mega2560+w5100+16relay box не могу управлять более 10 реле
Сб, 12/01/2019 - 03:20
Добрый вечер. Нужна помощь форума. Имеется Mega2560+w5100+16 relay box (активация низким уровнем).
С 1 по 10 реле отрабатывают как положено, при активации OFF после 10 (допустим 15) отработают 2 и 5 реле, при этом на странице соответственно изменится индикация на 2 и 5 реле (соответственно если 16 - 2 и 6 реле).
D скетче указано*Just for a note, varables start from 0 to 9, as 0 is counted as well, thus 10 outputs.* , я понимаю, что он подходит до 10 портов включительно.
#include <Ethernet.h>
#include <SPI.h>
#include <EEPROM.h>
//CONFIGURATION
//IP manual settings
byte ip[] = {
192, 168, 1, 110 }; //Manual setup only
// if need to change the MAC address (Very Rare)
byte mac[] = {
0xAA, 0xBB, 0xCC, 0xDD, 0xEE, 0xFF };
//Ethernet Port
EthernetServer server = EthernetServer(80); //default html port 80
//The number of outputs going to be switched.
int outputQuantity = 16; //should not exceed 10???
//Invert the output of the leds
boolean outputInverted = true; //true or false
// This is done in case the relay board triggers the relay on negative, rather then on positive supply
//Html page refresh
int refreshPage = 15; //default is 10sec.
//Beware that if you make it refresh too fast, the page could become inacessable.
//Display or hide the "Switch on all Pins" buttons at the bottom of page
int switchOnAllPinsButton = false; //true or false
//Button Array
//Just for a note, varables start from 0 to 9, as 0 is counted as well, thus 10 outputs.
// Select the pinout address
int outputAddress[16] = { 22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37}; //Allocate 10??? spaces and name the output pin address.
//PS pin addresses 10, 11, 12 and 13 on the Duemilanove are used for the ethernet shield, therefore cannot be used.
//PS pin addresses 10, 50, 51 and 52 and 53 on the Mega are used for the ethernet shield, therefore cannot be used.
//PS pin addresses 4, are used for the SD card, therefore cannot be used.
//PS. pin address 2 is used for interrupt-driven notification, therefore could not be used.
// Write the text description of the output channel
String buttonText[16] = {
"РЕЛЕ 1","РЕЛЕ 2","РЕЛЕ 3","РЕЛЕ 4","РЕЛЕ 5","РЕЛЕ 6","РЕЛЕ 7","РЕЛЕ 8","РЕЛЕ 9","РЕЛЕ 10","РЕЛЕ 11","РЕЛЕ 12","РЕЛЕ 13","РЕЛЕ 14","РЕЛЕ 15","РЕЛЕ 16"};
// Set the output to retain the last status after power recycle.
int retainOutputStatus[16] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};//1-retain the last status. 0-will be off after power cut.
//VARIABLES DECLARATION
int outp = 0;
boolean printLastCommandOnce = false;
boolean printButtonMenuOnce = false;
boolean initialPrint = true;
String allOn = "";
String allOff = "";
boolean reading = false;
boolean outputStatus[16]; //Create a boolean array for the maximum ammount.
unsigned long timeConnectedAt;
boolean writeToEeprom = false;
EthernetClient client;
//RUN ONCE
//Beginning of Program
void setup(){
initEepromValues();
readEepromValues();
//Set pins as Outputs
boolean currentState = false;
for (int var = 0; var < outputQuantity; var++){
pinMode(outputAddress[var], OUTPUT);
//Switch all outputs to either on or off on Startup
if(outputInverted == true) {
//digitalWrite(outputAddress[var], HIGH);
if(outputStatus[var] == 0){currentState = true;}else{currentState = false;} //check outputStatus if off, switch output accordingly
digitalWrite(outputAddress[var], currentState);
else{
//digitalWrite(outputAddress[var], LOW);
if(outputStatus[var] == 0){currentState = false;}else{currentState = true;}//check outputStatus if off, switch output accordingly
//Setting up the IP address. Comment out the one you dont need.
//Ethernet.begin(mac); //for DHCP address. (Address will be printed to serial.)
Ethernet.begin(mac, ip); //for manual setup. (Address is the one configured above.)
server.begin();
Serial.print("Server started at ");
Serial.println(Ethernet.localIP());
//LOOP
//Run once
void loop(){
// listen for incoming clients, and process requests.
checkForClient();
//checkForClient Function
void checkForClient(){
EthernetClient client = server.available();
if (client) {
// an http request ends with a blank line
boolean currentLineIsBlank = true;
boolean sentHeader = false;
while (client.connected()) {
if (client.available()) {
//if header was not set send it
//read user input
char c = client.read();
if(c == '*'){
printHtmlHeader(client); //call for html header and css
printLoginTitle(client);
printHtmlFooter(client);
//sentHeader = true;
if(!sentHeader){
// printHtmlButtonTitle(client); //print the button title
//This is for the arduino to construct the page on the fly.
sentHeader = true;
//read user input
// char c = client.read();
//if there was reading but is blank there was no reading
if(reading && c == ' '){
reading = false;
//if there is a ? there was user input
if(c == '?') {
reading = true; //found the ?, begin reading the info
// if there was user input switch the relevant output
if(reading){
//if user input is H set output to 1
if(c == 'H') {
outp = 1;
//if user input is L set output to 0
if(c == 'L') {
outp = 0;
Serial.print(c); //print the value of c to serial communication
//Serial.print(outp);
//Serial.print('\n');
switch (c) {
case '0':
//add code here to trigger on 0
triggerPin(outputAddress[0], client, outp);
case '1':
//add code here to trigger on 1
triggerPin(outputAddress[1], client, outp);
case '2':
//add code here to trigger on 2
triggerPin(outputAddress[2], client, outp);
case '3':
//add code here to trigger on 3
triggerPin(outputAddress[3], client, outp);
case '4':
//add code here to trigger on 4
triggerPin(outputAddress[4], client, outp);
case '5':
//add code here to trigger on 5
triggerPin(outputAddress[5], client, outp);
//printHtml(client);
case '6':
//add code here to trigger on 6
triggerPin(outputAddress[6], client, outp);
case '7':
//add code here to trigger on 7
triggerPin(outputAddress[7], client, outp);
case '8':
//add code here to trigger on 8
triggerPin(outputAddress[8], client, outp);
case '9':
//add code here to trigger on 9
triggerPin(outputAddress[9], client, outp);
case '10':
//add code here to trigger on 10
triggerPin(outputAddress[10], client, outp);
case '11':
//add code here to trigger on 11
triggerPin(outputAddress[11], client, outp);
case '12':
triggerPin(outputAddress[12], client, outp);
case '13':
//add code here to trigger on 13
triggerPin(outputAddress[13], client, outp);
case '14':
//add code here to trigger on 14
triggerPin(outputAddress[14], client, outp);
case '15':
//add code here to trigger on 15
triggerPin(outputAddress[15], client, outp);
} //end of switch case
}//end of switch switch the relevant output
//if user input was blank
if (c == '\n' && currentLineIsBlank){
printLastCommandOnce = true;
printButtonMenuOnce = true;
triggerPin(777, client, outp); //Call to read input and print menu. 777 is used not to update any outputs
printHtmlFooter(client); //Prints the html footer
{ //if there is no client
//And time of last page was served is more then a minute.
if (millis() > (timeConnectedAt + 60000)){
if (writeToEeprom == true){
writeEepromValues(); //write to EEprom the current output statuses
Serial.println("No Clients for more then a minute - Writing statuses to Eeprom.");
//triggerPin Function
void triggerPin(int pin, EthernetClient client, int outp){
//Switching on or off outputs, reads the outputs and prints the buttons
//Setting Outputs
if (pin != 777){
if(outp == 1) {
if (outputInverted ==false){
digitalWrite(pin, HIGH);
else{
digitalWrite(pin, LOW);
if(outp == 0){
else{
//Refresh the reading of outputs
readOutputStatuses();
//Prints the buttons
if (printButtonMenuOnce == true){
printHtmlButtons(client);
//printHtmlButtons Function
//print the html buttons to switch on/off channels
void printHtmlButtons(EthernetClient client){
//Start to create the html table
client.println("");
//client.println("<p>");
client.println("<FORM>");
client.println("<table border=\"0\" align=\"left\">");
//Start printing button by button
for (int var = 0; var < outputQuantity; var++) {
//set command for all on/off
allOn += "H";
allOn += outputAddress[var];
allOff += "L";
allOff += outputAddress[var];
//Print begining of row
client.print("<tr>\n");
//текст кнопок
//Prints the button Text
client.print("<td><h2>");
client.print(buttonText[var]);
client.print("</h2></td>\n");
//Prints the ON Buttons
client.print("<td>");
//client.print(buttonText[var]);
client.print("<INPUT TYPE=\"button\" VALUE=\"ON ");
client.print("\" onClick=\"parent.location='/?H");
client.print(var);
client.print("'\"></td>\n");
//Prints the OFF Buttons
client.print(" <td><INPUT TYPE=\"button\" VALUE=\"OFF");
//client.print(var);
client.print("\" onClick=\"parent.location='/?L");
client.print(var);
//Print first part of the Circles or the LEDs
//Invert the LED display if output is inverted.
if (outputStatus[var] == true ){ //If Output is ON
if (outputInverted == false){ //and if output is not inverted
client.print(" <td><div class='green-circle'><div class='glare'></div></div></td>\n"); //Print html for ON LED
else{ //else output is inverted then
client.print(" <td><div class='black-circle'><div class='glare'></div></div></td>\n"); //Print html for OFF LED
else //If Output is Off
//Print end of row
client.print("</tr>\n");
//Display or hide the Print all on Pins Button
if (switchOnAllPinsButton == true ){
//Prints the ON All Pins Button
client.print("<tr>\n<td><INPUT TYPE=\"button\" VALUE=\"Switch ON All Pins");
client.print("\" onClick=\"parent.location='/?");
client.print(allOn);
//Prints the OFF All Pins Button
client.print("<td><INPUT TYPE=\"button\" VALUE=\"Switch OFF All Pins");
client.print(allOff);
client.print("'\"></td>\n<td></td>\n<td></td>\n</tr>\n");
//Closing the table and form
client.println("</table>");
client.println("</FORM>");
//client.println("</p>");
//readOutputStatuses Function
//Reading the Output Statuses
void readOutputStatuses(){
outputStatus[var] = digitalRead(outputAddress[var]);
//Serial.print(outputStatus[var]);
//readEepromValues Function
//Read EEprom values and save to outputStatus
void readEepromValues(){
for (int adr = 0; adr < outputQuantity; adr++) {
outputStatus[adr] = EEPROM.read(adr);
//writeEepromValues Function
//Write EEprom values
void writeEepromValues(){
EEPROM.write(adr, outputStatus[adr]);
//initEepromValues Function
//Initialiaze EEprom values
//if eeprom values are not the correct format ie not euqual to 0 or 1 (thus greater then 1) initialize by putting 0
void initEepromValues(){
for (int adr = 0; adr < outputQuantity; adr++){
if (EEPROM.read(adr) > 1){
EEPROM.write(adr, 0);
//htmlHeader Function
//Prints html header
void printHtmlHeader(EthernetClient client){
Serial.print("Serving html Headers at ms -");
timeConnectedAt = millis(); //Record the time when last page was served.
Serial.print(timeConnectedAt); // Print time for debbugging purposes
writeToEeprom = true; // page loaded so set to action the write to eeprom
// send a standard http response header
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html;charset=UTF-8");//"Content-Type: text/html;charset=UTF-8"
client.println("Connnection: close");
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<head>");
// add page title
client.println("<title>Удаленное управление</title>");
client.println("<meta name=\"description\" content=\"Удаленное управление\"/>");
//перзагрузка страницы,рефреш
// add a meta refresh tag, so the browser pulls again every x seconds:
client.print("<meta http-equiv=\"refresh\" content=\"");
client.print(refreshPage);
client.println("; url=/\">");
// add other browser configuration
client.println("<meta name=\"apple-mobile-web-app-capable\" content=\"yes\">");
client.println("<meta name=\"apple-mobile-web-app-status-bar-style\" content=\"default\">");
client.println("<meta name=\"viewport\" content=\"width=device-width, user-scalable=no\">");
//inserting the styles data, usually found in CSS files.
client.println("<style type=\"text/css\">");
client.println("");
//This will set how the page will look graphically
client.println("html { height:100%; }");
client.println(" body {");
client.println(" height: 100%;");
client.println(" margin: 0;");
client.println(" font-family: helvetica, sans-serif;");
client.println(" -webkit-text-size-adjust: none;");
client.println(" }");
client.println("");
client.println("body {");
client.println(" -webkit-background-size: 100% 21px;");
client.println(" background-color: #c5ccd3;");
client.println(" background-image:");
client.println(" -webkit-gradient(linear, left top, right top,");
client.println(" color-stop(.75, transparent),");
client.println(" color-stop(.75, rgba(255,255,255,.1)) );");
client.println(" -webkit-background-size: 7px;");
client.println("");
client.println(".view {");
client.println(" min-height: 100%;");
client.println(" overflow: auto;");
client.println("");
client.println(".header-wrapper {");
client.println(" height: 44px;");
client.println(" font-weight: bold;");
client.println(" text-shadow: rgba(0,0,0,0.7) 0 -1px 0;");
client.println(" border-top: solid 1px rgba(255,255,255,0.6);");
client.println(" border-bottom: solid 1px rgba(0,0,0,0.6);");
client.println(" color: #fff;");
client.println(" background-color: #8195af;");
client.println(" -webkit-gradient(linear, left top, left bottom,");
client.println(" from(rgba(255,255,255,.4)),");
client.println(" to(rgba(255,255,255,.05)) ),");
client.println(" from(transparent),");
client.println(" to(rgba(0,0,64,.1)) );");
client.println(" background-repeat: no-repeat;");
client.println(" background-position: top left, bottom left;");
client.println(" -webkit-background-size: 100% 21px, 100% 22px;");
client.println(" -webkit-box-sizing: border-box;");
client.println("");
client.println(".header-wrapper h1 {");
client.println(" text-align: center;");
client.println(" font-size: 20px;");
client.println(" line-height: 44px;");
client.println("");
client.println(".group-wrapper {");
client.println(" margin: 9px;");
client.println("");
client.println(".group-wrapper h2 {");
client.println(" color: #4c566c;");
client.println(" font-size: 17px;");
client.println(" line-height: 0.8;");
client.println(" text-shadow: #fff 0 1px 0;");
client.println(" margin: 20px 10px 12px;");
client.println("");
client.println(".group-wrapper h3 {");
client.println(" font-size: 12px;");
client.println(" line-height: 1;");
client.println("");
client.println(".group-wrapper h4 {"); //Text for description
client.println(" color: #212121;");
client.println(" font-size: 14px;");
client.println(" text-shadow: #aaa 1px 1px 3px;");
client.println(" margin: 5px 5px 5px;");
client.println("");
client.println(".group-wrapper table {");
client.println(" background-color: #fff;");
client.println(" -webkit-border-radius: 10px;");
client.println(" -moz-border-radius: 10px;");
client.println(" -khtml-border-radius: 10px;");
client.println(" border-radius: 10px;");
client.println(" line-height: 20px;");
client.println(" margin: 9px 0 20px;");
client.println(" border: solid 1px #a9abae;");
client.println(" padding: 11px 3px 12px 3px;");
client.println(" margin-left:auto;");
client.println(" margin-right:auto;");
client.println(" -moz-transform :scale(1);"); //Code for Mozilla Firefox
client.println(" -moz-transform-origin: 0 0;");
client.println("");
//how the green (ON) LED will look
client.println(".green-circle {");
client.println(" display: block;");
client.println(" height: 23px;");
client.println(" width: 23px;");
client.println(" background-color: #0f0;");
//client.println(" background-color: rgba(60, 132, 198, 0.8);");
client.println(" -moz-border-radius: 11px;");
client.println(" -webkit-border-radius: 11px;");
client.println(" -khtml-border-radius: 11px;");
client.println(" border-radius: 11px;");
client.println(" margin-left: 1px;");
client.println(" background-image: -webkit-gradient(linear, 0% 0%, 0% 90%, from(rgba(46, 184, 0, 0.8)), to(rgba(148, 255, 112, .9)));@");
client.println(" border: 2px solid #ccc;");
client.println(" -webkit-box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px;");
client.println(" -moz-box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px; /* FF 3.5+ */");
client.println(" box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px; /* FF 3.5+ */");
client.println("");
//how the black (off)LED will look
client.println(".black-circle {");
client.println(" background-color: #040;");
client.println("");
//this will add the glare to both of the LEDs
client.println(" .glare {");
client.println(" position: relative;");
client.println(" top: 1;");
client.println(" left: 5px;");
client.println(" height: 1px;");
client.println(" width: 13px;");
client.println(" padding: 5px 0;");
client.println(" background-color: rgba(200, 200, 200, 0.25);");
client.println(" background-image: -webkit-gradient(linear, 0% 0%, 0% 95%, from(rgba(255, 255, 255, 0.7)), to(rgba(255, 255, 255, 0)));");
client.println("");
//and finally this is the end of the style data and header
client.println("</style>");
client.println("</head>");
//now printing the page itself
client.println("<body>");
client.println("<div class=\"view\">");
client.println(" <div class=\"header-wrapper\">");
client.println(" <h1>Умный дом</h1>");
client.println(" </div>");
} //end of htmlHeader
//htmlFooter Function
//Prints html footer
void printHtmlFooter(EthernetClient client){
//Set Variables Before Exiting
allOn = "";
allOff = "";
/*client.println("\n</div>\n</body>\n</html>");
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection:
Serial.println(" - Done, Closing Connection.");
delay (2); //delay so that it will give time for client buffer to clear and does not repeat multiple pages.
} //end of htmlFooter
//printHtmlButtonTitle Function
//Prints html button title
void printHtmlButtonTitle(EthernetClient client){
client.println("<div class=\"group-wrapper\">");
client.println();
//printLoginTitle Function
void printLoginTitle(EthernetClient client){
client.println(" <h2>Please enter the user data to login.</h2>");
client.println();
если я правильно понимаю нужный мне алгоритм в строке
Пробовал вести отсчет var = -6, результата нет.
Подскажите как расширить диапазон 0-9 до 0-15?
Ну и правильно, что не работает
char c = client.read(); ... switch (c) { case '10':Надо посылающую часть переделывать что бы для десятог реле посылала 'A', 11го 'B' итд. А в скетче заменить '10' на 'A', '11' на 'B' и далее
можно поподробнее про переделку посылающей части?
нужно каждый порт прописать - типа порт 10 = a,
порт 11 = b и так далее, может есть какие нибудь примеры?
Как я могу привести пример если понятия не имею что там у вас на другом конце? Вы уж там сами разбирайтесь. Направление я указал.
dim5555, при таком определении номера канала, как у Вас, этот номер должен кодироваться единственным символом. Символов '10', '11' и т.д. не бывает - это двухсимвольные последовательности, из которых Си, согласно стандарту, берет только первый символ. Т.е. у Вас определено 7 веток '1'.
asam Вам правильно советует: самый простой путь - заменить все двухсимвольные последовательности. которые Вы сами вставили в код, на одиночные символы. Какие символы использовать - Вам решать.
Взаимно согласованные изменения, естественно, нужны как в приемной, так и в передающей частях.
вроде все изменил, но теперь появилась ошибка *exit status 1
#include <Ethernet.h> #include <SPI.h> #include <EEPROM.h> //////////////////////////////////////////////////////////////////////// //CONFIGURATION //////////////////////////////////////////////////////////////////////// //IP manual settings byte ip[] = { 192, 168, 1, 110 }; //Manual setup only // if need to change the MAC address (Very Rare) byte mac[] = { 0xAA, 0xBB, 0xCC, 0xDD, 0xEE, 0xFF }; //Ethernet Port EthernetServer server = EthernetServer(80); //default html port 80 //The number of outputs going to be switched. int outputQuantity = 16; //should not exceed 10??? //Invert the output of the leds boolean outputInverted = true; //true or false // This is done in case the relay board triggers the relay on negative, rather then on positive supply //Html page refresh int refreshPage = 15; //default is 10sec. //Beware that if you make it refresh too fast, the page could become inacessable. //Display or hide the "Switch on all Pins" buttons at the bottom of page int switchOnAllPinsButton = false; //true or false //Button Array //Just for a note, varables start from 0 to 9, as 0 is counted as well, thus 10 outputs. // Select the pinout address byte outputAddress[8] = { 22,23,24,25,26,27,28,29}; //Allocate 10 spaces and name the output pin address. byte outputAddress2[8]= { 30,31,32,33,34,35,36,37}; //PS pin addresses 10, 11, 12 and 13 on the Duemilanove are used for the ethernet shield, therefore cannot be used. //PS pin addresses 10, 50, 51 and 52 and 53 on the Mega are used for the ethernet shield, therefore cannot be used. //PS pin addresses 4, are used for the SD card, therefore cannot be used. //PS. pin address 2 is used for interrupt-driven notification, therefore could not be used. // Write the text description of the output channel String buttonText[16] = { "РЕЛЕ 1","РЕЛЕ 2","РЕЛЕ 3","РЕЛЕ 4","РЕЛЕ 5","РЕЛЕ 6","РЕЛЕ 7","РЕЛЕ 8","РЕЛЕ 9","РЕЛЕ 10","РЕЛЕ 11","РЕЛЕ 12","РЕЛЕ 13","РЕЛЕ 14","РЕЛЕ 15","РЕЛЕ 16"}; // Set the output to retain the last status after power recycle. int retainOutputStatus[16] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};//1-retain the last status. 0-will be off after power cut. //////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////// //VARIABLES DECLARATION //////////////////////////////////////////////////////////////////////// int outp = 0; boolean printLastCommandOnce = false; boolean printButtonMenuOnce = false; boolean initialPrint = true; String allOn = ""; String allOff = ""; boolean reading = false; boolean outputStatus[8]; //Create a boolean array for the maximum ammount. boolean outputStatus2[8]; // relays 9-16 unsigned long timeConnectedAt; boolean writeToEeprom = false; EthernetClient client; //////////////////////////////////////////////////////////////////////// //RUN ONCE //////////////////////////////////////////////////////////////////////// //Beginning of Program void setup(){ Serial.begin(9600); //initEepromValues(); //readEepromValues(); //Set pins as Outputs boolean currentState = false; for (int var = 0; var < 9; var++){ digitalWrite(outputAddress[var], HIGH); pinMode(outputAddress[var], OUTPUT); } for (int var2 = 0; var2 < 9; var2++){ pinMode(outputAddress2[var2], OUTPUT); digitalWrite(outputAddress2[var2], HIGH); } Ethernet.begin(mac, ip); //for manual setup. (Address is the one configured above.) server.begin(); Serial.print("Server started at "); Serial.println(Ethernet.localIP()); } //////////////////////////////////////////////////////////////////////// //LOOP //////////////////////////////////////////////////////////////////////// //Run once void loop(){ // listen for incoming clients, and process requests. checkForClient(); } //////////////////////////////////////////////////////////////////////// //checkForClient Function //////////////////////////////////////////////////////////////////////// // void checkForClient(){ EthernetClient client = server.available(); // if (client) { // an http request ends with a blank line boolean currentLineIsBlank = true; boolean sentHeader = false; while (client.connected()) { if (client.available()) { //if header was not set send it //read user input char c = client.read(); Serial.println(c); readString.concat(c); if(c == '*'){ printHtmlHeader(client); //call for html header and css printLoginTitle(client); printHtmlFooter(client); //sentHeader = true; break; } if(!sentHeader){ printHtmlHeader(client); //call for html header and css //This is for the arduino to construct the page on the fly. sentHeader = true; } //read user input // char c = client.read(); //if there was reading but is blank there was no reading if(reading && c == ' '){ reading = false; } //if there is a ? there was user input if(c == '?') { reading = true; //found the ?, begin reading the info } // if there was user input switch the relevant output if(reading){ //if user input is H set output to 1 if(c == 'H') { outp = 1; } //if user input is L set output to 0 if(c == 'L') { outp = 0; } Serial.print(c); //print the value of c to serial communication //Serial.print(outp); //Serial.print('\n'); switch (c) { case '0': //add code here to trigger on 0 triggerPin(outputAddress[0], client, outp); break; case '1': //add code here to trigger on 1 triggerPin(outputAddress[1], client, outp); break; case '2': //add code here to trigger on 2 triggerPin(outputAddress[2], client, outp); break; case '3': //add code here to trigger on 3 triggerPin(outputAddress[3], client, outp); break; case '4': //add code here to trigger on 4 triggerPin(outputAddress[4], client, outp); break; case '5': //add code here to trigger on 5 triggerPin(outputAddress[5], client, outp); // printHtml(client); break; case '6': //add code here to trigger on 6 triggerPin(outputAddress[6], client, outp); break; case '7': //add code here to trigger on 7 triggerPin(outputAddress[7], client, outp); break; case '8': //add code here to trigger on 8 triggerPin(outputAddress[8], client, outp); break; case '9': // add code here to trigger on 9 triggerPin(outputAddress[9], client, outp); break; case 'A': triggerPin(outputAddress[10], client, outp); break; case 'B': triggerPin(outputAddress[11], client, outp); break; case 'C': triggerPin(outputAddress[12], client, outp); break; case 'D': triggerPin(outputAddress[13], client, outp); break; case 'F': triggerPin(outputAddress[15], client, outp); break; case 'Logout': login=false; readString=""; break; } //end of switch case }//end of switch switch the relevant output //if user input was blank if (c == '\n' && currentLineIsBlank){ printLastCommandOnce = true; printButtonMenuOnce = true; triggerPin(777, client, outp); //Call to read input and print menu. 777 is used not to update any outputs break; } } } printHtmlFooter(client); //Prints the html footer } else { //if there is no client //And time of last page was served is more then a minute. if (millis() > (timeConnectedAt + 60000)){ if (writeToEeprom == true){ writeEepromValues(); //write to EEprom the current output statuses Serial.println("No Clients for more then a minute - Writing statuses to Eeprom."); writeToEeprom = false; } } } } //////////////////////////////////////////////////////////////////////// //triggerPin Function //////////////////////////////////////////////////////////////////////// // void triggerPin(int pin, EthernetClient client, int outp){ //Switching on or off outputs, reads the outputs and prints the buttons //Setting Outputs if (pin != 777){ if(outp == 1) { if (outputInverted ==false){ digitalWrite(pin, HIGH); } else{ digitalWrite(pin, LOW); } } if(outp == 0){ if (outputInverted ==false){ digitalWrite(pin, LOW); } else{ digitalWrite(pin, HIGH); } } } //Refresh the reading of outputs readOutputStatuses(); //Prints the buttons if (printButtonMenuOnce == true){ printHtmlButtons(client); printButtonMenuOnce = false; } } //////////////////////////////////////////////////////////////////////// //printHtmlButtons Function //////////////////////////////////////////////////////////////////////// //print the html buttons to switch on/off channels void printHtmlButtons(EthernetClient client){ //Start to create the html table client.println(""); //client.println("<p>"); client.println("<FORM>"); client.println("<table border=\"0\" align=\"left\">"); //Start printing button by button for (int var = 0; var < outputQuantity; var++) { //set command for all on/off allOn += "H"; allOn += outputAddress[var]; allOff += "L"; allOff += outputAddress[var]; //Print begining of row client.print("<tr>\n"); //текст кнопок //Prints the button Text client.print("<td><h2>"); client.print(buttonText[var]); client.print("</h2></td>\n"); //Prints the ON Buttons client.print("<td>"); //client.print(buttonText[var]); client.print("<INPUT TYPE=\"button\" VALUE=\"ON "); //client.print(buttonText[var]); client.print("\" onClick=\"parent.location='/?H"); client.print(var); client.print("'\"></td>\n"); //Prints the OFF Buttons client.print(" <td><INPUT TYPE=\"button\" VALUE=\"OFF"); //client.print(var); client.print("\" onClick=\"parent.location='/?L"); client.print(var); client.print("'\"></td>\n"); //Print first part of the Circles or the LEDs //Invert the LED display if output is inverted. if (outputStatus[var] == true ){ //If Output is ON if (outputInverted == false){ //and if output is not inverted client.print(" <td><div class='green-circle'><div class='glare'></div></div></td>\n"); //Print html for ON LED } else{ //else output is inverted then client.print(" <td><div class='black-circle'><div class='glare'></div></div></td>\n"); //Print html for OFF LED } } else //If Output is Off { if (outputInverted == false){ //and if output is not inverted client.print(" <td><div class='black-circle'><div class='glare'></div></div></td>\n"); //Print html for OFF LED } else{ //else output is inverted then client.print(" <td><div class='green-circle'><div class='glare'></div></div></td>\n"); //Print html for ON LED } } //Print end of row client.print("</tr>\n"); } //Display or hide the Print all on Pins Button if (switchOnAllPinsButton == true ){ //Prints the ON All Pins Button client.print("<tr>\n<td><INPUT TYPE=\"button\" VALUE=\"Switch ON All Pins"); client.print("\" onClick=\"parent.location='/?"); client.print(allOn); client.print("'\"></td>\n"); //Prints the OFF All Pins Button client.print("<td><INPUT TYPE=\"button\" VALUE=\"Switch OFF All Pins"); client.print("\" onClick=\"parent.location='/?"); client.print(allOff); client.print("'\"></td>\n<td></td>\n<td></td>\n</tr>\n"); } //Closing the table and form client.println("</table>"); client.println("</FORM>"); //client.println("</p>"); } //////////////////////////////////////////////////////////////////////// //readOutputStatuses Function //////////////////////////////////////////////////////////////////////// //Reading the Output Statuses void readOutputStatuses(){ for (int var = 0; var < outputQuantity; var++) { outputStatus[var] = digitalRead(outputAddress[var]); outputStatus2[var] = digitalRead(outputAddress2[var]); //Serial.print(outputStatus[var]); } } //////////////////////////////////////////////////////////////////////// //readEepromValues Function //////////////////////////////////////////////////////////////////////// //Read EEprom values and save to outputStatus void readEepromValues(){ for (int adr = 0; adr < outputQuantity; adr++) { outputStatus[adr] = EEPROM.read(adr); } } //////////////////////////////////////////////////////////////////////// //writeEepromValues Function //////////////////////////////////////////////////////////////////////// //Write EEprom values void writeEepromValues(){ for (int adr = 0; adr < outputQuantity; adr++) { EEPROM.write(adr, outputStatus[adr]); } } //////////////////////////////////////////////////////////////////////// //initEepromValues Function //////////////////////////////////////////////////////////////////////// //Initialiaze EEprom values //if eeprom values are not the correct format ie not euqual to 0 or 1 (thus greater then 1) initialize by putting 0 void initEepromValues(){ for (int adr = 0; adr < outputQuantity; adr++){ if (EEPROM.read(adr) > 1){ EEPROM.write(adr, 0); } } } //////////////////////////////////////////////////////////////////////// //htmlHeader Function //////////////////////////////////////////////////////////////////////// //Prints html header void printHtmlHeader(EthernetClient client){ Serial.print("Serving html Headers at ms -"); timeConnectedAt = millis(); //Record the time when last page was served. Serial.print(timeConnectedAt); // Print time for debbugging purposes writeToEeprom = true; // page loaded so set to action the write to eeprom // send a standard http response header client.println("HTTP/1.1 200 OK"); client.println("Content-Type: text/html;charset=UTF-8");//"Content-Type: text/html;charset=UTF-8" client.println("Connnection: close"); client.println(); client.println("<!DOCTYPE HTML>"); client.println("<head>"); // add page title client.println("<title>Удаленное управление</title>"); client.println("<meta name=\"description\" content=\"Удаленное управление\"/>"); /* //перзагрузка страницы,рефреш // add a meta refresh tag, so the browser pulls again every x seconds: client.print("<meta http-equiv=\"refresh\" content=\""); client.print(refreshPage); client.println("; url=/\">"); */ // add other browser configuration client.println("<meta name=\"apple-mobile-web-app-capable\" content=\"yes\">"); client.println("<meta name=\"apple-mobile-web-app-status-bar-style\" content=\"default\">"); client.println("<meta name=\"viewport\" content=\"width=device-width, user-scalable=no\">"); //inserting the styles data, usually found in CSS files. client.println("<style type=\"text/css\">"); client.println(""); //This will set how the page will look graphically client.println("html { height:100%; }"); client.println(" body {"); client.println(" height: 100%;"); client.println(" margin: 0;"); client.println(" font-family: helvetica, sans-serif;"); client.println(" -webkit-text-size-adjust: none;"); client.println(" }"); client.println(""); client.println("body {"); client.println(" -webkit-background-size: 100% 21px;"); client.println(" background-color: #c5ccd3;"); client.println(" background-image:"); client.println(" -webkit-gradient(linear, left top, right top,"); client.println(" color-stop(.75, transparent),"); client.println(" color-stop(.75, rgba(255,255,255,.1)) );"); client.println(" -webkit-background-size: 7px;"); client.println(" }"); client.println(""); client.println(".view {"); client.println(" min-height: 100%;"); client.println(" overflow: auto;"); client.println(" }"); client.println(""); client.println(".header-wrapper {"); client.println(" height: 44px;"); client.println(" font-weight: bold;"); client.println(" text-shadow: rgba(0,0,0,0.7) 0 -1px 0;"); client.println(" border-top: solid 1px rgba(255,255,255,0.6);"); client.println(" border-bottom: solid 1px rgba(0,0,0,0.6);"); client.println(" color: #fff;"); client.println(" background-color: #8195af;"); client.println(" background-image:"); client.println(" -webkit-gradient(linear, left top, left bottom,"); client.println(" from(rgba(255,255,255,.4)),"); client.println(" to(rgba(255,255,255,.05)) ),"); client.println(" -webkit-gradient(linear, left top, left bottom,"); client.println(" from(transparent),"); client.println(" to(rgba(0,0,64,.1)) );"); client.println(" background-repeat: no-repeat;"); client.println(" background-position: top left, bottom left;"); client.println(" -webkit-background-size: 100% 21px, 100% 22px;"); client.println(" -webkit-box-sizing: border-box;"); client.println(" }"); client.println(""); client.println(".header-wrapper h1 {"); client.println(" text-align: center;"); client.println(" font-size: 20px;"); client.println(" line-height: 44px;"); client.println(" margin: 0;"); client.println(" }"); client.println(""); client.println(".group-wrapper {"); client.println(" margin: 9px;"); client.println(" }"); client.println(""); client.println(".group-wrapper h2 {"); client.println(" color: #4c566c;"); client.println(" font-size: 17px;"); client.println(" line-height: 0.8;"); client.println(" font-weight: bold;"); client.println(" text-shadow: #fff 0 1px 0;"); client.println(" margin: 20px 10px 12px;"); client.println(" }"); client.println(""); client.println(".group-wrapper h3 {"); client.println(" color: #4c566c;"); client.println(" font-size: 12px;"); client.println(" line-height: 1;"); client.println(" font-weight: bold;"); client.println(" text-shadow: #fff 0 1px 0;"); client.println(" margin: 20px 10px 12px;"); client.println(" }"); client.println(""); client.println(".group-wrapper h4 {"); //Text for description client.println(" color: #212121;"); client.println(" font-size: 14px;"); client.println(" line-height: 1;"); client.println(" font-weight: bold;"); client.println(" text-shadow: #aaa 1px 1px 3px;"); client.println(" margin: 5px 5px 5px;"); client.println(" }"); client.println(""); client.println(".group-wrapper table {"); client.println(" background-color: #fff;"); client.println(" -webkit-border-radius: 10px;"); client.println(" -moz-border-radius: 10px;"); client.println(" -khtml-border-radius: 10px;"); client.println(" border-radius: 10px;"); client.println(" font-size: 20px;"); client.println(" line-height: 20px;"); client.println(" margin: 9px 0 20px;"); client.println(" border: solid 1px #a9abae;"); client.println(" padding: 11px 3px 12px 3px;"); client.println(" margin-left:auto;"); client.println(" margin-right:auto;"); client.println(" -moz-transform :scale(1);"); //Code for Mozilla Firefox client.println(" -moz-transform-origin: 0 0;"); client.println(" }"); client.println(""); //how the green (ON) LED will look client.println(".green-circle {"); client.println(" display: block;"); client.println(" height: 23px;"); client.println(" width: 23px;"); client.println(" background-color: #0f0;"); //client.println(" background-color: rgba(60, 132, 198, 0.8);"); client.println(" -moz-border-radius: 11px;"); client.println(" -webkit-border-radius: 11px;"); client.println(" -khtml-border-radius: 11px;"); client.println(" border-radius: 11px;"); client.println(" margin-left: 1px;"); client.println(" background-image: -webkit-gradient(linear, 0% 0%, 0% 90%, from(rgba(46, 184, 0, 0.8)), to(rgba(148, 255, 112, .9)));@"); client.println(" border: 2px solid #ccc;"); client.println(" -webkit-box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px;"); client.println(" -moz-box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px; /* FF 3.5+ */"); client.println(" box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px; /* FF 3.5+ */"); client.println(" }"); client.println(""); //how the black (off)LED will look client.println(".black-circle {"); client.println(" display: block;"); client.println(" height: 23px;"); client.println(" width: 23px;"); client.println(" background-color: #040;"); client.println(" -moz-border-radius: 11px;"); client.println(" -webkit-border-radius: 11px;"); client.println(" -khtml-border-radius: 11px;"); client.println(" border-radius: 11px;"); client.println(" margin-left: 1px;"); client.println(" -webkit-box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px;"); client.println(" -moz-box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px; /* FF 3.5+ */"); client.println(" box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px; /* FF 3.5+ */"); client.println(" }"); client.println(""); //this will add the glare to both of the LEDs client.println(" .glare {"); client.println(" position: relative;"); client.println(" top: 1;"); client.println(" left: 5px;"); client.println(" -webkit-border-radius: 10px;"); client.println(" -moz-border-radius: 10px;"); client.println(" -khtml-border-radius: 10px;"); client.println(" border-radius: 10px;"); client.println(" height: 1px;"); client.println(" width: 13px;"); client.println(" padding: 5px 0;"); client.println(" background-color: rgba(200, 200, 200, 0.25);"); client.println(" background-image: -webkit-gradient(linear, 0% 0%, 0% 95%, from(rgba(255, 255, 255, 0.7)), to(rgba(255, 255, 255, 0)));"); client.println(" }"); client.println(""); //and finally this is the end of the style data and header client.println("</style>"); client.println("</head>"); //now printing the page itself client.println("<body>"); client.println("<div class=\"view\">"); client.println(" <div class=\"header-wrapper\">"); client.println(" <h1>Умный дом</h1>"); client.println(" </div>"); ////// } //end of htmlHeader //////////////////////////////////////////////////////////////////////// //htmlFooter Function //////////////////////////////////////////////////////////////////////// //Prints html footer void printHtmlFooter(EthernetClient client){ //Set Variables Before Exiting printLastCommandOnce = false; printButtonMenuOnce = false; allOn = ""; allOff = ""; /*client.println("\n</div>\n</body>\n</html>"); delay(1); // give the web browser time to receive the data client.stop(); // close the connection: Serial.println(" - Done, Closing Connection."); delay (2); //delay so that it will give time for client buffer to clear and does not repeat multiple pages. */ delay(1); // give the web browser time to receive the data client.stop(); // close the connection: Serial.println(" - Done, Closing Connection."); delay (2); //delay so that it will give time for client buffer to clear and does not repeat multiple pages. } //end of htmlFooter //////////////////////////////////////////////////////////////////////// //printHtmlButtonTitle Function //////////////////////////////////////////////////////////////////////// //Prints html button title void printHtmlButtonTitle(EthernetClient client){ client.println("<div class=\"group-wrapper\">"); client.println(); } //////////////////////////////////////////////////////////////////////// //printLoginTitle Function //////////////////////////////////////////////////////////////////////// //Prints html button title void printLoginTitle(EthernetClient client){ client.println("<div class=\"group-wrapper\">"); client.println(" <h2>Please enter the user data to login.</h2>"); client.println(); }вроде все изменил, но теперь появилась ошибка *exit status 1
Dim, на будущее - указывайте весь текст ошибки. Думаете так интересно просматривать ваши сотни строк кода. чтобы найти, где у вас readString ? - в ошибке указан номер строки
Если правильно нашел, это строка 144. Насколько я вижу, в новом коде она вообще лишняя. попробуйте ее просто закомментировать
поправил код,
куча ошибок..
#include <Ethernet.h> #include <SPI.h> #include <EEPROM.h> //////////////////////////////////////////////////////////////////////// //CONFIGURATION //////////////////////////////////////////////////////////////////////// //IP manual settings byte ip[] = { 192, 168, 1, 110 }; //Manual setup only // if need to change the MAC address (Very Rare) byte mac[] = { 0xAA, 0xBB, 0xCC, 0xDD, 0xEE, 0xFF }; //Ethernet Port EthernetServer server = EthernetServer(80); //default html port 80 //The number of outputs going to be switched. int outputQuantity = 16; //should not exceed 10??? //Invert the output of the leds boolean outputInverted = true; //true or false // This is done in case the relay board triggers the relay on negative, rather then on positive supply //Html page refresh int refreshPage = 15; //default is 10sec. //Beware that if you make it refresh too fast, the page could become inacessable. //Display or hide the "Switch on all Pins" buttons at the bottom of page int switchOnAllPinsButton = false; //true or false //Button Array //Just for a note, varables start from 0 to 9, as 0 is counted as well, thus 10 outputs. // Select the pinout address byte outputAddress[8] = { 22,23,24,25,26,27,28,29}; //Allocate 10 spaces and name the output pin address. byte outputAddress2[8]= { 30,31,32,33,34,35,36,37}; //PS pin addresses 10, 11, 12 and 13 on the Duemilanove are used for the ethernet shield, therefore cannot be used. //PS pin addresses 10, 50, 51 and 52 and 53 on the Mega are used for the ethernet shield, therefore cannot be used. //PS pin addresses 4, are used for the SD card, therefore cannot be used. //PS. pin address 2 is used for interrupt-driven notification, therefore could not be used. // Write the text description of the output channel String buttonText[16] = { "РЕЛЕ 1","РЕЛЕ 2","РЕЛЕ 3","РЕЛЕ 4","РЕЛЕ 5","РЕЛЕ 6","РЕЛЕ 7","РЕЛЕ 8","РЕЛЕ 9","РЕЛЕ 10","РЕЛЕ 11","РЕЛЕ 12","РЕЛЕ 13","РЕЛЕ 14","РЕЛЕ 15","РЕЛЕ 16"}; // Set the output to retain the last status after power recycle. int retainOutputStatus[16] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};//1-retain the last status. 0-will be off after power cut. //////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////// //VARIABLES DECLARATION //////////////////////////////////////////////////////////////////////// int outp = 0; boolean printLastCommandOnce = false; boolean printButtonMenuOnce = false; boolean initialPrint = true; String allOn = ""; String allOff = ""; boolean reading = false; boolean outputStatus[8]; //Create a boolean array for the maximum ammount. boolean outputStatus2[8]; // relays 9-16 unsigned long timeConnectedAt; boolean writeToEeprom = false; EthernetClient client; //////////////////////////////////////////////////////////////////////// //RUN ONCE //////////////////////////////////////////////////////////////////////// //Beginning of Program void setup(){ Serial.begin(9600); //initEepromValues(); //readEepromValues(); //Set pins as Outputs boolean currentState = false; for (int var = 0; var < 9; var++){ digitalWrite(outputAddress[var], HIGH); pinMode(outputAddress[var], OUTPUT); } for (int var2 = 0; var2 < 9; var2++){ pinMode(outputAddress2[var2], OUTPUT); digitalWrite(outputAddress2[var2], HIGH); } Ethernet.begin(mac, ip); //for manual setup. (Address is the one configured above.) server.begin(); Serial.print("Server started at "); Serial.println(Ethernet.localIP()); } //////////////////////////////////////////////////////////////////////// //LOOP //////////////////////////////////////////////////////////////////////// //Run once void loop(){ // listen for incoming clients, and process requests. checkForClient(); } //////////////////////////////////////////////////////////////////////// //checkForClient Function //////////////////////////////////////////////////////////////////////// // void checkForClient(){ EthernetClient client = server.available(); // if (client) { // an http request ends with a blank line boolean currentLineIsBlank = true; boolean sentHeader = false; while (client.connected()) { if (client.available()) { //if header was not set send it //read user input char c = client.read(); Serial.println(c); //readString.concat(c); if(c == '*'){ printHtmlHeader(client); //call for html header and css printHtmlFooter(client); //sentHeader = true; break; } if(!sentHeader){ printHtmlHeader(client); //call for html header and css //This is for the arduino to construct the page on the fly. sentHeader = true; } //read user input // char c = client.read(); //if there was reading but is blank there was no reading if(reading && c == ' '){ reading = false; } //if there is a ? there was user input if(c == '?') { reading = true; //found the ?, begin reading the info } // if there was user input switch the relevant output if(reading){ //if user input is H set output to 1 if(c == 'H') { outp = 1; } //if user input is L set output to 0 if(c == 'L') { outp = 0; } Serial.print(c); //print the value of c to serial communication //Serial.print(outp); //Serial.print('\n'); switch (c) { case '0': //add code here to trigger on 0 triggerPin(outputAddress[0], client, outp); break; case '1': //add code here to trigger on 1 triggerPin(outputAddress[1], client, outp); break; case '2': //add code here to trigger on 2 triggerPin(outputAddress[2], client, outp); break; case '3': //add code here to trigger on 3 triggerPin(outputAddress[3], client, outp); break; case '4': //add code here to trigger on 4 triggerPin(outputAddress[4], client, outp); break; case '5': //add code here to trigger on 5 triggerPin(outputAddress[5], client, outp); // printHtml(client); break; case '6': //add code here to trigger on 6 triggerPin(outputAddress[6], client, outp); break; case '7': //add code here to trigger on 7 triggerPin(outputAddress[7], client, outp); break; case '8': //add code here to trigger on 8 triggerPin(outputAddress[8], client, outp); break; case '9': // add code here to trigger on 9 triggerPin(outputAddress[9], client, outp); break; case 'A': triggerPin(outputAddress[10], client, outp); break; case 'B': triggerPin(outputAddress[11], client, outp); break; case 'C': triggerPin(outputAddress[12], client, outp); break; case 'D': triggerPin(outputAddress[13], client, outp); break; case 'F': triggerPin(outputAddress[15], client, outp); readString=""; break; } //end of switch case }//end of switch switch the relevant output //if user input was blank if (c == '\n' && currentLineIsBlank){ printLastCommandOnce = true; printButtonMenuOnce = true; triggerPin(777, client, outp); //Call to read input and print menu. 777 is used not to update any outputs break; } } } printHtmlFooter(client); //Prints the html footer } else { //if there is no client //And time of last page was served is more then a minute. if (millis() > (timeConnectedAt + 60000)){ if (writeToEeprom == true){ writeEepromValues(); //write to EEprom the current output statuses Serial.println("No Clients for more then a minute - Writing statuses to Eeprom."); writeToEeprom = false; } } } } //////////////////////////////////////////////////////////////////////// //triggerPin Function //////////////////////////////////////////////////////////////////////// // void triggerPin(int pin, EthernetClient client, int outp){ //Switching on or off outputs, reads the outputs and prints the buttons //Setting Outputs if (pin != 777){ if(outp == 1) { if (outputInverted ==false){ digitalWrite(pin, HIGH); } else{ digitalWrite(pin, LOW); } } if(outp == 0){ if (outputInverted ==false){ digitalWrite(pin, LOW); } else{ digitalWrite(pin, HIGH); } } } //Refresh the reading of outputs readOutputStatuses(); //Prints the buttons if (printButtonMenuOnce == true){ printHtmlButtons(client); printButtonMenuOnce = false; } } //////////////////////////////////////////////////////////////////////// //printHtmlButtons Function //////////////////////////////////////////////////////////////////////// //print the html buttons to switch on/off channels void printHtmlButtons(EthernetClient client){ //Start to create the html table client.println(""); //client.println("<p>"); client.println("<FORM>"); client.println("<table border=\"0\" align=\"left\">"); //Start printing button by button for (int var = 0; var < outputQuantity; var++) { //set command for all on/off allOn += "H"; allOn += outputAddress[var]; allOff += "L"; allOff += outputAddress[var]; //Print begining of row client.print("<tr>\n"); //текст кнопок //Prints the button Text client.print("<td><h2>"); client.print(buttonText[var]); client.print("</h2></td>\n"); //Prints the ON Buttons client.print("<td>"); //client.print(buttonText[var]); client.print("<INPUT TYPE=\"button\" VALUE=\"ON "); //client.print(buttonText[var]); client.print("\" onClick=\"parent.location='/?H"); client.print(var); client.print("'\"></td>\n"); //Prints the OFF Buttons client.print(" <td><INPUT TYPE=\"button\" VALUE=\"OFF"); //client.print(var); client.print("\" onClick=\"parent.location='/?L"); client.print(var); client.print("'\"></td>\n"); //Print first part of the Circles or the LEDs //Invert the LED display if output is inverted. if (outputStatus[var] == true ){ //If Output is ON if (outputInverted == false){ //and if output is not inverted client.print(" <td><div class='green-circle'><div class='glare'></div></div></td>\n"); //Print html for ON LED } else{ //else output is inverted then client.print(" <td><div class='black-circle'><div class='glare'></div></div></td>\n"); //Print html for OFF LED } } else //If Output is Off { if (outputInverted == false){ //and if output is not inverted client.print(" <td><div class='black-circle'><div class='glare'></div></div></td>\n"); //Print html for OFF LED } else{ //else output is inverted then client.print(" <td><div class='green-circle'><div class='glare'></div></div></td>\n"); //Print html for ON LED } } //Print end of row client.print("</tr>\n"); } //Display or hide the Print all on Pins Button if (switchOnAllPinsButton == true ){ //Prints the ON All Pins Button client.print("<tr>\n<td><INPUT TYPE=\"button\" VALUE=\"Switch ON All Pins"); client.print("\" onClick=\"parent.location='/?"); client.print(allOn); client.print("'\"></td>\n"); //Prints the OFF All Pins Button client.print("<td><INPUT TYPE=\"button\" VALUE=\"Switch OFF All Pins"); client.print("\" onClick=\"parent.location='/?"); client.print(allOff); client.print("'\"></td>\n<td></td>\n<td></td>\n</tr>\n"); } //Closing the table and form client.println("</table>"); client.println("</FORM>"); //client.println("</p>"); } //////////////////////////////////////////////////////////////////////// //readOutputStatuses Function //////////////////////////////////////////////////////////////////////// //Reading the Output Statuses void readOutputStatuses(){ for (int var = 0; var < outputQuantity; var++) { outputStatus[var] = digitalRead(outputAddress[var]); outputStatus2[var] = digitalRead(outputAddress2[var]); //Serial.print(outputStatus[var]); } } //////////////////////////////////////////////////////////////////////// //readEepromValues Function //////////////////////////////////////////////////////////////////////// //Read EEprom values and save to outputStatus void readEepromValues(){ for (int adr = 0; adr < outputQuantity; adr++) { outputStatus[adr] = EEPROM.read(adr); } } //////////////////////////////////////////////////////////////////////// //writeEepromValues Function //////////////////////////////////////////////////////////////////////// //Write EEprom values void writeEepromValues(){ for (int adr = 0; adr < outputQuantity; adr++) { EEPROM.write(adr, outputStatus[adr]); } } //////////////////////////////////////////////////////////////////////// //initEepromValues Function //////////////////////////////////////////////////////////////////////// //Initialiaze EEprom values //if eeprom values are not the correct format ie not euqual to 0 or 1 (thus greater then 1) initialize by putting 0 void initEepromValues(){ for (int adr = 0; adr < outputQuantity; adr++){ if (EEPROM.read(adr) > 1){ EEPROM.write(adr, 0); } } } //////////////////////////////////////////////////////////////////////// //htmlHeader Function //////////////////////////////////////////////////////////////////////// //Prints html header void printHtmlHeader(EthernetClient client){ Serial.print("Serving html Headers at ms -"); timeConnectedAt = millis(); //Record the time when last page was served. Serial.print(timeConnectedAt); // Print time for debbugging purposes writeToEeprom = true; // page loaded so set to action the write to eeprom // send a standard http response header client.println("HTTP/1.1 200 OK"); client.println("Content-Type: text/html;charset=UTF-8");//"Content-Type: text/html;charset=UTF-8" client.println("Connnection: close"); client.println(); client.println("<!DOCTYPE HTML>"); client.println("<head>"); // add page title client.println("<title>Удаленное управление</title>"); client.println("<meta name=\"description\" content=\"Удаленное управление\"/>"); /* //перзагрузка страницы,рефреш // add a meta refresh tag, so the browser pulls again every x seconds: client.print("<meta http-equiv=\"refresh\" content=\""); client.print(refreshPage); client.println("; url=/\">"); */ // add other browser configuration client.println("<meta name=\"apple-mobile-web-app-capable\" content=\"yes\">"); client.println("<meta name=\"apple-mobile-web-app-status-bar-style\" content=\"default\">"); client.println("<meta name=\"viewport\" content=\"width=device-width, user-scalable=no\">"); //inserting the styles data, usually found in CSS files. client.println("<style type=\"text/css\">"); client.println(""); //This will set how the page will look graphically client.println("html { height:100%; }"); client.println(" body {"); client.println(" height: 100%;"); client.println(" margin: 0;"); client.println(" font-family: helvetica, sans-serif;"); client.println(" -webkit-text-size-adjust: none;"); client.println(" }"); client.println(""); client.println("body {"); client.println(" -webkit-background-size: 100% 21px;"); client.println(" background-color: #c5ccd3;"); client.println(" background-image:"); client.println(" -webkit-gradient(linear, left top, right top,"); client.println(" color-stop(.75, transparent),"); client.println(" color-stop(.75, rgba(255,255,255,.1)) );"); client.println(" -webkit-background-size: 7px;"); client.println(" }"); client.println(""); client.println(".view {"); client.println(" min-height: 100%;"); client.println(" overflow: auto;"); client.println(" }"); client.println(""); client.println(".header-wrapper {"); client.println(" height: 44px;"); client.println(" font-weight: bold;"); client.println(" text-shadow: rgba(0,0,0,0.7) 0 -1px 0;"); client.println(" border-top: solid 1px rgba(255,255,255,0.6);"); client.println(" border-bottom: solid 1px rgba(0,0,0,0.6);"); client.println(" color: #fff;"); client.println(" background-color: #8195af;"); client.println(" background-image:"); client.println(" -webkit-gradient(linear, left top, left bottom,"); client.println(" from(rgba(255,255,255,.4)),"); client.println(" to(rgba(255,255,255,.05)) ),"); client.println(" -webkit-gradient(linear, left top, left bottom,"); client.println(" from(transparent),"); client.println(" to(rgba(0,0,64,.1)) );"); client.println(" background-repeat: no-repeat;"); client.println(" background-position: top left, bottom left;"); client.println(" -webkit-background-size: 100% 21px, 100% 22px;"); client.println(" -webkit-box-sizing: border-box;"); client.println(" }"); client.println(""); client.println(".header-wrapper h1 {"); client.println(" text-align: center;"); client.println(" font-size: 20px;"); client.println(" line-height: 44px;"); client.println(" margin: 0;"); client.println(" }"); client.println(""); client.println(".group-wrapper {"); client.println(" margin: 9px;"); client.println(" }"); client.println(""); client.println(".group-wrapper h2 {"); client.println(" color: #4c566c;"); client.println(" font-size: 17px;"); client.println(" line-height: 0.8;"); client.println(" font-weight: bold;"); client.println(" text-shadow: #fff 0 1px 0;"); client.println(" margin: 20px 10px 12px;"); client.println(" }"); client.println(""); client.println(".group-wrapper h3 {"); client.println(" color: #4c566c;"); client.println(" font-size: 12px;"); client.println(" line-height: 1;"); client.println(" font-weight: bold;"); client.println(" text-shadow: #fff 0 1px 0;"); client.println(" margin: 20px 10px 12px;"); client.println(" }"); client.println(""); client.println(".group-wrapper h4 {"); //Text for description client.println(" color: #212121;"); client.println(" font-size: 14px;"); client.println(" line-height: 1;"); client.println(" font-weight: bold;"); client.println(" text-shadow: #aaa 1px 1px 3px;"); client.println(" margin: 5px 5px 5px;"); client.println(" }"); client.println(""); client.println(".group-wrapper table {"); client.println(" background-color: #fff;"); client.println(" -webkit-border-radius: 10px;"); client.println(" -moz-border-radius: 10px;"); client.println(" -khtml-border-radius: 10px;"); client.println(" border-radius: 10px;"); client.println(" font-size: 20px;"); client.println(" line-height: 20px;"); client.println(" margin: 9px 0 20px;"); client.println(" border: solid 1px #a9abae;"); client.println(" padding: 11px 3px 12px 3px;"); client.println(" margin-left:auto;"); client.println(" margin-right:auto;"); client.println(" -moz-transform :scale(1);"); //Code for Mozilla Firefox client.println(" -moz-transform-origin: 0 0;"); client.println(" }"); client.println(""); //how the green (ON) LED will look client.println(".green-circle {"); client.println(" display: block;"); client.println(" height: 23px;"); client.println(" width: 23px;"); client.println(" background-color: #0f0;"); //client.println(" background-color: rgba(60, 132, 198, 0.8);"); client.println(" -moz-border-radius: 11px;"); client.println(" -webkit-border-radius: 11px;"); client.println(" -khtml-border-radius: 11px;"); client.println(" border-radius: 11px;"); client.println(" margin-left: 1px;"); client.println(" background-image: -webkit-gradient(linear, 0% 0%, 0% 90%, from(rgba(46, 184, 0, 0.8)), to(rgba(148, 255, 112, .9)));@"); client.println(" border: 2px solid #ccc;"); client.println(" -webkit-box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px;"); client.println(" -moz-box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px; /* FF 3.5+ */"); client.println(" box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px; /* FF 3.5+ */"); client.println(" }"); client.println(""); //how the black (off)LED will look client.println(".black-circle {"); client.println(" display: block;"); client.println(" height: 23px;"); client.println(" width: 23px;"); client.println(" background-color: #040;"); client.println(" -moz-border-radius: 11px;"); client.println(" -webkit-border-radius: 11px;"); client.println(" -khtml-border-radius: 11px;"); client.println(" border-radius: 11px;"); client.println(" margin-left: 1px;"); client.println(" -webkit-box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px;"); client.println(" -moz-box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px; /* FF 3.5+ */"); client.println(" box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px; /* FF 3.5+ */"); client.println(" }"); client.println(""); //this will add the glare to both of the LEDs client.println(" .glare {"); client.println(" position: relative;"); client.println(" top: 1;"); client.println(" left: 5px;"); client.println(" -webkit-border-radius: 10px;"); client.println(" -moz-border-radius: 10px;"); client.println(" -khtml-border-radius: 10px;"); client.println(" border-radius: 10px;"); client.println(" height: 1px;"); client.println(" width: 13px;"); client.println(" padding: 5px 0;"); client.println(" background-color: rgba(200, 200, 200, 0.25);"); client.println(" background-image: -webkit-gradient(linear, 0% 0%, 0% 95%, from(rgba(255, 255, 255, 0.7)), to(rgba(255, 255, 255, 0)));"); client.println(" }"); client.println(""); //and finally this is the end of the style data and header client.println("</style>"); client.println("</head>"); //now printing the page itself client.println("<body>"); client.println("<div class=\"view\">"); client.println(" <div class=\"header-wrapper\">"); client.println(" <h1>Умный дом</h1>"); client.println(" </div>"); ////// } //end of htmlHeader //////////////////////////////////////////////////////////////////////// //htmlFooter Function //////////////////////////////////////////////////////////////////////// //Prints html footer void printHtmlFooter(EthernetClient client){ //Set Variables Before Exiting printLastCommandOnce = false; printButtonMenuOnce = false; allOn = ""; allOff = ""; /*client.println("\n</div>\n</body>\n</html>"); delay(1); // give the web browser time to receive the data client.stop(); // close the connection: Serial.println(" - Done, Closing Connection."); delay (2); //delay so that it will give time for client buffer to clear and does not repeat multiple pages. */ delay(1); // give the web browser time to receive the data client.stop(); // close the connection: Serial.println(" - Done, Closing Connection."); delay (2); //delay so that it will give time for client buffer to clear and does not repeat multiple pages. } //end of htmlFooter //////////////////////////////////////////////////////////////////////// //printHtmlButtonTitle Function //////////////////////////////////////////////////////////////////////// //Prints html button title void printHtmlButtonTitle(EthernetClient client){ client.println("<div class=\"group-wrapper\">"); client.println(); } //////////////////////////////////////////////////////////////////////// //printLoginTitle Function //////////////////////////////////////////////////////////////////////// //Prints html button title void printLoginTitle(EthernetClient client){ client.println("<div class=\"group-wrapper\">"); client.println(" <h2>Please enter the user data to login.</h2>"); client.println(); }Функции должны быть объявлены до их использования.
спасибо , видно просто не хватает знаний...
вот эта версия на 20 реле компилируется нормально, отображаются все 20 реле, c 1 по 10 работают как положено - далее если допустим включить реле 14 отработают реле 2 и 4.
Ребята , поправьте пожалуйста скетч, уже сутки не сплю...
#include <Ethernet.h> #include <SPI.h> #include <EEPROM.h> //////////////////////////////////////////////////////////////////////// //CONFIGURATION //////////////////////////////////////////////////////////////////////// //IP manual settings byte ip[] = { 192, 168, 1, 110 }; //Manual setup only // if need to change the MAC address (Very Rare) byte mac[] = { 0xAA, 0xBB, 0xCC, 0xDD, 0xEE, 0xFF }; //Ethernet Port EthernetServer server = EthernetServer(80); //default html port 80 //The number of outputs going to be switched. int outputQuantity = 20; //should not exceed 10??? //Invert the output of the leds boolean outputInverted = true; //true or false // This is done in case the relay board triggers the relay on negative, rather then on positive supply //Html page refresh int refreshPage = 15; //default is 10sec. //Beware that if you make it refresh too fast, the page could become inacessable. //Display or hide the "Switch on all Pins" buttons at the bottom of page int switchOnAllPinsButton = false; //true or false //Button Array //Just for a note, varables start from 0 to 9, as 0 is counted as well, thus 10 outputs. // Select the pinout address int outputAddress[10] = { 22,23,24,25,26,27,28,29,30,31}; //Allocate 10 int outputAddress2[10]= { 32,33,34,35,36,37,38,39,40,41}; //Allocate 10 //PS pin addresses 10, 11, 12 and 13 on the Duemilanove are used for the ethernet shield, therefore cannot be used. //PS pin addresses 10, 50, 51 and 52 and 53 on the Mega are used for the ethernet shield, therefore cannot be used. //PS pin addresses 4, are used for the SD card, therefore cannot be used. //PS. pin address 2 is used for interrupt-driven notification, therefore could not be used. // Write the text description of the output channel String buttonText[20] = { "Relay 1","Relay 2","Relay 3","Relay 4","Relay 5","Relay 6","Relay 7","Relay 8","Relay 9","Relay 10","Relay 11","Relay 12","Relay 13","Relay 14","Relay 15","Relay 16","Relay 17","Relay 18","Relay 19","Relay 20"}; // Set the output to retain the last status after power recycle. int retainOutputStatus[20] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};//1-retain the last status. 0-will be off after power cut. //////////////////////////////////////////////////////////////////////// //////////////////////////////////////////////////////////////////////// //VARIABLES DECLARATION //////////////////////////////////////////////////////////////////////// int outp = 0; boolean printLastCommandOnce = false; boolean printButtonMenuOnce = false; boolean initialPrint = true; String allOn = ""; String allOff = ""; boolean reading = false; boolean outputStatus[20]; //Create a boolean array for the maximum ammount. unsigned long timeConnectedAt; boolean writeToEeprom = false; EthernetClient client; //////////////////////////////////////////////////////////////////////// //RUN ONCE //////////////////////////////////////////////////////////////////////// //Beginning of Program void setup(){ Serial.begin(9600); initEepromValues(); readEepromValues(); //Set pins as Outputs boolean currentState = false; for (int var = 0; var < 11; var++){ digitalWrite(outputAddress[var], HIGH); pinMode(outputAddress[var], OUTPUT); } for (int var2 = 0; var2 < 11; var2++){ pinMode(outputAddress2[var2], OUTPUT); digitalWrite(outputAddress2[var2], HIGH); } //Setting up the IP address. Comment out the one you dont need. //Ethernet.begin(mac); //for DHCP address. (Address will be printed to serial.) Ethernet.begin(mac, ip); //for manual setup. (Address is the one configured above.) server.begin(); Serial.print("Server started at "); Serial.println(Ethernet.localIP()); } //////////////////////////////////////////////////////////////////////// //LOOP //////////////////////////////////////////////////////////////////////// //Run once void loop(){ // listen for incoming clients, and process requests. checkForClient(); } //////////////////////////////////////////////////////////////////////// //checkForClient Function //////////////////////////////////////////////////////////////////////// // void checkForClient(){ EthernetClient client = server.available(); if (client) { // an http request ends with a blank line boolean currentLineIsBlank = true; boolean sentHeader = false; while (client.connected()) { if (client.available()) { //if header was not set send it //read user input char c = client.read(); if(c == '*'){ printHtmlHeader(client); //call for html header and css printLoginTitle(client); printHtmlFooter(client); //sentHeader = true; break; } if(!sentHeader){ printHtmlHeader(client); //call for html header and css // printHtmlButtonTitle(client); //print the button title //This is for the arduino to construct the page on the fly. sentHeader = true; } //read user input // char c = client.read(); //if there was reading but is blank there was no reading if(reading && c == ' '){ reading = false; } //if there is a ? there was user input if(c == '?') { reading = true; //found the ?, begin reading the info } // if there was user input switch the relevant output if(reading){ //if user input is H set output to 1 if(c == 'H') { outp = 1; } //if user input is L set output to 0 if(c == 'L') { outp = 0; } Serial.print(c); //print the value of c to serial communication //Serial.print(outp); //Serial.print('\n'); switch (c) { case '0': //add code here to trigger on 0 triggerPin(outputAddress[0], client, outp); break; case '1': //add code here to trigger on 1 triggerPin(outputAddress[1], client, outp); break; case '2': //add code here to trigger on 2 triggerPin(outputAddress[2], client, outp); break; case '3': //add code here to trigger on 3 triggerPin(outputAddress[3], client, outp); break; case '4': //add code here to trigger on 4 triggerPin(outputAddress[4], client, outp); break; case '5': //add code here to trigger on 5 triggerPin(outputAddress[5], client, outp); // printHtml(client); break; case '6': //add code here to trigger on 6 triggerPin(outputAddress[6], client, outp); break; case '7': //add code here to trigger on 7 triggerPin(outputAddress[7], client, outp); break; case '8': //add code here to trigger on 8 triggerPin(outputAddress[8], client, outp); break; case '9': // add code here to trigger on 9 triggerPin(outputAddress[9], client, outp); break; case 'A': triggerPin(outputAddress[10], client, outp); break; case 'B': triggerPin(outputAddress[11], client, outp); break; case 'C': triggerPin(outputAddress[12], client, outp); break; case 'D': triggerPin(outputAddress[13], client, outp); break; case 'E': triggerPin(outputAddress[14], client, outp); break; case 'F': triggerPin(outputAddress[15], client, outp); break; case 'G': triggerPin(outputAddress[16], client, outp); break; case 'H': triggerPin(outputAddress[17], client, outp); break; case 'I': triggerPin(outputAddress[18], client, outp); break; case 'J': triggerPin(outputAddress[19], client, outp); break; } //end of switch case }//end of switch switch the relevant output //if user input was blank if (c == '\n' && currentLineIsBlank){ printLastCommandOnce = true; printButtonMenuOnce = true; triggerPin(777, client, outp); //Call to read input and print menu. 777 is used not to update any outputs break; } } } printHtmlFooter(client); //Prints the html footer } else { //if there is no client //And time of last page was served is more then a minute. if (millis() > (timeConnectedAt + 60000)){ if (writeToEeprom == true){ writeEepromValues(); //write to EEprom the current output statuses Serial.println("No Clients for more then a minute - Writing statuses to Eeprom."); writeToEeprom = false; } } } } //////////////////////////////////////////////////////////////////////// //triggerPin Function //////////////////////////////////////////////////////////////////////// // void triggerPin(int pin, EthernetClient client, int outp){ //Switching on or off outputs, reads the outputs and prints the buttons //Setting Outputs if (pin != 777){ if(outp == 1) { if (outputInverted ==false){ digitalWrite(pin, HIGH); } else{ digitalWrite(pin, LOW); } } if(outp == 0){ if (outputInverted ==false){ digitalWrite(pin, LOW); } else{ digitalWrite(pin, HIGH); } } } //Refresh the reading of outputs readOutputStatuses(); //Prints the buttons if (printButtonMenuOnce == true){ printHtmlButtons(client); printButtonMenuOnce = false; } } //////////////////////////////////////////////////////////////////////// //printHtmlButtons Function //////////////////////////////////////////////////////////////////////// //print the html buttons to switch on/off channels void printHtmlButtons(EthernetClient client){ //Start to create the html table client.println(""); //client.println("<p>"); client.println("<FORM>"); client.println("<table border=\"0\" align=\"left\">"); //Start printing button by button for (int var = 0; var < outputQuantity; var++) { //set command for all on/off allOn += "H"; allOn += outputAddress[var]; allOff += "L"; allOff += outputAddress[var]; //Print begining of row client.print("<tr>\n"); //текст кнопок //Prints the button Text client.print("<td><h2>"); client.print(buttonText[var]); client.print("</h2></td>\n"); //Prints the ON Buttons client.print("<td>"); //client.print(buttonText[var]); client.print("<INPUT TYPE=\"button\" VALUE=\"ON "); //client.print(buttonText[var]); client.print("\" onClick=\"parent.location='/?H"); client.print(var); client.print("'\"></td>\n"); //Prints the OFF Buttons client.print(" <td><INPUT TYPE=\"button\" VALUE=\"OFF"); //client.print(var); client.print("\" onClick=\"parent.location='/?L"); client.print(var); client.print("'\"></td>\n"); //Print first part of the Circles or the LEDs //Invert the LED display if output is inverted. if (outputStatus[var] == true ){ //If Output is ON if (outputInverted == false){ //and if output is not inverted client.print(" <td><div class='green-circle'><div class='glare'></div></div></td>\n"); //Print html for ON LED } else{ //else output is inverted then client.print(" <td><div class='black-circle'><div class='glare'></div></div></td>\n"); //Print html for OFF LED } } else //If Output is Off { if (outputInverted == false){ //and if output is not inverted client.print(" <td><div class='black-circle'><div class='glare'></div></div></td>\n"); //Print html for OFF LED } else{ //else output is inverted then client.print(" <td><div class='green-circle'><div class='glare'></div></div></td>\n"); //Print html for ON LED } } //Print end of row client.print("</tr>\n"); } //Display or hide the Print all on Pins Button if (switchOnAllPinsButton == true ){ //Prints the ON All Pins Button client.print("<tr>\n<td><INPUT TYPE=\"button\" VALUE=\"Switch ON All Pins"); client.print("\" onClick=\"parent.location='/?"); client.print(allOn); client.print("'\"></td>\n"); //Prints the OFF All Pins Button client.print("<td><INPUT TYPE=\"button\" VALUE=\"Switch OFF All Pins"); client.print("\" onClick=\"parent.location='/?"); client.print(allOff); client.print("'\"></td>\n<td></td>\n<td></td>\n</tr>\n"); } //Closing the table and form client.println("</table>"); client.println("</FORM>"); //client.println("</p>"); } //////////////////////////////////////////////////////////////////////// //readOutputStatuses Function //////////////////////////////////////////////////////////////////////// //Reading the Output Statuses void readOutputStatuses(){ for (int var = 0; var < outputQuantity; var++) { outputStatus[var] = digitalRead(outputAddress[var]); //Serial.print(outputStatus[var]); } } //////////////////////////////////////////////////////////////////////// //readEepromValues Function //////////////////////////////////////////////////////////////////////// //Read EEprom values and save to outputStatus void readEepromValues(){ for (int adr = 0; adr < outputQuantity; adr++) { outputStatus[adr] = EEPROM.read(adr); } } //////////////////////////////////////////////////////////////////////// //writeEepromValues Function //////////////////////////////////////////////////////////////////////// //Write EEprom values void writeEepromValues(){ for (int adr = 0; adr < outputQuantity; adr++) { EEPROM.write(adr, outputStatus[adr]); } } //////////////////////////////////////////////////////////////////////// //initEepromValues Function //////////////////////////////////////////////////////////////////////// //Initialiaze EEprom values //if eeprom values are not the correct format ie not euqual to 0 or 1 (thus greater then 1) initialize by putting 0 void initEepromValues(){ for (int adr = 0; adr < outputQuantity; adr++){ if (EEPROM.read(adr) > 1){ EEPROM.write(adr, 0); } } } //////////////////////////////////////////////////////////////////////// //htmlHeader Function //////////////////////////////////////////////////////////////////////// //Prints html header void printHtmlHeader(EthernetClient client){ Serial.print("Serving html Headers at ms -"); timeConnectedAt = millis(); //Record the time when last page was served. Serial.print(timeConnectedAt); // Print time for debbugging purposes writeToEeprom = true; // page loaded so set to action the write to eeprom // send a standard http response header client.println("HTTP/1.1 200 OK"); client.println("Content-Type: text/html;charset=UTF-8");//"Content-Type: text/html;charset=UTF-8" client.println("Connnection: close"); client.println(); client.println("<!DOCTYPE HTML>"); client.println("<head>"); // add page title client.println("<title>MajorDomo</title>"); client.println("<meta name=\"description\" content=\"Удаленное управление\"/>"); /* //перзагрузка страницы,рефреш // add a meta refresh tag, so the browser pulls again every x seconds: client.print("<meta http-equiv=\"refresh\" content=\""); client.print(refreshPage); client.println("; url=/\">"); */ // add other browser configuration client.println("<meta name=\"apple-mobile-web-app-capable\" content=\"yes\">"); client.println("<meta name=\"apple-mobile-web-app-status-bar-style\" content=\"default\">"); client.println("<meta name=\"viewport\" content=\"width=device-width, user-scalable=no\">"); //inserting the styles data, usually found in CSS files. client.println("<style type=\"text/css\">"); client.println(""); //This will set how the page will look graphically client.println("html { height:100%; }"); client.println(" body {"); client.println(" height: 100%;"); client.println(" margin: 0;"); client.println(" font-family: helvetica, sans-serif;"); client.println(" -webkit-text-size-adjust: none;"); client.println(" }"); client.println(""); client.println("body {"); client.println(" -webkit-background-size: 100% 21px;"); client.println(" background-color: #c5ccd3;"); client.println(" background-image:"); client.println(" -webkit-gradient(linear, left top, right top,"); client.println(" color-stop(.75, transparent),"); client.println(" color-stop(.75, rgba(255,255,255,.1)) );"); client.println(" -webkit-background-size: 7px;"); client.println(" }"); client.println(""); client.println(".view {"); client.println(" min-height: 100%;"); client.println(" overflow: auto;"); client.println(" }"); client.println(""); client.println(".header-wrapper {"); client.println(" height: 44px;"); client.println(" font-weight: bold;"); client.println(" text-shadow: rgba(0,0,0,0.7) 0 -1px 0;"); client.println(" border-top: solid 1px rgba(255,255,255,0.6);"); client.println(" border-bottom: solid 1px rgba(0,0,0,0.6);"); client.println(" color: #fff;"); client.println(" background-color: #8195af;"); client.println(" background-image:"); client.println(" -webkit-gradient(linear, left top, left bottom,"); client.println(" from(rgba(255,255,255,.4)),"); client.println(" to(rgba(255,255,255,.05)) ),"); client.println(" -webkit-gradient(linear, left top, left bottom,"); client.println(" from(transparent),"); client.println(" to(rgba(0,0,64,.1)) );"); client.println(" background-repeat: no-repeat;"); client.println(" background-position: top left, bottom left;"); client.println(" -webkit-background-size: 100% 21px, 100% 22px;"); client.println(" -webkit-box-sizing: border-box;"); client.println(" }"); client.println(""); client.println(".header-wrapper h1 {"); client.println(" text-align: center;"); client.println(" font-size: 20px;"); client.println(" line-height: 44px;"); client.println(" margin: 0;"); client.println(" }"); client.println(""); client.println(".group-wrapper {"); client.println(" margin: 9px;"); client.println(" }"); client.println(""); client.println(".group-wrapper h2 {"); client.println(" color: #4c566c;"); client.println(" font-size: 17px;"); client.println(" line-height: 0.8;"); client.println(" font-weight: bold;"); client.println(" text-shadow: #fff 0 1px 0;"); client.println(" margin: 20px 10px 12px;"); client.println(" }"); client.println(""); client.println(".group-wrapper h3 {"); client.println(" color: #4c566c;"); client.println(" font-size: 12px;"); client.println(" line-height: 1;"); client.println(" font-weight: bold;"); client.println(" text-shadow: #fff 0 1px 0;"); client.println(" margin: 20px 10px 12px;"); client.println(" }"); client.println(""); client.println(".group-wrapper h4 {"); //Text for description client.println(" color: #212121;"); client.println(" font-size: 14px;"); client.println(" line-height: 1;"); client.println(" font-weight: bold;"); client.println(" text-shadow: #aaa 1px 1px 3px;"); client.println(" margin: 5px 5px 5px;"); client.println(" }"); client.println(""); client.println(".group-wrapper table {"); client.println(" background-color: #fff;"); client.println(" -webkit-border-radius: 10px;"); client.println(" -moz-border-radius: 10px;"); client.println(" -khtml-border-radius: 10px;"); client.println(" border-radius: 10px;"); client.println(" font-size: 20px;"); client.println(" line-height: 20px;"); client.println(" margin: 9px 0 20px;"); client.println(" border: solid 1px #a9abae;"); client.println(" padding: 11px 3px 12px 3px;"); client.println(" margin-left:auto;"); client.println(" margin-right:auto;"); client.println(" -moz-transform :scale(1);"); //Code for Mozilla Firefox client.println(" -moz-transform-origin: 0 0;"); client.println(" }"); client.println(""); //how the green (ON) LED will look client.println(".green-circle {"); client.println(" display: block;"); client.println(" height: 23px;"); client.println(" width: 23px;"); client.println(" background-color: #0f0;"); //client.println(" background-color: rgba(60, 132, 198, 0.8);"); client.println(" -moz-border-radius: 11px;"); client.println(" -webkit-border-radius: 11px;"); client.println(" -khtml-border-radius: 11px;"); client.println(" border-radius: 11px;"); client.println(" margin-left: 1px;"); client.println(" background-image: -webkit-gradient(linear, 0% 0%, 0% 90%, from(rgba(46, 184, 0, 0.8)), to(rgba(148, 255, 112, .9)));@"); client.println(" border: 2px solid #ccc;"); client.println(" -webkit-box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px;"); client.println(" -moz-box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px; /* FF 3.5+ */"); client.println(" box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px; /* FF 3.5+ */"); client.println(" }"); client.println(""); //how the black (off)LED will look client.println(".black-circle {"); client.println(" display: block;"); client.println(" height: 23px;"); client.println(" width: 23px;"); client.println(" background-color: #040;"); client.println(" -moz-border-radius: 11px;"); client.println(" -webkit-border-radius: 11px;"); client.println(" -khtml-border-radius: 11px;"); client.println(" border-radius: 11px;"); client.println(" margin-left: 1px;"); client.println(" -webkit-box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px;"); client.println(" -moz-box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px; /* FF 3.5+ */"); client.println(" box-shadow: rgba(11, 140, 27, 0.5) 0px 10px 16px; /* FF 3.5+ */"); client.println(" }"); client.println(""); //this will add the glare to both of the LEDs client.println(" .glare {"); client.println(" position: relative;"); client.println(" top: 1;"); client.println(" left: 5px;"); client.println(" -webkit-border-radius: 10px;"); client.println(" -moz-border-radius: 10px;"); client.println(" -khtml-border-radius: 10px;"); client.println(" border-radius: 10px;"); client.println(" height: 1px;"); client.println(" width: 13px;"); client.println(" padding: 5px 0;"); client.println(" background-color: rgba(200, 200, 200, 0.25);"); client.println(" background-image: -webkit-gradient(linear, 0% 0%, 0% 95%, from(rgba(255, 255, 255, 0.7)), to(rgba(255, 255, 255, 0)));"); client.println(" }"); client.println(""); //and finally this is the end of the style data and header client.println("</style>"); client.println("</head>"); //now printing the page itself client.println("<body>"); client.println("<div class=\"view\">"); client.println(" <div class=\"header-wrapper\">"); client.println(" <h1>Умный дом</h1>"); client.println(" </div>"); ////// } //end of htmlHeader //////////////////////////////////////////////////////////////////////// //htmlFooter Function //////////////////////////////////////////////////////////////////////// //Prints html footer void printHtmlFooter(EthernetClient client){ //Set Variables Before Exiting printLastCommandOnce = false; printButtonMenuOnce = false; allOn = ""; allOff = ""; /*client.println("\n</div>\n</body>\n</html>"); delay(1); // give the web browser time to receive the data client.stop(); // close the connection: Serial.println(" - Done, Closing Connection."); delay (2); //delay so that it will give time for client buffer to clear and does not repeat multiple pages. */ delay(1); // give the web browser time to receive the data client.stop(); // close the connection: Serial.println(" - Done, Closing Connection."); delay (2); //delay so that it will give time for client buffer to clear and does not repeat multiple pages. } //end of htmlFooter //////////////////////////////////////////////////////////////////////// //printHtmlButtonTitle Function //////////////////////////////////////////////////////////////////////// //Prints html button title void printHtmlButtonTitle(EthernetClient client){ client.println("<div class=\"group-wrapper\">"); client.println(); } //////////////////////////////////////////////////////////////////////// //printLoginTitle Function //////////////////////////////////////////////////////////////////////// //Prints html button title void printLoginTitle(EthernetClient client){ client.println("<div class=\"group-wrapper\">"); client.println(" <h2>Please enter the user data to login.</h2>"); client.println(); }Не надо включать реле 14, надо включать D.
не могу понять как это сделать.
до этого с ардуиной не работал.
могу рассмотреть вариант Вашей помощи на материальной основе
К глобальным переменным прибавляете такую:
char relayIds[outputQuantity] = {'0', '1', ..., '9', 'A', 'B'...}; // Недостающие символы дорисуйте сами
А client.print(var); замените на client.print(relayIds[var]);
Впрочем, всё равно это будет работать плохо, так как неправильно обрабатывается outputAddress[] и outputAddress2[]
А скетч я этот помню... он на интструктейблесе лежал. Что-то там версии 4.0.1 Я в него температуру с DS-ок запихивал по просьбе товарищей. Там еще несколько некорректных конструкций внутри имеется.
Для помощи на материальной основе есть раздел "Ищу исполнителя". Если не будете тянуть, то сразу откликнусь.
При всем моем уважении я постесняюсь продложить Вам копейки. На али готовое *железное*устройство на 16 каналов 500 руб. https://hz.ru.aliexpress.com/item/16-Channel-28J60-W5100-RJ45-Network-Control-Switch-5V-Internet-Relay-Module-5V-DC-Network-Relay/32826476670.html?spm=a2g0s.13010208.99999999.27.12b83c00EOUtnF Завтра оплачу, мегу куда нибудь потом пристрою.. Тему прошу закрыть. Всем спасибо за помощь.
у вас неправильная логика. если вы считаете, что если на Али готовый блок стоит 500. то доработка вашего кода должна быть дешевле. Заказная разработка всегда дороже.
Я сам работаю с кодом в области автомобилей, цену работы умом и руками знаю и ценю.
У меня и в мыслях не было никого обидеть. Было бы время - сам сел бы и разобрался.
Мне тема кода всегда была и будет интересна. Просто если есть готовое устройство которое будет включать у меня на даче свет, ,боилер, электро_теплый пол и прочее когда я буду в любой точке мира и это все за 500 рублей. Дома и так все работает на Sonoff, теперь очередь дачи.
Я и сам за копейки не работаю и Вам мизерную оплату мне предлагать стыдно.
С уважением.Дмитрий.
https://www.youtube.com/watch?v=LwDDEIx63cA
За 500рублей скорее всего не получится - исполнительные устройства будут стоить дороже. А реальные проекты такого посмотри в разделе "проекты". Там народ решает подобные задачи и бесплатно раздает их нам.
lДобрый вечер. Спасибо за видео. Очень познавательно.
По поводу исполнительных устройств - их цена на али -копейки.
На предыдущий проект брал на али 40 амперные Твердотельные реле под силовую нагрузку+радиатор по 500 рублей,материнку под проект MajorDoMo снял с автосканера Faw ( индустриальная плата мини пк на Intel Atom) он все равно валялся без дела, старий tp-link 1043(с прошивкой OpenWrt) достал с полки.
Купил по мелочи на али разные побрякушки от Sonoff сенсорные Wi-fi выключатели, реле. бюджет всего купленного пока не превысил 5000 рублей. За работу мне никому платить не нужно.
Штука интересная (теоретически). На борту ENC28J60, а не W5100 и какой-то STM8 (не могу рассмотреть модель). Вот картинки покрупнее: https://www.aliexpress.com/item/8-Channel-ENC28J60-28J60-W5100-RJ45-Network-Relay-Control-Switch-5V-Internet-Relay-Module-P2P-WIFI/32958288720.html
Вроде даже разъем программирования выведен на плату, так что любители СТМ-ок могут получить для экспериментов готовый модуль с сетью.
P.S. Судя по всему на одной плате собираются 8-relay module и 16-relay module. Так что по старой китайской тридиции ляовай может получить не W5100 / 16 outputs, а вполне себе Brand new ENC28J60 / 8 outputs. Причём, выходы, видимо, будут с TTL 3.3V
P.P.S. Удалось сыскать брата на W5100, но только в музее: https://wiznetmuseum.com/portfolio-items/w5100-network-relay-control-module-weiba/?portfolioID=10935 . Партномер FC-188, МК Nuvoton. Думал, что хоть там будет ATMega, которую можно приспособить под свои нужды...
На фотографии там STM8005C6T6. Но придти может и с Nuvoton-ом каким-нибудь. Я пытался вольтметры с STM8 заказать. На фотках ясно было видно STM8, а пришли все (у 3-х продавцов заказывал) с Nuvoton-ами
Что-то гугел про STM8005C6T6 ничего не знает. Я у нескольких продавцов вглядывался в мутнофотки... То ли 005, то ли 003... Но, так как не разбираюсь в СТМ-ках - ничего так и не выглядел.
S пропустил - STM8S005C6T6
https://www.st.com/en/microcontrollers/stm8s005c6.html
Mожет кому-то поможет.Mне помогло в понимании кода http://startingelectronics.org/tutorials/arduino/arduino-MEGA-24-output-web-server/
Лучше про девайс с алиэкспресс поведайте - чего он и как.
девайс уже оплачен и покинул китай . едет почтой финляндии . как приедет - протестирую и отпишусь в этой теме.
Posti Finland.. ждем в гости через месяц ))
посылку получил. работает стабильно. питание платы 5 вольт. 16 каналов выходных. управляемый выход 3.3 вольта положительной полярности.
МК - STM? Какие буквы написаны на ём?
