Передача данных в Google Sheet
Здравствуйте!
Прошу Вашей помощи:
Была программа для передачи данных в Google Sheet на ESР8266
#include <ESP8266WiFi.h>
#include <Wire.h>
#include <WiFiClientSecure.h>
#include <DHT.h>
#include <EEPROM.h>
LiquidCrystal_I2C _lcd1(0x27, 20, 4);
int _dispTempLength1=0;
boolean _isNeedClearDisp1;
DHT _dht1(0, DHT22, 11);
extern "C"
#include "user_interface.h"
bool En_128741382_1;
float data1_float_128741382_1;
float data2_float_128741382_1;
WiFiClientSecure client_128741382_1;
bool _ri__128741382_1= 0;
bool _ro__128741382_1= 0;
bool ESPControllerWifiClient_HRD = 0;
bool ESPControllerWifiClient_status = 1;
bool ESPControllerWifiClient_isDHCP = 1;
bool ESPControllerWifiClient_IsNeedReconect = 0;
bool ESPControllerWifiClient_workStatus = 1;
char ESPControllerWifiClient_SSID[40] = "Home";
char ESPControllerWifiClient_password[40] = "147852369";
IPAddress ESPControllerWifiClient_ip(0, 0, 0, 0);
IPAddress ESPControllerWifiClient_dns (0, 0, 0, 1);
IPAddress ESPControllerWifiClient_gateway (0, 0, 0, 1);
IPAddress ESPControllerWifiClient_subnet (255, 255, 255, 0);
uint8_t ESPControllerWifiClient_mac[6] = {0x0, 0x0, 0x0, 0x0, 0x0, 0x0};
bool isNeededCommitESP8266EEprom = 0;
float _dht1_humOut = 0.00;
float _dht1_tempOut = 0.00;
unsigned long _dht1Tti = 0UL;
bool _gen1I = 0;
bool _gen1O = 0;
unsigned long _gen1P = 0UL;
String _SysParRead_1_Out;
int _disp1oldLength = 0;
Wire.pins(4, 5);
Wire.begin();
delay(10);
EEPROM.begin(5);
if(((readByteFromEEPROM(0, 0, 0x0))) != 163)
(updateByteToEEPROM(0, 0, 0x0, (163)));
(updateUnsignedLongToEEPROM(1, 0, 0x0, (0)));
EEPROM.commit();
ESPControllerWifiClient_ip = _ipAddressFromUnsignetLong(readUnsignedLongFromEEPROM(1, 0, 0x0));
WiFi.mode(WIFI_STA);
_esp8266WifiModuleClientReconnect();
_lcd1.init();
_lcd1.backlight();
_dht1Tti = millis();
client_128741382_1.setInsecure();
if (_isNeedClearDisp1)
_lcd1.clear();
_isNeedClearDisp1= 0;
if (isNeededCommitESP8266EEprom)
EEPROM.commit();
isNeededCommitESP8266EEprom=0;
if(ESPControllerWifiClient_IsNeedReconect)
ESPControllerWifiClient_status = WiFi.status() == WL_CONNECTED;
if (ESPControllerWifiClient_status)
if (! ESPControllerWifiClient_HRD)
ESPControllerWifiClient_ip = WiFi.localIP();
ESPControllerWifiClient_subnet = WiFi.subnetMask();
ESPControllerWifiClient_gateway = WiFi.gatewayIP();
ESPControllerWifiClient_dns = WiFi.dnsIP();
WiFi.macAddress(ESPControllerWifiClient_mac);
ESPControllerWifiClient_HRD = 1;
//Плата:1
if(_isTimer(_dht1Tti, 1000))
_dht1_humOut = _dht1.readHumidity();
_dht1_tempOut = _dht1.readTemperature();
if (!(0))
if (! _gen1I)
_gen1I = 1;
_gen1O = 1;
_gen1P = millis();
_gen1I = 0 ;
_gen1O= 0;
if (_gen1I)
if (_isTimer (_gen1P , 2000))
_gen1P = millis();
_gen1O = ! _gen1O;
En_128741382_1 = _gen1O;
data1_float_128741382_1 = _dht1_tempOut;
data2_float_128741382_1 = _dht1_humOut;
if ((En_128741382_1) &&(!_ri__128741382_1))
_ro__128741382_1= 1;
_ri__128741382_1=En_128741382_1;
if(_ro__128741382_1)
sendData_128741382_1(data1_float_128741382_1, data2_float_128741382_1);
_SysParRead_1_Out = ESPControllerWifiClient_ip.toString();
if (!(0))
_dispTempLength1 = ((_SysParRead_1_Out)).length();
if (_disp1oldLength > _dispTempLength1)
_isNeedClearDisp1 = 1;
_disp1oldLength = _dispTempLength1;
_lcd1.setCursor(0, 0);
_lcd1.print((_SysParRead_1_Out));
if (_disp1oldLength > 0)
bool _isTimer(unsigned long startTime, unsigned long period)
unsigned long currentTime;
currentTime = millis();
if (currentTime>= startTime)
return (currentTime>=(startTime + period));
return (currentTime >=(4294967295-startTime+period));
void sendData_128741382_1(float data1, float data2)
if (!client_128741382_1.connect("script.google.com", 443))
return;
String GAS_ID = "AKfycbyCTL1FLhwijxl5uFc792BEOuqDKsLfQ4TncoEq-8ReRdKV-prp9NpCaLV6oaanhm1QXg";
String string_data1=String(data1);
String string_data2=String(data2);
String url = "/macros/s/" + GAS_ID + "/exec?temperature=" + string_data1 + "&humidity=" + string_data2;
client_128741382_1.print(String("GET ")+url+" HTTP/1.1\r\n"+"Host: "+"script.google.com"+"\r\n"+"User-Agent: BuildFailureDetectorESP8266\r\n"+"Connection: close\r\n\r\n");
while (client_128741382_1.connected())
String line = client_128741382_1.readStringUntil('\n');
if (line == "\r")
line.startsWith("{\"state\":\"success\"");
byte readByteFromEEPROM(int addres, byte bitAddres, byte chipAddres)
return EEPROM.read(addres);
void updateByteToEEPROM(int addres, byte bitAddres, byte chipAddres, byte value)
isNeededCommitESP8266EEprom = 1;
return EEPROM.write(addres, value);
unsigned long readUnsignedLongFromEEPROM(int addres, byte bitAddres, byte chipAddres)
byte x[4];
for(byte i = 0; i < 4; i++)
x[i] = readByteFromEEPROM((addres+i), bitAddres, chipAddres);
unsigned long *y = (unsigned long *)&x;
return y[0];
void updateUnsignedLongToEEPROM(int addres, byte bitAddres, byte chipAddres, unsigned long value)
byte *x = (byte *)&value;
updateByteToEEPROM((addres+i), bitAddres, chipAddres, x[i]);
int hexStrToInt(String instring)
byte len = instring.length();
if (len == 0) return 0;
int result = 0;
for (byte i = 0; i < 8; i++) // только первые 8 цыфар влезуть в uint32
char ch = instring[i];
if (ch == 0) break;
result <<= 4;
if (isdigit(ch))
result = result | (ch - '0');
else result = result | (ch - 'A' + 10);
return result;
void _esp8266WifiModuleClientReconnect()
if(_checkMacAddres(ESPControllerWifiClient_mac))
wifi_set_macaddr(0, const_cast<uint8*>(ESPControllerWifiClient_mac));
if(ESPControllerWifiClient_isDHCP)
WiFi.config(0U, 0U, 0U, 0U, 0U);
WiFi.config(ESPControllerWifiClient_ip, ESPControllerWifiClient_gateway, ESPControllerWifiClient_subnet, ESPControllerWifiClient_dns , ESPControllerWifiClient_dns);
WiFi.begin(ESPControllerWifiClient_SSID, ESPControllerWifiClient_password);
IPAddress _ipAddressFromUnsignetLong(unsigned long value)
IPAddress result;
for (byte i = 0; i < 4; i++)
result[i] = x[i];
return result;
bool checkIPAdressString(String value)
IPAddress temp;
return temp.fromString(value);
IPAddress _ipAddressFromString(String value)
IPAddress temp;
return temp;
unsigned long _unsignetLongFromIPAdress(IPAddress value)
byte buufer[4] = {0, 0, 0, 0};
buufer[i] = value[i];
unsigned long *y = (unsigned long *)&buufer;
return y[0];
bool _checkMacAddres(byte array[])
bool result = 0;
for (byte i = 0; i < 6; i++)
if (array[i] == 255)
return 0;
if (array[i] > 0)
result = 1;
return result;
void _parseMacAddressString(String value, byte array[])
int index;
byte buffer[6] = {255, 255, 255, 255, 255, 255};
byte raz = 0;
String tempString;
while ((value.length() > 0) && (raz <= 6))
index = value.indexOf(":");
if (index == -1)
tempString = value;
value = "";
tempString = value.substring(0, index);
value = value.substring(index + 1);
buffer[raz] = byte(hexStrToInt(tempString));
raz++;
if (_checkMacAddres(buffer))
array[i] = buffer[i];
bool _compareMacAddreses(byte array1[], byte array2[])
if (array1[i] != array2[i])
return 0;
return 1;
bool _compareMacAddresWithString(byte array[], String value)
_parseMacAddressString(value, buffer);
return _compareMacAddreses(array, buffer);
bool _checkMacAddresString(String value)
return _checkMacAddres(buffer);
String _macAddresToString(byte array[])
String result = "";
String temp ="";
temp=String(array[i],HEX);
if (temp.length() < 2)
temp = String("0") + temp;
result = result + temp;
if (i < 5)
result = result + String(":");
result.toUpperCase();
return result;
но при переходе на ЕСП 32 вылезла ошибка:
Arduino: 1.8.13 (Windows 7), Плата:"ESP32 Dev Module, Disabled, Minimal SPIFFS (1.9MB APP with OTA/190KB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
C:\Users\User\AppData\Local\Temp\ide\pr1\pr1.ino: In function 'void setup()':
pr1:44:24: error: 'class WiFiClientSecure' has no member named 'setInsecure'
Несколько библиотек найдено для "WiFi.h"
Используется: D:\User\Загрузки\ide\ideV6\portable\packages\esp32\hardware\esp32\1.0.4\libraries\WiFi
Не используется: d:\User\Загрузки\ide\ideV6\libraries\WiFi
exit status 1'class WiFiClientSecure' has no member named 'setInsecure'
Не подскажите что это может быть?
Вот тут:
всё написано
угу
А если вбить эту строчку в гугль - первым же ответом вылазит, как это лечить
https://github.com/Links2004/arduinoWebSockets/issues/648
это называется программирование, друг
Судя по вопросу. ты очень далек от этого...
угу
Но у меня в проекте не используется WebSockets.
Подскажите как подправить код программы?
Есть немножко.
угу
Вам же дали ссылку, там написано буквально следующее: https://github.com/Links2004/arduinoWebSockets/issues/648#issuecomment-803830381
https://github.com/Links2004/arduinoWebSockets/issues/648#issuecomment-804094174
You were right, it was still on 1.0.4. Fixed!
I went to Tools -> Board... -> Boards Manager and updated to 1.0.5.
А на будущее - перепишите на MicroPython благо для ESP32 он существует.
Обновил плату до версии 1.0.6. все компилируется но данные приходят раз в 20 секунд а должно приходить раз в 2 секунды. После 4 записи данных на лист прием данных останавливается.
Что может быть?
