не могу понять что нужно компилятору
Пт, 01/05/2015 - 21:26
[code]
Arduino Esplora educational data logger and data viewer.
Logs data into a microSD and "plot" it into the LCD.
Written by Angelo Scialabba
<a.scialabba@arduino.cc>
11/04/2013
#include <Esplora.h>
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include <TFT.h> // Arduino LCD library
#include <SPI.h>
#include <SD.h>
#define SD_CS 8
#define MENU 0
#define RECORD 1
#define DISPLAY 2
#define GRAPH 3
int st;
int STORE_DELAY = 1000;
void setup(){
// initialize the screen
EsploraTFT.begin();
// clear the screen
EsploraTFT.background(0,0,0);
st = MENU; //Select menu for default option
// ---------Splash Screen---------
EsploraTFT.stroke(0,255,0);
EsploraTFT.setTextSize(4);
EsploraTFT.text("Esplora",0,25);
EsploraTFT.stroke(255,255,255);
EsploraTFT.setTextSize(1);
EsploraTFT.text("Educational datalogger",0,60);
delay(3000);
void loop(){
//Read the option selected execute the right function
switch(st){
case MENU:
menu(); // Main menu
case RECORD:
record(); // Record data menu
case DISPLAY:
display(); // Display the sensor data
case GRAPH:
graph(); // Display the graph of stored data
void menu(){
EsploraTFT.text("Select an option:\n1.Record data\n2.Diplay data\n3.Graph\n",0,25);
delay(500);
while(1) // infinite loop until a button is pressed
if (Esplora.readButton(SWITCH_1) == LOW) {
st = RECORD; // set new option
return; // the "while" will break and the loop function will execute the new option
} else if (Esplora.readButton(SWITCH_2) == LOW) {
st = DISPLAY; // same here
return;
} else if (Esplora.readButton(SWITCH_3) == LOW) {
st = GRAPH; // same here
return;
void record() {
int value;
File dataFile;
SD.begin(SD_CS); // init the SD library
SD.remove("data.txt"); // delete old data file
dataFile = SD.open("data.txt", FILE_WRITE);
String data;
EsploraTFT.background(0,0,0); //clear the screen
if (!dataFile) {
EsploraTFT.stroke(255,255,255); //+
EsploraTFT.setTextSize(2); //| Show error Message
EsploraTFT.text("SD Error\n",0,0); //|
EsploraTFT.setTextSize(1); //|
EsploraTFT.text("Plug in your SD\nand restart Esplora.",0,30); //+
while(1){
EsploraTFT.text("Recording\n",0,0);
EsploraTFT.text("Hold Switch 1 to stop.",0,30); // Start recording
delay(500);
while(1){ // infinite loop, will break if button 1 is pressed
dataFile.close(); // Close file
st = MENU; //and return to main menu
return;
data = ""; //+
value = Esplora.readLightSensor(); //| Read Data from sensor - Change Esplora.readLightSensor()
data += String(value); //| and store it - to change the input sensor
data+= "\r\n"; //| in the sd card
dataFile.print(data); //|
delay(STORE_DELAY); //+
void display()
int value;
char tmp[5];
String tmp_string;
EsploraTFT.background(0,0,0); //Clear the screen
while(1) {
tmp_string=String(Esplora.readLightSensor()); //Read the sensor value
tmp_string.toCharArray(tmp, 5); //convert the value into a string
EsploraTFT.text(tmp,0,0); //write the string on the lcd
delay(500);
EsploraTFT.stroke(0,0,0);
EsploraTFT.text(tmp,0,0); //erase the old value from the screen
st = MENU; //return to main menu when button 1 is pressed
return;
void graph(){
int value,index,xPos;
unsigned long i,points,div,position_index;
File dataFile;
char tmp[6];
SD.begin(SD_CS);
dataFile = SD.open("data.txt", FILE_READ); //open the data file
String data;
points = 0;
xPos=0;
if (!dataFile) {
EsploraTFT.stroke(255,255,255); //show an error message
EsploraTFT.setTextSize(2); //if the file does not exist
EsploraTFT.text("SD Error\n",0,0); //or the sd card is not present
while(1){
for (i=0;i<dataFile.size();i++){
if (dataFile.read()=='\n') points++; // count how many values the file contains
position_index=0;
div = points/EsploraTFT.width();
if (div == 0){ //points available on screen are more that stored ones
div = EsploraTFT.width()/points; //fit the data in the screen and read from file
dataFile.seek(0);
for (i = 0 ; i<points;i++){
for (index = 0; index<6; index++){
tmp[index] = dataFile.read();
if (tmp[index] =='\n'){
tmp[index-1] = '\0';
value = atoi(tmp); //convert the text into a number
value = map(value,0,1023,0,EsploraTFT.height()); //map the value
EsploraTFT.line(i*div, EsploraTFT.height() - value, i*div, EsploraTFT.height()); //draw the value on lcd
} else { //all stored data can't be drawed on screen
dataFile.seek(0);
position_index++;
if ((position_index-1) % div == 0){ // select only few points
value = atoi(tmp); // convert
value = map(value,0,1023,0,EsploraTFT.height()); // and print values on LCD
EsploraTFT.line(xPos, EsploraTFT.height() - value, xPos, EsploraTFT.height());
xPos++;
while(1){
dataFile.close(); //when button 1 is pressed
st = MENU; //go to main menu
return;
[/code]
А от нас то что нужно, не могу понять
