2 LEDD проблема
Ср, 19/12/2018 - 23:09
Здравствуйте
Могу включить каждый отдельно, но когда включаю диод на БД14 второй не включается.
#include "EmonLib.h" // Include Emon Library
EnergyMonitor emon1; // Create an instance
#include <LiquidCrystal.h>
LiquidCrystal lcd(PA0, PA1, PA2, PA3, PA4, PA5);
const int ResetPin = PB12;
const int numReadings = 50;
int LED = PB15;
int LED2 = PB14;
int readings[numReadings]; // the readings from the analog input
int readIndex = 0; // the index of the current reading
int total = 0; // the running total
int average = 0; // the average
int inputPin = PA7;
int analogInput = PB0;
int value = 0;
float vout = 0.0;
float vin = 0.0;
float Vo;
float Irms = 0.0;
//float Vo;
float Io;
// initialize all the readings to 0:
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
readings[thisReading] = 0;
pinMode(PB15, OUTPUT); // LED
pinMode(PB14, OUTPUT); // LED2
pinMode(ResetPin, INPUT_PULLDOWN);
pinMode(PA7, INPUT); // AC
pinMode(PB0, INPUT_ANALOG); //DC
lcd.begin(16, 2);
//emon1.voltage(PA7, 234.26, 1.7); // Voltage: input pin, calibration, phase_shift
emon1.current(PA7, 2.8);
emon1.calcVI(20, 2000);
if (digitalRead(ResetPin) == HIGH)
Io = emon1.Irms;
// subtract the last reading:
total = total - readings[readIndex];
// read from the sensor:
readings[readIndex] = analogRead(inputPin);
// add the reading to the total:
total = total + readings[readIndex];
// advance to the next position in the array:
readIndex = readIndex + 1;
// if we're at the end of the array...
if (readIndex >= numReadings) {
// ...wrap around to the beginning:
readIndex = 0;
// calculate the average:
average = total / numReadings;
// send it to the computer as ASCII digits
Serial.println(average);
delay(1);
//(digitalRead(ResetPin) == HIGH)
Vo = vin;
else {
// read the value at analog input
value = analogRead(analogInput);
vout = (value * 3.3) / 4190.0; // 4200
vin = vout;
if (vin < 0.09)
vin = 0.0; //statement to quash undesired reading !
float Irms = emon1.Irms;
//if (Irms - Vo <= 0.90 && Irms - Vo >= 0.100) // delta 0.3
if (Irms - Io <= 0.90 && Irms - Io >= 0.100) // AC
digitalWrite(PB15, HIGH);
LED = 1;
digitalWrite(PB15, LOW);
LED = 0;
if (vin - Vo <= 0.4 && vin - Vo >= 0.1) // DC
// if(vin-Vo<= 1.20 && vin-Vo >= 1.00)
digitalWrite(PB14, HIGH);
LED2 = 1;
digitalWrite(PB14, LOW);
LED2 = 0;
lcd.setCursor(0, 1);
lcd.print(vin);
lcd.setCursor(5, 1);
lcd.print("o");
lcd.print(Vo, 2);
lcd.setCursor(11, 1);
lcd.print (vin - Vo);
//delay(500);
lcd.setCursor(0, 0);
lcd.print(Irms);
lcd.setCursor(5, 0);
lcd.print("o");
lcd.print(Io, 2);
lcd.setCursor(11, 0);
lcd.print (Irms - Io);
А можно расшивровать "когда включаю диод на БД14 второй не включается." ?
Исправление
БД14 =
LED2 = PB14;Ну я догадался, что БД14 это PB14. Вопросы
- Каким образом происходит " включаю диод на БД14" ?
- Почему при этом должен включаться второй? Может просто условие в 109 строчке не выполняется?
Добавь между 107 и 109 строкой
Serial.print("Vin="); Serial.print(vin); Serial.print(" Vo="); Serial.println(Vo);И посмотри в сериал мониторе какие там значения.
эти значения я вижу на LCD
Ну, и какие они?
Они как у обычного вольтметра , работают как надо, проблема только с LED.
Значения vin - Vo в диапазоне 0.1 - 0.4 есть?
Исправь 109 строчку на
сообщение #9 = ничего не изменилось
