Не запускается arduino-1.6.8
vitoZ
Здравствуйте.
Не запускается arduino-1.6.8. После окна с загрузкой ничего не происходит. В корне с программой создается текстовый файл с информацией об ошибке (прилагаю). Пробовал переустанавливать Java RE, не помогает.
Текст ошибки:
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000087bc, pid=2024, tid=3916
# JRE version: Java(TM) SE Runtime Environment (8.0_66-b17) (build 1.8.0_66-b17)
# Java VM: Java HotSpot(TM) Client VM (25.66-b17 mixed mode windows-x86 )
# Problematic frame:
# C 0x000087bc
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x24a98800): JavaThread "cc.arduino.packages.discoverers.serial.SerialBoardsLister" [_thread_in_native, id=3916, stack(0x24fc0000,0x25010000)]
siginfo: ExceptionCode=0xc0000005, ExceptionInformation=0x00000008 0x000087bc
Registers:
EAX=0x0014f9e8, EBX=0x00000000, ECX=0x0014fa03, EDX=0x2500ee36
ESP=0x2500ee70, EBP=0x000019b4, ESI=0x00000301, EDI=0x2500efa0
EIP=0x000087bc, EFLAGS=0x00010206
Top of Stack: (sp=0x2500ee70)
0x2500ee70: 000004ac 00220410 2500ee95 0000010b
0x2500ee80: 2500ee95 0000010b 2500ee90 00000000
0x2500ee90: 00000042 00000400 01068000 ff000003
0x2500eea0: 5a033600 45005400 57002000 44004300
0x2500eeb0: 41004d00 54002000 63006500 6e006800
0x2500eec0: 6c006f00 67006f00 65006900 20007300
0x2500eed0: 53004d00 00004d00 00000000 00000000
0x2500eee0: 00000000 00000000 00000000 00000000
Instructions: (pc=0x000087bc)
0x0000879c:
[error occurred during error reporting (printing registers, top of stack, instructions near pc), id 0xc0000005]
Register to memory mapping:
EAX=0x0014f9e8 is an unknown value
EBX=0x00000000 is an unknown value
ECX=0x0014fa03 is an unknown value
EDX=0x2500ee36 is pointing into the stack for thread: 0x24a98800
ESP=0x2500ee70 is pointing into the stack for thread: 0x24a98800
EBP=0x000019b4 is an unknown value
ESI=0x00000301 is an unknown value
EDI=0x2500efa0 is pointing into the stack for thread: 0x24a98800
Stack: [0x24fc0000,0x25010000], sp=0x2500ee70, free space=315k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C 0x000087bc
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j processing.app.Platform.resolveDeviceAttachedToNative(Ljava/lang/String;)Ljava/lang/String;+0
j processing.app.Platform.resolveDeviceByVendorIdProductId(Ljava/lang/String;Ljava/util/Map;Ljava/lang/String;)Ljava/util/Map;+2
j cc.arduino.packages.discoverers.serial.SerialBoardsLister.run()V+96
j java.util.TimerThread.mainLoop()V+221
j java.util.TimerThread.run()V+1
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x24aebc00 JavaThread "cc.arduino.packages.discoverers.network.BoardReachabilityFilter" [_thread_blocked, id=3692, stack(0x25130000,0x25180000)]
0x24aab800 JavaThread "cc.arduino.packages.discoverers.network.NetworkChecker" [_thread_in_native, id=3496, stack(0x25040000,0x25090000)]
=>0x24a98800 JavaThread "cc.arduino.packages.discoverers.serial.SerialBoardsLister" [_thread_in_native, id=3916, stack(0x24fc0000,0x25010000)]
0x24a37c00 JavaThread "AWT-Windows" daemon [_thread_in_native, id=1872, stack(0x24cd0000,0x24d20000)]
0x24a1c800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=4080, stack(0x24e40000,0x24e90000)]
0x2415b400 JavaThread "Service Thread" daemon [_thread_blocked, id=2396, stack(0x24880000,0x248d0000)]
0x24162800 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=3528, stack(0x24610000,0x24660000)]
0x24161800 JavaThread "Attach Listener" daemon [_thread_blocked, id=556, stack(0x24330000,0x24380000)]
0x24160c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=3440, stack(0x24660000,0x246b0000)]
0x2411b400 JavaThread "Finalizer" daemon [_thread_blocked, id=1040, stack(0x24450000,0x244a0000)]
0x24119000 JavaThread "Reference Handler" daemon [_thread_blocked, id=3864, stack(0x244b0000,0x24500000)]
0x012d5000 JavaThread "main" [_thread_in_native, id=4044, stack(0x00240000,0x00290000)]
Other Threads:
0x24113400 VMThread [stack: 0x243d0000,0x24420000] [id=3188]
0x2415d800 WatcherThread [stack: 0x24720000,0x24770000] [id=1288]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap:
def new generation total 39296K, used 28705K [0x03c00000, 0x066a0000, 0x0e6a0000)
eden space 34944K, 69% used [0x03c00000, 0x053c8488, 0x05e20000)
from space 4352K, 100% used [0x06260000, 0x066a0000, 0x066a0000)
to space 4352K, 0% used [0x05e20000, 0x05e20000, 0x06260000)
tenured generation total 87424K, used 2182K [0x0e6a0000, 0x13c00000, 0x23c00000)
the space 87424K, 2% used [0x0e6a0000, 0x0e8c1978, 0x0e8c1a00, 0x13c00000)
Metaspace used 10974K, capacity 11300K, committed 11392K, reserved 11648K
Card table byte_map: [0x01a40000,0x01b50000] byte_map_base: 0x01a22000
Polling page: 0x00290000
CodeCache: size=32768Kb used=1451Kb max_used=1451Kb free=31316Kb
bounds [0x01bd0000, 0x01d40000, 0x03bd0000]
total_blobs=836 nmethods=594 adapters=174
compilation: enabled
Compilation events (10 events):
Event: 10.261 Thread 0x24162800 596 java.util.regex.Pattern$Single::isSatisfiedBy (14 bytes)
Event: 10.261 Thread 0x24162800 nmethod 596 0x01d3a208 code [0x01d3a300, 0x01d3a390]
Event: 10.275 Thread 0x24162800 597 java.util.regex.Matcher::start (22 bytes)
Event: 10.276 Thread 0x24162800 nmethod 597 0x01d3a3c8 code [0x01d3a4d0, 0x01d3a5bc]
Event: 10.278 Thread 0x24162800 598 ! com.github.zafarkhaja.semver.VersionParser::consumeNextCharacter (22 bytes)
Event: 10.278 Thread 0x24162800 nmethod 598 0x01d3a648 code [0x01d3a760, 0x01d3a8b4]
Event: 10.280 Thread 0x24162800 599 com.github.zafarkhaja.semver.VersionParser$CharType$1::isMatchedBy (9 bytes)
Event: 10.280 Thread 0x24162800 nmethod 599 0x01d3aa08 code [0x01d3ab00, 0x01d3abf0]
Event: 10.280 Thread 0x24162800 600 com.github.zafarkhaja.semver.VersionParser$CharType$1::isMatchedBy (30 bytes)
Event: 10.281 Thread 0x24162800 nmethod 600 0x01d3ac88 code [0x01d3ad80, 0x01d3ae50]
GC Heap History (2 events):
Event: 7.473 GC heap before
{Heap before GC invocations=0 (full 0):
def new generation total 39296K, used 34944K [0x03c00000, 0x066a0000, 0x0e6a0000)
eden space 34944K, 100% used [0x03c00000, 0x05e20000, 0x05e20000)
from space 4352K, 0% used [0x05e20000, 0x05e20000, 0x06260000)
to space 4352K, 0% used [0x06260000, 0x06260000, 0x066a0000)
tenured generation total 87424K, used 0K [0x0e6a0000, 0x13c00000, 0x23c00000)
the space 87424K, 0% used [0x0e6a0000, 0x0e6a0000, 0x0e6a0200, 0x13c00000)
Metaspace used 8350K, capacity 8522K, committed 8576K, reserved 8576K
Event: 7.498 GC heap after
Heap after GC invocations=1 (full 0):
def new generation total 39296K, used 4352K [0x03c00000, 0x066a0000, 0x0e6a0000)
eden space 34944K, 0% used [0x03c00000, 0x03c00000, 0x05e20000)
Deoptimization events (0 events):
No events
Internal exceptions (10 events):
Event: 10.282 Thread 0x012d5000 Exception (0x05350b18) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u66\4988\hotspot\src\share\vm\prims\jni.cpp, line 709]
(0x05350fb8) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u66\4988\hotspot\src\share\vm\prims\jni.cpp, line 709]
Event: 10.285 Thread 0x012d5000 Exception
(0x053601f0) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u66\4988\hotspot\src\share\vm\prims\jni.cpp, line 709]
(0x05360780) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u66\4988\hotspot\src\share\vm\prims\jni.cpp, line 709]
Event: 10.286 Thread 0x012d5000 Exception
(0x053699c8) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u66\4988\hotspot\src\share\vm\prims\jni.cpp, line 709]
(0x05369f30) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u66\4988\hotspot\src\share\vm\prims\jni.cpp, line 709]
Event: 10.287 Thread 0x012d5000 Exception
(0x05373a48) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u66\4988\hotspot\src\share\vm\prims\jni.cpp, line 709]
Event: 10.291 Thread 0x012d5000 Exception
(0x05374028) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u66\4988\hotspot\src\share\vm\prims\jni.cpp, line 709]
Event: 10.293 Thread 0x012d5000 Exception
(0x0537d828) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u66\4988\hotspot\src\share\vm\prims\jni.cpp, line 709]
(0x0537dd90) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u66\4988\hotspot\src\share\vm\prims\jni.cpp, line 709]
Events (10 events):
Event: 10.170 loading class java/util/stream/FindOps
Event: 10.181 loading class java/util/stream/FindOps done
Event: 10.182 loading class java/util/stream/FindOps$FindOp
Event: 10.206 loading class java/util/stream/FindOps$FindOp done
Event: 10.206 loading class java/util/Optional
Event: 10.220 loading class java/util/Optional done
Event: 10.222 loading class java/util/stream/FindOps$FindSink$OfRef
Event: 10.222 loading class java/util/stream/FindOps$FindSink done
Event: 10.222 loading class java/util/stream/FindOps$FindSink$OfRef done
Dynamic libraries:
0x002a0000 - 0x002d3000 C:\arduino-1.6.8\java\bin\javaw.exe
0x77980000 - 0x77abc000 C:\Windows\SYSTEM32\ntdll.dll
0x763d0000 - 0x764a4000 C:\Windows\system32\kernel32.dll
0x75bb0000 - 0x75bfa000 C:\Windows\system32\KERNELBASE.dll
0x76560000 - 0x76600000 C:\Windows\system32\ADVAPI32.dll
0x778d0000 - 0x7797c000 C:\Windows\system32\msvcrt.dll
0x76390000 - 0x763a9000 C:\Windows\SYSTEM32\sechost.dll
0x761b0000 - 0x76251000 C:\Windows\system32\RPCRT4.dll
0x762c0000 - 0x76389000 C:\Windows\system32\USER32.dll
0x764b0000 - 0x764fe000 C:\Windows\system32\GDI32.dll
0x76550000 - 0x7655a000 C:\Windows\system32\LPK.dll
0x77830000 - 0x778cd000 C:\Windows\system32\USP10.dll
0x749c0000 - 0x74b5e000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_41e6975e2bd6f2b2\COMCTL32.dll
0x76260000 - 0x762b7000 C:\Windows\system32\SHLWAPI.dll
0x763b0000 - 0x763cf000 C:\Windows\system32\IMM32.DLL
0x766c0000 - 0x7678c000 C:\Windows\system32\MSCTF.dll
0x6ad40000 - 0x6adff000 C:\arduino-1.6.8\java\bin\msvcr100.dll
0x61650000 - 0x61a15000 C:\arduino-1.6.8\java\bin\client\jvm.dll
0x6eca0000 - 0x6eca7000 C:\Windows\system32\WSOCK32.dll
0x768f0000 - 0x76925000 C:\Windows\system32\WS2_32.dll
0x75f10000 - 0x75f16000 C:\Windows\system32\NSI.dll
0x72330000 - 0x72362000 C:\Windows\system32\WINMM.dll
0x750c0000 - 0x750c9000 C:\Windows\system32\VERSION.dll
0x76930000 - 0x76935000 C:\Windows\system32\PSAPI.DLL
0x6efb0000 - 0x6efe1000 C:\arduino-1.6.8\java\bin\splashscreen.dll
0x74840000 - 0x74880000 C:\Windows\system32\uxtheme.dll
0x76790000 - 0x768ec000 C:\Windows\system32\ole32.dll
0x75a20000 - 0x75a2c000 C:\Windows\system32\CRYPTBASE.dll
0x76630000 - 0x766bf000 C:\Windows\system32\OLEAUT32.DLL
0x737d0000 - 0x737dc000 C:\arduino-1.6.8\java\bin\verify.dll
0x736f0000 - 0x73711000 C:\arduino-1.6.8\java\bin\java.dll
0x73770000 - 0x73783000 C:\arduino-1.6.8\java\bin\zip.dll
0x76940000 - 0x7758a000 C:\Windows\system32\SHELL32.dll
0x75ad0000 - 0x75adb000 C:\Windows\system32\profapi.dll
0x6a7f0000 - 0x6a935000 C:\arduino-1.6.8\java\bin\awt.dll
0x74510000 - 0x74523000 C:\Windows\system32\dwmapi.dll
0x6c190000 - 0x6c1c9000 C:\arduino-1.6.8\java\bin\fontmanager.dll
0x70670000 - 0x70686000 C:\arduino-1.6.8\java\bin\net.dll
0x75510000 - 0x7554c000 C:\Windows\system32\mswsock.dll
0x75500000 - 0x75506000 C:\Windows\System32\wship6.dll
0x737b0000 - 0x737bf000 C:\arduino-1.6.8\java\bin\nio.dll
0x70570000 - 0x705a0000 C:\arduino-1.6.8\java\bin\t2k.dll
0x01480000 - 0x014b6000 C:\arduino-1.6.8\lib\listSerialsj.dll
0x77690000 - 0x7782d000 C:\Windows\system32\SETUPAPI.dll
0x75b50000 - 0x75b77000 C:\Windows\system32\CFGMGR32.dll
0x75c00000 - 0x75c12000 C:\Windows\system32\DEVOBJ.dll
0x73c10000 - 0x73c2c000 C:\Windows\system32\IPHLPAPI.DLL
0x73c00000 - 0x73c07000 C:\Windows\system32\WINNSI.DLL
0x71310000 - 0x71322000 C:\Windows\system32\dhcpcsvc.DLL
0x71300000 - 0x7130d000 C:\Windows\system32\dhcpcsvc6.DLL
0x753d0000 - 0x75414000 C:\Windows\system32\DNSAPI.dll
0x75550000 - 0x75566000 C:\Windows\system32\CRYPTSP.dll
0x752f0000 - 0x7532b000 C:\Windows\system32\rsaenh.dll
0x75130000 - 0x75147000 C:\Windows\system32\USERENV.dll
0x74fb0000 - 0x74fb5000 C:\Windows\System32\wshtcpip.dll
0x701a0000 - 0x701a6000 C:\Windows\system32\rasadhlp.dll
0x01b50000 - 0x01b8d000 C:\Users\Витэк\AppData\Local\Temp\jna-995565865\jna1230380675345970082.dll
0x64000000 - 0x6401b000 C:\Users\Витэк\.jssc\windows\jSSC-2.8_x86.dll
0x742f0000 - 0x743db000 C:\Windows\system32\dbghelp.dll
VM Arguments:
jvm_args: -Dsun.java2d.d3d=false -DAPP_DIR=C:\arduino-1.6.8 -Xms128M -Xmx512M
java_command: processing.app.Base
java_class_path (initial): C:\arduino-1.6.8\lib\apple.jar;C:\arduino-1.6.8\lib\arduino-core.jar;C:\arduino-1.6.8\lib\batik-1.8.jar;C:\arduino-1.6.8\lib\batik-anim-1.8.jar;C:\arduino-1.6.8\lib\batik-awt-util-1.8.jar;C:\arduino-1.6.8\lib\batik-bridge-1.8.jar;C:\arduino-1.6.8\lib\batik-codec-1.8.jar;C:\arduino-1.6.8\lib\batik-css-1.8.jar;C:\arduino-1.6.8\lib\batik-dom-1.8.jar;C:\arduino-1.6.8\lib\batik-ext-1.8.jar;C:\arduino-1.6.8\lib\batik-gvt-1.8.jar;C:\arduino-1.6.8\lib\batik-parser-1.8.jar;C:\arduino-1.6.8\lib\batik-rasterizer-1.8.jar;C:\arduino-1.6.8\lib\batik-script-1.8.jar;C:\arduino-1.6.8\lib\batik-squiggle-1.8.jar;C:\arduino-1.6.8\lib\batik-svg-dom-1.8.jar;C:\arduino-1.6.8\lib\batik-svgpp-1.8.jar;C:\arduino-1.6.8\lib\batik-transcoder-1.8.jar;C:\arduino-1.6.8\lib\batik-util-1.8.jar;C:\arduino-1.6.8\lib\batik-xml-1.8.jar;C:\arduino-1.6.8\lib\bcpg-jdk15on-152.jar;C:\arduino-1.6.8\lib\bcprov-jdk15on-152.jar;C:\arduino-1.6.8\lib\commons-codec-1.7.jar;C:\arduino-1.6.8\lib\commons-compress-1.8.jar;C:\arduino-1.6.8\lib\commons-exec-1.1.jar;C:\arduino-1.6.8\lib\commons-httpclient-3.1.jar;C:\arduino-1.6.8\lib\commons-lang3-3.3.2.jar;C:\arduino-1.6.8\lib\commons-logging-1.0.4.jar;C:\arduino-1.6.8\lib\commons-net-3.3.jar;C:\arduino-1.6.8\lib\jackson-annotations-2.6.3.jar;C:\arduino-1.6.8\lib\jackson-core-2.6.3.jar;C:\arduino-1.6.8\lib\jackson-databind-2.6.3.jar;C:\arduino-1.6.8\lib\jackson-module-mrbean-2.6.3.jar;C:\arduino-1.6.8\lib\java-semver-0.8.0.jar;C:\arduino-1.6.8\lib\jmdns-3.4.1.jar;C:\arduino-1.6.8\lib\jna-4.1.0.jar;C:\arduino-1.6.8\lib\jna-platform-4.1.0.jar;C:\arduino-1.6.8\lib\jsch-0.1.50.jar;C:\arduino-1.6.8\lib\jssc-2.8.0.jar;C:\arduino-1.6.8\lib\pde.jar;C:\arduino-1.6.8\lib\rsyntaxtextarea-2.5.8.1+arduino.jar;C:\arduino-1.6.8\lib\xml-apis-1.3.04.jar;C:\arduino-1.6.8\lib\xml-apis-ext-1.3.04.jar;C:\arduino-1.6.8\lib\xmlgraphics-commons-2.0.jar
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\ProgramData\Oracle\Java\javapath;C:\oraclexe\app\oracle\product\11.2.0\server\bin;;C:\Program Files\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Windows Kits\8.1\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\arduino-1.6.8\java\bin
USERNAME
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 23 Stepping 10, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 7 Build 7601 (6.1.7601.17514)
CPU:total 1 (2 cores per cpu, 1 threads per core) family 6 model 23 stepping 10, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, tsc
Memory: 4k page, physical 1047736k(172444k free), swap 2197784k(174120k free)
vm_info: Java HotSpot(TM) Client VM (25.66-b17) for windows-x86 JRE (1.8.0_66-b17), built on Oct 6 2015 19:59:47 by "java_re" with MS VC++ 10.0 (VS2010)
time: Fri Jul 22 01:49:48 2016
elapsed time: 10 seconds (0d 0h 0m 10s)
Клапауций 232
удали антивирус
vitoZ
Нет антивируса, только Брандмауэр Windows. Щас попробую его отключить.
(не помогло)
DIYMan
DIYMan аватар
Винда какая? x86 или x64? В смысле- 32-х битная или 64-х?
vitoZ
32-битная
