Проблема в одной строчке кода
Пт, 17/04/2020 - 12:26
Здраствуйте. Почему некорректно работает строчка 53?
#include<stdio.>
void crc16(unsigned char data[], unsigned char len)
static unsigned char table_CRC_Hi[]=
0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41,0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40,
0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40,0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41,
static unsigned char table_CRC_Lo[]=
0x00,0xC0,0xC1,0x01,0xC3,0x03,0x02,0xC2,0xC6,0x06,0x07,0xC7,0x05,0xC5,0xC4,0x04,
0xCC,0x0C,0x0D,0xCD,0x0F,0xCF,0xCE,0x0E,0x0A,0xCA,0xCB,0x0B,0xC9,0x09,0x08,0xC8,
0xD8,0x18,0x19,0xD9,0x1B,0xDB,0xDA,0x1A,0x1E,0xDE,0xDF,0x1F,0xDD,0x1D,0x1C,0xDC,
0x14,0xD4,0xD5,0x15,0xD7,0x17,0x16,0xD6,0xD2,0x12,0x13,0xD3,0x11,0xD1,0xD0,0x10,
0xF0,0x30,0x31,0xF1,0x33,0xF3,0xF2,0x32,0x36,0xF6,0xF7,0x37,0xF5,0x35,0x34,0xF4,
0x3C,0xFC,0xFD,0x3D,0xFF,0x3F,0x3E,0xFE,0xFA,0x3A,0x3B,0xFB,0x39,0xF9,0xF8,0x38,
0x28,0xE8,0xE9,0x29,0xEB,0x2B,0x2A,0xEA,0xEE,0x2E,0x2F,0xEF,0x2D,0xED,0xEC,0x2C,
0xE4,0x24,0x25,0xE5,0x27,0xE7,0xE6,0x26,0x22,0xE2,0xE3,0x23,0xE1,0x21,0x20,0xE0,
0xA0,0x60,0x61,0xA1,0x63,0xA3,0xA2,0x62,0x66,0xA6,0xA7,0x67,0xA5,0x65,0x64,0xA4,
0x6C,0xAC,0xAD,0x6D,0xAF,0x6F,0x6E,0xAE,0xAA,0x6A,0x6B,0xAB,0x69,0xA9,0xA8,0x68,
0x78,0xB8,0xB9,0x79,0xBB,0x7B,0x7A,0xBA,0xBE,0x7E,0x7F,0xBF,0x7D,0xBD,0xBC,0x7C,
0xB4,0x74,0x75,0xB5,0x77,0xB7,0xB6,0x76,0x72,0xB2,0xB3,0x73,0xB1,0x71,0x70,0xB0,
0x50,0x90,0x91,0x51,0x93,0x53,0x52,0x92,0x96,0x56,0x57,0x97,0x55,0x95,0x94,0x54,
0x9C,0x5C,0x5D,0x9D,0x5F,0x9F,0x9E,0x5E,0x5A,0x9A,0x9B,0x5B,0x99,0x59,0x58,0x98,
0x88,0x48,0x49,0x89,0x4B,0x8B,0x8A,0x4A,0x4E,0x8E,0x8F,0x4F,0x8D,0x4D,0x4C,0x8C,
0x44,0x84,0x85,0x45,0x87,0x47,0x46,0x86,0x82,0x42,0x43,0x83,0x41,0x81,0x80,0x40,
unsigned char CRC_Hi = 0xFF;
unsigned char CRC_Lo = 0xFF;
unsigned char index = 0;
unsigned char count = 0;
unsigned char tmp_len = len;
while(len--)
index = CRC_Hi ^ data[count++]; //так работает
//index = CRC_Hi ^ *data++; //так не работает
CRC_Hi = CRC_Lo ^ table_CRC_Hi[index];
CRC_Lo = table_CRC_Lo[index];
data[tmp_len] = CRC_Hi;
data[tmp_len+1] = CRC_Lo;
unsigned char data[10] = {0x01,0x06,0xA0,0x01,0x27,0x10,0x00,0x00,0x00,0x00};
int main()
crc16(data, 6);
printf("%x %x %x %x %x %x %x %x", data[0], data[1], data[2], data[3], data[4], data[5], data[6], data[7]);
а скобки экономим, да?
А вот так:
и следовало бы третью строчку тоже изменить на
57 58 выходят за пределы массива
нет, конкретно в этом коде не выходит. массив длиной 10 элементов, а len =6
А вот так:
ИМХО - (*(data++)) не есть data[i++] и (*data++) тоже не то. Ближе будет ((*data)++)
И сколько будет 6 + 6?
С какого бодуна?
Да, нет, нормально там вроде всё. Некрасиво без скобок, но работало бы.
Ошибка в в другом. В закомментированной строчке изменяется data а потом в строке 57-58 используется, как если бы не менялась. rkit, наверное это имел в виду, только неправильно назвал.
не, mykaida прав, попробовал - у меня *(data++) даже не компилируется, пишет "аргумент инкремента должен быть lvalue"
а вот так вот работает - ну это тривиально
unsignedchardata[]объявил, а неunsignedchar*data- как все нормальные люди. Мне такое и голову прийти не могло :-)так тоже работает
while(len--) { //index = CRC_Hi ^ data[count++]; //так работает index = CRC_Hi ^ *data++; //так не работает CRC_Hi = CRC_Lo ^ table_CRC_Hi[index]; CRC_Lo = table_CRC_Lo[index]; } *data++ = CRC_Hi; *data++ = CRC_Lo; }просто я думал что после инкремента адреса все равно можно обратиться к любому значению массива обычной записью
так тоже работает
while(len--) { //index = CRC_Hi ^ data[count++]; //так работает index = CRC_Hi ^ *data++; //так не работает CRC_Hi = CRC_Lo ^ table_CRC_Hi[index]; CRC_Lo = table_CRC_Lo[index]; } *data++ = CRC_Hi; *data++ = CRC_Lo; }заголовок функции поменяли? - если нет, так компилироваться не должно
Нельзя. ++ изменяет значение указателя навсегда. Чтобы так не попадаться - нужно сделать отдельный указатель и его ++. Но тут данная операция будет оверхедом.
все компилится и работает в онлайн компиляторе
все равно поправьте строчку 3 - она у вас идиотская
хорошо, напишу как полагается
