Тот код я уже удалил. Попытаюсь дописать по новой. Я использовал вот этот пример.
[code]
This sketch shows how to use multiple WiFi networks.
In this example, ESP8266 works in AP mode.
It demonstrates:
- Fast connect to previous WiFi network at startup
- Registering multiple networks (at least 1)
- Connect to WiFi with strongest signal (RSSI)
- Fall back to connect to next WiFi when a connection failed or lost
- Fall back to connect to hidden SSID's which are not reported by WiFi scan
To enable debugging output, select in the Arduino iDE:
- Tools | Debug Port: Serial
- Tools | Debug Level: WiFi
#include <ESP8266WiFiMulti.h>
ESP8266WiFiMulti wifiMulti;
// WiFi connect timeout per AP. Increase when connecting takes longer.
const uint32_t connectTimeoutMs = 5000;
// Don't save WiFi configuration in flash - optional
WiFi.persistent(false);
Serial.begin(115200);
Serial.println("\nESP8266 Multi WiFi example");
// Set WiFi to station mode
WiFi.mode(WIFI_STA);
// Register multi WiFi networks
wifiMulti.addAP("test1", "12345678");
wifiMulti.addAP("test2", "12345678");
wifiMulti.addAP("test3", "12345678");
// More is possible
// Maintain WiFi connection
if (wifiMulti.run(connectTimeoutMs) == WL_CONNECTED) {
Serial.print("WiFi connected: ");
Serial.print(WiFi.SSID());
Serial.print(" ");
Serial.println(WiFi.localIP());
} else {
Serial.println("WiFi not connected!");
[/code]
Ну как-то так. Ошибки естественно есть. Подскажите - исправлю.
Для коннекта воспользуйтесь библиотекой как тут
Так вот у меня и не получается это совместить что-бы работало.
не увидел в коде, что пробовал совмещать
[code] /* This sketch shows how to use multiple WiFi networks. In this example, ESP8266 works in AP mode. It demonstrates: - Fast connect to previous WiFi network at startup - Registering multiple networks (at least 1) - Connect to WiFi with strongest signal (RSSI) - Fall back to connect to next WiFi when a connection failed or lost - Fall back to connect to hidden SSID's which are not reported by WiFi scan To enable debugging output, select in the Arduino iDE: - Tools | Debug Port: Serial - Tools | Debug Level: WiFi */ #include <ESP8266WiFiMulti.h> ESP8266WiFiMulti wifiMulti; // WiFi connect timeout per AP. Increase when connecting takes longer. const uint32_t connectTimeoutMs = 5000; void setup() { // Don't save WiFi configuration in flash - optional WiFi.persistent(false); Serial.begin(115200); Serial.println("\nESP8266 Multi WiFi example"); // Set WiFi to station mode WiFi.mode(WIFI_STA); // Register multi WiFi networks wifiMulti.addAP("test1", "12345678"); wifiMulti.addAP("test2", "12345678"); wifiMulti.addAP("test3", "12345678"); // More is possible } void loop() { // Maintain WiFi connection if (wifiMulti.run(connectTimeoutMs) == WL_CONNECTED) { Serial.print("WiFi connected: "); Serial.print(WiFi.SSID()); Serial.print(" "); Serial.println(WiFi.localIP()); } else { Serial.println("WiFi not connected!"); } delay(1000); } [/code]Тот код я уже удалил. Попытаюсь дописать по новой. Я использовал вот этот пример.
и что? пример не работает?
