Что не так с кодом - MQTT + w5100+UNOv3
maksmkv
Всем привет. Вот есть рабочий код - упраление реле через RF433. Запускаю mosquitoo - минуты 2 отсилы все работает,  а  потом  пишет disconnect  - почему так происходит?
  433toMQTTto433  - Arduino program for home automation
   Act as a gateway between your nodes and a MQTT broker
 Send and receiving command by MQTT
  This program enables to:
 - receive MQTT data from a topic and send RF 433Mhz signal corresponding to the received MQTT data
 - publish MQTT data to a different topic related to received 433Mhz signal
  Contributors:
  - 1technophile
  - Spudtater
  Based on:
  - MQTT library (https://github.com/knolleary)
  - RCSwitch
  Project home: https://github.com/1technophile/433toMQTTto433
  Blog: https://1technophile.blogspot.com/
Permission is hereby granted, free of charge, to any person obtaining a copy of this software
and associated documentation files (the "Software"), to deal in the Software without restriction,
including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense,
and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so,
subject to the following conditions:
The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED
TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
Some usefull commands to test gateway with mosquitto
Subscribe to the subject for data receiption from RF signal
mosquitto_sub -t home/433toMQTT
Send data by MQTT to convert it on RF signal
mosquitto_pub -t home/MQTTto433/ -m 1315153
#include <Ethernet.h>
#include <PubSubClient.h>
#include <RCSwitch.h> // library for controling Radio frequency switch
RCSwitch mySwitch = RCSwitch();
//Do we want to see trace for debugging purposes
#define TRACE 1  // 0= trace off 1 = trace on
// Update these with values suitable for your network.
byte mac[]    = {  0xDE, 0xED, 0xBA, 0xFE, 0x34, 0x99 };
byte localserver[] = { 192, 168, 1, 237 };
byte ip[]     = { 192, 168, 1, 74 };
//adding this to bypass to problem of the arduino builder issue 50
void callback(char*topic, byte* payload,unsigned int length);
EthernetClient ethClient;
// client parameters
PubSubClient client(localserver, 1883, callback, ethClient);
//MQTT last attemps reconnection number
long lastReconnectAttempt = 0;
boolean reconnect() {
  if (client.connect("433toMQTTto433")) {
    // Once connected, publish an announcement...
    client.publish("outTopic","hello world");
    // Client connected
    trc("connected");
    //Topic subscribed so as to get data
    String topicNameRec = String("home/MQTTto433/");
    //Subscribing to topic(s)
    subscribing(topicNameRec);
  return client.connected();
// Callback function, when the gateway receive an MQTT value on the topics subscribed this function is called
void callback(char* topic, byte* payload, unsigned int length) {
  // In order to republish this payload, a copy must be made
  // as the orignal payload buffer will be overwritten whilst
  // constructing the PUBLISH packet.
  trc("Hey I got a callback ");
  // Allocate the correct amount of memory for the payload copy
  byte* p = (byte*)malloc(length);
  // Copy the payload to the new buffer
  memcpy(p,payload,length);
  // Conversion to a printable string
  p[length] = '\0';
  String callbackstring = String((char *) p);
  String topicNameRec = String((char*) topic);
  //launch the function to treat received data
  receivingMQTT(topicNameRec,callbackstring);
  // Free the memory
  free(p);
  //Launch serial for debugging purposes
  //Begining ethernet connection
  Ethernet.begin(mac, ip);
  delay(1500);
  // RF transmitter is connected to this pin 9, we activate it only when sending RF data to avoid conflict between transmitter and receiver
  pinMode(9, OUTPUT);
  digitalWrite(9, LOW);
  mySwitch.enableTransmit(10); // RF Transmitter is connected to Arduino Pin #10
  mySwitch.setRepeatTransmit(10); //increase transmit repeat to avoid lost of rf sendings
  mySwitch.enableReceive(0);  // Receiver on inerrupt 0 => that is pin #2
  //MQTT client connexion management
  if (!client.connected()) {
    long now = millis();
    if (now - lastReconnectAttempt > 5000) {
      lastReconnectAttempt = now;
      trc("client mqtt not connected, trying to connect");
      // Attempt to reconnect
      if (reconnect()) {
  } else {
    // MQTT loop
    client.loop();
  // Receive loop, if data received by RF433 send it by MQTT to MQTTsubject
  if (mySwitch.available()) {
    // Topic on which we will send data
    trc("Receiving 433Mhz signal");
    String MQTTsubject = "home/433toMQTT";
    long MQTTvalue;
    MQTTvalue=mySwitch.getReceivedValue();
    mySwitch.resetAvailable();
    if (client.connected()) {
      trc("Sending 433Mhz signal to MQTT");
      trc(String(MQTTvalue));
      sendMQTT(MQTTsubject,String(MQTTvalue));
    } else {
      if (reconnect()) {
void subscribing(String topicNameRec){ // MQTT subscribing to topic
  char topicStrRec[26];
  topicNameRec.toCharArray(topicStrRec,26);
  // subscription to topic for receiving data
  boolean pubresult = client.subscribe(topicStrRec);
  if (pubresult) {
    trc("subscription OK to");
    trc(topicNameRec);
void receivingMQTT(String topicNameRec, String callbackstring) {
  trc("Receiving data by MQTT");
  trc(topicNameRec);
  char topicOri[26] = "";
  char topicStrAck[26] = "";
  char datacallback[26] = "";
  // Below you send RF signal following data value received by MQTT
    // converting string to char for condition statement
    callbackstring.toCharArray(datacallback,26);
    trc(datacallback);
    long int data = atol(datacallback);
    trc("Send received data by RF 433");
    trc(String(data));
    //send received MQTT value by RF signal (example of signal sent data = 5264660), we activate the transmitter on pin 9 the time to send data by RF
    digitalWrite(9, HIGH);
    mySwitch.send(data, 24);
//send MQTT data dataStr to topic topicNameSend
void sendMQTT(String topicNameSend, String dataStr){
    char topicStrSend[26];
    topicNameSend.toCharArray(topicStrSend,26);
    char dataStrSend[200];
    dataStr.toCharArray(dataStrSend,200);
    boolean pubresult = client.publish(topicStrSend,dataStrSend);
    trc("sending ");
    trc(dataStr);
    trc("to ");
    trc(topicNameSend);
//trace
void trc(String msg){
  if (TRACE) {
  Serial.println(msg);
AG
MQTT сервер разрывает соединение по таймауту, нужно регулярно слать ему PINGи.
