Не могу скомпилировать код
JekaPin
Помоите пожалуйста, никак не хочет компилироваться код
/******** * Arduino Pong * By Pete Lamonica * modified by duboisvb * updated by James Bruce (http://www.makeuseof.com/tag/author/jbruce * A simple implementation of Pong on the Arduino using a TV for output. ********/ #include <TVout.h> #include <fontALL.h> #define WHEEL_ONE_PIN 0 //analog #define WHEEL_TWO_PIN 1 //analog // #define BUTTON_ONE_PIN 2 //digital to start game // #define BUTTON_TWO_PIN 3 //digital to reset and go back to main menu #define PADDLE_HEIGHT 14 #define PADDLE_WIDTH 1 #define RIGHT_PADDLE_X (TV.hres()-4) #define LEFT_PADDLE_X 2 #define IN_GAMEA 0 //in game state - draw constants of the game box #define IN_GAMEB 0 //in game state - draw the dynamic part of the game #define IN_MENU 1 //in menu state #define GAME_OVER 2 //game over state #define LEFT_SCORE_X (TV.hres()/2-15) #define RIGHT_SCORE_X (TV.hres()/2+10) #define SCORE_Y 4 #define MAX_Y_VELOCITY 6 #define PLAY_TO 7 #define LEFT 0 #define RIGHT 1 TVout TV; unsigned char x,y; boolean button1Status = false; // boolean button2Status = false; int wheelOnePosition = 0; int wheelTwoPosition = 0; int rightPaddleY = 0; int leftPaddleY = 0; unsigned char ballX = 0; unsigned char ballY = 0; char ballVolX = 2; char ballVolY = 2; int leftPlayerScore = 0; int rightPlayerScore = 0; int frame = 0; int state = IN_MENU; void processInputs() { wheelOnePosition = analogRead(WHEEL_ONE_PIN); // delay(50); wheelTwoPosition = analogRead(WHEEL_TWO_PIN); // delay(50); // button1Status = (digitalRead(BUTTON_ONE_PIN)); button1Status = true; // button2Status = (digitalRead(BUTTON_TWO_PIN) == LOW); if ((button1Status == 0)&& (state == GAME_OVER)) { Serial.println("game over, drawing menu"); drawMenu (); } delay(50); //Serial.println(button1Status); //Serial.println(state); //Serial.println(button2Status); //Serial.println(wheelOnePosition); //Serial.println(wheelTwoPosition); } void drawGameScreen() { // TV.clear_screen(); //draw right paddle rightPaddleY = ((wheelOnePosition /8) * (TV.vres()-PADDLE_HEIGHT))/ 128; x = RIGHT_PADDLE_X; for(int i=0; i<PADDLE_WIDTH; i++) { TV.draw_line(x+i,rightPaddleY,x+i,rightPaddleY+PADDLE_HEIGHT,1); } //draw left paddle leftPaddleY = ((wheelTwoPosition /8) * (TV.vres()-PADDLE_HEIGHT))/ 128; x = LEFT_PADDLE_X; for(int i=0; i<PADDLE_WIDTH; i++) { TV.draw_line(x+i,leftPaddleY,x+i,leftPaddleY+PADDLE_HEIGHT,1); } //draw score TV.print_char(LEFT_SCORE_X,SCORE_Y,'0'+leftPlayerScore); TV.print_char(RIGHT_SCORE_X,SCORE_Y,'0'+rightPlayerScore); //draw ball TV.set_pixel(ballX, ballY, 2); } //player == LEFT or RIGHT void playerScored(byte player) { if(player == LEFT) leftPlayerScore++; if(player == RIGHT) rightPlayerScore++; //check for win if(leftPlayerScore == PLAY_TO || rightPlayerScore == PLAY_TO) { state = GAME_OVER; } ballVolX = -ballVolX; } void drawBox() { TV.clear_screen(); //draw net for(int i=1; i<TV.vres() - 4; i+=6) { TV.draw_line(TV.hres()/2,i,TV.hres()/2,i+3,1); } // had to make box a bit smaller to fit tv TV.draw_line(0, 0, 0,95,1 ); // left TV.draw_line(0, 0, 126,0,1 ); // top TV.draw_line(126, 0, 126,95,1 ); // right TV.draw_line(0, 95, 126,95,1 ); // bottom state = IN_GAMEB; } void drawMenu() { x = 0; y = 0; char volX =3; char volY = 3; TV.clear_screen(); TV.select_font(font8x8); TV.print(10, 5, "Arduino Pong"); TV.select_font(font4x6); TV.print(22, 35, "Press Button"); TV.print(30, 45, "To Start"); delay(1000); while(!button1Status) { Serial.println("menu"); Serial.println(button1Status); processInputs(); TV.delay_frame(3); if(x + volX < 1 || x + volX > TV.hres() - 1) volX = -volX; if(y + volY < 1 || y + volY > TV.vres() - 1) volY = -volY; if(TV.get_pixel(x + volX, y + volY)) { TV.set_pixel(x + volX, y + volY, 0); if(TV.get_pixel(x + volX, y - volY) == 0) { volY = -volY; } else if(TV.get_pixel(x - volX, y + volY) == 0) { volX = -volX; } else { volX = -volX; volY = -volY; } } TV.set_pixel(x, y, 0); x += volX; y += volY; TV.set_pixel(x, y, 1); } TV.select_font(font4x6); state = IN_GAMEA; } void setup() { //Serial.begin(9600); x=0; y=0; TV.begin(_NTSC); //for devices with only 1k sram(m168) use TV.begin(_NTSC,128,56) ballX = TV.hres() / 2; ballY = TV.vres() / 2; // pinMode(BUTTON_ONE_PIN, INPUT); // sets the digital pin as output } void loop() { processInputs(); if(state == IN_MENU) { drawMenu(); } if(state == IN_GAMEA) { //Serial.println("gamA"); //Serial.println(button1Status); drawBox(); } if(state == IN_GAMEB) { if(frame % 1 == 0) { //every third frame ballX += ballVolX; ballY += ballVolY; // change if hit top or bottom if(ballY <= 1 || ballY >= TV.vres()-1) { ballVolY = -ballVolY; delay(50); TV.tone( 2000,30 ); } // test left side for wall hit if(ballVolX < 0 && ballX == LEFT_PADDLE_X+PADDLE_WIDTH-1 && ballY >= leftPaddleY && ballY <= leftPaddleY + PADDLE_HEIGHT) { ballVolX = -ballVolX; ballVolY += 2 * ((ballY - leftPaddleY) - (PADDLE_HEIGHT / 2)) / (PADDLE_HEIGHT / 2); delay(50); TV.tone(2000,30 ); } // test right side for wall hit if(ballVolX > 0 && ballX == RIGHT_PADDLE_X && ballY >= rightPaddleY && ballY <= rightPaddleY + PADDLE_HEIGHT) { ballVolX = -ballVolX; ballVolY += 2 * ((ballY - rightPaddleY) - (PADDLE_HEIGHT / 2)) / (PADDLE_HEIGHT / 2); delay(50); TV.tone( 2000,30 ); } //limit vertical speed if(ballVolY > MAX_Y_VELOCITY) ballVolY = MAX_Y_VELOCITY; if(ballVolY < -MAX_Y_VELOCITY) ballVolY = -MAX_Y_VELOCITY; // Scoring if(ballX <= 1) { playerScored(RIGHT); // sound delay(50); TV.tone( 500,300 ); } if(ballX >= TV.hres() - 1) { playerScored(LEFT); // sound delay(50); TV.tone( 500,300 ); } } // if(button1Status) Serial.println((int)ballVolX); drawGameScreen(); } if(state == GAME_OVER) { drawGameScreen(); TV.select_font(font8x8); TV.print(29,25,"GAME"); TV.print(68,25,"OVER"); while(!button1Status) { processInputs(); delay(50); } TV.select_font(font4x6); //reset the font //reset the scores leftPlayerScore = 0; rightPlayerScore = 0; state = IN_MENU; } TV.delay_frame(1); if(++frame == 60) frame = 0; //increment and/or reset frame counter }
Выдает ошибку
sketch_may22a.ino:9:19: fatal error: TVout.h: No such file or directory
compilation terminated.
Ошибка компиляции.
Хотя библиотека tvout стоит
Araris
Во-первых, на будущее: http://arduino.ru/forum/obshchii/vstavka-programmnogo-koda-v-temukommentarii
Во-вторых, проблема в данном случае не в коде, а в том, что компилятор не может найти файл TVout.h (и, думаю, не только его), проверьте еще раз, действительно ли библиотека установлена (http://arduino.ua/ru/guide/Libraries).
JekaPin
Спасибо за  http://arduino.ru/forum/obshchii/vstavka-programmnogo-koda-v-temukommentarii, но я проверил и выяснил, что библиотека установлена
Jeka_M
Jeka_M аватар
Напишите полный путь к файлу TVout.h
JekaPin
C:\Users\Евгений\Documents\Arduino\libraries\TVout\TVout.h
Новая проблема, я переустановил библиотеку и теперь выдает
sketch_may22a.ino:10:21: fatal error: fontALL.h: No such file or directory
Ошибка компиляции.
Jeka_M
Jeka_M аватар
В папке libraries кроеме TVout ещё должна быть папка TVoutfonts со всем содержимым, включяя fontALL.h
То есть так:
C:\Users\USER\Documents\Arduino\libraries\TVout\
C:\Users\USER\Documents\Arduino\libraries\TVoutfonts\
bwn
Да и кириллица в путях не всегда одинаково полезна.
