Дребезг кнопки
Ср, 04/04/2012 - 00:25
Привет!
Прошу помочь устранить дребезг кнопки програмным путём. Собрать триггер пока неизчего, установка кондёра в паралель не помогает... замут Блюма недопираю...
const [color=#CC6600]int[/color] buttonPin = 2; const [color=#CC6600]int[/color] ledPin = 13; const [color=#CC6600]int[/color] led2Pin = 12; [color=#CC6600]int[/color] x = 2000000; [color=#CC6600]int[/color] buttonPushCounter = 0; [color=#CC6600]int[/color] buttonState = 0; [color=#CC6600]int[/color] lastButtonState =0; [color=#CC6600]unsigned[/color] [color=#CC6600]long[/color] duration; [color=#CC6600]void[/color] [color=#CC6600][b]setup[/b][/color]() { [color=#CC6600]pinMode[/color](buttonPin, [color=#006699]INPUT[/color]); [color=#CC6600]pinMode[/color](ledPin, [color=#006699]OUTPUT[/color]); [color=#CC6600]pinMode[/color](led2Pin, [color=#006699]OUTPUT[/color]); [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]begin[/color](9600); } [color=#CC6600]void[/color] [color=#CC6600][b]loop[/b][/color]() { buttonState = [color=#CC6600]digitalRead[/color](buttonPin); [color=#CC6600]if[/color] (buttonState != lastButtonState) { [color=#CC6600]if[/color] (buttonState == [color=#006699]HIGH[/color]) { buttonPushCounter++; [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]println[/color]([color=#006699]"on"[/color]); [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]print[/color]([color=#006699]"number of button pushes: "[/color]); [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]println[/color](buttonPushCounter); } [color=#CC6600]else[/color] { [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]println[/color]([color=#006699]"off"[/color]); } } lastButtonState = buttonState; [color=#CC6600]if[/color] (buttonPushCounter % 2 == 0) { [color=#CC6600]digitalWrite[/color](ledPin, [color=#006699]LOW[/color]); } [color=#CC6600]else[/color] { [color=#CC6600]digitalWrite[/color](ledPin, [color=#006699]HIGH[/color]); } duration = [color=#CC6600]pulseIn[/color](buttonPin, [color=#006699]HIGH[/color]); [color=#CC6600][b]Serial[/b][/color].[color=#CC6600]println[/color](duration); [color=#CC6600]if[/color] (duration > x ){ [color=#CC6600]digitalWrite[/color](led2Pin, [color=#006699]HIGH[/color]); } }
const int buttonPin = 2; const int ledPin = 13; const int led2Pin = 12; int x = 2000000; int buttonPushCounter = 0; int buttonState = 0; int lastButtonState =0; unsigned long duration; void setup() { pinMode(buttonPin, INPUT); pinMode(ledPin, OUTPUT); pinMode(led2Pin, OUTPUT); Serial.begin(9600); } void loop() { buttonState = digitalRead(buttonPin); if (buttonState != lastButtonState) { if (buttonState == HIGH) { buttonPushCounter++; Serial.println("on"); Serial.print("number of button pushes: "); Serial.println(buttonPushCounter); } else { Serial.println("off"); } } lastButtonState = buttonState; if (buttonPushCounter % 2 == 0) { digitalWrite(ledPin, LOW); } else { digitalWrite(ledPin, HIGH); } duration = pulseIn(buttonPin, HIGH); Serial.println(duration); if (duration > x ){ digitalWrite(led2Pin, HIGH); } }Вы можете описать, что вы хотите от этого кода?
Определяем переменные
В loop():
curState=curState*9/10+digitalRead(ButtonPin)*10; curStateI=curState*10; // переводим вещественное число в целое (диапазон 0...10) if(curStateI==STATE_ON && curStateI!=oldStateI) { // произошло надежное включение кнопки - выполняем необходимые действия [...] // и готовимся к дальнейшему слежению oldStateI=curStateI; } if(curStateI==STATE_OFF && curStateI!=oldStateI) { // произошло надежное выключение кнопки - выполняем необходимые действия (если таковые есть) [...] // и готовимся к дальнейшему слежению oldStateI=curStateI; }Программные триггеры будут срабатывать после завершения переходных процессов в кнопке (что при включении - первый, что при выключении - второй) и установившегося состояния (10 циклов с одним и тем же результатом опроса).
Чтобы кнопка "не западала", в цикле должны стоять обе проверки - и на нажатие, и на отпускание кнопки.
Ну и еще: в цикле не деолжно быть задержек - а то сглаживание не будет успевать происходить. Впрочем, в случае delay-ев мучает уже не проблема дребезга контактов, а "эстонский" тип реакции микроконтроллера ;)
Вместо ЛЕД будут реле. Должны работать по алгоритму --- при кратком нажатии кнопки срабатывает реле1, если удерживать кнопку 2 сек или более, сработать должны оба реле.
step962 , спасибо сейчас попробую!
const int buttonPin = 2; const int ledPin = 13; const int led2Pin = 12; int x = 2000000; int buttonPushCounter = 0; int buttonState = 0; int lastButtonState =0; unsigned long duration; int oldStateI, curStateI; // целые числа - текущее и предыдущее состояние кнопки float curState; // здесь будет храниться среднее арифм. 10 последних опросов состояния кнопки int STATE_ON(buttonState == HIGH); int STATE_OFF(buttonState == LOW); void setup() { pinMode(buttonPin, INPUT); pinMode(ledPin, OUTPUT); pinMode(led2Pin, OUTPUT); Serial.begin(9600); } void loop() { curState=curState*9/10+digitalRead(buttonPin)*10; curStateI=curState*10; // переводим вещественное число в целое (диапазон 0...10) if (curStateI==STATE_ON && curStateI!=oldStateI) { // произошло надежное включение кнопки - выполняем необходимые действия digitalWrite(ledPin, HIGH); duration = pulseIn(buttonPin, HIGH); Serial.println(duration); if (duration > x ){ digitalWrite(led2Pin, HIGH); } // и готовимся к дальнейшему слежению oldStateI=curStateI; } if(curStateI==STATE_OFF && curStateI!=oldStateI) { // произошло надежное выключение кнопки - выполняем необходимые действия (если таковые есть) // и готовимся к дальнейшему слежению oldStateI=curStateI; } }step962, попробовал ваш пример, без изменений :(
А это вы что такое делаете:
Если не ошибаюсь, то переменная типа int принимает целые значения от -65535 до 65535, так что что у вас на самом деле хранитстся в int х неизвестно.
Так как х, buttonPin, ledPin, led2Pin не меняются лучше использовать #define:
1. Зажигает ЛЕД
2. Измеряет время нажатия на кнопку (кнопка без фиксации)
3. для отладки, выводит на терминал время нажатия
ЛЕД1 работает как надо, но ЛЕД2, который по условию должен загорется через 2 сек, не загорается( если установить х=0,1 сек, загорается через раз)
int х время нажатия кнопки
И?
Вспомнил вроде, переменная типа int принимает целые значения от -32767 до 32767, а вы пытаетесь туда засунуть 2000000
И?
if (duration > x ){
так я пытаюсь научить ардуину зажигать лед в случае удержания кнопки дольше времени х
А по какому алгоритму реле должны выключаться?
Еще раз, читайте внимательно:
Переменная типа int принимает целые значения от -32767 до 32767, а вы пытаетесь туда засунуть 2000000
Вы понимаете, что число 2000000 больше, чем 32767. Этим кодом:
вы пытаетесь в отверстие диаметром 32767мм засунуть шар диаметром 2000000мм. Так понятнее?
при втором нажатии на кноку, не стал дописывать пока с этим не разобрался
При следующем коротком нажатии отключаются оба реле? или так же как и включаются - при коротком нажатии отключается только первое реле, а при длинном оба
ГЫ-ГЫ, пробовал и 1000, всё равно не работает... реле1 будет вкл. зажигание, реле2 стартер
да оба
да оба
соврал, реле2 откл от внешнего сигнала
Старт-кнопка?
Старт-кнопка?
точно!!!
А такой алгоритм не хотите?
Нажимаем только на кнопку:
первое нажатие кнопки запуска- включается режим АСС(работает только магнитола и прикуриватель)
второе нажатие- дополнительно включается зажигание.
Третие нажатие -OFF, выключает АСС и зажигание
Удерживая педаль тормоза, нажимаем кнопку engine start:
короткое нажатие на кнопку включает АСС, зажигание и стартер( на 0,8(примерно) секунды). Если двигатель запускается хорошо- этого времени работы стартера вполне достаточно. Если двигатель холодный, то:
более длительное нажатие кнопки - включается АСС, зажигание и стартер(на время удержания кнопки запуска)
www.a-pik.ru/catalog/moduli_start_engine/engine-start-new-v.2
Можно из алгоритма убрать АСС.
хочется именно свой алгоритм, чужих полно например http://www.rlocman.ru/forum/showthread.php?t=1370&page=7
вся проблема в дребезге, остальное вроде мелочи
а может и не в нём? ну не понимает ардуишка, что я жму кнопку долго...
Просто вы с алгоритмом не определились, а это уже проверенный и удобный алгоритм.
тоже самое, что ключом крутить
1
31
14
0
14
0
144767
31
0
0
1729
0
0
0
0
вот такие значения выдаёт
на терминале при нажатии на кнопку, причём нули - это длинные нажатия
#define buttonPin 2 #define relePin1 13 #define relePin2 12 #define x 1000 // время удержания кнопки unsigned long duration = 0; boolean stateButton, relestate1 = 0; void setup() { pinMode(relePin1, OUTPUT); pinMode(relePin2, OUTPUT); } void loop(){ if(digitalRead(buttonPin) && !stateButton){ relestate1 = !relestate1; stateButton = 1; duration = millis(); } if(!digitalRead(buttonPin)){ stateButton = 0; } if(stateButton && millis()-duration > x){ digitalWrite(relePin2, HIGH); } if(relestate1){ digitalWrite(relePin1, HIGH); } else{ digitalWrite(relePin1, LOW); digitalWrite(relePin2, LOW); } }Проверить сейчас не начем, попробуйте и отпишитесь по результату
Перекопируйте еще раз
работает хаотично, но ЛЕД2 зажигается ровно по времени!!!
завтра попробую разобратся, сегодня нет сил уже, пойду спать. Спасибо Максим!!!!!!
Что значит хаотично?
#define buttonPin 2 #define relePin1 13 #define relePin2 12 #define x 1000 // время удержания кнопки unsigned long duration = 0; boolean stateButton, relestate1 = 0; void setup() { pinMode(relePin1, OUTPUT); pinMode(relePin2, OUTPUT); } void loop(){ if(digitalRead(buttonPin) && !stateButton){ relestate1 = !relestate1; stateButton = 1; delay(150); duration = millis(); } if(!digitalRead(buttonPin)){ delay(50); stateButton = 0; } if(stateButton && millis()-duration > x){ digitalWrite(relePin2, HIGH); } if(relestate1){ digitalWrite(relePin1, HIGH); } else{ digitalWrite(relePin1, LOW); digitalWrite(relePin2, LOW); } }а так? и если что-то не так пишите подробнее
каждый раз цикл проходит по разному
еще раз перекопируйте
теперь супер!!!!!!
Должно работать так: короткое нажатие включает реле1 последующее короткое нажатие выключает реле1, длинное нажатие сразу влючает реле1 и через секунду реле2, последующее короткое нажатие выключает оба реле.
верно, так и работает, то чтоя хотел
Есть недочет - если сначала влючить реле1 коротким нажатием, а потом попытаться включить реле2 длинным нажатием, то сначала выключится реле1 и через секунду включится реле2. Есть такой недочет?
временами при нажатии диод загорается, и при отпускании кнопки тухнет, как будто кнопку 2 раза нажал, хотя щелчок один
есть
попродуйте в 22 строке увеличить задержку с 50 до 100
есть
замените 25 строку на это:
if(stateButton && relestate1 && millis()-duration > x){там есть только 150 задержка, менял в обе стороны, только хуже
не помогло
я же вам писал перекопируйте еще раз
Что не помогло?
