Arduino GSM shield
Yezdoghlyan
Нужна примитивная работающая программа для GSM платы чтобы при включении отправила смс "привет" на данный номер. Спасибо за помощ
Gippopotam
Gippopotam аватар
Какой модуль?
Чем не устраивает пример из дефолтной библиотеки?
Yezdoghlyan
я использовал эту программу,
SMS sender
 This sketch, for the Arduino GSM shield,sends an SMS message
 that you send it through the serial monitor. To make it work,
 open the serial monitor, and when you see the READY message,
 type a message to send. Make sure the serial monitor is set
 to send a newline when you press return.
 Circuit:
 * GSM shield
 created 25 Feb 2012
 by Tom Igoe
 This example is in the public domain.
// libraries
#include <GSM.h>
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess; // include a 'true' parameter for debug enabled
GSM_SMS sms;
void setup()
  // initialize serial communications
  Serial.println("SMS Messages Sender");
  // connection state
  boolean notConnected = true;
  // Start GSM shield
  // If your SIM has PIN, pass it as a parameter of begin() in quotes
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      Serial.println("Not connected");
  Serial.println("GSM initialized");
void loop()
  Serial.print("Enter a mobile number: ");
  char remoteNumber[20];  // telephone number to send sms
  readSerial(remoteNumber);
  Serial.println(remoteNumber);
  // sms text
  Serial.print("Now, enter SMS content: ");
  char txtMsg[200];
  readSerial(txtMsg);
  Serial.println("SENDING");
  Serial.println();
  Serial.println("Message:");
  Serial.println(txtMsg);
  // send the message
  sms.beginSMS(remoteNumber);
  sms.print(txtMsg);
  sms.endSMS();
  Serial.println("\nCOMPLETE!\n");
  Read input serial
int readSerial(char result[])
  int i = 0;
  while(1)
    while (Serial.available() > 0)
      char inChar = Serial.read();
      if (inChar == '\n')
        result[i] = '\0';
        Serial.flush();
        return 0;
      if(inChar!='\r')
        result[i] = inChar;
        i++;
но она выдавала ошибку
C:\Program Files\Arduino\libraries\GSM\GSM3ShieldV1ModemVerification.cpp: In member function 'String GSM3ShieldV1ModemVerification::getIMEI()':
C:\Program Files\Arduino\libraries\GSM\GSM3ShieldV1ModemVerification.cpp:72: error: conversion from 'int' to 'String' is ambiguous
C:\Program Files\Arduino\hardware\arduino\cores\arduino/WString.h:61: note: candidates are: String::String(const __FlashStringHelper*)
C:\Program Files\Arduino\hardware\arduino\cores\arduino/WString.h:59: note:                 String::String(const char*)
Sll
Sll аватар
заработал пример?
