Ошибка компеляции
Чт, 19/09/2019 - 14:21
При компиляции вылетает вот такая ошибка
(.text+0x0): multiple definition of `Udp'
никак не могу понять почему.
сечас работает сборка ethernet с tcp SNMP , есть необходимость настроить UDP NTP
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <Agentuino.h>
#include <SPI.h>
float temp2 = 0;
float temp3 = 0;
float temp4 = 0;
float temp5 = 0;
const char reg= "C"; //C=Temperature in Centigrade, F=Temperature in Farenheight
static byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //Mac Address for Arduino Ethernet Shield
static byte ip[] = { 192, 168, 111, 33 }; //IP Address for Arduino Ethernet Shield
static byte gateway[] = { 192, 168, 111, 1 };
static byte subnet[] = { 255, 255, 255, 0 };
int term2=0;
int term3=0;
int term4=0;
int term5=0;
unsigned int localPort = 8647;
IPAddress timeServer(132, 163, 4, 101); // NTP-сервер time-a.timefreq.bldrdoc.gov
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
EthernetUDP Udp;
const int timeZone PROGMEM = 3; // TimeZone
const char sysDescr[] PROGMEM = "1.3.6.1.2.1.1.1.0"; // System Description
const char sysContact[] PROGMEM = "1.3.6.1.2.1.1.4.0"; // System Contact
const char sysName[] PROGMEM = "1.3.6.1.2.1.1.5.0"; // System Name
const char sysLocation[] PROGMEM = "1.3.6.1.2.1.1.6.0"; // System Location
const char sysServices[] PROGMEM = "1.3.6.1.2.1.1.7.0"; // System Services
//My Custom OID's
const char temperature2[] PROGMEM = "1.3.6.1.3.2016.5.0.2"; //Temperature in Celsius
const char temperature3[] PROGMEM = "1.3.6.1.3.2016.5.0.3"; //Temperature in Celsius
const char temperature4[] PROGMEM = "1.3.6.1.3.2016.5.0.4"; //Temperature in Celsius
const char temperature5[] PROGMEM = "1.3.6.1.3.2016.5.0.5"; //Temperature in Celsius
// RFC1213 local values
static char locDescr[] = "SNMP Temperature monitoring"; // read-only (static)
static char locContact[50] = "radio-portal.ru";
static char locName[20] = "ServerRoom";
static char locLocation[20] = "Planet Earth";
static int32_t locServices = 2; // read-only (static)
uint32_t prevMillis = millis();
char oid[SNMP_MAX_OID_LEN];
SNMP_API_STAT_CODES api_status;
SNMP_ERR_CODES status;
void pduReceived()
SNMP_PDU pdu;
api_status = Agentuino.requestPdu(&pdu);
if ((pdu.type == SNMP_PDU_GET || pdu.type == SNMP_PDU_GET_NEXT || pdu.type == SNMP_PDU_SET)
&& pdu.error == SNMP_ERR_NO_ERROR && api_status == SNMP_API_STAT_SUCCESS ) {
pdu.OID.toString(oid);
if ( strcmp_P(oid, sysDescr ) == 0 ) {
if ( pdu.type == SNMP_PDU_SET ) {
pdu.type = SNMP_PDU_RESPONSE;
pdu.error = SNMP_ERR_READ_ONLY;
} else {
status = pdu.VALUE.encode(SNMP_SYNTAX_OCTETS, locDescr);
pdu.error = status;
} else if ( strcmp_P(oid, sysName ) == 0 ) {
status = pdu.VALUE.decode(locName, strlen(locName));
pdu.error = status;
} else {
status = pdu.VALUE.encode(SNMP_SYNTAX_OCTETS, locName);
pdu.error = status;
} else if ( strcmp_P(oid, sysContact ) == 0 ) {
status = pdu.VALUE.decode(locContact, strlen(locContact));
pdu.error = status;
} else {
status = pdu.VALUE.encode(SNMP_SYNTAX_OCTETS, locContact);
pdu.error = status;
} else if ( strcmp_P(oid, sysLocation ) == 0 ) {
status = pdu.VALUE.decode(locLocation, strlen(locLocation));
pdu.error = status;
} else {
status = pdu.VALUE.encode(SNMP_SYNTAX_OCTETS, locLocation);
pdu.error = status;
} else if ( strcmp_P(oid, sysServices) == 0 ) {
} else {
status = pdu.VALUE.encode(SNMP_SYNTAX_INT, locServices);
pdu.error = status;
else if ( strcmp_P(oid, temperature2 ) == 0 )
status = pdu.VALUE.encode(SNMP_SYNTAX_INT, term2);
pdu.error = status;
else if ( strcmp_P(oid, temperature3 ) == 0 )
status = pdu.VALUE.encode(SNMP_SYNTAX_INT, term3);
pdu.error = status;
else if ( strcmp_P(oid, temperature4 ) == 0 )
status = pdu.VALUE.encode(SNMP_SYNTAX_INT, term4);
pdu.error = status;
else if ( strcmp_P(oid, temperature5 ) == 0 )
status = pdu.VALUE.encode(SNMP_SYNTAX_INT, term5);
pdu.error = status;
else {
pdu.error = SNMP_ERR_NO_SUCH_NAME;
Agentuino.responsePdu(&pdu);
Agentuino.freePdu(&pdu);
Ethernet.begin(mac); //Initialize Ethernet Shield
api_status = Agentuino.begin(); //Begin Snmp agent on Ethernet shield
if ( api_status == SNMP_API_STAT_SUCCESS ) {
Agentuino.onPduReceive(pduReceived);
delay(10);
return;
Udp.begin(localPort);
Agentuino.listen();
float kPinTemp2 = analogRead(2);
float kPinTemp3 = analogRead(3);
float kPinTemp4 = analogRead(4);
float kPinTemp5 = analogRead(5);
float terme2=( kPinTemp2/1023.0 )*5.0*1000/10;
float terme3=( kPinTemp3/1023.0 )*5.0*1000/10;
float terme4=( kPinTemp4/1023.0 )*5.0*1000/10;
float terme5=( kPinTemp5/1023.0 )*5.0*1000/10;
if ( reg == "F" ) {
float terme2=((terme2 ) * 9.0 / 5.0) + 32.0;
float terme3=((terme3 ) * 9.0 / 5.0) + 32.0;
float terme4=((terme4 ) * 9.0 / 5.0) + 32.0;
float terme5=((terme5 ) * 9.0 / 5.0) + 32.0;
term2=(int)terme2;
term3=(int)terme3;
term4=(int)terme4;
term5=(int)terme5;
sendNTPpacket(timeServer); // Отсылаем время-серверу NTP-пакет
// Ждем, чтобы увидеть, доступен ли ответ:
if ( Udp.parsePacket() ) {
// Пакет получен, значит считываем данные оттуда:
Udp.read(packetBuffer,NTP_PACKET_SIZE); // считываем содержимое пакета в буфер
// Временная отметка начинается с 40 байта полученного пакета
// и его длина составляет четыре байта или два слова.
// Для начала извлекаем два этих слова:
unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
// Совмещаем четыре байта (два слова) в длинное целое.
// Это и будет NTP-временем (секунды начиная с 1 января 1990 года):
unsigned long secsSince1900 = highWord << 16 | lowWord;
Serial.print("Seconds since Jan 1 1900 = " ); // "Секунды, прошедшие с 1 января 1990 = "
Serial.println(secsSince1900);
// Теперь конвертируем NTP-время в обычное время:
Serial.print("Unix time = "); // "Unix-время = "
// Время Unix стартует с 1 января 1970 года. В секундах это 2208988800:
const unsigned long seventyYears = 2208988800UL;
// Вычитаем 70 лет:
unsigned long epoch = secsSince1900 - seventyYears;
// Выводим на Serial Monitor Unix-время:
Serial.println(epoch);
// Выводим на Serial Monitor информацию о часах, минутах и секундах:
Serial.print("The UTC time is "); // "Среднее время по Гринвичу = ", // UTC – это среднее время по Гринвичу (GMT):
Serial.print((epoch % 86400L) / 3600); // выводим часы (86400 эквивалентно количеству секунд в день):
Serial.print(':');
if ( ((epoch % 3600) / 60) < 10 ) {
// У первых десяти минут каждого часа должна спереди стоять цифра «0»:
Serial.print('0');
Serial.print((epoch % 3600) / 60); // выводим минуты (3600 эквивалентно количеству секунд в минуте):
Serial.print(':');
if ( (epoch % 60) < 10 ) {
// У первых десяти секунд каждой минуты спереди должна стоять цифра «0»:
Serial.print('0');
Serial.println(epoch %60); // выводим секунды
// Ждем 10 секунд перед новым запросом о времени:
delay(10000);
// Отправляем NTP-запрос к время-серверу по указанному адресу:
unsigned long sendNTPpacket(IPAddress& address)
// Отправляем все байты (вплоть до 0-ого) в буфер:
memset(packetBuffer, 0, NTP_PACKET_SIZE);
// Инициализируем значения, необходимые для формирования NTP-запроса
// (подробнее о пакетах см. в URL выше):
packetBuffer[0] = 0b11100011; // LI (leap indicator, т.е. «индикатор перехода»), версия, режим работы
packetBuffer[1] = 0; // слой (или тип часов)
packetBuffer[2] = 6; // интервал запросов
packetBuffer[3] = 0xEC; // точность
// 8 байтов с нулями, обозначающие базовую задержку и базовую дисперсию
packetBuffer[12] = 49;
packetBuffer[13] = 0x4E;
packetBuffer[14] = 49;
packetBuffer[15] = 52;
// После заполнения всех указанных полей
// вы сможете отправлять пакет с запросом о временной метке:
Udp.beginPacket(address, 123); // NTP-запрос идет на порт 123
Udp.write(packetBuffer,NTP_PACKET_SIZE);
Udp.endPacket();
а аффтар чо говорит?
что такое аффтар?
Вы, простите за нескромный вопрос, какой религии придерживаетесь?
своей собсвенной
Понятно. Значит, это Ваша собственная религия запрещает Вам:
1) публиковать сообщения об ошибках полностью, копипастом
2) давать ссылки на те библиотеки, которые используете, т.к. их полно одноимённых.
Да, кстати, "аффтар" - это тот, кто написал этот код. Вас спросили почему Вы обращаетесь к нам, а не к нему.
Я автор этого кода (ну по кране мере той части которая работает), часть которая не компелится взята из примера, и отдельно она тоже работает
C:\Users\Doc\AppData\Local\Temp\arduino_build_756449\libraries\Agentuino-master\Agentuino.cpp.o (symbol from plugin): In function `Udp':
C:\Users\Doc\AppData\Local\Temp\arduino_build_756449\sketch\sketch_sep14av5.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
Используем библиотеку Ethernet версии 2.0.0 из папки: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\Ethernet
Используем библиотеку Agentuino-master в папке: D:\YandexDisk\Документы\ITG\Arduino\libraries\Agentuino-master (legacy)
Используем библиотеку SPI версии 1.0 из папки: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\libraries\SPI
exit status 1
Ошибка компиляции для платы Arduino/Genuino Uno.
имя Udp уже используется в библиотеке, просто выберите другое
что такое аффтар?
Как так: "аффтар" не знаешь, а "компЕляция" знаешь? Решительно не понимаю! Непоследовательность не красит джентльмена.
Ну, дать ссылки на библиотеки религия таки не позволила.
А что касается сообщения, то что именно в нём Вам непонятно?
Это означает, что переменная Udp определена в Вашем коде (строка №26) и в библиотеке Agentuino. Не знаю какая у Вас библиотека (это, видимо, секретно), но если вот эта, то в строке №28. Система видит две одинаковые переменные и не понимает какую использовать.
Я автор этого кода
Мне пофиг, но поверить в это не могу. У автора этого кода не может быть проблемы с которой Вы сюда пришили. Вернее, возникнуть такая ситуация может, но проблемой для автора этого кода она стать не может.
Я автор этого кода
Евгений, он же скромно написал, что автор только той части. что работает :) Сначала он написал свой код:
void setup() { } void loop() {}и он работал!
А потом добавил чужую глючную библиотеку и понеслось...
Я автор этого кода
смешно....
работает вот это
#include <EthernetUdp.h> #include <Ethernet.h> #include <Agentuino.h> #include <SPI.h> #include <Flash.h> float temp2 = 0; float temp3 = 0; float temp4 = 0; float temp5 = 0; const char reg= "C"; //C=Temperature in Centigrade, F=Temperature in Farenheight static byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //Mac Address for Arduino Ethernet Shield static byte ip[] = { 192, 168, 111, 33 }; //IP Address for Arduino Ethernet Shield static byte gateway[] = { 192, 168, 111, 1 }; static byte subnet[] = { 255, 255, 255, 0 }; int term2=0; int term3=0; int term4=0; int term5=0; const char sysDescr[] PROGMEM = "1.3.6.1.2.1.1.1.0"; // System Description const char sysContact[] PROGMEM = "1.3.6.1.2.1.1.4.0"; // System Contact const char sysName[] PROGMEM = "1.3.6.1.2.1.1.5.0"; // System Name const char sysLocation[] PROGMEM = "1.3.6.1.2.1.1.6.0"; // System Location const char sysServices[] PROGMEM = "1.3.6.1.2.1.1.7.0"; // System Services //My Custom OID's const char temperature2[] PROGMEM = "1.3.6.1.3.2016.5.0.2"; //Temperature in Celsius const char temperature3[] PROGMEM = "1.3.6.1.3.2016.5.0.3"; //Temperature in Celsius const char temperature4[] PROGMEM = "1.3.6.1.3.2016.5.0.4"; //Temperature in Celsius const char temperature5[] PROGMEM = "1.3.6.1.3.2016.5.0.5"; //Temperature in Celsius // RFC1213 local values static char locDescr[] = "SNMP Temperature monitoring"; // read-only (static) static char locContact[50] = "radio-portal.ru"; static char locName[20] = "ServerRoom"; static char locLocation[20] = "Planet Earth"; static int32_t locServices = 2; // read-only (static) uint32_t prevMillis = millis(); char oid[SNMP_MAX_OID_LEN]; SNMP_API_STAT_CODES api_status; SNMP_ERR_CODES status; void pduReceived() { SNMP_PDU pdu; api_status = Agentuino.requestPdu(&pdu); if ((pdu.type == SNMP_PDU_GET || pdu.type == SNMP_PDU_GET_NEXT || pdu.type == SNMP_PDU_SET) && pdu.error == SNMP_ERR_NO_ERROR && api_status == SNMP_API_STAT_SUCCESS ) { pdu.OID.toString(oid); if ( strcmp_P(oid, sysDescr ) == 0 ) { if ( pdu.type == SNMP_PDU_SET ) { pdu.type = SNMP_PDU_RESPONSE; pdu.error = SNMP_ERR_READ_ONLY; } else { status = pdu.VALUE.encode(SNMP_SYNTAX_OCTETS, locDescr); pdu.type = SNMP_PDU_RESPONSE; pdu.error = status; } } else if ( strcmp_P(oid, sysName ) == 0 ) { if ( pdu.type == SNMP_PDU_SET ) { status = pdu.VALUE.decode(locName, strlen(locName)); pdu.type = SNMP_PDU_RESPONSE; pdu.error = status; } else { status = pdu.VALUE.encode(SNMP_SYNTAX_OCTETS, locName); pdu.type = SNMP_PDU_RESPONSE; pdu.error = status; } } else if ( strcmp_P(oid, sysContact ) == 0 ) { if ( pdu.type == SNMP_PDU_SET ) { status = pdu.VALUE.decode(locContact, strlen(locContact)); pdu.type = SNMP_PDU_RESPONSE; pdu.error = status; } else { status = pdu.VALUE.encode(SNMP_SYNTAX_OCTETS, locContact); pdu.type = SNMP_PDU_RESPONSE; pdu.error = status; } } else if ( strcmp_P(oid, sysLocation ) == 0 ) { if ( pdu.type == SNMP_PDU_SET ) { status = pdu.VALUE.decode(locLocation, strlen(locLocation)); pdu.type = SNMP_PDU_RESPONSE; pdu.error = status; } else { status = pdu.VALUE.encode(SNMP_SYNTAX_OCTETS, locLocation); pdu.type = SNMP_PDU_RESPONSE; pdu.error = status; } } else if ( strcmp_P(oid, sysServices) == 0 ) { if ( pdu.type == SNMP_PDU_SET ) { pdu.type = SNMP_PDU_RESPONSE; pdu.error = SNMP_ERR_READ_ONLY; } else { status = pdu.VALUE.encode(SNMP_SYNTAX_INT, locServices); pdu.type = SNMP_PDU_RESPONSE; pdu.error = status; } } else if ( strcmp_P(oid, temperature2 ) == 0 ) { if ( pdu.type == SNMP_PDU_SET ) { pdu.type = SNMP_PDU_RESPONSE; pdu.error = SNMP_ERR_READ_ONLY; } else { status = pdu.VALUE.encode(SNMP_SYNTAX_INT, term2); pdu.type = SNMP_PDU_RESPONSE; pdu.error = status; } } else if ( strcmp_P(oid, temperature3 ) == 0 ) { if ( pdu.type == SNMP_PDU_SET ) { pdu.type = SNMP_PDU_RESPONSE; pdu.error = SNMP_ERR_READ_ONLY; } else { status = pdu.VALUE.encode(SNMP_SYNTAX_INT, term3); pdu.type = SNMP_PDU_RESPONSE; pdu.error = status; } } else if ( strcmp_P(oid, temperature4 ) == 0 ) { if ( pdu.type == SNMP_PDU_SET ) { pdu.type = SNMP_PDU_RESPONSE; pdu.error = SNMP_ERR_READ_ONLY; } else { status = pdu.VALUE.encode(SNMP_SYNTAX_INT, term4); pdu.type = SNMP_PDU_RESPONSE; pdu.error = status; } } else if ( strcmp_P(oid, temperature5 ) == 0 ) { if ( pdu.type == SNMP_PDU_SET ) { pdu.type = SNMP_PDU_RESPONSE; pdu.error = SNMP_ERR_READ_ONLY; } else { status = pdu.VALUE.encode(SNMP_SYNTAX_INT, term5); pdu.type = SNMP_PDU_RESPONSE; pdu.error = status; } } else { pdu.type = SNMP_PDU_RESPONSE; pdu.error = SNMP_ERR_NO_SUCH_NAME; } Agentuino.responsePdu(&pdu); } Agentuino.freePdu(&pdu); } void setup() { Ethernet.begin(mac); //Initialize Ethernet Shield api_status = Agentuino.begin(); //Begin Snmp agent on Ethernet shield if ( api_status == SNMP_API_STAT_SUCCESS ) { Agentuino.onPduReceive(pduReceived); delay(10); return; } delay(10); } void loop() { Agentuino.listen(); float kPinTemp2 = analogRead(2); float kPinTemp3 = analogRead(3); float kPinTemp4 = analogRead(4); float kPinTemp5 = analogRead(5); float terme2=( kPinTemp2/1023.0 )*5.0*1000/10; float terme3=( kPinTemp3/1023.0 )*5.0*1000/10; float terme4=( kPinTemp4/1023.0 )*5.0*1000/10; float terme5=( kPinTemp5/1023.0 )*5.0*1000/10; if ( reg == "F" ) { float terme2=((terme2 ) * 9.0 / 5.0) + 32.0; float terme3=((terme3 ) * 9.0 / 5.0) + 32.0; float terme4=((terme4 ) * 9.0 / 5.0) + 32.0; float terme5=((terme5 ) * 9.0 / 5.0) + 32.0; } term2=(int)terme2; term3=(int)terme3; term4=(int)terme4; term5=(int)terme5; }а вот инициализировать одновременно UDP c TCP никак не выходит
как только включается UDP tcp перестает работать
Сделай доброе дело, сообщение отредактируй и вставь код правильно, а то модеры код просто сотрут.
Ардуиновская Ethernet.h очень... учебная. Функции, обслуживающие любой из протоколов (UDP | TCP) периодически пытаются захватить все не-CLOSED сокеты. Поэтому предсказуемость результата, при смешивании функционала из обоих классов, отсутствует.
Не зная элементарного английского, или не зная ссылки на гугл транслейтер нет смысла учиться программировать. Double definition должно о чём-то говорить. Если не говорит - в сад.
И не зная, что такое definition - ещё более в сад.
И вообще в сад! Там зимние сорта яблок поспевать норовят, надо собирать и варенье, джемы, повидло. Ой, повидло вообще обожаю!
Неужели и в голову не пришло открыть translate.google.com (к примеру) и почитать что он там на перевоздил? Или это типа очень сложно, много букафф, пусть лучше другие этим занимаются?
У нас в этом году яблок почти нет, увы.
