AJAX модуль ESP8266 + Ардуино
elik745i
Помогите модифицировать код, что бы работало через AJAX, а не обновлением страницы, 3 дня бьюсь бьюсь, никак не могу сделать.
#include <SoftwareSerial.h>
#include <ESP8266pro.h>
#include <ESP8266proServer.h>
#include <OneWire.h>
#define DEBUG true
const int  RX=10;
const int  TX=11;
const int  ts=9;     //temp sensor DS18B20
const int  il=13;    //indicator led
const int  ms=12;    //master switch relay
  #define ONE_WIRE_BUS ts
const int   TN = 1400;                  //tone
float t;            //temperature
unsigned long previousMillis = 0;         //check sensors
const long interval = 60000;               //Sampling interval time mSec
const long COM_BAUD = 38400;                       //ESP UART baudrate
const String mode = "1";                           //1 - Client, 2 - Access Point, 3 - Both
const String ssid = "sazz Wireless Network";       //Network SSID
const String password = "Samir2012A";              //Network Password
const String ipaddress = "192.168.0.201";          //Desired IP address
const String subnetworkmask = "255.255.255.0";
const String gateway = "192.168.0.1";
SoftwareSerial esp8266(RX, TX); // RX, TX
ESP8266pro wifi(esp8266, Serial);
ESP8266proServer server(wifi, onClientRequest);
String requestPaths[ESP_MAX_CONNECTIONS];
    pinMode(ts, INPUT);
    esp8266.begin(COM_BAUD);
    Serial.begin(COM_BAUD);    //for debug
  sendData("AT+RST\r\n",3400,DEBUG); // reset module
  sendData("AT+GMR\r\n",2000,DEBUG); // Sofware version
  sendData("AT+CWMODE="+mode+"\r\n",1000,DEBUG); // configure as access point
  sendData("AT+CWJAP=\""+ssid+"\",\""+password+"\"\r\n",10000,DEBUG); // connect to AP
  sendData("AT+CIPSTA_DEF=\""+ipaddress+"\",\""+gateway+"\",\""+subnetworkmask+"\"\r\n",1000,DEBUG); // set ip address
  sendData("AT+CIPMUX=1\r\n",1000,DEBUG); // configure for multiple connections
  //sendData("AT+CIPSERVER=1,80\r\n",1000,DEBUG); // turn on server on port 80
  // Start server on port 80
  server.start(80);
  Serial.println();
  Serial.println("=================================");
  Serial.println("Server started: http://" + ipaddress);
  sensors.begin();  //for dallas temp sensor
  checkSensors();   //check all available sensors and save values to RAM
  digitalWrite(il,HIGH);
  digitalWrite(il,LOW);
    void loop() {        // Process incoming requests
                          server.processRequests();
                          if(currentMillis - previousMillis >= interval)
                          checkSensors();
        void onClientRequest(ESP8266proConnection* connection,
        char* buffer, int length, boolean completed) {
          Serial.print(buffer);
          if (strncmp(buffer, "GET ", 4) == 0)   {
            // We found GET HTTP request
            char* p = strstr(buffer + 4, " ");
            *p = '\0'; // erase string after path
            requestPaths[connection->getId()] = (String)((char*)buffer + 4);   }
            if (completed)   {     String path = requestPaths[connection->getId()];
            if (path == "/")
              connection->send(F(
                "HTTP/1.0 200 OK\r\n\r\n"
                "<head>"
                "<meta http-equiv='refresh' content='300'>"
                "<title>ESP8266 + ARDUINO</title>"
                "</head>"
                "<body>"
                "<div id=\"changedDiv\" style=\" width: 250px;  height: 250px; border-radius: 14px; box-shadow: rgb(0, 0, 0) 0px 0px 20px; opacity: 1;"
                "<div style=\"padding-right:20px; padding-left:20px; padding-top:20px; padding-bottom:20px;\">"
                "<h1 align=\"center\">ESP8266 + ARDUINO</h1><br>"));
              connection->send(F(
                      "<h2> Temp = "
                      connection->send(String(t));
            if(digitalRead(ms)==LOW){
              connection->send(F(
                        "<br><br><input type=\"button\" onclick=\"window.location.href='/led2'\" value=\"Switch is OFF\" />"
            }else{
               connection->send(F(
                        "<br><br><input type=\"button\" onclick=\"window.location.href='/led3'\" value=\"Switch is ON\" />"
              connection->send(F(
                        "</div>"
                        "</div>"
                        "</body>"
                        "</html>"
            else if (path.startsWith("/led"))
                           if (path.substring(4) == "0"){
                            masterswitchOn();
                            Serial.println("Turning masterswitch ON");
                            connection->send(F(
                            "<html>"
                            "<meta http-equiv='refresh' content='1; url=/' />"
                            "</html>"
                            if (path.substring(4) == "1")
                              masterswitchOff();
                              Serial.println("Turning masterswitch OFF");
                              connection->send(F(
                            "<html>"
                            "</html>"
              else     {
                            connection->send(F("HTTP/1.0 404 Not Found\r\n\r\n"));
                            connection->send(F("<h1>4 0 4</h1>"));
                            connection->send(F("Yes, this is true. :("));
                             connection->close();
void checkSensors(){
                      sensors.requestTemperatures();     // Send the command to get temperatures
                      t = sensors.getTempCByIndex(0);
                      Serial.print("Temperature = ");
                      Serial.print(t);
                      Serial.println(" Celsius");
void masterswitchOn(){
                      digitalWrite(ms,HIGH);
void masterswitchOff(){
                      digitalWrite(ms,LOW);
String sendData(String command, const int timeout, boolean debug)
    String response = "";
    esp8266.print(command); // send the read character to the esp8266
    long int time = millis();
    while( (time+timeout) > millis())
      while(esp8266.available())
        // The esp has data so display its output to the serial window
        char c = esp8266.read(); // read the next character.
        response+=c;
    if(debug)
      Serial.print(response);
    return response;
библиотеки
Gippopotam
Gippopotam аватар
Вы знаете, что такое AJAX?
elik745i
Асинхронный Джава с использованием ХМЛ не? я не программист, и мои навыки годятся максимум что то там по легкому изменить, добавить, подстроить, вот и прошу вашей помощи, тех, кто знает...
Gippopotam
Gippopotam аватар
Ну в таком случае - вам сначала нужно сделать полноценный сервер, который будет отвечать на запросы клиента (ибо в данном случае речь идет о клиентском приложении на яваскрипте) и давать ему то, что он просит.
elik745i
Сервер есть, раз прошу нет? Мне лишь нужно изменить код в соотвествии с примером из библиотеки Эзернет, вот как это по этой ссылке: https://startingelectronics.org/tutorials/arduino/ethernet-shield-web-se... С одной лишь разницей, что у меня ответ и прием будет идти не через эзернет шилд, а через вайфай модуль...
Gippopotam
Gippopotam аватар
elik745i пишет:
Трижды перечитал. Ничего не понял.
elik745i
#define DEBUG true
const int  RX=10;
const int  TX=11;
const String ssid = "ssid";       //Network SSID
const String password = "wifipassword";              //Network Password
const String apipaddress = "192.168.4.1";          //Desired IP address
const String cipaddress = "192.168.0.201";          //Desired IP address
    pinMode(7, INPUT);        // switch is attached to Arduino pin 7
    pinMode(8, INPUT);        // switch is attached to Arduino pin 8
    pinMode(ts, INPUT);
    pinMode(ms, OUTPUT);
    pinMode(il, OUTPUT);
  sendData("AT+CIPSTA_DEF=\""+cipaddress+"\",\""+gateway+"\",\""+subnetworkmask+"\"\r\n",1000,DEBUG); // set ip address
  server.start(80);
  Serial.println();
  if(mode=="1"){
  Serial.println("Server started: http://" + cipaddress);
  if(mode=="2"){
  Serial.println("Server started: http://" + apipaddress);
  if(mode=="3"){
  Serial.println("Server started:");
  Serial.println("Access Point: http://" + apipaddress);
  Serial.println("Client: http://" + cipaddress);
                 delay(100);
       //if (path == "/")
       if (path.startsWith("/ajax_switch&nocache="))
              Serial.println("AJAX request received");
                if (digitalRead(7)) {
                connection->send(F("<p>Switch 7 state: ON</p>"));
                else {
                connection->send(F("<p>Switch 7 state: OFF</p>"));
               if (digitalRead(8)) {
                connection->send(F("<p>Switch 8 state: ON</p>"));
              else {
                connection->send(F("<p>Switch 8 state: OFF</p>"));
              // read analog pin A2
               int analog_val = analogRead(2);
               connection->send(F("<p>Analog A2: "));
               connection->send(String(analog_val));
               connection->send(F("</p>"));
       else if (path == "/"){
             connection->send(F(
                "HTTP/1.1 200 OK\r\n\r\n"
                "<!DOCTYPE html>\r\n"
                "<html>\r\n"
                "<head>\r\n"
                "<title>Arduino Web Page</title>\r\n"
                "<script>\r\n"
                "function GetSwitchAnalogData() {\r\n"
                "nocache = \"&nocache=\" + Math.random() * 1000000;\r\n"
                "var request = new XMLHttpRequest();\r\n"
                "request.onreadystatechange = function() {\r\n"
                "if (this.readyState == 4) {\r\n"
                "if (this.status == 200) {\r\n"
                "if (this.responseText != null) {\r\n"
                "document.getElementById(\"sw_an_data\").innerHTML = this.responseText;\r\n"
                "}}}}\r\n"
                "request.open(\"GET\", \"ajax_switch\" + nocache, true);\r\n"
                "request.send(null);\r\n"
                "setTimeout('GetSwitchAnalogData()', 1000);\r\n"
                "}\r\n"
                "</script>\r\n"
                "</head>\r\n"
                "<body onload=\"GetSwitchAnalogData()\">\r\n"
                "<h1>Arduino AJAX Input</h1>\r\n"
                "<div id=\"sw_an_data\">\r\n"
                "</div>\r\n"
                "</body>\r\n"
                "</html>\r\n"));
           delay(10);
                      Serial.print(t);
        response+=c;
    if(debug)
    return response;
Вот наконецта сделал, уф....если можете упростить, сделать более стабильным, буду только рад...
Теперь можно выкинуть дорогой и грамоский, никому не нужный эзернет и смело переходить на вайфай модули!
Tomasina
Tomasina аватар
сколько памяти кушает?
int freeRam()
   extern int __heap_start, *__brkval;
   int v;
   return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
Serial.print("free RAM: ");
Serial.println(freeRam);
elik745i
276...
хороший код, только вот так более правильно:
Serial.println(freeRam());
в принципе можно обойтись и без него в низу в Ардуино ИДЕ показывает сколько останется чего... ;)
