arduino uno + ethernet shiel нужна помощь
domrustika
привет всем. собственно все видно на видео. помогите кто может что исправить в коде нужно?
 * arduWebRelays.ino
 * Created: 07/09/2013 15:55:00
 *  Author: Guillaume Carriere - guillaume.carriere@gmail.com
  VCC -   3.3V
  GND -    GND
  SCK - Pin 13
  SO  - Pin 12
  SI  - Pin 11
  CS  - Pin  8 # Selectable with the ether.begin() function
#include <EtherCard.h>
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x32 };
static byte myip[] = { 192,168,2,50 };
int etap = 0;
#define BUFFER_SIZE   500
byte Ethernet::buffer[BUFFER_SIZE];
BufferFiller bfill;
#define CS_PIN       10
#define RELAIS_1     5
#define RELAIS_2     6
bool relais1Status = false;
bool relais2Status = false;
const char http_OK[] PROGMEM =
"HTTP/1.0 200 OK\r\n"
"Content-Type: text/html\r\n"
"Pragma: no-cache\r\n\r\n";
const char http_Found[] PROGMEM =
"HTTP/1.0 302 Found\r\n"
"Location: /\r\n\r\n";
const char http_Unauthorized[] PROGMEM =
"HTTP/1.0 401 Unauthorized\r\n"
"Content-Type: text/html\r\n\r\n"
"<h1>401 Unauthorized</h1>";
void homePage()
  bfill.emit_p(PSTR("$F"
    "<title>Интернет-розетка</title>"
    "Розетка 1: <a href=\"?relais1=$F\">$F</a><br />"
    "Розетка 2: <a href=\"?relais2=$F\">$F</a>"),
  http_OK,
  relais1Status?PSTR("off"):PSTR("on"),
  relais1Status?PSTR("<font color=\"green\"><b>Выключено</b></font>"):PSTR("<font color=\"red\">Включено</font>"),
  relais2Status?PSTR("off"):PSTR("on"),
  relais2Status?PSTR("<font color=\"green\"><b>Выключено</b></font>"):PSTR("<font color=\"red\">Включено</font>"));
  Serial.begin(115200);
  pinMode(RELAIS_1, OUTPUT);
  pinMode(RELAIS_2, OUTPUT);
  if (ether.begin(BUFFER_SIZE, mymac, CS_PIN) == 0)
    Serial.println("Cannot initialise ethernet.");
    Serial.println("Ethernet initialised.");
  ether.staticSetup(myip);
//  Serial.println("Setting up DHCP");
//  if (!ether.dhcpSetup())
//    Serial.println( "DHCP failed");
  ether.printIp("My IP: ", ether.myip);
  ether.printIp("Netmask: ", ether.netmask);
  ether.printIp("GW IP: ", ether.gwip);
  ether.printIp("DNS IP: ", ether.dnsip);
//  digitalWrite(RELAIS_1, relais1Status);
//  digitalWrite(RELAIS_2, relais2Status);
  delay(1);   // necessary for my system
  word len = ether.packetReceive();   // check for ethernet packet
  word pos = ether.packetLoop(len);   // check for tcp packet
  if (pos) {
    bfill = ether.tcpOffset();
    char *data = (char *) Ethernet::buffer + pos;
    if (strncmp("GET /", data, 5) != 0) {
      // Unsupported HTTP request
      // 304 or 501 response would be more appropriate
      bfill.emit_p(http_Unauthorized);
    else {
      Serial.print("----");
      Serial.print(data);
      Serial.println("----");
      data += 5;
      if (data[0] == ' ') {
        // Return home page
        homePage();
      else if (strncmp("?relais1=on ", data, 12) == 0) {
        if (etap == 0)
            relais1Status = true;
            delay(1500);
            etap ++;
        bfill.emit_p(http_Found);
        if (etap > 2)
            etap = 0;
      else if (strncmp("?relais1=off ", data, 13) == 0) {
        if (etap == 0)
            delay(1500);
            etap ++;
      else {
        // Page not found
    ether.httpServerReply(bfill.position());    // send http response
http://youtu.be/FnnWvMbb5v8
Penni
Penni аватар
Даже не смотря видео скажите что будет при etap=1?
domrustika
я не знаю мне код писал мой друг, но он не смог реализовать как надо.
поэтому прошу помощи здесь.
Penni
Penni аватар
Если бы объяснили логику работы может кто-то и помог бы, а так мягко говорят другу надо выговор сделать за такой код. При etap=1 вообще ничего не делается. При получении on или off выполняется один и тот же код (абсолютно одинаковых 6ть строк) и при этом ничего не возвращается клиенту, в браузере ничего не будет обновляться.
Как оно должно работать?
domrustika
логика работы должна быть простой -
заходим на страницу . жмем 1 раз мышкой на слове включено первой строки-------она меняется на слово выключено-------реле вЫключается и через секунду опять включается.
вот только и всего что нужно.
и так по кругу.
Penni
Penni аватар
И когда нажимаем на вЫключено тоже самое должно произойти? :)
domrustika
да :) это реле нужно чисто для того что бы через интернет РЕСЕСТИТЬ модем. тоесть реле будет стоять в РАЗРЫВ провода питания роутера и перегружать его по нажатию на надпись.
Penni
Penni аватар
Понятно, ну тогда для интереса комментируем 113, 114, 120, 121, 123-126 строки и смотрим что получится. Должно щелкаться, но надпись в браузере все равно не меняться.
domrustika
сделал так. теперь при нажатии на надпись реле щелкает 3 раза и только потом устанавливается.(загорается его светодиод)
почему так? все так как мне надо только надо убрать тройное срабатывание реле.
Penni
Penni аватар
Ну а в ком-порт что выдает? Какие заголовки приходят? Похоже друг с помощью etap пытался отсеить лишнее, да неудачно. В общем что в ком порт выдает?
domrustika
приходит в программу terminal какая то ересь вроде такой
©NРЩБюљњЂа”ў и
может Вы можете свой вариант кода предложить для моего сценария?
был бы очень благодарен.
Penni
Penni аватар
Я с ENC28J60 не работал, библиотеку EtherCard.h не знаю. Проще тот код что есть поправить чтобы работал. В 60 строке замените 115200 на 9600. Соответственно в терминале выставьте скорость 9600. Терминалов из Arduino IDE пользуетесь или сторонним? Надо просто понять что там приходит, раз три раза срабатывает значит strncmp три раза находит в буфере искомое.
Penni
Penni аватар
Попробуйте ради интереса взять исходный скетч ничего не комментируя. 123 строку заменить на if (epat==3). А 126 строку заменить на } else etap++;
domrustika
огромное Вам спасибо!!!))))) последний пост ваш все решил)) теперь работает все как надо)))
только еще 1 вопрос остался как на страницу после нажатия на надпись вывести хоть что нибудь да любое символ надпись да что угодно что бы я знал что реле сработало? а то как щас---- я жму на надпись включено -----реле выкл/включается а на странице ничего не поймешь нажалась она или нет может хоть надпись менять при срабатывании на выключено????
Penni
Penni аватар
Да у Вас там криво сделано в том плане что страница формируется после перещелкивания реле, а значит реле всегда включено и надпись не меняется. Надо переделывать ответ. Вечером время будет посмотрю как можно
Penni
Penni аватар
Ну если особо не заморачиваться, то можно попробовать следующим образом:
В 28 пишем bool relais1Status = true;
В 52 строке пишем relais1Status?PSTR("on"):PSTR("on"),
115 строку комментируем
116 строку меняем на
 digitalWrite(RELAIS_1, HIGH);
118 заменяем на relais1Status = !relais1Status;
119 строку меняем на
digitalWrite(RELAIS_1, LOW);
Смотрим что получилось
Ну и соответственно все те изменения что были раньше сделаны, с которыми всё худо бедно заработало.
pastry777
ересь приходит если не совпадает скорость ком порта в мониторе и в скетче,установите соответствующую..
