WebClient. Не выполняется запрос
Вс, 17/12/2017 - 23:47
Всем привет. Есть сервер который принимает число и выводит его. Пытаюсь выполнить GET запрос но ничего не происходит.
Клиент:
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS)
char server[] = "http://wcfrestservice222.azurewebsites.net"; // name address for Google (using DNS)
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 0, 177);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
// Open serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// try to congifure using IP address instead of DHCP:
Ethernet.begin(mac, ip);
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected");
// Make a HTTP request:
client.println("GET /Service1/ddd/7 HTTP/1.1");
client.println("Host: http://wcfrestservice222.azurewebsites.net");
client.println("Connection: close");
client.println();
} else {
// if you didn't get a connection to the server:
Serial.println("connection failed");
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println();
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
while (true);
Сервер:
public class Service1
// TODO: Implement the collection resource that will contain the SampleItem instances
[WebInvoke(UriTemplate = "/rrr", Method = "GET")]
public string GetCollection()
// TODO: Replace the current implementation to return a collection of SampleItem instances
return SampleItem.Id.ToString();
[WebInvoke(UriTemplate = "/ddd/{id}", Method = "GET")]
public string Create(string id)
SampleItem.Id = Int32.Parse(id);
// TODO: Add the new instance of SampleItem to the collection
return "Hello Vova";
[WebGet(UriTemplate = "{id}")]
public SampleItem Get(string id)
// TODO: Return the instance of SampleItem with the given id
throw new NotImplementedException();
[WebInvoke(UriTemplate = "{id}", Method = "PUT")]
public SampleItem Update(string id, SampleItem instance)
// TODO: Update the given instance of SampleItem in the collection
[WebInvoke(UriTemplate = "{id}", Method = "DELETE")]
public void Delete(string id)
// TODO: Remove the instance of SampleItem with the given id from the collection
Привет!
И что? Вы просто решили проинформировать нас? Или у Вас есть какие-то вопросы или пожелания к сообществу? Если есть, так озвучьте, не стесняйтесь.
Выполняю запрос:
#include <SPI.h> #include <Ethernet.h> // Enter a MAC address for your controller below. // Newer Ethernet shields have a MAC address printed on a sticker on the shield byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // if you don't want to use DNS (and reduce your sketch size) // use the numeric IP instead of the name for the server: //IPAddress server(74,125,232,128); // numeric IP for Google (no DNS) char server[] = "http://wcfrestservice222.azurewebsites.net"; // name address for Google (using DNS) // Set the static IP address to use if the DHCP fails to assign IPAddress ip(192, 168, 0, 177); // Initialize the Ethernet client library // with the IP address and port of the server // that you want to connect to (port 80 is default for HTTP): EthernetClient client; void setup() { // Open serial communications and wait for port to open: Serial.begin(9600); while (!Serial) { ; // wait for serial port to connect. Needed for native USB port only } // start the Ethernet connection: if (Ethernet.begin(mac) == 0) { Serial.println("Failed to configure Ethernet using DHCP"); // try to congifure using IP address instead of DHCP: Ethernet.begin(mac, ip); } // give the Ethernet shield a second to initialize: delay(1000); Serial.println("connecting..."); // if you get a connection, report back via serial: if (client.connect(server, 80)) { Serial.println("connected"); // Make a HTTP request: client.println("GET /Service1/ddd/7 HTTP/1.1"); client.println("Host: http://wcfrestservice222.azurewebsites.net"); client.println("Connection: close"); client.println(); } else { // if you didn't get a connection to the server: Serial.println("connection failed"); } } void loop() { // if there are incoming bytes available // from the server, read them and print them: if (client.available()) { char c = client.read(); Serial.print(c); } // if the server's disconnected, stop the client: if (!client.connected()) { Serial.println(); Serial.println("disconnecting."); client.stop(); // do nothing forevermore: while (true); } }Ссылка на севрер неправильно отображается, когда вставляю код(http://wcfrestservice222.azurewebsites.net)
Сервер:
[WebInvoke(UriTemplate = "/ddd/{id}", Method = "GET")] public string Create(string id) { SampleItem.Id = Int32.Parse(id); // TODO: Add the new instance of SampleItem to the collection return "Hello Vova"; } [WebInvoke(UriTemplate = "/rrr", Method = "GET")] public string GetCollection() { // TODO: Replace the current implementation to return a collection of SampleItem instances return SampleItem.Id.ToString(); }Заголоков HOST должен быть без http:// - это как минимум.
Спасибо, все заработало
