Как подключить sd card к LCD.Keypad
Чт, 09/07/2015 - 08:20
Всем привет!)
Ребят,подскажите как подключить sd cart к LSD.Keypad вместе с Arduino
Подключил все правильно вроде,в программе порты поменял !
Заранее спасибо!
Вот программа
#include <SD.h>
File myFile;
// Open serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.print("Initializing SD card...");
// On the Ethernet Shield, CS is pin 4. It's set as an output by default.
// Note that even if it's not used as the CS pin, the hardware SS pin
// (10 on most Arduino boards, 53 on the Mega) must be left as an output
// or the SD library functions will not work.
pinMode(10, OUTPUT);
if (!SD.begin(0)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
if (SD.exists("example.txt")) {
Serial.println("example.txt exists.");
else {
Serial.println("example.txt doesn't exist.");
// open a new file and immediately close it:
Serial.println("Creating example.txt...");
myFile = SD.open("example.txt", FILE_WRITE);
myFile.close();
// Check to see if the file exists:
else {
// delete the file:
Serial.println("Removing example.txt...");
SD.remove("example.txt");
if (SD.exists("example.txt")){
else {
// nothing happens after setup finishes.
http://arduino.ru/forum/obshchii/vstavka-programmnogo-koda-v-temukomment...
Спасибо ты так помог мне!!!
Доволен? #include <SD.h> File myFile; void setup() { // Open serial communications and wait for port to open: Serial.begin(9600); while (!Serial) { ; // wait for serial port to connect. Needed for Leonardo only } Serial.print("Initializing SD card..."); // On the Ethernet Shield, CS is pin 4. It's set as an output by default. // Note that even if it's not used as the CS pin, the hardware SS pin // (10 on most Arduino boards, 53 on the Mega) must be left as an output // or the SD library functions will not work. pinMode(10, OUTPUT); if (!SD.begin(0)) { Serial.println("initialization failed!"); return; } Serial.println("initialization done."); if (SD.exists("example.txt")) { Serial.println("example.txt exists."); } else { Serial.println("example.txt doesn't exist."); } // open a new file and immediately close it: Serial.println("Creating example.txt..."); myFile = SD.open("example.txt", FILE_WRITE); myFile.close(); // Check to see if the file exists: if (SD.exists("example.txt")) { Serial.println("example.txt exists."); } else { Serial.println("example.txt doesn't exist."); } // delete the file: Serial.println("Removing example.txt..."); SD.remove("example.txt"); if (SD.exists("example.txt")){ Serial.println("example.txt exists."); } else { Serial.println("example.txt doesn't exist."); } } void loop() { // nothing happens after setup finishes. }#include <SD.h> File myFile; void setup() { // Open serial communications and wait for port to open: Serial.begin(9600); while (!Serial) { ; // wait for serial port to connect. Needed for Leonardo only } Serial.print("Initializing SD card..."); // On the Ethernet Shield, CS is pin 4. It's set as an output by default. // Note that even if it's not used as the CS pin, the hardware SS pin // (10 on most Arduino boards, 53 on the Mega) must be left as an output // or the SD library functions will not work. pinMode(10, OUTPUT); if (!SD.begin(0)) { Serial.println("initialization failed!"); return; } Serial.println("initialization done."); if (SD.exists("example.txt")) { Serial.println("example.txt exists."); } else { Serial.println("example.txt doesn't exist."); } // open a new file and immediately close it: Serial.println("Creating example.txt..."); myFile = SD.open("example.txt", FILE_WRITE); myFile.close(); // Check to see if the file exists: if (SD.exists("example.txt")) { Serial.println("example.txt exists."); } else { Serial.println("example.txt doesn't exist."); } // delete the file: Serial.println("Removing example.txt..."); SD.remove("example.txt"); if (SD.exists("example.txt")){ Serial.println("example.txt exists."); } else { Serial.println("example.txt doesn't exist."); } } void loop() { // nothing happens after setup finishes. }какой злой
Еще один новичек недовольный форумом? Если Вы такой нервный то пишите сразу в "ищу исполнителя" - там больше шансов что с Вами будут общаться как Вы изволите. Ну или в спортлото напишите.
Там занято крутым инженером по свету. Хочет професиональное световое оборудование из ардуино, и бесплатно. Угрожает что иначе обратится к ультраспецам. Выбивает слезу расказами про детей и аналоговые ишрушки.
В дополнение к посту dimax. А еще, код нужно под спойлер прятать...
