падение esp8266 при попытке генерации qrcode в html
Втр, 16/08/2022 - 14:22
Добрый день.
Библиотека #include "qrcode.h"
Часть генерации кода:
Ошибка в консоли:
12:13:09.565 -> AP IP address: 192.168.4.1
12:13:09.565 -> HTTP server started
12:13:09.610 -> A8:48:FA:FF:25:A3
12:13:09.610 -> LOWLOWLOWLOWLOWLOWLOWLOWLOWLOWLOWLOWLOWLOWLOWLOWLOWLOWLOWLOWLOWLOWLOWLOWLOW
12:13:33.583 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
12:13:33.629 ->
12:13:33.629 -> Exception (3):
12:13:33.629 -> epc1=0x4000bf64 epc2=0x00000000 epc3=0x00000000 excvaddr=0x40240d31 depc=0x00000000
12:13:33.765 ->
12:13:33.765 -> >>>stack>>>
12:13:33.765 ->
12:13:33.765 -> ctx: cont
12:13:33.765 -> sp: 3ffffce0 end: 3fffffc0 offset: 0190
12:13:33.811 -> 3ffffe70: 3ffee6c4 00000000 3ffee6a0 000002e6
12:13:33.858 -> 3ffffe80: 40240d31 3ffee7a0 3ffffecc 40206f93
12:13:33.904 -> 3ffffe90: 40240d31 3ffee7a0 3ffffecc 40207601
12:13:33.995 -> 3ffffea0: 00000000 69746365 00000000 3ffee978
12:13:33.995 -> 3ffffeb0: 3fffdad0 00000001 3fff00c4 402037e0
12:13:34.087 -> 3ffffec0: 3ffee6e8 3ffefd20 00000000 3fff07d4
12:13:34.133 -> 3ffffed0: 000002ef 80000000 3ffee800 3ffee978
12:13:34.179 -> 3ffffee0: 3fffdad0 3ffee6e8 3fff00c4 40209daa
12:13:34.225 -> 3ffffef0: 00000000 00000000 00000000 401000e9
12:13:34.272 -> 3fffff00: 00000000 00000000 3ffee6a0 40201bc9
12:13:34.364 -> 3fffff10: 00000000 3ffee6e8 3ffee6a0 40203704
12:13:34.364 -> 3fffff20: 00000000 00000000 00000000 69746365
12:13:34.458 -> 3fffff30: 00000000 0011001f 401002bd 00000000
12:13:34.503 -> 3fffff40: 0000656c 00000000 00000000 00000001
12:13:34.548 -> 3fffff50: 00000000 00000000 3ffee6a0 3ffee978
12:13:34.594 -> 3fffff60: 3fffdad0 3ffee6c4 3ffee6a0 40203b5a
12:13:34.640 -> 3fffff70: 4020a6ec 00000000 00001388 4020565c
12:13:34.686 -> 3fffff80: 00000000 00000000 3fff057c 00000000
12:13:34.732 -> 3fffff90: 3fffdad0 00000000 3ffee800 40203c5c
12:13:34.822 -> 3fffffa0: 3fffdad0 00000000 3ffee964 402080e4
12:13:34.868 -> 3fffffb0: feefeffe feefeffe 3ffe85e0 40100d05
12:13:34.913 -> <<<stack<<<
12:13:34.913 ->
12:13:34.913 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
Что делаю не так?
Падение происходит в момент отображения html страницы при подключении AP IP address: 192.168.4.1
точнее
1. https://arduino.ru/forum/obshchii/vstavka-programmnogo-koda-v-temukommentarii - это обязательно, если Ваша цель говорить по существу, а не брызгать слюной, что никто не помогает.
2. Код нужен полностью по огрызку никто Вам ничего разумного не скажет. Как можно короче, но полный код. У Вас тут даже нет описания переменных - о чём говорить можно?
#include <EEPROM.h> #include <ESP8266WiFi.h> #include <WiFiClient.h> #include <ESP8266WebServer.h> #include "qrcode.h" #define EEPROM_SIZE 512 #ifndef APSSID #define APSSID "WD" #define APPSK "12345678" #endif /* Set these to your desired credentials. */ const char *ssid = APSSID; const char *password = APPSK; String qrCodeHtml = ""; const char index_html_start[] PROGMEM = R"rawliteral( <!DOCTYPE HTML><html> <head> <meta name="viewport" content="width=device-width, initial-scale=1"> <style> html { font-family: Arial; display: inline-block; margin: 0px auto; text-align: center; } .white { height: 10px; width: 10px; display: inline-block; } .black { height: 20px; width: 10px; background: black; display: inline-block; } </style> </head> <body> <h2>Water device</h2> <form action="/action" method="POST"> <p> Wifi SSID </p> <input type="text" name="ssid"> <p> Wifi Password </p> <input type="password" name="password"> <input type="submit" name="action" value="Save and restart"> </form> <br/> <div> )rawliteral"; const char index_html_end[] PROGMEM = R"rawliteral( </div> </body> </html>)rawliteral"; ESP8266WebServer server(80); /* Just a little test message. Go to http://192.168.4.1 in a web browser connected to this access point to see it. */ void handleRoot() { server.send(200, "text/html", index_html_start + qrCodeHtml + index_html_end ); } void handleAction() { if( ! server.hasArg("ssid") || ! server.hasArg("password") || server.arg("ssid") == NULL || server.arg("password") == NULL) { server.send(400, "text/plain", "Enter SSID and Password"); return; } String ssid = server.arg("ssid"); String password = server.arg("password"); int address = 0; String ap_mode = "2"; EEPROM.write(address, ap_mode[0]); Serial.println("writing ap_mode to eeprom:"); Serial.println(ap_mode); Serial.print("Wrote address: "); Serial.println(address); // save ssid int charSSIDLength = 10; Serial.println("writing ssid to eeprom:"); for (int i = 0; i < charSSIDLength; i++) { address = address + 1; EEPROM.write(address, ssid[i]); Serial.print("Wrote address: "); Serial.println(address); Serial.print("Wrote: "); Serial.println(ssid[i]); } // save password int charPasswordLength = 10; Serial.println("writing password to eeprom:"); for (int j = 0; j < charPasswordLength; j++) { address = address + 1; EEPROM.write(address, password[j]); Serial.print("Wrote address: "); Serial.println(address); Serial.print("Wrote: "); Serial.println(password[j]); } EEPROM.commit(); server.send(200, "text/html", "Rebooting..."); ESP.restart(); } void setup() { QRCode qrcode; uint8_t qrcodeData[qrcode_getBufferSize(3)]; qrcode_initText(&qrcode, qrcodeData, 3, 0, "HELLO WORLD"); for (uint8_t y = 0; y < qrcode.size; y++) { // Each horizontal module for (uint8_t x = 0; x < qrcode.size; x++) { qrCodeHtml += qrcode_getModule(&qrcode, x, y) ? "<span class='black'></span>": "<span class='white'></span>"; // delay(100); } qrCodeHtml +="<br/>"; } // put your setup code here, to run once: pinMode(13, INPUT); pinMode(LED_BUILTIN, OUTPUT); digitalWrite(LED_BUILTIN, HIGH); delay(1000); digitalWrite(LED_BUILTIN, LOW); Serial.begin(9600); EEPROM.begin(EEPROM_SIZE); int address = 0; String ap_mode = ""; Serial.print(qrCodeHtml); Serial.print("ApMode: "); Serial.println("Reading EEPROM AP MODE"); Serial.print("Read address: "); Serial.println(0); ap_mode += char(EEPROM.read(0)); Serial.println(ap_mode); if (ap_mode == "2") { Serial.print("SSID: "); Serial.println("Reading EEPROM ssid"); String readed_sid=""; for (int i = 0; i < 10; i++) { Serial.print("Read address: "); Serial.println(i+1); readed_sid += char(EEPROM.read(i + 1)); Serial.print("Read: "); Serial.println(char(EEPROM.read(i + 1))); if(readed_sid[i]=='\0') break; } Serial.println(readed_sid.length()); Serial.println(readed_sid); Serial.print("Password: "); Serial.println("Reading EEPROM password"); String readed_password=""; for (int j = 1; j < 10; j++) { Serial.print("Read address: "); Serial.println(j+10); readed_password += char(EEPROM.read(9 + j + 1)); Serial.print("Read: "); Serial.println(char(EEPROM.read(9+ j + 1))); if(char(EEPROM.read(9+ j + 1))=='\0') break; } Serial.println(readed_password.length()); Serial.println(readed_password); // WiFi.mode(WIFI_STA); WiFi.begin(readed_sid, readed_password); //WiFi.begin("RS", "12345678"); int attempts = 0; while (WiFi.status() != WL_CONNECTED) { delay(500); attempts++; Serial.print("."); Serial.print(WiFi.status()); if (attempts > 20) { int address = 0; String ap_mode = "1"; EEPROM.write(address, ap_mode[0]); Serial.println("writing ap_mode to eeprom:"); Serial.println(ap_mode); Serial.print("Wrote address: "); Serial.println(address); EEPROM.commit(); ESP.restart(); } } Serial.println(""); Serial.print("Connected! IP address: "); Serial.println(WiFi.localIP()); } else { // cold start // init AP //WiFi.mode(WIFI_AP); WiFi.softAP(ssid, password); IPAddress myIP = WiFi.softAPIP(); Serial.print("AP IP address: "); Serial.println(myIP); server.on("/", handleRoot); server.on("/action", HTTP_POST, handleAction); server.begin(); Serial.println("HTTP server started"); } //mac print Serial.println(WiFi.macAddress()); } void loop() { // put your main code here, to run repeatedly: if (digitalRead(13) == HIGH) { digitalWrite(LED_BUILTIN, HIGH); Serial.write("HIGH"); } else { digitalWrite(LED_BUILTIN, LOW); Serial.write("LOW"); } server.handleClient(); delay(1000); }Прошу прощения, я на старте изучения)
У тебя память бесконечная, что ли, для такой "генерации"?
А как лучше сделать?
скорее всего валится по фрагментации/недостатку памяти.
Судя по всему автор кода генерит qrcode в виде сотен строчек типа
которые все потом тупо добавляются в одну несчастную переменную типа String
Это не Гайвер писал? за такое надо ойца отрывать
например в виде картинки
Ну я на старте изучения))) про шарундулы согласен. Буду благодарен за живой пример как надо реализовать)
Идея была динамичные данные преобразовать в qr. Например серийный номер или MAC чипа. Не совсем понимаю как это превратить в картинку и после выдать в html
Вы прикидывали, какой длины получается вся строчка? Каков размер генерируемого Вами qrcode - Х х У ?
нет
ну что. отвечаю сам...
В вашем скетче создается Ку-Ар-код размером 29х29 квадратиков. Каждый квадратик у вас кодируется строчкой порядка 25-30 символов. Итого один Ку-Ар-код в ХТМЛ занимает порядка 25к, что многовато, с учетом того что на ЕСП8266 при запуске вебсервера остается дай бог 30к памяти
Это не считая того, как вы кромсаете память сотнями создаваемых и убиваемых экземпляров String
Для начала посмотрите функцию String.reserve, а если не поможет - избавляйтесь от String вовсе. Но даже этого может не хватить - тогда придется создавать Ку-Ар-код как точечный рисунок
Втупую - так.
for (uint8_t x = 0; x < qrcode.size; x++) { // client - WiFi Client или как там его.... client.print(qrcode_getModule(&qrcode, x, y) ? "<span class='black'></span>": "<span class='white'></span>"); // delay(100); }Какие в жёппу <спаны>??? Это ж картинка - ну вывести её как картинку. Поставить библиотеку готовую для графики ...или вообще скинуть прям бинарником этот массив на браузер и там нарисовать красивое кошерным ДжаваСкриптом.
Какому ушлёпку пришла в голову идея рисовать КуЭр код спанами?? Вместо КАЖДОЙ точки вотака ерня: <span class='black'></span> ???
Лучше генерировать qr на клиенте.
а пересылать в каком виде?
догадайся
