Датчики и бибилиотека DHT
Вс, 13/05/2018 - 17:04
Помогите, проблема с библиотекой DHT, не могу считать данные из датчика,
test4:145: error: expected unqualified-id before '.' token
test4:146: error: expected primary-expression before '.' token
test4:147: error: expected primary-expression before '.' token
Помогите, мучаюсь второй день
// include the library code for LCD shield:
#include <Wire.h>
#include <Adafruit_MCP23017.h>
#include <Adafruit_RGBLCDShield.h>
// include code for temperature and humidity
#include <DHT.h>
//Setup Temperature and humidity
#define dht_dpin 2 //chanel for temperature sensor
//dht DHT;
//Setup LCD
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
// These #defines make it easy to set the backlight color
#define OFF 0x0
#define RED 0x1
#define YELLOW 0x3
#define GREEN 0x2
#define TEAL 0x6
#define BLUE 0x4
#define VIOLET 0x5
#define WHITE 0x7
//ports for input devices
int const smallPM1 = 13;
int const largePM1 = 12;
int const smallPM2 = 5;
int const largePM2 = 4;
int const mq2port = A0;
int const NO2port = A2;
int const mq9port = A1;
int const O3port = A3;
int const mq9powerPort = 3;
// constants for use with gas sensors
float const mq2seriesResistor = 47000;
float const NO2seriesResistor = 22000;
float const mq9seriesResistor = 10000;
float const O3seriesResistor = 22000;
// variables for use in running particulate matter calculations
long const sampleRate = 20;
long measurementCount = 0;
long smallPM1Count = 0;
long largePM1Count = 0;
long smallPM2Count = 0;
long largePM2Count = 0;
long priorSampleTime = 0;
double smallPM1percentRunning;
double largePM1percentRunning;
double smallPM2percentRunning;
double largePM2percentRunning;
//variables for gas sensor calcuations
float mq2resistance;
float NO2resistance;
float mq9resistance;
float O3resistance;
//variables for temperature and humidity
int temperature;
int humidity;
//miscellaneous variables
int mq9power = 300;
int displayNumber = 0;
lcd.begin(16, 2);
pinMode (smallPM1, INPUT);
pinMode (largePM1, INPUT);
pinMode (smallPM2, INPUT);
pinMode (largePM2, INPUT);
pinMode (mq2port, INPUT);
pinMode (NO2port, INPUT);
pinMode (mq9port, INPUT);
pinMode (O3port, INPUT);
pinMode (mq9power, OUTPUT);
analogWrite (mq9powerPort, mq9power);
lcd.setBacklight(WHITE);
samplePMDetectors(); //sample particulate detectors for 2 seconds and update running Averages
readResistances(); //calculateResistancesFromInputs
readTemperatureAndHumidity(); //aquire temperature and humidity data takes about 25ms
timestampSerial(); //print time
printRunningPMDataToSerial(); //print percentages to Serial
printGasDataToSerial(); //print gas sensor data to Serial
printTempAndHumidityToSerial();//print temperature and humidity data
Serial.println();
Serial.println();
displayLCD(); //display data on LCD
void samplePMDetectors() {
for (int i = 0; i < 100; i++) {
while (millis() - priorSampleTime < sampleRate) {
priorSampleTime = millis();
measurementCount += 1;
if (digitalRead(smallPM1) == 0) {
smallPM1Count += 1;
if (digitalRead(largePM1) == 0) {
largePM1Count += 1;
if (digitalRead(smallPM2) == 0) {
smallPM2Count += 1;
if (digitalRead(largePM2) == 0) {
largePM2Count += 1;
//calculate running PM percentages
smallPM1percentRunning = 100.0 * smallPM1Count / measurementCount;
largePM1percentRunning = 100.0 * largePM1Count / measurementCount;
smallPM2percentRunning = 100.0 * smallPM2Count / measurementCount;
largePM2percentRunning = 100.0 * largePM2Count / measurementCount;
void readResistances() {
//read gas sensor data
int mq2rawInput = analogRead(mq2port);
int NO2rawInput = analogRead(NO2port);
int mq9rawInput = analogRead(mq9port);
int O3rawInput = analogRead(O3port);
//calculate resistances
mq2resistance = mq2seriesResistor * ((1023.0 / mq2rawInput) - 1.0);
NO2resistance = NO2seriesResistor * ((1023.0 / NO2rawInput) - 1.0);
mq9resistance = mq9seriesResistor * ((1023.0 / mq9rawInput) - 1.0);
O3resistance = NO2seriesResistor * ((1023.0 / O3rawInput) - 1.0);
void readTemperatureAndHumidity() {
DHT.read11(dht_dpin);
humidity = (int) DHT.humidity;
temperature = (int) DHT.temperature;
void timestampSerial() {
Serial.print("Milliseconds since the program started: ");
Serial.println(millis());
void printRunningPMDataToSerial() {
Serial.println("Particulate Matter Data");
Serial.print("Measurement Count: ");
Serial.println(measurementCount);
Serial.print("Small PM detector 1: ");
Serial.println(smallPM1percentRunning);
Serial.print("Large PM detector 1: ");
Serial.println(largePM1percentRunning);
Serial.print("Small PM detector 2: ");
Serial.println(smallPM2percentRunning);
Serial.print("Large PM detector 2: ");
Serial.println(largePM2percentRunning);
Serial.println();
void printGasDataToSerial() {
Serial.println("Gas Sensor Data");
Serial.print("MQ-2 Resistance: ");
Serial.println(mq2resistance);
Serial.print("NO2 Resistance: ");
Serial.println(NO2resistance);
Serial.print("MQ-9 (CO2) Resistance: ");
Serial.println(mq9resistance);
Serial.print("Ozone Resistance: ");
Serial.println(O3resistance);
Serial.println();
void printTempAndHumidityToSerial() {
Serial.println("Temperature and Humidity Data");
Serial.print("temperature = ");
Serial.print(temperature);
Serial.print("C ");
Serial.print("Current humidity = ");
Serial.print(humidity);
Serial.println("% ");
Serial.println();
void displayLCD() {
lcd.clear();
lcd.setCursor(0, 0);
switch (displayNumber) {
case 0:
lcd.print("MeasurementTime");
lcd.setCursor(0, 1);
lcd.print(millis() / 1000);
case 1:
lcd.print("SmallPM#1:");
lcd.print(smallPM1percentRunning);
lcd.print(" %");
case 3:
lcd.print("LargePM#1:");
lcd.print(largePM1percentRunning);
lcd.print(" %");
case 2:
lcd.print("SmallPM#2:");
lcd.print(smallPM2percentRunning);
lcd.print(" %");
case 4:
lcd.print("LargePM#2:");
lcd.print(largePM2percentRunning);
lcd.print(" %");
case 5:
lcd.print("MQ2 Resistance:");
lcd.print((long) mq2resistance);
lcd.print(" Ohm");
case 6:
lcd.print("MQ9 Resistance:");
lcd.print((long) mq9resistance);
lcd.print(" Ohm");
case 7:
lcd.print("NO2 Resistance:");
lcd.print((long) NO2resistance);
lcd.print(" Ohm");
case 8:
lcd.print("O3 Resistance:");
lcd.print((long) O3resistance);
lcd.print(" Ohm");
case 9:
lcd.print("Temperature");
lcd.print(temperature);
lcd.print("C");
case 10:
lcd.print("Humidity");
lcd.print("%");
default:
displayNumber = -1;
lcd.clear();
displayNumber += 1;
Откуда взялась переменная DHT на 143-145 и что она должна делать?
она хранит занчения
float humidity = DHT.humidity;
float temperature = DHT.temperature;
А взялась она откуда? Каждая используемая переменная должна быть объявлена. В какой строчке объявлена переменная DHT?
DHT - функция для считывания данных
Переменнные humidity и temperature объявлены
Бред пишете. Срочно читать буквари по Си. Иначе то, что Вы раскомментируете 11-ю строку Вам ненадолго поможет.
DHT - это не функция, это класс и Вы обязаны объявить экземпляр этого класса. Вы попытались сделать это в строке 11, но неправильно, компилятор ругался, а поскольку отлаживаетесь Вы методом тыка, Вы её просто закомментировали.
Для начала, объявите нормально экземпляр класса DHT (хотя бы поменяйте местами DHT и dht в строке 11! Только этого недостаточно, ему ещё надо пин и тип датчика задать.
А чего Вы их тогда к DHT прицепили через точку? В таком контексте они не объявлены. Их просто нет в классе DHT.
Когда Вы объявите экземпляр класса DHT, то будете читать влажность и температуру методами readHumidity и readTemperature.
