GLCD + SD Чтение bitmap изображений
Доброго времени суток. У меня дисплей 128x64 KS0108, хотелось бы научить его читать bmp с SD карточки.
Нашел скетч, но для TFT дисплея
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include <SPI.h>
#include <SD.h>
// TFT display and SD card will share the hardware SPI interface.
// Hardware SPI pins are specific to the Arduino board type and
// cannot be remapped to alternate pins. For Arduino Uno,
// Duemilanove, etc., pin 11 = MOSI, pin 12 = MISO, pin 13 = SCK.
#define SD_CS 4 // Chip select line for SD card
#define TFT_CS 10 // Chip select line for TFT display
#define TFT_DC 9 // Data/command line for TFT
#define TFT_RST 8 // Reset line for TFT (or connect to +5V)
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
void setup(void) {
// Our supplier changed the 1.8" display slightly after Jan 10, 2012
// so that the alignment of the TFT had to be shifted by a few pixels
// this just means the init code is slightly different. Check the
// color of the tab to see which init code to try. If the display is
// cut off or has extra 'random' pixels on the top & left, try the
// other option!
// If your TFT's plastic wrap has a Red Tab, use the following:
tft.initR(INITR_REDTAB); // initialize a ST7735R chip, red tab
// If your TFT's plastic wrap has a Green Tab, use the following:
//tft.initR(INITR_GREENTAB); // initialize a ST7735R chip, green tab
Serial.print("Initializing SD card...");
if (!SD.begin(SD_CS)) {
Serial.println("failed!");
return;
Serial.println("OK!");
bmpDraw("parrot.bmp", 0, 0);
// This function opens a Windows Bitmap (BMP) file and
// displays it at the given coordinates. It's sped up
// by reading many pixels worth of data at a time
// (rather than pixel by pixel). Increasing the buffer
// size takes more of the Arduino's precious RAM but
// makes loading a little faster. 20 pixels seems a
// good balance.
#define BUFFPIXEL 20
void bmpDraw(char *filename, uint8_t x, uint8_t y) {
File bmpFile;
int bmpWidth, bmpHeight; // W+H in pixels
uint8_t bmpDepth; // Bit depth (currently must be 24)
uint32_t bmpImageoffset; // Start of image data in file
uint32_t rowSize; // Not always = bmpWidth; may have padding
uint8_t sdbuffer[3*BUFFPIXEL]; // pixel buffer (R+G+B per pixel)
uint8_t buffidx = sizeof(sdbuffer); // Current position in sdbuffer
boolean goodBmp = false; // Set to true on valid header parse
boolean flip = true; // BMP is stored bottom-to-top
int w, h, row, col;
uint8_t r, g, b;
uint32_t pos = 0, startTime = millis();
if((x >= tft.width()) || (y >= tft.height())) return;
Serial.println();
Serial.print("Loading image '");
Serial.print(filename);
Serial.println('\'');
// Open requested file on SD card
if ((bmpFile = SD.open(filename)) == NULL) {
Serial.print("File not found");
return;
// Parse BMP header
if(read16(bmpFile) == 0x4D42) { // BMP signature
Serial.print("File size: "); Serial.println(read32(bmpFile));
(void)read32(bmpFile); // Read & ignore creator bytes
bmpImageoffset = read32(bmpFile); // Start of image data
Serial.print("Image Offset: "); Serial.println(bmpImageoffset, DEC);
// Read DIB header
Serial.print("Header size: "); Serial.println(read32(bmpFile));
bmpWidth = read32(bmpFile);
bmpHeight = read32(bmpFile);
if(read16(bmpFile) == 1) { // # planes -- must be '1'
bmpDepth = read16(bmpFile); // bits per pixel
Serial.print("Bit Depth: "); Serial.println(bmpDepth);
if((bmpDepth == 24) && (read32(bmpFile) == 0)) { // 0 = uncompressed
goodBmp = true; // Supported BMP format -- proceed!
Serial.print("Image size: ");
Serial.print(bmpWidth);
Serial.print('x');
Serial.println(bmpHeight);
// BMP rows are padded (if needed) to 4-byte boundary
rowSize = (bmpWidth * 3 + 3) & ~3;
// If bmpHeight is negative, image is in top-down order.
// This is not canon but has been observed in the wild.
if(bmpHeight < 0) {
bmpHeight = -bmpHeight;
flip = false;
// Crop area to be loaded
w = bmpWidth;
h = bmpHeight;
if((x+w-1) >= tft.width()) w = tft.width() - x;
if((y+h-1) >= tft.height()) h = tft.height() - y;
// Set TFT address window to clipped image bounds
tft.setAddrWindow(x, y, x+w-1, y+h-1);
for (row=0; row<h; row++) { // For each scanline...
// Seek to start of scan line. It might seem labor-
// intensive to be doing this on every line, but this
// method covers a lot of gritty details like cropping
// and scanline padding. Also, the seek only takes
// place if the file position actually needs to change
// (avoids a lot of cluster math in SD library).
if(flip) // Bitmap is stored bottom-to-top order (normal BMP)
pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
else // Bitmap is stored top-to-bottom
pos = bmpImageoffset + row * rowSize;
if(bmpFile.position() != pos) { // Need seek?
bmpFile.seek(pos);
buffidx = sizeof(sdbuffer); // Force buffer reload
for (col=0; col<w; col++) { // For each pixel...
// Time to read more pixel data?
if (buffidx >= sizeof(sdbuffer)) { // Indeed
bmpFile.read(sdbuffer, sizeof(sdbuffer));
buffidx = 0; // Set index to beginning
// Convert pixel from BMP to TFT format, push to display
b = sdbuffer[buffidx++];
g = sdbuffer[buffidx++];
r = sdbuffer[buffidx++];
tft.pushColor(tft.Color565(r,g,b));
} // end pixel
} // end scanline
Serial.print("Loaded in ");
Serial.print(millis() - startTime);
Serial.println(" ms");
} // end goodBmp
bmpFile.close();
if(!goodBmp) Serial.println("BMP format not recognized.");
// These read 16- and 32-bit types from the SD card file.
// BMP data is stored little-endian, Arduino is little-endian too.
// May need to reverse subscript order if porting elsewhere.
uint16_t read16(File f) {
uint16_t result;
((uint8_t *)&result)[0] = f.read(); // LSB
((uint8_t *)&result)[1] = f.read(); // MSB
return result;
uint32_t read32(File f) {
uint32_t result;
((uint8_t *)&result)[2] = f.read();
((uint8_t *)&result)[3] = f.read(); // MSB
return result;
По идее можно портировать скетч для ks0108, так как изображение выводится на экран с помощью простой фукции: tft.pushColor(tft.Color565(r,g,b));
Я портировал скетч изменив эту строчку на: if (b) GLCD.SetDot(col, row, 0); else GLCD.SetDot(col, row, 255); (col И row - координаты) И еще пару, отвечающие за размеры дисплея.
Все заработало, но файл изображения должен быть обязательно 24bit-ным (тк. TFT дисплей - цветной), а мне бы хотелось сделать его монохромным(памяти занимает меньше и быстрее), то есть 1bit-ным. За это как раз отвечают строчки:
bmpDepth - я изменил на 1. Но никак не пойму, что делать со следующей строчкой, именно она отвечает цвета/размер одной пиксельной строчки. Подскажите что делать?
Ауууу. Есть кто-нибудь, знающий структуру bmp изображения?
Ну, как-бы, поиск в Гугле/Яндексе возвращает много всего полезного для освоения BMP-формата. Та же Wiki имеет в своих недрах вполне подробное описание.
Это все понятно, но я не понимаю как это (пере)реализовать в скетче. Строчка: rowSize = (bmpWidth * 3 + 3) & ~3; -- размер одной строки с данными, так как изображение монохромное, то "размер одной строки = ширина изображения". Я переписал ее на: rowSize=bmpWidth;, но на экране какая-то чепухня :(
Видимо, я просто не вижу кусок кода в скетче, который нужно заменить.
Для монохромного (в том смысле, который употребляется в описаниях "монохромных" LCD), а по сути "черно-белого" (корректно будет - бинарного) изображения
rowSize = (bmpWidth+7)/8;
поскольку информация об одном пикселе изображения прекрасно умещается в один бит.
Хм... а ссылку которую step62 читали? Там же написанно что при 24-рех - на каждый пиксель идет 3 байта. Что мы и видем в оригинальной строке. Отсюда можно сделать вывод что rowSize это размер строки "в байтах".
А для монохромного изображения сказанно что "Каждый бит изображения представляет один пиксель". А 1байт=8бит, а не 1байт=1бит (как можно подумать по строке rowSize=bmpWidth).
Вообщем похоже вам нужно поделить ширину на 8 мь и округлить в большую сторону (например 12-бит знаймут в памяти 2 байта). Потом опять укурится в описание и понять "нафига они делали BMP rows are padded (if needed) to 4-byte boundary" и нужно ли вам тот же финт ушами делать.
Можете вообще, для начала, посчитать это все руками. Для какого-то одного изображения. Характеристики которого вы знаете. И просто присвоить это значение rowSize. "Прихадкодить его". Посмотреть что выйдет.
Можете изначально сделать "специальное тестовое изображение". Шириной в 32 пиксели. Тогда, по идее, размер строки должна быть ровно 4-ре байта (если в строке еще нет каких-то дополнительных данных кроме самих пикселей). И ничего "равнять" не нужно будет.
А можете вообще тупо. Обернуть все в цикл. И попрбовать пройти с разными rowSize. От 0 до 100 :) Если на какой-то из них появится картинка - будете знать "какое число правильное", а потом будете думать "откуда оно должно высчитатся". Если "так и не появится" - ну значит траблы совсем не в этой строке.
Вот где-бы мне научится так кратко излагать? :) Чувствую у меня скоро ответ на вопрос "который час" будет вызывать три пейджауна ответа :(
