Greenhouse-controller ошибки при проверки скетча.
Чт, 06/07/2017 - 14:53
Здравствуйте! На Гитхабе https://github.com/talktocory/greenhouse-controller нашёл интересный проект, но при проверке скетча выпадают ошибки:
Arduino: 1.8.3 (Windows 10), Плата:"Arduino/Genuino Uno"
C:\Downloads\Greenhouse\Greenhouse.ino: In function 'void loop()':
Greenhouse:159: error: 'displayMenu' was not declared in this scope
displayMenu(currentMenu);
Greenhouse:162: error: 'waitForInput' was not declared in this scope
buttonPressed = waitForInput(1000);
Greenhouse:280: error: 'InTimeSpan' was not declared in this scope
if (InTimeSpan(lightsOnHh, lightsOnMm, lightsOffHh, lightsOffMm)) {
exit status 1
Ну и сам скетч:
// see: https://learn.adafruit.com/dht/using-a-dhtxx-sensor #include <DHT.h> #include <Wire.h> // Comes with Arduino IDE // Get the LCD I2C Library here: // https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads // Move any other LCD libraries to another folder or delete them // See Library "Docs" folder for possible commands etc. #include <LiquidCrystal_I2C.h> #include <Time.h> #include <TimeLib.h> #include <DS1307RTC.h> // a basic DS1307 library that returns time as a time_t #include <IRremote.h> #include <IRremoteInt.h> // ******************************************************** // Constants // ******************************************************** #define RECV_PIN 10 // IR receiver pin #define DHTPIN 2 #define DHTTYPE DHT11 #define RELAYLIGHTS 3 #define RELAYHEATER 5 #define RELAYHUMIDIFIER 4 #define RELAYVENTILATION 6 const char *monthName[12] = { "Jan", "Feb", "Mar", "Apr", "May", "Jun", "Jul", "Aug", "Sep", "Oct", "Nov", "Dec" }; // ******************************************************** // Global Variables // ******************************************************** // greenhouse variables float tempSet, tempAct, humSet, humAct, sensorValue; int lightsOnHh, lightsOnMm, lightsOffHh, lightsOffMm; int ventilationFrqHh, ventilationDurMm; unsigned long lastVentilationStart, nextVentilationStart, nextVentilationEnd; String buttonPressed; String currentMenu; tmElements_t tm; /* initialize temp/hum sensor * SDA - ANALOG Pin 4 * SCL - ANALOG pin 5 */ DHT dht(DHTPIN, DHTTYPE); // initialize IR receiver // Digital pin 2 IRrecv irrecv(RECV_PIN); decode_results irMessage; // set the LCD address to 0x27 for a 20 chars 4 line display // Set the pins on the I2C chip used for LCD connections: // addr, en,rw,rs,d4,d5,d6,d7,bl,blpol // see: https://arduino-info.wikispaces.com/LCD-Blue-I2C /* * SDA - ANALOG Pin 4 * SCL - ANALOG pin 5 * On most Arduino boards, SDA (data line) is on analog input pin 4, and SCL (clock line) is on analog input pin 5 */ LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address // ******************************************************** // Utility Functions // ******************************************************** void printDigits(int digits){ if(digits < 10) lcd.print('0'); lcd.print(digits); } bool getTime(const char *str) { int Hour, Min, Sec; if (sscanf(str, "%d:%d:%d", &Hour, &Min, &Sec) != 3) return false; tm.Hour = Hour; tm.Minute = Min; tm.Second = Sec; return true; } bool getDate(const char *str) { char Month[12]; int Day, Year; uint8_t monthIndex; if (sscanf(str, "%s %d %d", Month, &Day, &Year) != 3) return false; for (monthIndex = 0; monthIndex < 12; monthIndex++) { if (strcmp(Month, monthName[monthIndex]) == 0) break; } if (monthIndex >= 12) return false; tm.Day = Day; tm.Month = monthIndex + 1; tm.Year = CalendarYrToTm(Year); return true; } // ******************************************************** // Setup // ******************************************************** void setup() { // set up the LCD's number of columns and rows: lcd.begin(16, 2); lcd.clear(); // start the ir receiver irrecv.enableIRIn(); // start the // Serial monitor // Serial.begin(9600); // while (!Serial) ; // wait for Arduino // Serial Monitor setSyncProvider(RTC.get); // the function to get the time from the RTC if(timeStatus()!= timeSet) { // Serial.println("Date and time not set. Setting it to last compile time."); // get the date and time the compiler was run if (getDate(__DATE__) && getTime(__TIME__)) { RTC.write(tm); } } else { // Serial.println("RTC has set the system time"); } // Set system defaults tempSet = 22.0; tempAct = tempSet; humSet = 60.0; humAct = humSet; lightsOnHh = 6; lightsOnMm = 0; lightsOffHh = 22; lightsOffMm = 0; ventilationFrqHh = 1; ventilationDurMm = 15; lastVentilationStart = now(); // Display the main menu currentMenu = "menu_0"; // Setup Relays pinMode(RELAYLIGHTS, OUTPUT); pinMode(RELAYHEATER, OUTPUT); pinMode(RELAYHUMIDIFIER, OUTPUT); pinMode(RELAYVENTILATION, OUTPUT); digitalWrite(RELAYLIGHTS, HIGH); digitalWrite(RELAYHEATER, HIGH); digitalWrite(RELAYHUMIDIFIER, HIGH); digitalWrite(RELAYVENTILATION, HIGH); } void loop() { // Refresh the display displayMenu(currentMenu); // Give user 1 second to press button buttonPressed = waitForInput(1000); // If menu item was pressed then change // the menu. Otherwise, redisplay the // current menu. if (buttonPressed == "Mode"){ if (currentMenu.startsWith("menu_0")){ currentMenu = "menu_1"; } else if (currentMenu.equals("menu_1")){ currentMenu = "menu_2"; } else if (currentMenu.equals("menu_2")){ currentMenu = "menu_3"; } else if (currentMenu.equals("menu_3")){ currentMenu = "menu_4"; } else if (currentMenu.equals("menu_4")){ currentMenu = "menu_5"; } else if (currentMenu.equals("menu_5")){ currentMenu = "menu_6"; } else if (currentMenu.equals("menu_6")){ currentMenu = "menu_7"; } else if (currentMenu.equals("menu_7")){ currentMenu = "menu_8"; } else if (currentMenu.equals("menu_8")){ currentMenu = "menu_9"; } else if (currentMenu.equals("menu_9")){ currentMenu = "menu_10"; } else if (currentMenu.equals("menu_10")){ currentMenu = "menu_0"; } } else if (buttonPressed == "Volume Up"){ if (currentMenu.equals("menu_1")){ tm.Hour = tm.Hour + 1; RTC.write(tm); } else if (currentMenu.equals("menu_2")){ tm.Minute = tm.Minute + 1; RTC.write(tm); } else if (currentMenu.equals("menu_3")){ tempSet += 0.1; } else if (currentMenu.equals("menu_4")){ humSet += 1.0; } else if (currentMenu.equals("menu_5")){ lightsOffHh++; } else if (currentMenu.equals("menu_6")){ lightsOnMm++; } else if (currentMenu.equals("menu_7")){ lightsOffHh++; } else if (currentMenu.equals("menu_8")){ lightsOffMm++; } else if (currentMenu.equals("menu_9")){ ventilationFrqHh++; } else if (currentMenu.equals("menu_10")){ ventilationDurMm++; } } else if (buttonPressed == "Volume Down"){ if (currentMenu.equals("menu_1")){ tm.Hour = tm.Hour - 1; RTC.write(tm); } else if (currentMenu.equals("menu_2")){ tm.Minute = tm.Minute - 1; RTC.write(tm); } else if (currentMenu.equals("menu_3")){ tempSet -= 0.1; } else if (currentMenu.equals("menu_4")){ humSet -= 1.0; } else if (currentMenu.equals("menu_5")){ lightsOffHh--; } else if (currentMenu.equals("menu_6")){ lightsOnMm--; } else if (currentMenu.equals("menu_7")){ lightsOffHh--; } else if (currentMenu.equals("menu_8")){ lightsOffMm--; } else if (currentMenu.equals("menu_9")){ ventilationFrqHh--; } else if (currentMenu.equals("menu_10")){ ventilationDurMm--; } } // Read temp and humidity sensorValue = dht.readTemperature(); if (!isnan(sensorValue)){ tempAct = sensorValue; } sensorValue = dht.readHumidity(); if (!isnan(sensorValue)){ humAct = sensorValue; } // Adjust Lights if (InTimeSpan(lightsOnHh, lightsOnMm, lightsOffHh, lightsOffMm)) { digitalWrite(RELAYLIGHTS, LOW); } else { digitalWrite(RELAYLIGHTS, HIGH); } // Adjust Humidity if ((humAct + 5) < humSet){ digitalWrite(RELAYHUMIDIFIER, LOW); } else if ((humAct - 5) > humSet) { digitalWrite(RELAYHUMIDIFIER, HIGH); } // Adjust Heater if ((tempAct + 2) < tempSet){ digitalWrite(RELAYHEATER, LOW); } else if ((tempAct - 2) > tempSet) { digitalWrite(RELAYHEATER, HIGH); } // Adjust Ventilation nextVentilationStart = lastVentilationStart + ventilationFrqHh * 60 * 60; nextVentilationEnd = nextVentilationStart + ventilationDurMm * 60; if ((now() > nextVentilationStart) && (now() < nextVentilationEnd)){ lastVentilationStart = nextVentilationStart; digitalWrite(RELAYVENTILATION, LOW); } else { digitalWrite(RELAYVENTILATION, HIGH); } }
Очень хочется понять, что за ошибки и как их исправить?
Есть ещё видео: https://www.youtube.com/watch?v=KjPOGInt5jc , но это если кому интересно.
что за ошибки
В тексте не хватает трёх функций: displayMenu, waitForInput и InTimeSpan
как их исправить?
Найти эти функции (возможно, они там же в проекте валяются, или, может быть, у Вас не та версия какой-нибудь библиотеки, или ещё что-нибудь) или написать их самому.
Женя! Опять практика по коррекционной педагогике?
Там, в проекте, который он смотрит, все и лежит.
Если пассажир не в курсе этого, то он рано начал интересоваться проектами. Нужно поучиться.
ТС! (Топик Стартер - тот, кто начал тему)
Всему нужно учиться, даже если рукоблудием без знаний заниматься, можно хрен оторвать. Уж простите мой французский.
Вам просто нужно ВСЕ файлы проекта записать в один каталог и открывать.
Мда.....всё как-то сложно, на гитхабе есть ещё три скетча, помимо основного, может тут:
// ******************************************************** // Constants // ******************************************************** const String BTN_POWER = "Power"; const String BTN_MODE = "Mode"; const String BTN_MUTE = "Mute"; const String BTN_REV = "Reverse"; const String BTN_FWD = "Forward"; const String BTN_PLAY = "Play/Pause"; const String BTN_VOL_DOWN = "Volume Down"; const String BTN_VOL_UP = "Volume Up"; const String BTN_EQ = "Equlalizer"; const String BTN_0 = "0"; const String BTN_100 = "100+"; const String BTN_BACK = "Back"; const String BTN_1 = "1"; const String BTN_2 = "2"; const String BTN_3 = "3"; const String BTN_4 = "4"; const String BTN_5 = "5"; const String BTN_6 = "6"; const String BTN_7 = "7"; const String BTN_8 = "8"; const String BTN_9 = "9"; // ******************************************************** // Functions // ******************************************************** // Decode the actual button pressed on the IR remote String decodeInput(decode_results &results){ switch(results.value) { case 0xFFA25D: return BTN_POWER; break; case 0xFF629D: return BTN_MODE; break; case 0xFFE21D: return BTN_MUTE; break; case 0xFF22DD: return BTN_REV; break; case 0xFF02FD: return BTN_FWD; break; case 0xFFC23D: return BTN_PLAY; break; case 0xFFE01F: return BTN_VOL_DOWN; break; case 0xFFA857: return BTN_VOL_UP; break; case 0xFF906F: return BTN_EQ; break; case 0xFF6897: return BTN_0;или тут:
void displayMenu(String newMenu){ if (newMenu == "menu_0") { currentMenu = newMenu; displayMenu_0(); } else if (newMenu == "menu_1") { currentMenu = newMenu; displayMenu_1(); } else if (newMenu == "menu_2") { currentMenu = newMenu; displayMenu_2(); } else if (newMenu == "menu_3") { currentMenu = newMenu; displayMenu_3(); } else if (newMenu == "menu_4") { currentMenu = newMenu; displayMenu_4(); } else if (newMenu == "menu_5") { currentMenu = newMenu; displayMenu_5(); } else if (newMenu == "menu_6") { currentMenu = newMenu; displayMenu_6(); } else if (newMenu == "menu_7") { currentMenu = newMenu; displayMenu_7(); } else if (newMenu == "menu_8") { currentMenu = newMenu; displayMenu_8(); } else if (newMenu == "menu_9") { currentMenu = newMenu; displayMenu_9(); } else if (newMenu == "menu_10") { currentMenu = newMenu; displayMenu_10(); } } // Home screen displays time, humidity and temp void displayMenu_0(){ lcd.clear(); if (RTC.read(tm)) { lcd.setCursor(0, 0); lcd.print("Time: "); printDigits(tm.Hour); lcd.print(':'); printDigits(tm.Minute); lcd.print(':'); printDigits(tm.Second); lcd.setCursor(0, 1); lcd.print("T: "); lcd.print(tempAct, 2); lcd.print(" H: "); lcd.print(humAct, 1); } else { if (RTC.chipPresent()) { // Serial.println("The DS1307 is stopped. Please run the SetTime"); // Serial.println("example to initialize the time and begin running."); // Serial.println(); } else { // Serial.println("DS1307 read error! Please check the circuitry."); // Serial.println(); } } } // Time Settings void displayMenu_1(){ lcd.clear(); lcd.setCursor(0, 0); lcd.print("Time hh: "); printDigits(tm.Hour); lcd.setCursor(0, 1); lcd.print("Use + - to Adj"); } // Time Settings void displayMenu_2(){ lcd.clear(); lcd.setCursor(0, 0); lcd.print("Time mm: "); printDigits(tm.Minute); lcd.setCursor(0, 1); lcd.print("Use + - to Adj"); } // Temp Settings void displayMenu_3(){ lcd.clear(); lcd.setCursor(0, 0); lcd.print("Temp: "); lcd.print(tempSet, 1); lcd.setCursor(0, 1); lcd.print("Use + - to Adj"); } // Hummidity Settings void displayMenu_4(){ lcd.clear(); lcd.setCursor(0, 0); lcd.print("Humidity: "); lcd.print(humSet, 0); lcd.setCursor(0, 1); lcd.print("Use + - to Adj"); } // Light Settings void displayMenu_5(){ lcd.clear(); lcd.setCursor(0, 0); lcd.print("Light On hh: "); printDigits(lightsOnHh); lcd.setCursor(0, 1); lcd.print("Use + - to Adj"); } // Light Settings void displayMenu_6(){ lcd.clear(); lcd.setCursor(0, 0); lcd.print("Light On mm: "); printDigits(lightsOnMm); lcd.setCursor(0, 1); lcd.print("Use + - to Adj"); } void displayMenu_7(){ lcd.clear(); lcd.setCursor(0, 0); lcd.print("Light Off hh: "); printDigits(lightsOffHh); lcd.setCursor(0, 1); lcd.print("Use + - to Adj"); } // Light Settings void displayMenu_8(){ lcd.clear(); lcd.setCursor(0, 0); lcd.print("Light Off mm: "); printDigits(lightsOffMm); lcd.setCursor(0, 1); lcd.print("Use + - to Adj"); } // Ventilation Settings void displayMenu_9(){ lcd.clear(); lcd.setCursor(0, 0); lcd.print("Vent Frq hh: "); printDigits(ventilationFrqHh); lcd.setCursor(0, 1); lcd.print("Use + - to Adj"); } // Ventilation Settings void displayMenu_10(){ lcd.clear(); lcd.setCursor(0, 0); lcd.print("Vent Dur mm: "); printDigits(ventilationDurMm); lcd.setCursor(0, 1); lcd.print("Use + - to Adj"); }ну или здесь:
boolean InTimeSpan(int startHh, int startMm, int stopHh, int stopMm){ long startTimeInSeconds = (long) startHh * 60 * 60 + (long) startMm * 60; // // Serial.print("Start time in seconds: "); // // Serial.println(startTimeInSeconds); long stopTimeInSeconds = (long) stopHh * 60 * 60 + (long) stopMm * 60; // // Serial.print("Stop time in seconds: "); // // Serial.println(stopTimeInSeconds); long currentTimeInSeconds = (long) tm.Hour * 60 * 60 + (long) tm.Minute * 60; // // Serial.print("Current time in seconds: "); // // Serial.println(currentTimeInSeconds); boolean isBeforeEnd = currentTimeInSeconds < stopTimeInSeconds; // // Serial.print("Is before end time?: "); // // Serial.println(isBeforeEnd); boolean isAfterStart = currentTimeInSeconds >= startTimeInSeconds; // // Serial.print("Is after start time?: "); // // Serial.println(isAfterStart); // Deal with timespans that go over midnight if (stopTimeInSeconds < startTimeInSeconds) { // // Serial.print("In Timespan: "); // // Serial.println(isAfterStart || isBeforeEnd); return isAfterStart || isBeforeEnd; } else { // // Serial.print("In Timespan: "); // // Serial.println(isAfterStart && isBeforeEnd); return isAfterStart && isBeforeEnd; } // Time span : 22:00 to 2:00 // Time 21:00 // isBeforeEnd: false // isAfterStart: false // Time 23:00 // isBeforeEnd: false // isAfterStart: true // Time 3:00 // isBeforeEnd: true // isAfterStart: false }Вообще, хотелось бы, разжевать и в рот положить. Спасибо, что откликнулись!
Согласен, но практика бесценна!
Нет, никаких практик. Я даже не смотрел, что там в проекте. То, что там должно всё лежать я предполагал (и написал об этом ТС, что "может там же и валяются")), пусть ищет. Я что ли за него искать буду?
Тему можно закрыть, разобрался. А Вам господа, нужно поучиться не хамить, а если не хотите помочь, то лучше не засорять тему. Всем спасибо!!!
Вы нас поучить решили? Ну-ну ... :)
Уважеемый, Вы не находите, что сами себе противоречите?
Вам помогли, притом, помогли эффективно - проект, насколько я понял, заработал. И после этого Вы заявляете, что, якобы, помочь можно было и лучше. Да откуда Вам знать, как лучше всего помогать!
А это такое жизненное кредо: постучать в дверь, попросить воды, напиться, а потом насрать на пороге.
