Adafruit_ST7735 + rtos зависает
Чт, 14/07/2022 - 10:42
Всем привет. Пытаюсь сделать вывод на экран в 2х разных потоках, через Adafruit_ST7735. Как МК использую Raspberry pi pico. Код:
#include <Adafruit_GFX.h>
#include <Adafruit_ST7735.h>
#include <SPI.h>
#include <mbed.h>
#include <rtos.h>
#include <platform/Callback.h>
using namespace rtos;
#if !defined(ARDUINO_ARCH_RP2040)
#error For RP2040 only
#endif
#if defined(ARDUINO_ARCH_MBED)
#define PIN_SD_MOSI PIN_SPI_MOSI
#define PIN_SD_MISO PIN_SPI_MISO
#define PIN_SD_SCK PIN_SPI_SCK
#define PIN_SD_SS PIN_SPI_SS
#else
#define PIN_SD_MOSI PIN_SPI0_MOSI
#define PIN_SD_MISO PIN_SPI0_MISO
#define PIN_SD_SCK PIN_SPI0_SCK
#define PIN_SD_SS PIN_SPI0_SS
#endif
#define _RP2040_SD_LOGLEVEL_ 0
#include <RP2040_SD.h>
#define ST7735_DRIVER
#define TFT_INVERSION_ON
#define TFT_CS 18
#define TFT_RST 22
#define TFT_DC 19
#define TFT_SCLK 21
#define TFT_MOSI 20
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
Semaphore s1(1);
Semaphore s2(0);
Thread t2;
#define BUFFPIXEL 20
uint16_t read16(File f) {
uint16_t result;
((uint8_t *)&result)[0] = f.read(); // LSB
((uint8_t *)&result)[1] = f.read(); // MSB
return result;
uint32_t read32(File f) {
uint32_t result;
((uint8_t *)&result)[2] = f.read();
((uint8_t *)&result)[3] = f.read(); // MSB
return result;
void bmpDraw(char *filename, uint8_t x, uint16_t y) {
File bmpFile;
int bmpWidth, bmpHeight; // W+H in pixels
uint8_t bmpDepth; // Bit depth (currently must be 24)
uint32_t bmpImageoffset; // Start of image data in file
uint32_t rowSize; // Not always = bmpWidth; may have padding
uint8_t sdbuffer[3*BUFFPIXEL]; // pixel buffer (R+G+B per pixel)
uint8_t buffidx = sizeof(sdbuffer); // Current position in sdbuffer
boolean goodBmp = false; // Set to true on valid header parse
boolean flip = true; // BMP is stored bottom-to-top
int w, h, row, col;
uint8_t r, g, b;
uint32_t pos = 0, startTime = millis();
if((x >= tft.width()) || (y >= tft.height())) return;
Serial.println();
Serial.print(F("Loading image '"));
Serial.print(filename);
Serial.println("'");
// Open requested file on SD card
if ((bmpFile = SD.open(filename)) == NULL) {
Serial.print(F("File "));
Serial.println(F(" not found"));
return;
// Parse BMP header
if(read16(bmpFile) == 0x4D42) { // BMP signature
Serial.print(F("File size: ")); Serial.println(read32(bmpFile));
(void)read32(bmpFile); // Read & ignore creator bytes
bmpImageoffset = read32(bmpFile); // Start of image data
Serial.print(F("Image Offset: ")); Serial.println(bmpImageoffset, DEC);
// Read DIB header
Serial.print(F("Header size: ")); Serial.println(read32(bmpFile));
bmpWidth = read32(bmpFile);
bmpHeight = read32(bmpFile);
if(read16(bmpFile) == 1) { // # planes -- must be '1'
bmpDepth = read16(bmpFile); // bits per pixel
Serial.print(F("Bit Depth: ")); Serial.println(bmpDepth);
if((bmpDepth == 24) && (read32(bmpFile) == 0)) { // 0 = uncompressed
goodBmp = true; // Supported BMP format -- proceed!
Serial.print(F("Image size: "));
Serial.print(bmpWidth);
Serial.print('x');
Serial.println(bmpHeight);
rowSize = (bmpWidth * 3 + 3) & ~3;
if(bmpHeight < 0) {
bmpHeight = -bmpHeight;
flip = false;
// Crop area to be loaded
w = bmpWidth;
h = bmpHeight;
if((x+w-1) >= tft.width()) w = tft.width() - x;
if((y+h-1) >= tft.height()) h = tft.height() - y;
tft.startWrite();
tft.setAddrWindow(x, y, w, h);
tft.endWrite();
for (row=0; row<h; row++) { // For each scanline...
if(flip) // Bitmap is stored bottom-to-top order (normal BMP)
pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
else // Bitmap is stored top-to-bottom
pos = bmpImageoffset + row * rowSize;
if(bmpFile.position() != pos) { // Need seek?
bmpFile.seek(pos);
buffidx = sizeof(sdbuffer); // Force buffer reload
for (col=0; col<w; col++) { // For each pixel...
// Time to read more pixel data?
if (buffidx >= sizeof(sdbuffer)) { // Indeed
bmpFile.read(sdbuffer, sizeof(sdbuffer));
buffidx = 0; // Set index to beginning
// Convert pixel from BMP to TFT format, push to display
b = sdbuffer[buffidx++];
g = sdbuffer[buffidx++];
r = sdbuffer[buffidx++];
tft.pushColor(tft.color565(r,g,b));
} // end pixel
} // end scanline
tft.endWrite();
Serial.print(F("Loaded in "));
Serial.print(millis() - startTime);
Serial.println(" ms");
bmpFile.close();
if(!goodBmp) Serial.println(F("BMP format not recognized."));
void runCore1 ()
s1.acquire();
while (true) {
bmpDraw("img/TEST.bmp", 0, 10);
s2.release();
tft.initR(INITR_BLACKTAB);
Serial.println(F("Initialized"));
tft.fillScreen(ST77XX_BLACK);
tft.setRotation(3);
t2.start(mbed::callback(runCore1)); //тут отображается нормально
delay(3000);
tft.setFont(&TIMES8pt8b);
tft.setTextColor(ST7735_WHITE);
/* А вот тут зависает и Pico начинает мигать зеленым светодиодом*/
tft.setCursor(40, 15);
tft.println(utf8cyr("Print TEST"));
bmpDraw("img/TEST2.bmp", 40, 20);
Подскажите плиииз, что может быть не так и как правильно реализовать вывод на экран в разных потоках? Спасибо!
семафор(semaphore) , мьютекс(mutex)
