не работает nRF24L01
Пнд, 12/08/2013 - 20:56
Всем привет, подключил один nRF24L01 к меге, и один к уно... запустил пример GettingStarted, но они чей-то общаться не хотят, пишут в мониторе порта :
Now sending 705605...failed.
Failed, response timed out.
Помогите разобраться чайнику...
Мегу подключал вот так:
40(CE), 51 (MOSI), 50(MISO), 52(SCK), 53(CSN)
ЕЕ скетч:
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include "printf.h"
// Hardware configuration
// Set up nRF24L01 radio on SPI bus plus pins 40 & 53
RF24 radio(40,53);
// Topology
// Radio pipe addresses for the 2 nodes to communicate.
const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };
// Role management
// Set up role. This sketch uses the same software for all the nodes
// in this system. Doing so greatly simplifies testing.
// The various roles supported by this sketch
typedef enum { role_ping_out = 1, role_pong_back } role_e;
// The debug-friendly names of those roles
const char* role_friendly_name[] = { "invalid", "Ping out", "Pong back"};
// The role of the current running sketch
role_e role = role_pong_back;
void setup(void)
// Print preamble
Serial.begin(57600);
printf_begin();
printf("\n\rRF24/examples/GettingStarted/\n\r");
printf("ROLE: %s\n\r",role_friendly_name[role]);
printf("*** PRESS 'T' to begin transmitting to the other node\n\r");
// Setup and configure rf radio
radio.begin();
// optionally, increase the delay between retries & # of retries
radio.setRetries(15,15);
// optionally, reduce the payload size. seems to
// improve reliability
//radio.setPayloadSize(8);
// Open pipes to other nodes for communication
// This simple sketch opens two pipes for these two nodes to communicate
// back and forth.
// Open 'our' pipe for writing
// Open the 'other' pipe for reading, in position #1 (we can have up to 5 pipes open for reading)
//if ( role == role_ping_out )
//radio.openWritingPipe(pipes[0]);
radio.openReadingPipe(1,pipes[1]);
//else
//radio.openWritingPipe(pipes[1]);
//radio.openReadingPipe(1,pipes[0]);
// Start listening
radio.startListening();
// Dump the configuration of the rf unit for debugging
radio.printDetails();
void loop(void)
// Ping out role. Repeatedly send the current time
if (role == role_ping_out)
// First, stop listening so we can talk.
radio.stopListening();
// Take the time, and send it. This will block until complete
unsigned long time = millis();
printf("Now sending %lu...",time);
bool ok = radio.write( &time, sizeof(unsigned long) );
if (ok)
printf("ok...");
printf("failed.\n\r");
// Now, continue listening
// Wait here until we get a response, or timeout (250ms)
unsigned long started_waiting_at = millis();
bool timeout = false;
while ( ! radio.available() && ! timeout )
if (millis() - started_waiting_at > 200 )
timeout = true;
// Describe the results
if ( timeout )
printf("Failed, response timed out.\n\r");
// Grab the response, compare, and send to debugging spew
unsigned long got_time;
radio.read( &got_time, sizeof(unsigned long) );
// Spew it
printf("Got response %lu, round-trip delay: %lu\n\r",got_time,millis()-got_time);
// Try again 1s later
// Pong back role. Receive each packet, dump it out, and send it back
if ( role == role_pong_back )
// if there is data ready
if ( radio.available() )
// Dump the payloads until we've gotten everything
bool done = false;
while (!done)
// Fetch the payload, and see if this was the last one.
done = radio.read( &got_time, sizeof(unsigned long) );
// Spew it
printf("Got payload %lu...",got_time);
// Delay just a little bit to let the other unit
// make the transition to receiver
delay(20);
// Send the final one back.
radio.write( &got_time, sizeof(unsigned long) );
printf("Sent response.\n\r");
// Now, resume listening so we catch the next packets.
// Change roles
if ( Serial.available() )
char c = toupper(Serial.read());
if ( c == 'T' && role == role_pong_back )
printf("*** CHANGING TO TRANSMIT ROLE -- PRESS 'R' TO SWITCH BACK\n\r");
// Become the primary transmitter (ping out)
role = role_ping_out;
else if ( c == 'R' && role == role_ping_out )
printf("*** CHANGING TO RECEIVE ROLE -- PRESS 'T' TO SWITCH BACK\n\r");
// Become the primary receiver (pong back)
// vim:cin:ai:sts=2 sw=2 ft=cppУно подкючал:
9(CE), 11 (MOSI), 12(MISO), 13(SCK), 10(CSN)
ЕЕ Скет:
#include <SPI.h>
#include "RF24.h"
#include "printf.h"
// Set up nRF24L01 radio on SPI bus plus pins 9 & 10
RF24 radio(9,10);
// Topology
// Role management
void setup(void)
// Print preamble
printf_begin();
radio.begin();
// back and forth.
//else
// Start listening
void loop(void)
if (ok)
printf("ok...");
timeout = true;
if ( timeout )
// Spew it
bool done = false;
while (!done)
// Spew it
delay(20);
// Change roles
а как понять эту строчку? где выбрать плату в качестве передатчика? или я что-то не понял О_о
Разобралсо... на моем китаезном датчике CE и CSN местами перепутаны...
ну так и понимайте, что у вас оба скеча одинаковые :)
что бы один начал пинговать а второй отвечать нужно задать им роли через сериал...одному послать R а второму T
Тоже столкнулся с непоняткой... только у меня nrf24l01+
Скачал mirf библиотеку, на ардуино уно залил пинг-сервер:
/** * An Mirf example which copies back the data it recives. * * Pins: * Hardware SPI: * MISO -> 12 * MOSI -> 11 * SCK -> 13 * * Configurable: * CE -> 8 * CSN -> 7 * */ #include <SPI.h> #include <Mirf.h> #include <nRF24L01.h> #include <MirfHardwareSpiDriver.h> void setup(){ Serial.begin(9600); /* * Set the SPI Driver. */ Mirf.spi = &MirfHardwareSpi; /* * Setup pins / SPI. */ Mirf.init(); /* * Configure reciving address. */ Mirf.setRADDR((byte *)"serv1"); /* * Set the payload length to sizeof(unsigned long) the * return type of millis(). * * NB: payload on client and server must be the same. */ Mirf.payload = sizeof(unsigned long); /* * Write channel and payload config then power up reciver. */ Mirf.config(); Serial.println("Listening..."); } void loop(){ /* * A buffer to store the data. */ byte data[Mirf.payload]; /* * If a packet has been recived. * * isSending also restores listening mode when it * transitions from true to false. */ if(!Mirf.isSending() && Mirf.dataReady()){ Serial.println("Got packet"); /* * Get load the packet into the buffer. */ Mirf.getData(data); /* * Set the send address. */ Mirf.setTADDR((byte *)"clie1"); /* * Send the data back to the client. */ Mirf.send(data); /* * Wait untill sending has finished * * NB: isSending returns the chip to receving after returning true. */ Serial.println("Reply sent."); } }на клиент(на нано):
/** * A Mirf example to test the latency between two Ardunio. * * Pins: * Hardware SPI: * MISO -> 12 * MOSI -> 11 * SCK -> 13 * * Configurable: * CE -> 8 * CSN -> 7 * * Note: To see best case latency comment out all Serial.println * statements not displaying the result and load * 'ping_server_interupt' on the server. */ #include <SPI.h> #include <Mirf.h> #include <nRF24L01.h> #include <MirfHardwareSpiDriver.h> void setup(){ Serial.begin(9600); /* * Setup pins / SPI. */ /* To change CE / CSN Pins: * * Mirf.csnPin = 9; * Mirf.cePin = 7; */ /* Mirf.cePin = 7; Mirf.csnPin = 8; */ Mirf.spi = &MirfHardwareSpi; Mirf.init(); /* * Configure reciving address. */ Mirf.setRADDR((byte *)"clie1"); /* * Set the payload length to sizeof(unsigned long) the * return type of millis(). * * NB: payload on client and server must be the same. */ Mirf.payload = sizeof(unsigned long); /* * Write channel and payload config then power up reciver. */ /* * To change channel: * * Mirf.channel = 10; * * NB: Make sure channel is legal in your area. */ Mirf.config(); Serial.println("Beginning ... "); } void loop(){ unsigned long time = millis(); Mirf.setTADDR((byte *)"serv1"); Mirf.send((byte *)&time); while(Mirf.isSending()){ } Serial.println("Finished sending"); delay(10); while(!Mirf.dataReady()){ //Serial.println("Waiting"); if ( ( millis() - time ) > 1000 ) { Serial.println("Timeout on response from server!"); return; } } Mirf.getData((byte *) &time); Serial.print("Ping: "); Serial.println((millis() - time)); delay(1000); }И тишина... что такое - не пойму. есессно, я в настройсках выбрал для каждого свою плату.
Вроде заработал пинг... Вот только почему-то очень много пропусков.... растояние между передатчиками примерно пол метра. с 2х разных ЮСБ портов.
Это я понимал...
