно, заработает ли?
я так понял, автор даже не пробовал делать это сам. А денег жалко...
хотя на такой код и правда денег жалко... писал какой-то школьник, четыре одинаковых куска кода просто скопировано один в другой
вот тебе фотка, сам суди школьник он или нет https://github.com/sijah
как по мне, далеко уже не
В эти дни я работаю в Markaz Group Of Schools в Кожикоде, Керала, в качестве ИТ-координатора и Фасилитатора!....
материальное воплощение понятия "индийский код" :)
а какая разница, можно разговаривать о живописи Моне или Ренуара, а код он или выпоняет возложенные на него функции или нет )))
За редактирование индусского кода нужно требовать молока за вредность... или хотя-бы удвоения гонорара.
это если понимаешь, а если как я нет и, вникать крайне неохота, пол-часа на всё про всё и - компилиуется жеж, а вот работает или нет - загадка, по идее должен, я бы даже с уверенностью сказал - обязан )))
Ну, этих функций на самом деле достаточно много.
Кроме того, что код должен работать, он должен работать стабильно.
Кроме того, правильный код должен адекватно реагировать на неправильные входные данные (применительно к МК - правильно вести себя при неисправности оборудования).
Код должен допускать поддержку. Т.е. его при необходимости должно быть легко понять другому программисту.
Ну и еще: код должен делать именно то, что задумал программист, а не просто "выполнять какие-то функции".
1260 р
1260 р
откуда такая экзотическая цифра сложилась? я понимаю вышестоящие предложения подразумевают изучение библиотек...а в твоём случае?
1260 р
думаю это половина от последнего предложения (2500/2)
А потом Бармалею стало жалко, что он продешевил и он решил накинуть 10 рублей :)
1260 р
тогда встречное предложение - за 1000 дам код как получилось, если не взлетит закажешь у Бармалея, всё одно сэкономишь (1000 + 1260) или 260 рублей меньше чем у Бармалея (если взлетит) )))
Уже взлетело, разобрался сам))
Всем спасибо.
Всем спасибо.
даже на пивасик никто не заработал )))
