USBasp и Arduino
Втр, 05/07/2016 - 18:40
Всем привет. Сегодня полуичл простой программатор USBasp на атмемге8.
Первым делом решил прошить программатор. Собрал как надо.
Далее в avrdude
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin>avrdude -C ../etc/avrdude.conf -c avrisp -P COM4 -b 19200 -p m8 -v
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "../etc/avrdude.conf"
Using Port : COM4
Using Programmer : avrisp
Overriding Baud Rate : 19200
AVR Part : ATmega8
Chip Erase delay : 10000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 4 20 128 0 no 512 4 0 9000 9000 0xff 0xff
flash 33 10 64 0 yes 8192 64 128 4500 4500 0xff 0x00
lfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
lock 0 0 0 0 no 1 0 0 2000 2000 0x00 0x00
calibration 0 0 0 0 no 4 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel AVR ISP
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0x1e9307
avrdude: safemode: lfuse reads as 9F
avrdude: safemode: hfuse reads as D9
avrdude: safemode: Fuses OK (H:FF, E:D9, L:9F)
avrdude done. Thank you.
Тут типо ок
Длаее:
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin>avrdude -C ../etc/avrdude.conf -c avrisp -P COM4 -b 19200 -p m8 -U flash:w:file.hex
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "file.hex"
avrdude: input file file.hex auto detected as Intel Hex
avrdude: writing flash (4700 bytes):
Writing | ################################################## | 100% 7.18s
avrdude: 4700 bytes of flash written
avrdude: verifying flash memory against file.hex:
avrdude: load data flash data from input file file.hex:
avrdude: input file file.hex contains 4700 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 3.73s
avrdude: verifying ...
avrdude: 4700 bytes of flash verified
Прошивка пару раз зависала на этапе проверки. На третий раз все прошилось
Далее не меняя схему подключения я решил залить стд блинк выбрав программатор USBasp, палту уно, и загрузку с помощью программатора.
В итоге получил:
avrdude: error: programm enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
Кто чем подскажет как решить проблему
купи кондиционер.
