Arduino & Ubuntu
ramon_sobaka
Не могу подключить к Ubuntu (На Вин8 все отлично). Установлены gcc-avr, avr-libc and openjdk-6-jre. IDE установлена.  Лог dmesg
[   15.342803]    inputs:
[   15.342805]      Internal Mic=0x13
[   15.342806]      Mic=0xe
[   15.352019] input: HDA Intel MID Headphone Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[   15.352118] input: HDA Intel MID Headphone Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[   15.352188] input: HDA Intel MID Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[   15.352487] hda-intel 0000:02:00.1: Handle VGA-switcheroo audio client
[   15.352490] hda-intel 0000:02:00.1: Using LPIB position fix
[   15.352531] snd_hda_intel 0000:02:00.1: irq 45 for MSI/MSI-X
[   15.354845] hda-intel 0000:02:00.1: Enable sync_write for stable communication
[   15.358041] Broadcom 43xx driver loaded [ Features: PNL ]
[   15.376310] device-mapper: multipath: version 1.6.0 loaded
[   15.385643] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:02:00.1/sound/card1/input12
[   15.427723] cdc_acm 2-1.3:1.0: This device cannot do calls on its own. It is not a modem.
[   15.427762] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[   15.428196] usbcore: registered new interface driver cdc_acm
[   15.428198] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[   15.490177] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[   15.529082] Linux video capture interface: v2.00
[   15.672668] input: Dell WMI hotkeys as /devices/virtual/input/input13
[   15.715443] b43 ssb0:0: Direct firmware load failed with error -2
[   15.715450] b43 ssb0:0: Falling back to user helper
[   15.716084] b43 ssb0:0: Direct firmware load failed with error -2
[   15.716093] b43 ssb0:0: Falling back to user helper
[   15.765804] b43 ssb0:0: Direct firmware load failed with error -2
[   15.765813] b43 ssb0:0: Falling back to user helper
[   15.766459] b43 ssb0:0: Direct firmware load failed with error -2
[   15.766462] b43 ssb0:0: Falling back to user helper
[   15.767964] b43-phy0 ERROR: Firmware file "b43/ucode15.fw" not found
[   15.767969] b43-phy0 ERROR: Firmware file "b43-open/ucode15.fw" not found
[   15.767972] b43-phy0 ERROR: You must go to http://wireless.kernel.org/en/users/Drivers/b43#devicefirmware and download the correct firmware for this driver version. Please carefully read all instructions on this website.
[   16.150767] uvcvideo: Found UVC 1.00 device Laptop_Integrated_Webcam_2M (0c45:6417)
[   16.159886] input: Laptop_Integrated_Webcam_2M as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input14
[   16.160001] usbcore: registered new interface driver uvcvideo
[   16.160003] USB Video Class driver (1.1.1)
[   16.291030] fglrx: module license 'Proprietary. (C) 2002 - ATI Technologies, Starnberg, GERMANY' taints kernel.
[   16.291036] Disabling lock debugging due to kernel taint
[   16.296402] fglrx: module verification failed: signature and/or  required key missing - tainting kernel
[   16.302327] <6>[fglrx] Maximum main memory to use for locked dma buffers: 3656 MBytes.
[   16.302634] <6>[fglrx]   vendor: 1002 device: 68e0 count: 1
[   16.303026] <6>[fglrx] ioport: bar 4, base 0x2000, size: 0x100
[   16.303233] <6>[fglrx] Kernel PAT support is enabled
[   16.303257] <6>[fglrx] module loaded - fglrx 13.35.5 [Mar 12 2014] with 1 minors
[   16.525949] type=1400 audit(1402986637.953:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=572 comm="apparmor_parser"
[   16.525958] type=1400 audit(1402986637.953:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=572 comm="apparmor_parser"
[   16.525964] type=1400 audit(1402986637.953:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=572 comm="apparmor_parser"
[   16.525972] type=1400 audit(1402986637.953:5): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/sbin/dhclient" pid=500 comm="apparmor_parser"
[   16.525980] type=1400 audit(1402986637.953:6): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=500 comm="apparmor_parser"
[   16.525986] type=1400 audit(1402986637.953:7): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=500 comm="apparmor_parser"
[   16.526635] type=1400 audit(1402986637.957:8): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=500 comm="apparmor_parser"
[   16.526642] type=1400 audit(1402986637.957:9): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=500 comm="apparmor_parser"
[   16.526687] type=1400 audit(1402986637.957:10): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=572 comm="apparmor_parser"
[   16.526694] type=1400 audit(1402986637.957:11): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=572 comm="apparmor_parser"
[   16.955082] cfg80211: World regulatory domain updated:
[   16.955087] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   16.955089] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   16.955090] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   16.955092] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[   16.955093] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   16.955094] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   17.155205] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[   18.419589] init: failsafe main process (756) killed by TERM signal
[   21.736726] audit_printk_skb: 174 callbacks suppressed
[   21.736730] type=1400 audit(1402986643.161:70): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/sbin/cups-browsed" pid=979 comm="apparmor_parser"
[   21.802231] type=1400 audit(1402986643.229:71): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=991 comm="apparmor_parser"
[   21.802240] type=1400 audit(1402986643.229:72): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/sbin/cupsd" pid=991 comm="apparmor_parser"
[   21.802663] type=1400 audit(1402986643.229:73): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/sbin/cupsd" pid=991 comm="apparmor_parser"
[   23.163576] init: gdm main process (1106) killed by TERM signal
[   23.965670] Bluetooth: Core ver 2.17
[   23.965697] NET: Registered protocol family 31
[   23.965698] Bluetooth: HCI device and connection manager initialized
[   23.965710] Bluetooth: HCI socket layer initialized
[   23.965713] Bluetooth: L2CAP socket layer initialized
[   23.965718] Bluetooth: SCO socket layer initialized
[   24.009438] init: cups main process (992) killed by HUP signal
[   24.009451] init: cups main process ended, respawning
[   24.858146] Bluetooth: RFCOMM TTY layer initialized
[   24.858162] Bluetooth: RFCOMM socket layer initialized
[   24.858169] Bluetooth: RFCOMM ver 1.11
[   24.932580] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   24.932586] Bluetooth: BNEP filters: protocol multicast
[   24.932599] Bluetooth: BNEP socket layer initialized
[   25.225794] vboxdrv: Found 4 processor cores.
[   25.226584] vboxdrv: fAsync=0 offMin=0x204 offMax=0x130e
[   25.226703] vboxdrv: TSC mode is 'synchronous', kernel timer mode is 'normal'.
[   25.226705] vboxdrv: Successfully loaded version 4.3.10_Ubuntu (interface 0x001a0007).
[   25.771510] vboxpci: IOMMU not found (not registered)
[   28.166888] r8169 0000:09:00.0 eth0: link down
[   28.166908] r8169 0000:09:00.0 eth0: link down
[   28.166935] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   28.167228] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   29.007859] init: samba-ad-dc main process (1159) terminated with status 1
[   29.797947] r8169 0000:09:00.0 eth0: link up
[   29.797964] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   37.467136] init: udev-fallback-graphics main process (1964) terminated with status 1
[   38.798640] fglrx_pci 0000:02:00.0: irq 46 for MSI/MSI-X
[   38.799443] <6>[fglrx] Firegl kernel thread PID: 2123
[   38.799648] <6>[fglrx] Firegl kernel thread PID: 2124
[   38.799830] <6>[fglrx] Firegl kernel thread PID: 2125
[   38.799966] <6>[fglrx] IRQ 46 Enabled
[   38.836468] <6>[fglrx] Reserved FB block: Shared offset:0, size:1000000
[   38.836472] <6>[fglrx] Reserved FB block: Unshared offset:f8c6000, size:4000
[   38.836474] <6>[fglrx] Reserved FB block: Unshared offset:f8ca000, size:436000
[   38.836475] <6>[fglrx] Reserved FB block: Unshared offset:3fff4000, size:c000
[   38.877753] <6>[fglrx] ATIF platform detected with notification ID: 0x81
[   41.999630] init: plymouth-upstart-bridge main process ended, respawning
[   42.006611] init: plymouth-upstart-bridge main process (2137) terminated with status 1
[   42.006625] init: plymouth-upstart-bridge main process ended, respawning
[   52.154004] type=1400 audit(1402986672.981:74): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=2485 comm="apparmor_parser"
[   52.154012] type=1400 audit(1402986672.981:75): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/sbin/cupsd" pid=2485 comm="apparmor_parser"
[   52.154434] type=1400 audit(1402986672.981:76): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/sbin/cupsd" pid=2485 comm="apparmor_parser"
[  197.748817] usb 2-1.3: USB disconnect, device number 3
[  199.503328] usb 2-1.3: new full-speed USB device number 4 using ehci-pci
[  199.596994] usb 2-1.3: New USB device found, idVendor=2341, idProduct=0036
[  199.597002] usb 2-1.3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[  199.597006] usb 2-1.3: Product: Arduino Leonardo
[  199.597010] usb 2-1.3: Manufacturer: Arduino LLC
[  199.597451] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[  207.549673] usb 2-1.3: USB disconnect, device number 4
[  207.748451] usb 2-1.3: new full-speed USB device number 5 using ehci-pci
[  207.844202] usb 2-1.3: New USB device found, idVendor=2341, idProduct=8036
[  207.844211] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  207.844236] usb 2-1.3: Product: Arduino Leonardo
[  207.844240] usb 2-1.3: Manufacturer: Arduino LLC
[  207.844653] cdc_acm 2-1.3:1.0: This device cannot do calls on its own. It is not a modem.
[  207.844692] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[  207.846666] input: Arduino LLC Arduino Leonardo as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.2/input/input15
[  207.846980] hid-generic 0003:2341:8036.0002: input,hidraw0: USB HID v1.01 Mouse [Arduino LLC Arduino Leonardo] on usb-0000:00:1d.0-1.3/input2
[  221.381931] usb 2-1.3: USB disconnect, device number 5
[  329.911745] usb 2-1.3: new full-speed USB device number 6 using ehci-pci
[  330.005545] usb 2-1.3: New USB device found, idVendor=2341, idProduct=0036
[  330.005550] usb 2-1.3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[  330.005554] usb 2-1.3: Product: Arduino Leonardo
[  330.005557] usb 2-1.3: Manufacturer: Arduino LLC
[  330.005933] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[  337.960964] usb 2-1.3: USB disconnect, device number 6
[  338.160853] usb 2-1.3: new full-speed USB device number 7 using ehci-pci
[  338.256365] usb 2-1.3: New USB device found, idVendor=2341, idProduct=8036
[  338.256372] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  338.256376] usb 2-1.3: Product: Arduino Leonardo
[  338.256380] usb 2-1.3: Manufacturer: Arduino LLC
[  338.256796] cdc_acm 2-1.3:1.0: This device cannot do calls on its own. It is not a modem.
[  338.256832] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[  338.259095] input: Arduino LLC Arduino Leonardo as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.2/input/input16
[  338.259402] hid-generic 0003:2341:8036.0003: input,hidraw0: USB HID v1.01 Mouse [Arduino LLC Arduino Leonardo] on usb-0000:00:1d.0-1.3/input2
[  432.995292] usb 2-1.3: USB disconnect, device number 7
[  438.726779] usb 2-1.3: new full-speed USB device number 8 using ehci-pci
[  438.820555] usb 2-1.3: New USB device found, idVendor=2341, idProduct=0036
[  438.820565] usb 2-1.3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[  438.820571] usb 2-1.3: Product: Arduino Leonardo
[  438.820577] usb 2-1.3: Manufacturer: Arduino LLC
[  438.820997] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[  446.772441] usb 2-1.3: USB disconnect, device number 8
[  446.971872] usb 2-1.3: new full-speed USB device number 9 using ehci-pci
[  447.067547] usb 2-1.3: New USB device found, idVendor=2341, idProduct=8036
[  447.067556] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  447.067560] usb 2-1.3: Product: Arduino Leonardo
[  447.067564] usb 2-1.3: Manufacturer: Arduino LLC
[  447.067947] cdc_acm 2-1.3:1.0: This device cannot do calls on its own. It is not a modem.
[  447.067982] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[  447.070466] input: Arduino LLC Arduino Leonardo as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.2/input/input17
[  447.070764] hid-generic 0003:2341:8036.0004: input,hidraw0: USB HID v1.01 Mouse [Arduino LLC Arduino Leonardo] on usb-0000:00:1d.0-1.3/input2
[  508.947225] systemd-hostnamed[8280]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
[ 1058.645919] perf samples too long (2525 > 2500), lowering kernel.perf_event_max_sample_rate to 50000
[ 1764.449368] usb 2-1.3: USB disconnect, device number 9
[ 2060.498464] usb 2-1.3: new full-speed USB device number 10 using ehci-pci
[ 2060.592086] usb 2-1.3: New USB device found, idVendor=2341, idProduct=0036
[ 2060.592093] usb 2-1.3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 2060.592097] usb 2-1.3: Product: Arduino Leonardo
[ 2060.592100] usb 2-1.3: Manufacturer: Arduino LLC
[ 2060.592590] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 2068.521136] usb 2-1.3: USB disconnect, device number 10
[ 2068.719354] usb 2-1.3: new full-speed USB device number 11 using ehci-pci
[ 2068.815138] usb 2-1.3: New USB device found, idVendor=2341, idProduct=8036
[ 2068.815145] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2068.815150] usb 2-1.3: Product: Arduino Leonardo
[ 2068.815153] usb 2-1.3: Manufacturer: Arduino LLC
[ 2068.815559] cdc_acm 2-1.3:1.0: This device cannot do calls on its own. It is not a modem.
[ 2068.815589] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 2068.817599] input: Arduino LLC Arduino Leonardo as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.2/input/input18
[ 2068.817970] hid-generic 0003:2341:8036.0005: input,hidraw0: USB HID v1.01 Mouse [Arduino LLC Arduino Leonardo] on usb-0000:00:1d.0-1.3/input2
[ 2336.718408] usb 2-1.3: USB disconnect, device number 11
[ 2338.553704] usb 2-1.3: new full-speed USB device number 12 using ehci-pci
[ 2338.647651] usb 2-1.3: New USB device found, idVendor=2341, idProduct=0036
[ 2338.647658] usb 2-1.3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 2338.647661] usb 2-1.3: Product: Arduino Leonardo
[ 2338.647664] usb 2-1.3: Manufacturer: Arduino LLC
[ 2338.648060] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 2346.590732] usb 2-1.3: USB disconnect, device number 12
[ 2346.790786] usb 2-1.3: new full-speed USB device number 13 using ehci-pci
[ 2346.886174] usb 2-1.3: New USB device found, idVendor=2341, idProduct=8036
[ 2346.886180] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2346.886184] usb 2-1.3: Product: Arduino Leonardo
[ 2346.886187] usb 2-1.3: Manufacturer: Arduino LLC
[ 2346.886450] cdc_acm 2-1.3:1.0: This device cannot do calls on its own. It is not a modem.
[ 2346.886475] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 2346.888371] input: Arduino LLC Arduino Leonardo as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.2/input/input19
[ 2346.888571] hid-generic 0003:2341:8036.0006: input,hidraw0: USB HID v1.01 Mouse [Arduino LLC Arduino Leonardo] on usb-0000:00:1d.0-1.3/input2
[ 2826.630893] usb 2-1.3: USB disconnect, device number 13
[ 2828.511679] usb 2-1.3: new full-speed USB device number 14 using ehci-pci
[ 2828.605228] usb 2-1.3: New USB device found, idVendor=2341, idProduct=0036
[ 2828.605234] usb 2-1.3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 2828.605236] usb 2-1.3: Product: Arduino Leonardo
[ 2828.605238] usb 2-1.3: Manufacturer: Arduino LLC
[ 2828.605624] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 2836.553997] usb 2-1.3: USB disconnect, device number 14
[ 2836.752793] usb 2-1.3: new full-speed USB device number 15 using ehci-pci
[ 2836.848568] usb 2-1.3: New USB device found, idVendor=2341, idProduct=8036
[ 2836.848576] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2836.848601] usb 2-1.3: Product: Arduino Leonardo
[ 2836.848606] usb 2-1.3: Manufacturer: Arduino LLC
[ 2836.848987] cdc_acm 2-1.3:1.0: This device cannot do calls on its own. It is not a modem.
[ 2836.849026] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 2836.851036] input: Arduino LLC Arduino Leonardo as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.2/input/input20
[ 2836.851354] hid-generic 0003:2341:8036.0007: input,hidraw0: USB HID v1.01 Mouse [Arduino LLC Arduino Leonardo] on usb-0000:00:1d.0-1.3/input2
[ 2902.386506] usb 2-1.3: USB disconnect, device number 15
[ 2934.757192] usb 2-1.3: new full-speed USB device number 16 using ehci-pci
[ 2934.850572] usb 2-1.3: New USB device found, idVendor=2341, idProduct=0036
[ 2934.850580] usb 2-1.3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 2934.850584] usb 2-1.3: Product: Arduino Leonardo
[ 2934.850588] usb 2-1.3: Manufacturer: Arduino LLC
[ 2934.851443] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 2942.804256] usb 2-1.3: USB disconnect, device number 16
[ 2943.002271] usb 2-1.3: new full-speed USB device number 17 using ehci-pci
[ 2943.098091] usb 2-1.3: New USB device found, idVendor=2341, idProduct=8036
[ 2943.098102] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2943.098108] usb 2-1.3: Product: Arduino Leonardo
[ 2943.098116] usb 2-1.3: Manufacturer: Arduino LLC
[ 2943.098515] cdc_acm 2-1.3:1.0: This device cannot do calls on its own. It is not a modem.
[ 2943.098555] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 2943.100665] input: Arduino LLC Arduino Leonardo as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.2/input/input21
[ 2943.100964] hid-generic 0003:2341:8036.0008: input,hidraw0: USB HID v1.01 Mouse [Arduino LLC Arduino Leonardo] on usb-0000:00:1d.0-1.3/input2
[ 3166.174030] usb 2-1.3: USB disconnect, device number 17
[ 3170.726612] usb 2-1.3: new full-speed USB device number 18 using ehci-pci
[ 3170.820294] usb 2-1.3: New USB device found, idVendor=2341, idProduct=0036
[ 3170.820301] usb 2-1.3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 3170.820305] usb 2-1.3: Product: Arduino Leonardo
[ 3170.820309] usb 2-1.3: Manufacturer: Arduino LLC
[ 3170.820783] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 3178.780826] usb 2-1.3: USB disconnect, device number 18
[ 3178.979704] usb 2-1.3: new full-speed USB device number 19 using ehci-pci
[ 3179.075495] usb 2-1.3: New USB device found, idVendor=2341, idProduct=8036
[ 3179.075503] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3179.075525] usb 2-1.3: Product: Arduino Leonardo
[ 3179.075529] usb 2-1.3: Manufacturer: Arduino LLC
[ 3179.075904] cdc_acm 2-1.3:1.0: This device cannot do calls on its own. It is not a modem.
[ 3179.075933] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 3179.078085] input: Arduino LLC Arduino Leonardo as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.2/input/input22
[ 3179.078453] hid-generic 0003:2341:8036.0009: input,hidraw0: USB HID v1.01 Mouse [Arduino LLC Arduino Leonardo] on usb-0000:00:1d.0-1.3/input2
[ 3255.115784] usb 2-1.3: USB disconnect, device number 19
[ 3259.481377] usb 2-1.3: new full-speed USB device number 20 using ehci-pci
[ 3259.575043] usb 2-1.3: New USB device found, idVendor=2341, idProduct=0036
[ 3259.575049] usb 2-1.3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 3259.575053] usb 2-1.3: Product: Arduino Leonardo
[ 3259.575056] usb 2-1.3: Manufacturer: Arduino LLC
[ 3259.575449] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 3265.667055] systemd-hostnamed[18483]: Warning: nss-myhostname is not installed. Changing the local hostname might make it unresolveable. Please install nss-myhostname!
[ 3267.532959] usb 2-1.3: USB disconnect, device number 20
[ 3267.730462] usb 2-1.3: new full-speed USB device number 21 using ehci-pci
[ 3267.825877] usb 2-1.3: New USB device found, idVendor=2341, idProduct=8036
[ 3267.825885] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3267.825889] usb 2-1.3: Product: Arduino Leonardo
[ 3267.825893] usb 2-1.3: Manufacturer: Arduino LLC
[ 3267.826304] cdc_acm 2-1.3:1.0: This device cannot do calls on its own. It is not a modem.
[ 3267.826339] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 3267.828597] input: Arduino LLC Arduino Leonardo as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.2/input/input23
[ 3267.828896] hid-generic 0003:2341:8036.000A: input,hidraw0: USB HID v1.01 Mouse [Arduino LLC Arduino Leonardo] on usb-0000:00:1d.0-1.3/input2
[ 3339.769644] usb 2-1.3: USB disconnect, device number 21
[ 4113.491765] usb 2-1.3: new full-speed USB device number 22 using ehci-pci
[ 4113.585423] usb 2-1.3: New USB device found, idVendor=2341, idProduct=0036
[ 4113.585430] usb 2-1.3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 4113.585434] usb 2-1.3: Product: Arduino Leonardo
[ 4113.585437] usb 2-1.3: Manufacturer: Arduino LLC
[ 4113.585979] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 4121.540956] usb 2-1.3: USB disconnect, device number 22
[ 4121.740873] usb 2-1.3: new full-speed USB device number 23 using ehci-pci
[ 4121.836384] usb 2-1.3: New USB device found, idVendor=2341, idProduct=8036
[ 4121.836393] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4121.836399] usb 2-1.3: Product: Arduino Leonardo
[ 4121.836404] usb 2-1.3: Manufacturer: Arduino LLC
[ 4121.836912] cdc_acm 2-1.3:1.0: This device cannot do calls on its own. It is not a modem.
[ 4121.836945] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 4121.839352] input: Arduino LLC Arduino Leonardo as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.2/input/input24
[ 4121.839766] hid-generic 0003:2341:8036.000B: input,hidraw0: USB HID v1.01 Mouse [Arduino LLC Arduino Leonardo] on usb-0000:00:1d.0-1.3/input2
[ 4177.639556] usb 2-1.3: USB disconnect, device number 23
[ 4193.300891] usb 2-1.3: new full-speed USB device number 24 using ehci-pci
[ 4193.394714] usb 2-1.3: New USB device found, idVendor=2341, idProduct=0036
[ 4193.394721] usb 2-1.3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 4193.394725] usb 2-1.3: Product: Arduino Leonardo
[ 4193.394729] usb 2-1.3: Manufacturer: Arduino LLC
[ 4193.395250] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 4201.356735] usb 2-1.3: USB disconnect, device number 24
[ 4201.553988] usb 2-1.3: new full-speed USB device number 25 using ehci-pci
[ 4201.649898] usb 2-1.3: New USB device found, idVendor=2341, idProduct=8036
[ 4201.649906] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4201.649910] usb 2-1.3: Product: Arduino Leonardo
[ 4201.649914] usb 2-1.3: Manufacturer: Arduino LLC
[ 4201.650333] cdc_acm 2-1.3:1.0: This device cannot do calls on its own. It is not a modem.
[ 4201.650373] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 4201.652633] input: Arduino LLC Arduino Leonardo as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.2/input/input25
[ 4201.652938] hid-generic 0003:2341:8036.000C: input,hidraw0: USB HID v1.01 Mouse [Arduino LLC Arduino Leonardo] on usb-0000:00:1d.0-1.3/input2
[ 4219.543953] usb 2-1.3: USB disconnect, device number 25
[ 4245.893162] usb 2-1.3: new full-speed USB device number 26 using ehci-pci
[ 4245.987273] usb 2-1.3: New USB device found, idVendor=2341, idProduct=0036
[ 4245.987279] usb 2-1.3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 4245.987283] usb 2-1.3: Product: Arduino Leonardo
[ 4245.987286] usb 2-1.3: Manufacturer: Arduino LLC
[ 4245.987784] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 4253.943537] usb 2-1.3: USB disconnect, device number 26
[ 4254.142410] usb 2-1.3: new full-speed USB device number 27 using ehci-pci
[ 4254.238072] usb 2-1.3: New USB device found, idVendor=2341, idProduct=8036
[ 4254.238079] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4254.238084] usb 2-1.3: Product: Arduino Leonardo
[ 4254.238087] usb 2-1.3: Manufacturer: Arduino LLC
[ 4254.238500] cdc_acm 2-1.3:1.0: This device cannot do calls on its own. It is not a modem.
[ 4254.238540] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 4254.240950] input: Arduino LLC Arduino Leonardo as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.2/input/input26
[ 4254.241266] hid-generic 0003:2341:8036.000D: input,hidraw0: USB HID v1.01 Mouse [Arduino LLC Arduino Leonardo] on usb-0000:00:1d.0-1.3/input2
[ 4272.130628] usb 2-1.3: USB disconnect, device number 27
[ 4277.044504] usb 2-1.3: new full-speed USB device number 28 using ehci-pci
[ 4277.138185] usb 2-1.3: New USB device found, idVendor=2341, idProduct=0036
[ 4277.138191] usb 2-1.3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 4277.138194] usb 2-1.3: Product: Arduino Leonardo
[ 4277.138197] usb 2-1.3: Manufacturer: Arduino LLC
[ 4277.138718] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 4285.087468] usb 2-1.3: USB disconnect, device number 28
[ 4285.285605] usb 2-1.3: new full-speed USB device number 29 using ehci-pci
[ 4285.381126] usb 2-1.3: New USB device found, idVendor=2341, idProduct=8036
[ 4285.381133] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4285.381138] usb 2-1.3: Product: Arduino Leonardo
[ 4285.381141] usb 2-1.3: Manufacturer: Arduino LLC
[ 4285.381567] cdc_acm 2-1.3:1.0: This device cannot do calls on its own. It is not a modem.
[ 4285.381597] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 4285.383727] input: Arduino LLC Arduino Leonardo as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.2/input/input27
[ 4285.384074] hid-generic 0003:2341:8036.000E: input,hidraw0: USB HID v1.01 Mouse [Arduino LLC Arduino Leonardo] on usb-0000:00:1d.0-1.3/input2
[ 4306.860773] usb 2-1.3: USB disconnect, device number 29
[ 4444.443697] usb 2-1.3: new full-speed USB device number 30 using ehci-pci
[ 4444.537398] usb 2-1.3: New USB device found, idVendor=2341, idProduct=0036
[ 4444.537404] usb 2-1.3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 4444.537408] usb 2-1.3: Product: Arduino Leonardo
[ 4444.537411] usb 2-1.3: Manufacturer: Arduino LLC
[ 4444.537780] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 4452.481283] usb 2-1.3: USB disconnect, device number 30
[ 4452.680787] usb 2-1.3: new full-speed USB device number 31 using ehci-pci
[ 4452.776445] usb 2-1.3: New USB device found, idVendor=2341, idProduct=8036
[ 4452.776451] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4452.776456] usb 2-1.3: Product: Arduino Leonardo
[ 4452.776460] usb 2-1.3: Manufacturer: Arduino LLC
[ 4452.776889] cdc_acm 2-1.3:1.0: This device cannot do calls on its own. It is not a modem.
[ 4452.776924] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 4452.779294] input: Arduino LLC Arduino Leonardo as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.2/input/input28
[ 4452.779634] hid-generic 0003:2341:8036.000F: input,hidraw0: USB HID v1.01 Mouse [Arduino LLC Arduino Leonardo] on usb-0000:00:1d.0-1.3/input2
[ 4644.855813] usb 2-1.3: USB disconnect, device number 31
[ 4648.345275] usb 2-1.3: new full-speed USB device number 32 using ehci-pci
[ 4648.439211] usb 2-1.3: New USB device found, idVendor=2341, idProduct=0036
[ 4648.439216] usb 2-1.3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 4648.439220] usb 2-1.3: Product: Arduino Leonardo
[ 4648.439223] usb 2-1.3: Manufacturer: Arduino LLC
[ 4648.439762] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 4656.386480] usb 2-1.3: USB disconnect, device number 32
[ 4656.586533] usb 2-1.3: new full-speed USB device number 33 using ehci-pci
[ 4656.682014] usb 2-1.3: New USB device found, idVendor=2341, idProduct=8036
[ 4656.682021] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4656.682025] usb 2-1.3: Product: Arduino Leonardo
[ 4656.682029] usb 2-1.3: Manufacturer: Arduino LLC
[ 4656.682492] cdc_acm 2-1.3:1.0: This device cannot do calls on its own. It is not a modem.
[ 4656.682521] cdc_acm 2-1.3:1.0: ttyACM0: USB ACM device
[ 4656.684622] input: Arduino LLC Arduino Leonardo as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.2/input/input29
[ 4656.684885] hid-generic 0003:2341:8036.0010: input,hidraw0: USB HID v1.01 Mouse [Arduino LLC Arduino Leonardo] on usb-0000:00:1d.0-1.3/input2
ramon_sobaka
Всем спасибо. Решено.
sudo chmod a+rw /dev/ttyACM0
