Arduino Mega и Ethernet shield не доступны в локалке
Пт, 23/10/2015 - 21:16
Всем доброго времени суток! Подлючил к Меге эзернет шилд, заливаю стандартный скетч из примера, выставляю ip 192.168.0.105, но ни через браузер, ни через ping их не видно =(
На ком порт выдает "server is at 0.0.0.0"
в чем может быть проблема, может кто сталкивался?
Фото Ethernet shield:
https://www.dropbox.com/s/xm8iyor18kdrhv6/eth1.jpg?dl=0
https://www.dropbox.com/s/8n6azr4vec4xr2r/eth2.jpg?dl=0
Фото Меги:
https://www.dropbox.com/s/j7eurdg413nda1w/ard.jpg?dl=0
Пинг:
https://www.dropbox.com/s/5zeucmn18qjev61/cmd.jpg?dl=0
Код:
Web Server
A simple web server that shows the value of the analog input pins.
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
* Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 0, 105);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
// Open serial communications and wait for port to open:
while (!Serial)
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
// listen for incoming clients
EthernetClient client = server.available();
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("<br />");
client.println("</html>");
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disconnected");
На роутере индикатор порта мигает, но в вэб морде роутера ардуину не видно...
Немного разобрался, там чип enc28j60, уже кучу библиотек перепробывал, все одно не работает =( Может есть у кого рабочая?
Спасибо за помощь, разобрался по этой статье и с библиотеками оттудаже =)
http://arduino-project.net/podklyuchenie-enc28j60-arduino-mega-2560/
Эзернет контроллер такойже как в статье, тот что был изначально оказался мертвый..
