Код выдаёт ошибку компиляции, помогите разобраться.
NVN Plus
Здравствуйте. Загружаю в IDE код Motion Controlled Dolly при компиляции на 186 строке затыкается. Я не силен в программировании, по этому справиться с ошибкой не выходит, помогите.
#include <AccelStepper.h>
// Define some steppers and the pins the will use
AccelStepper stepper1(1, 12, 11);
#define stepsPerRev      1600
#define stepPin          12
#define dirPin           11
#define ledPin           13
#define rotateLeftPin    7
#define rotateRightPin   6
#define savePositionAPin 5
#define savePositionBPin 4
#define gotoPositionAPin 3
#define gotoPositionBPin 2
#define maxSpeedPin      0
#define accelPin         1
// Set this to zero if you don't want debug messages printed
#define printDebug       0
// These are the constants that define the speed associated with the MaxSpeed pot
#define MAX_STEPS_PER_SECOND  1000    // At 200 s/r and 1/8th microstepping, this will be 333 rev/minute
#define MIN_STEPS_PER_SECOND  27      // At 200 steps/rev and 1/8th microstepping, this will be 1 rev/minute
// Change this value to scale the acceleration pot's scaling factor
#define ACCEL_RATIO           1
int buttonState = 0;
int stepNumber = 0;
int curSpeed = 100;
int dir = 0;
int maxSpeed = 0;
int accel = 0;
long savedPosA = 0;
long savedPosB = 0;
int loopCtr = 0;
float fMaxSpeed = 0.0;
float fStepsPerSecond = 0.0;
  pinMode(stepPin, OUTPUT);
  pinMode(dirPin, OUTPUT);
  pinMode(ledPin, OUTPUT);
  pinMode(rotateLeftPin, INPUT);
  pinMode(rotateRightPin, INPUT);
  pinMode(savePositionAPin, INPUT);
  pinMode(savePositionBPin, INPUT);
  pinMode(gotoPositionAPin, INPUT);
  pinMode(gotoPositionBPin, INPUT);
  if (printDebug)
    // Initialize the Serial port
  // blink the LED:
  blink(2);
  stepper1.setMaxSpeed(800.0);
  stepper1.setAcceleration(600.0);
  // Grab both speed and accel before we start
  maxSpeed = analogRead(maxSpeedPin);
  // Do the math to scale the 0-1023 value (maxSpeed) to
  // a range of MIN_STEPS_PER_SECOND to MAX_STEPS_PER_SECOND
  fMaxSpeed = maxSpeed / 1023.0;
  fStepsPerSecond = MIN_STEPS_PER_SECOND + (fMaxSpeed * (MAX_STEPS_PER_SECOND - MIN_STEPS_PER_SECOND));
  if (fStepsPerSecond > 1000)
    fStepsPerSecond = 1000;
  accel = analogRead(accelPin)/ACCEL_RATIO;
  // First, we need to see if either rotate button is down. They always take precidence.
  if(digitalRead(rotateLeftPin))
    stepper1.setSpeed(-fStepsPerSecond);
    while(digitalRead(rotateLeftPin))
      CheckPots();
      stepper1.runSpeed();
  else if (digitalRead(rotateRightPin))
    stepper1.setSpeed(fStepsPerSecond);
    while(digitalRead(rotateRightPin))
      CheckPots();
  // Go see if we need to update our analog conversions
  CheckPots();
  // Check to see if user is trying to save position A or B
  if(digitalRead(savePositionAPin))
    savedPosA = stepper1.currentPosition();
    if (printDebug)
      Serial.print("Saved A at :");
      Serial.println(savedPosA);
    while(digitalRead(savePositionAPin));
  if(digitalRead(savePositionBPin))
    savedPosB = stepper1.currentPosition();
    if (printDebug)
      Serial.print("Saved B at :");
      Serial.println(savedPosB);
    while(digitalRead(savePositionBPin));
  // Check to see if the user wants to go to position A or B
  if (digitalRead(gotoPositionAPin))
    if (printDebug)
      // Yup, let's go to position A
      Serial.print("cur pos = ");
      Serial.println(stepper1.currentPosition());
      Serial.print("Going to A = ");
      Serial.print("Speed = ");
      Serial.println(fStepsPerSecond);
      Serial.print("Accel = ");
      Serial.println(accel);
    stepper1.setAcceleration(0);
    stepper1.runToNewPosition(stepper1.currentPosition());
    stepper1.setMaxSpeed(fStepsPerSecond);
    stepper1.setAcceleration(accel);
    stepper1.runToNewPosition(savedPosA);
    if (printDebug)
      Serial.print("new pos = ");
    while(digitalRead(gotoPositionAPin));
  else if (digitalRead(gotoPositionBPin))
    // Yup, let's go to position B
    if (printDebug)
      Serial.print("Going to B = ");
    stepper1.runToNewPosition(savedPosB);
    if (printDebug)
    while (digitalRead(gotoPositionBPin));
// Blink the reset LED:
void blink(int howManyTimes)
  int i;
  for (i=0; i < howManyTimes; i++)
    digitalWrite(ledPin, HIGH);
    delay(200);
    digitalWrite(ledPin, LOW);
    delay(200);
void CheckPots(void)
  loopCtr++;
  // Only read these once in a while because they take a LONG time
  if (loopCtr == 100)
  // Read in the acceleration analog value
  // This needs to be scaled too, but to what?
  if (loopCtr >= 200)
    loopCtr = 0;
Алексей.
Алексей. аватар
ардуина иде 1.8.7, адафрутовская библиотека AccelStepper, плата ардуина уна, собрал код без изменений.
Скетч использует 5068 байт (15%) памяти устройства. Всего доступно 32256 байт.
Глобальные переменные используют 80 байт (3%) динамической памяти, оставляя 1968 байт для локальных переменных. Максимум: 2048 байт.
Что за ошибка у вас?
Текст сообщения об ошибке скопипастите, а то так трудно догадываться
NVN Plus
Скачал по вашей ссылке библиотеку и все скомпилировалось. Скетч от автора сопровождался библиотекой, которая видимо не корректно работала. Удалил её и загрузил вашу. Спасибо за помошь. Если позволите ещё вопросик. Можно ли этот скетч переделать для работы с DC мотором, а не шаговым? Если да, то что следует изменить для этого в коде?
asam
asam аватар
NVN Plus пишет:
Вы, сначала, лучше скажите что за штуку строите и как она должна себя вести?
NVN Plus
Собственно вот ссылка на девайс, только там автор это дело забросил, я же хочу подхватить и довести его до ума. Конечно шаговик круче, но хотелось бы чего-то попроще.
http://www.schweinert.com/motion-controlled-dolly-code/
А почему Вы решили, что мотор постоянного тока проще шаговика?
И еще: если Вы хотите что-то сделать, то первое что нужно - это внятно изложить, что Вы желаете, своими словами.
