NodeMCU и Telegram
Пнд, 07/03/2022 - 21:44
Добрый вечер!! помогите изменить код, на просторах нашел рабочий код, но не могу его переделать на работу с массивом CHAT_ID.
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include <UniversalTelegramBot.h>
// Wifi network station credentials
#define WIFI_SSID "xxx"
#define WIFI_PASSWORD "xxx"
// Telegram BOT Token (Get from Botfather)
#define BOT_TOKEN "xxx"
const unsigned long BOT_MTBS = 1000; // mean time between scan messages
X509List cert(TELEGRAM_CERTIFICATE_ROOT);
WiFiClientSecure secured_client;
UniversalTelegramBot bot(BOT_TOKEN, secured_client);
unsigned long bot_lasttime; // last time messages' scan has been done
const int ledPin = LED_BUILTIN;
int ledStatus = 0;
void handleNewMessages(int numNewMessages)
Serial.print("handleNewMessages ");
Serial.println(numNewMessages);
for (int i = 0; i < numNewMessages; i++)
String chat_id = bot.messages[i].chat_id;
String text = bot.messages[i].text;
String from_name = bot.messages[i].from_name;
if (from_name == "")
from_name = "Guest";
if (text == "/ledon")
digitalWrite(ledPin, LOW); // turn the LED on (HIGH is the voltage level)
ledStatus = 1;
bot.sendMessage(chat_id, "Led is ON", "");
if (text == "/ledoff")
ledStatus = 0;
digitalWrite(ledPin, HIGH); // turn the LED off (LOW is the voltage level)
bot.sendMessage(chat_id, "Led is OFF", "");
if (text == "/status")
if (ledStatus)
if (text == "/start")
String welcome = "Welcome to Universal Arduino Telegram Bot library, " + from_name + ".\n";
welcome += "This is Flash Led Bot example.\n\n";
welcome += "/ledon : to switch the Led ON\n";
welcome += "/ledoff : to switch the Led OFF\n";
welcome += "/status : Returns current status of LED\n";
bot.sendMessage(chat_id, welcome, "Markdown");
Serial.begin(115200);
Serial.println();
pinMode(ledPin, OUTPUT); // initialize digital ledPin as an output.
delay(10);
digitalWrite(ledPin, HIGH); // initialize pin as off (active LOW)
// attempt to connect to Wifi network:
configTime(0, 0, "pool.ntp.org"); // get UTC time via NTP
secured_client.setTrustAnchors(&cert); // Add root certificate for api.telegram.org
Serial.print("Connecting to Wifi SSID ");
Serial.print(WIFI_SSID);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
delay(500);
Serial.print("\nWiFi connected. IP address: ");
Serial.println(WiFi.localIP());
// Check NTP/Time, usually it is instantaneous and you can delete the code below.
Serial.print("Retrieving time: ");
time_t now = time(nullptr);
while (now < 24 * 3600)
Serial.print(".");
delay(100);
Serial.println(now);
if (millis() - bot_lasttime > BOT_MTBS)
int numNewMessages = bot.getUpdates(bot.last_message_received + 1);
while (numNewMessages)
Serial.println("got response");
handleNewMessages(numNewMessages);
bot_lasttime = millis();
вы прям так уверены. что любой знает, где тут должен быть этот массив?
отсюда пытаюсь взять строки https://randomnerdtutorials.com/telegram-control-esp32-esp8266-nodemcu-outputs/
#include <ESP8266WiFi.h> #include <WiFiClientSecure.h> #include <UniversalTelegramBot.h> // Wifi network station credentials #define WIFI_SSID "D9" #define WIFI_PASSWORD "хххх" // Telegram BOT Token (Get from Botfather) #define BOT_TOKEN "хххх" #define CHAT_ID "XXXXXXXXXX" const unsigned long BOT_MTBS = 1000; // mean time between scan messages X509List cert(TELEGRAM_CERTIFICATE_ROOT); WiFiClientSecure secured_client; UniversalTelegramBot bot(BOT_TOKEN, secured_client); unsigned long bot_lasttime; // last time messages' scan has been done const int ledPin = LED_BUILTIN; int ledStatus = 0; void handleNewMessages(int numNewMessages) { Serial.print("handleNewMessages "); Serial.println(numNewMessages); for (int i = 0; i < numNewMessages; i++) { String chat_id = String(bot.messages[i].chat_id); if (chat_id != CHAT_ID){ bot.sendMessage(chat_id, "Unauthorized user", ""); continue; String from_name = bot.messages[i].from_name; if (from_name == "") from_name = "Guest"; if (text == "/ledon") { digitalWrite(ledPin, LOW); // turn the LED on (HIGH is the voltage level) ledStatus = 1; bot.sendMessage(chat_id, "Led is ON", ""); } if (text == "/ledoff") { ledStatus = 0; digitalWrite(ledPin, HIGH); // turn the LED off (LOW is the voltage level) bot.sendMessage(chat_id, "Led is OFF", ""); } if (text == "/status") { if (ledStatus) { bot.sendMessage(chat_id, "Led is ON", ""); } else { bot.sendMessage(chat_id, "Led is OFF", ""); } } if (text == "/start") { String welcome = "Welcome to Universal Arduino Telegram Bot library, " + from_name + ".\n"; welcome += "This is Flash Led Bot example.\n\n"; welcome += "/ledon : to switch the Led ON\n"; welcome += "/ledoff : to switch the Led OFF\n"; welcome += "/status : Returns current status of LED\n"; bot.sendMessage(chat_id, welcome, "Markdown"); } } } void setup() { Serial.begin(115200); Serial.println(); pinMode(ledPin, OUTPUT); // initialize digital ledPin as an output. delay(10); digitalWrite(ledPin, HIGH); // initialize pin as off (active LOW) // attempt to connect to Wifi network: configTime(0, 0, "pool.ntp.org"); // get UTC time via NTP secured_client.setTrustAnchors(&cert); // Add root certificate for api.telegram.org Serial.print("Connecting to Wifi SSID "); Serial.print(WIFI_SSID); WiFi.begin(WIFI_SSID, WIFI_PASSWORD); while (WiFi.status() != WL_CONNECTED) { Serial.print("."); delay(500); } Serial.print("\nWiFi connected. IP address: "); Serial.println(WiFi.localIP()); // Check NTP/Time, usually it is instantaneous and you can delete the code below. Serial.print("Retrieving time: "); time_t now = time(nullptr); while (now < 24 * 3600) { Serial.print("."); delay(100); now = time(nullptr); } Serial.println(now); } void loop() { if (millis() - bot_lasttime > BOT_MTBS) { int numNewMessages = bot.getUpdates(bot.last_message_received + 1); while (numNewMessages) { Serial.println("got response"); handleNewMessages(numNewMessages); numNewMessages = bot.getUpdates(bot.last_message_received + 1); } bot_lasttime = millis(); } }всегда цитируйте сообщение об ошибках ПОЛНОСТЬЮ!
Строка 028 кода из первого поста потеряна в коде из #3
От этого ошибка. Дальше не смотрел.
Все получилось спасибо, еще вопросик а как добавить несколько CHAT_ID???
