нужна помощь с по работе OLED 1.3
Сб, 16/03/2019 - 12:51
здравствуйте. собирал маленькое устройство, но столкнулся с проблемой некорректной работы экранов на 1.3 дюйма. при оновлении температуры на дисплее изображение смещается кусками, иногда даже не прочитать температуру.
/* PrintTest.pde How to use the base class "Print" >>> Before compiling: Please remove comment from the constructor of the >>> connected graphics display (see below). Universal 8bit Graphics Library, https://github.com/olikraus/u8glib/ Copyright (c) 2012, olikraus@gmail.com All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met: * Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer. * Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution. THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #include "U8glib.h" // setup u8g object, please remove comment from one of the following constructor calls // IMPORTANT NOTE: The following list is incomplete. The complete list of supported // devices with all constructor calls is here: https://github.com/olikraus/u8glib/wiki/device //U8GLIB_SSD1306_128X64 u8g(10, 9); // HW SPI Com: CS = 10, A0 = 9 (Hardware Pins are SCK = 13 and MOSI = 11) U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE|U8G_I2C_OPT_DEV_0); // I2C / TWI //U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_DEV_0|U8G_I2C_OPT_NO_ACK|U8G_I2C_OPT_FAST); // Fast I2C / TWI #include <OneWire.h> #include <DallasTemperature.h> #define ONE_WIRE_BUS 8 // номер пина к которому подключен DS18B20 OneWire oneWire(ONE_WIRE_BUS); DallasTemperature sensors(&oneWire); void draw(void) { // graphic commands to redraw the complete screen should be placed here sensors.requestTemperatures(); u8g.setFont(u8g_font_helvR08); u8g.setPrintPos(36, 15); // call procedure from base class, http://arduino.cc/en/Serial/Print u8g.print("OUT TEMP"); u8g.setFont(u8g_font_fub25); u8g.setPrintPos(35, 50); // call procedure from base class, http://arduino.cc/en/Serial/Print u8g.print(String(sensors.getTempCByIndex(0) , 1)); u8g.setFont(u8g_font_helvR08); u8g.setPrintPos(33, 62); u8g.print("CHERY A13"); } void setup(void) { // flip screen, if required // u8g.setRot180(); sensors.begin(); } void loop(void) { // picture loop u8g.firstPage(); do { draw(); } while( u8g.nextPage() ); // rebuild the picture after some delay delay(500); }
Ни схемы, ни фото нет, но остатки кофейной гущи в кружке показывают, что вроде подтягивающие резисторы на линии I2C отсутствуют.
Попробуйте другую библиотеку - adafruit, например. Возможно корень зла в этом, но точно покажет только экспиримент.
до этого был другой дисплей, он работал спокойно с библиотекой OLED_I2C. но он разбился. заказал другие у того же продавца. а они с этой библиотекой отказались работать. видимо чипы разные. фот хотел скинуть, но не знаю как. сейчас пробую библиотеку AZOLED. с ней все прекрасно вроде работает, но не могу увеличить размер цифр.
Вы прочитали моё сообщени #1?
Запросто может оказаться, что на том дисплее резисторы уже были распаяны на модуле, а на этом - нет.
Просто неодинаковые и "когдапопальные" глюки со смещением - очень похоже.
все резисторы стоят. ради интереса подключил тот дисплей, на котором все изначально работало. в итоге он работает с этой библиотекой. то есть он работает и с библиотекой под 0.96 и под 1.3 дюйма. а новые экранчики работают только с библиатеками под 1.3. но обсалютно все экраны тормозят с библиотеками под 1.3 дюйма.
