Помогите правильно запрограммировать парсинг
Пнд, 10/08/2020 - 12:27
Используемый код из проекта в интернете:
#include "ArduinoJson.h"
#include "ESP8266WiFi.h"
#include "WiFiClient.h"
// Replace with your SSID and password details
char ssid[] = "REPLACE_WITH_YOUR_SSID";
char pass[] = "REPLACE_WITH_YOUR_PASSWORD";
WiFiClient client;
// Open Weather Map API server name
const char server[] = "api.openweathermap.org";
// Replace the next line to match your city and 2 letter country code
String nameOfCity = "REPLACE_WITH_YOUR_CITY,REPLACE_WITH_YOUR_COUNTRY_CODE";
// How your nameOfCity variable would look like for Lagos on Nigeria
//String nameOfCity = "Lagos,NG";
// Replace the next line with your API Key
String apiKey = "REPLACE_WITH_YOUR_API_KEY";
String text;
int jsonend = 0;
boolean startJson = false;
int status = WL_IDLE_STATUS;
int rainLed = 2; // Indicates rain
int clearLed = 3; // Indicates clear sky or sunny
int snowLed = 4; // Indicates snow
int hailLed = 5; // Indicates hail
#define JSON_BUFF_DIMENSION 2500
unsigned long lastConnectionTime = 10 * 60 * 1000; // last time you connected to the server, in milliseconds
const unsigned long postInterval = 10 * 60 * 1000; // posting interval of 10 minutes (10L * 1000L; 10 seconds delay for testing)
pinMode(clearLed, OUTPUT);
pinMode(rainLed, OUTPUT);
pinMode(snowLed, OUTPUT);
pinMode(hailLed, OUTPUT);
text.reserve(JSON_BUFF_DIMENSION);
WiFi.begin(ssid,pass);
Serial.println("connecting");
delay(500);
Serial.print(".");
Serial.println("WiFi Connected");
printWiFiStatus();
//OWM requires 10mins between request intervals
//check if 10mins has passed then conect again and pull
if (millis() - lastConnectionTime > postInterval) {
// note the time that the connection was made:
lastConnectionTime = millis();
makehttpRequest();
// print Wifi status
void printWiFiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
// to request data from OWM
void makehttpRequest() {
// close any connection before send a new request to allow client make connection to server
client.stop();
// if there's a successful connection:
if (client.connect(server, 80)) {
// Serial.println("connecting...");
// send the HTTP PUT request:
client.println("GET /data/2.5/forecast?q=" + nameOfCity + "&APPID=" + apiKey + "&mode=json&units=metric&cnt=2 HTTP/1.1");
client.println("Host: api.openweathermap.org");
client.println("User-Agent: ArduinoWiFi/1.1");
client.println("Connection: close");
client.println();
unsigned long timeout = millis();
while (client.available() == 0) {
if (millis() - timeout > 5000) {
Serial.println(">>> Client Timeout !");
client.stop();
return;
char c = 0;
while (client.available()) {
c = client.read();
// since json contains equal number of open and close curly brackets, this means we can determine when a json is completely received by counting
// the open and close occurences,
//Serial.print(c);
if (c == '{') {
startJson = true; // set startJson true to indicate json message has started
jsonend++;
if (c == '}') {
jsonend--;
if (startJson == true) {
text += c;
// if jsonend = 0 then we have have received equal number of curly braces
if (jsonend == 0 && startJson == true) {
parseJson(text.c_str()); // parse c string text in parseJson function
text = ""; // clear text string for the next time
startJson = false; // set startJson to false to indicate that a new message has not yet started
else {
// if no connction was made:
Serial.println("connection failed");
return;
//to parse json data recieved from OWM
void parseJson(const char * jsonString) {
//StaticJsonBuffer<4000> jsonBuffer;
const size_t bufferSize = 2*JSON_ARRAY_SIZE(1) + JSON_ARRAY_SIZE(2) + 4*JSON_OBJECT_SIZE(1) + 3*JSON_OBJECT_SIZE(2) + 3*JSON_OBJECT_SIZE(4) + JSON_OBJECT_SIZE(5) + 2*JSON_OBJECT_SIZE(7) + 2*JSON_OBJECT_SIZE(8) + 720;
DynamicJsonDocument jsonBuffer(bufferSize);
// FIND FIELDS IN JSON TREE
JsonObject& root = jsonBuffer.parseObject(jsonString);
if (!root.success()) {
Serial.println("parseObject() failed");
return;
JsonArray& list = root["list"];
JsonObject& nowT = list[0];
JsonObject& later = list[1];
// including temperature and humidity for those who may wish to hack it in
String city = root["city"]["name"];
float tempNow = nowT["main"]["temp"];
float humidityNow = nowT["main"]["humidity"];
String weatherNow = nowT["weather"][0]["description"];
float tempLater = later["main"]["temp"];
float humidityLater = later["main"]["humidity"];
String weatherLater = later["weather"][0]["description"];
// checking for four main weather possibilities
diffDataAction(weatherNow, weatherLater, "clear");
diffDataAction(weatherNow, weatherLater, "rain");
diffDataAction(weatherNow, weatherLater, "snow");
diffDataAction(weatherNow, weatherLater, "hail");
Serial.println();
//representing the data
void diffDataAction(String nowT, String later, String weatherType) {
int indexNow = nowT.indexOf(weatherType);
int indexLater = later.indexOf(weatherType);
// if weather type = rain, if the current weather does not contain the weather type and the later message does, send notification
if (weatherType == "rain") {
if (indexNow == -1 && indexLater != -1) {
digitalWrite(rainLed,HIGH);
digitalWrite(clearLed,LOW);
digitalWrite(snowLed,LOW);
digitalWrite(hailLed,LOW);
Serial.println("Oh no! It is going to " + weatherType + " later! Predicted " + later);
// for snow
else if (weatherType == "snow") {
digitalWrite(snowLed,HIGH);
digitalWrite(rainLed,LOW);
// can't remember last time I saw hail anywhere but just in case
else if (weatherType == "hail") {
digitalWrite(hailLed,HIGH);
// for clear sky, if the current weather does not contain the word clear and the later message does, send notification that it will be sunny later
else {
Serial.println("It is going to be sunny later! Predicted " + later);
digitalWrite(clearLed,HIGH);
Во все проектах в интернете используется такая строка:
На этом ошибка
'ArduinoJson6161_11::DynamicJsonDocument' has no member named 'parseObject'
Кто знает как правильно парсить в новых библиотеках arduinojson. Все проекты в интернете содержат эту строку. Хочу узнать правильную функцию. Пытался разобраться в h-никах - не понимаю ничего!
https://arduinojson.org/v6/doc/deserialization/
Спасибо. Помогло!
