Неправильный сбор информации с датчиков(ультразвуковой датчик\герконовый датчикх3)
Пнд, 25/06/2018 - 16:33
//Libraries
#include <LiquidCrystal.h>
#include <Keypad.h>
#include <NewPing.h>
#include "NewTone.h"
/*-----------------------KEYPAD-----------------------*/
const byte numRows= 4; //number of rows on the keypad
const byte numCols= 4; //number of columns on the keypad
char keypressed;
//keymap defines the key pressed according to the row and columns just as appears on the keypad
char keymap[numRows][numCols]=
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
//Code that shows the the keypad connections to the arduino terminals
byte rowPins[numRows] = {10, 11, 12, 13};//Rows 0 to 3
byte colPins[numCols] = {A2, A3, A4, A5};//Columns 0 to 3
//initializes an instance of the Keypad class
Keypad myKeypad= Keypad( makeKeymap(keymap), rowPins, colPins, numRows, numCols);
/*--------------------------CONSTANTS-------------------------*/
const int buzzer = A1; //Buzzer/small speaker
const int doorMagSen = 9; //Door magnetic sensor
const int windowMagSen = 2; //Window magnetic sensors
LiquidCrystal lcd(8,7,6,5,4,3); //lcd ((RS, E, D4, D5, D6, D7)
NewPing sonar(A0,A0,2000); // Trig Echo Max distance
/*--------------------------VARIABLES------------------------*/
String password="1488" ; //riable to store the current password
String tempPassword="" ; //Variable to store the input password
int doublecheck;
boolean armed = false; //Variable for system state (armed:true / unarmed:false)
boolean input_pass; //Variable for input password (correct:true / wrong:false)
boolean storedPassword = true;
boolean changedPassword = false;
boolean checkPassword = false;
int distance;
int i = 1; //variable to index an array
lcd.begin(16, 2); //Setup the LCD's number of columns and rows
pinMode(doorMagSen,INPUT_PULLUP); //Set all magnetic sensors as input withn internal pullup resistor
pinMode(windowMagSen,INPUT_PULLUP);
void loop() { //Main loop
if (armed){
systemIsArmed(); //Run function to activate the system
else if (!armed){
systemIsUnarmed(); //Run fuction to de activate the system
/********************************FUNCTIONS************************************/
//While system is unarmed
void systemIsUnarmed(){
int screenMsg=0;
lcd.clear(); //Clear lcd
unsigned long previousMillis = 0; //To make a delay by using millis() function
const long interval = 5000; //delay will be 5 sec.
//every "page"-msg of lcd will change every 5 sec
while(!armed){ //While system is unarmed do...
unsigned long currentMillis = millis(); //Store the current run-time of the system (millis function)
if (currentMillis - previousMillis >= interval) {
if(screenMsg==0){ //First page-message of lcd
lcd.setCursor(0,0);
lcd.print("SYSTEM ALARM OFF");
lcd.setCursor(0,1);
lcd.print("----------------");
screenMsg=1;
else{ //Second page-message of lcd
lcd.setCursor(0,0);
lcd.print("A to arm ");
lcd.setCursor(0,1);
lcd.print("B to change pass");
screenMsg=0;
keypressed = myKeypad.getKey(); //Read the pressed button
if (keypressed =='A'){ //If A is pressed, activate the system
NewTone(buzzer,500,200);
systemIsArmed(); //by calling the systemIsArmed function
else if (keypressed =='B'){//If B is pressed, change current password
doublecheck=0;
storedPassword=false;
if(!changedPassword){ //By calling the changePassword function
changePassword();
//While system is armed
void systemIsArmed(){
lcd.clear();
int count=10; //Count 10sec before activate the system
const long interval = 1000;
while(!armed){
distance = sonar.ping_cm(); //Store distance from sensor only for first time
//While system is unarmed - for 10sed do...
lcd.setCursor(0,0);
lcd.print(" SYSTEM WILL BE "); //Print message to lcd with 10 sec timer
lcd.setCursor(0,1);
lcd.print(" ARMED IN ");
//Screen counter 10sec
if (count>1){
count--; //Countdown timer
else{
armed=true; //Activate the system!
lcd.setCursor(12,1);
lcd.print(count); //show the timer at lcd second line 13 possition
while (armed){ //While system is armed do...
lcd.setCursor(0,0);
lcd.print("SYSTEM IS ARMED!");
lcd.setCursor(0,1);
int door = digitalRead(doorMagSen); //Read magnetic sensros and ultrasonic sensor
int window = digitalRead(windowMagSen);
int curr_distanse = sonar.ping_cm();
//Check values
if (window==HIGH){
alarmFunction(); //Call alarm!
if (door==HIGH){
unlockPassword(); //Disarm the system with correct password
//Ultrasonic sensor code
if (curr_distanse < (distance -5)){ //Check distanse (minus 5 for safety) with current distanse
alarmFunction();
//Door is opend, unlcok the system!
void unlockPassword() {
int count=21; //20 sec for alarm!
retry: //label for goto, retry in case of wrong password
tempPassword=""; //reset temp password (typing...)
lcd.clear(); //clear lcd
i=6; //variable to put * while typing pass
boolean buzzerState = false; //variable to help us make a beep NewTone
while(!checkPassword){ //While waiting for correct password do...
previousMillis = currentMillis; //play beep NewTone every 1 sec
if (!buzzerState){
NewTone(buzzer, 700);
buzzerState=true;
else{
noNewTone(buzzer);
buzzerState=false;
if (count>0){ //Screen counter 20sec
count--;
else{
alarmFunction(); //Times is up, ALARM!
lcd.setCursor(0,0);
lcd.print("ALARM IN: ");
//For screen counter - 20sec
if (count>=10){
lcd.setCursor(14,0);
lcd.print(count); //print countdown timer at lcd
else{ //catch '0'bellow 10 (eg 09)
lcd.print(" ");
lcd.print(count);
lcd.setCursor(0,1);
lcd.print("PASS>");
if (keypressed != NO_KEY){ //Accept only numbers and * from keypad
if (keypressed == '0' || keypressed == '1' || keypressed == '2' || keypressed == '3' ||
keypressed == '4' || keypressed == '5' || keypressed == '6' || keypressed == '7' ||
keypressed == '8' || keypressed == '9' ){
tempPassword += keypressed;
lcd.setCursor(i,1);
lcd.print("*"); //Put * on lcd
i++;
NewTone(buzzer,500,200); //Button NewTone
else if (keypressed == '*'){ //Check for password
if (password==tempPassword){//If it's correct unarmed the system
armed=false;
NewTone(buzzer,700,500);
else{ //if it's false, retry
tempPassword="";
NewTone(buzzer,200,200);
delay(300);
delay(300);
goto retry;
//Alarm
void alarmFunction(){
tempPassword="";
lcd.clear();
i=6;
const long interval = 500;
while(!checkPassword){ //Waiting for password to deactivate the alarm...
previousMillis = currentMillis; //Play a beep NewTone every 0.5 second
if (!buzzerState){
buzzerState=true;
else{
noNewTone(buzzer);
buzzerState=false;
lcd.setCursor(0,0);
lcd.print(" !!! ALARM !!! ");
lcd.setCursor(0,1);
lcd.print("PASS>");
lcd.setCursor(i,1);
lcd.print("*");
i++;
armed=false;
else{
tempPassword="";
delay(300);
delay(300);
goto retry;
//Change current password
void changePassword(){
tempPassword="";
lcd.clear();
i=1;
while(!changedPassword){ //Waiting for current password
keypressed = myKeypad.getKey(); //Read pressed keys
lcd.setCursor(0,0);
lcd.print("CURRENT PASSWORD");
lcd.setCursor(0,1);
lcd.print(">");
lcd.setCursor(i,1);
lcd.print("*");
i++;
NewTone(buzzer,800,200);
else if (keypressed=='#'){
i=1;
newPassword(); //Password is corrent, so call the newPassword function
else{ //Try again
tempPassword="";
delay(300);
delay(300);
goto retry;
String firstpass;
//Setup new password
void newPassword(){
tempPassword="";
changedPassword=false;
lcd.clear();
i=1;
while(!storedPassword){
if (doublecheck==0){
lcd.setCursor(0,0);
lcd.print("SET NEW PASSWORD");
lcd.setCursor(0,1);
lcd.print(">");
else{
lcd.setCursor(0,0);
lcd.print("One more time...");
lcd.setCursor(0,1);
lcd.print(">");
lcd.setCursor(i,1);
lcd.print("*");
i++;
if (doublecheck == 0){
firstpass=tempPassword;
doublecheck=1;
newPassword();
if (doublecheck==1){
doublecheck=0;
if (firstpass==tempPassword){
i=1;
firstpass="";
password = tempPassword; // New password saved
tempPassword="";//erase temp password
lcd.setCursor(0,0);
lcd.print("PASSWORD CHANGED");
lcd.setCursor(0,1);
storedPassword=true;
NewTone(buzzer,500,400);
delay(2000);
lcd.clear();
else{
firstpass="";
newPassword();
http://arduino.ru/forum/obshchii/vstavka-programmnogo-koda-v-temukomment...
//Libraries #include <LiquidCrystal.h> #include <Keypad.h> #include <NewPing.h> #include "NewTone.h" /*-----------------------KEYPAD-----------------------*/ const byte numRows= 4; //number of rows on the keypad const byte numCols= 4; //number of columns on the keypad char keypressed; //keymap defines the key pressed according to the row and columns just as appears on the keypad char keymap[numRows][numCols]= { {'1', '2', '3', 'A'}, {'4', '5', '6', 'B'}, {'7', '8', '9', 'C'}, {'*', '0', '#', 'D'} }; //Code that shows the the keypad connections to the arduino terminals byte rowPins[numRows] = {10, 11, 12, 13};//Rows 0 to 3 byte colPins[numCols] = {A2, A3, A4, A5};//Columns 0 to 3 //initializes an instance of the Keypad class Keypad myKeypad= Keypad( makeKeymap(keymap), rowPins, colPins, numRows, numCols); /*--------------------------CONSTANTS-------------------------*/ const int buzzer = A1; //Buzzer/small speaker const int doorMagSen = 9; //Door magnetic sensor const int windowMagSen = 2; //Window magnetic sensors LiquidCrystal lcd(8,7,6,5,4,3); //lcd ((RS, E, D4, D5, D6, D7) NewPing sonar(A0,A0,2000); // Trig Echo Max distance /*--------------------------VARIABLES------------------------*/ String password="1488" ; //riable to store the current password String tempPassword="" ; //Variable to store the input password int doublecheck; boolean armed = false; //Variable for system state (armed:true / unarmed:false) boolean input_pass; //Variable for input password (correct:true / wrong:false) boolean storedPassword = true; boolean changedPassword = false; boolean checkPassword = false; int distance; int i = 1; //variable to index an array /**********************************************************************************/ void setup() { lcd.begin(16, 2); //Setup the LCD's number of columns and rows pinMode(doorMagSen,INPUT_PULLUP); //Set all magnetic sensors as input withn internal pullup resistor pinMode(windowMagSen,INPUT_PULLUP); } void loop() { //Main loop if (armed){ systemIsArmed(); //Run function to activate the system } else if (!armed){ systemIsUnarmed(); //Run fuction to de activate the system } } /********************************FUNCTIONS************************************/ //While system is unarmed void systemIsUnarmed(){ int screenMsg=0; lcd.clear(); //Clear lcd unsigned long previousMillis = 0; //To make a delay by using millis() function const long interval = 5000; //delay will be 5 sec. //every "page"-msg of lcd will change every 5 sec while(!armed){ //While system is unarmed do... unsigned long currentMillis = millis(); //Store the current run-time of the system (millis function) if (currentMillis - previousMillis >= interval) { previousMillis = currentMillis; if(screenMsg==0){ //First page-message of lcd lcd.setCursor(0,0); lcd.print("SYSTEM ALARM OFF"); lcd.setCursor(0,1); lcd.print("----------------"); screenMsg=1; } else{ //Second page-message of lcd lcd.setCursor(0,0); lcd.print("A to arm "); lcd.setCursor(0,1); lcd.print("B to change pass"); screenMsg=0; } } keypressed = myKeypad.getKey(); //Read the pressed button if (keypressed =='A'){ //If A is pressed, activate the system NewTone(buzzer,500,200); systemIsArmed(); //by calling the systemIsArmed function } else if (keypressed =='B'){//If B is pressed, change current password doublecheck=0; NewTone(buzzer,500,200); storedPassword=false; if(!changedPassword){ //By calling the changePassword function changePassword(); } } } } //While system is armed void systemIsArmed(){ lcd.clear(); int count=10; //Count 10sec before activate the system unsigned long previousMillis = 0; const long interval = 1000; while(!armed){ distance = sonar.ping_cm(); //Store distance from sensor only for first time //While system is unarmed - for 10sed do... lcd.setCursor(0,0); lcd.print(" SYSTEM WILL BE "); //Print message to lcd with 10 sec timer lcd.setCursor(0,1); lcd.print(" ARMED IN "); unsigned long currentMillis = millis(); if (currentMillis - previousMillis >= interval) { previousMillis = currentMillis; //Screen counter 10sec if (count>1){ count--; //Countdown timer } else{ armed=true; //Activate the system! break; } } lcd.setCursor(12,1); lcd.print(count); //show the timer at lcd second line 13 possition } while (armed){ //While system is armed do... lcd.setCursor(0,0); lcd.print("SYSTEM IS ARMED!"); lcd.setCursor(0,1); lcd.print("----------------"); int door = digitalRead(doorMagSen); //Read magnetic sensros and ultrasonic sensor int window = digitalRead(windowMagSen); int curr_distanse = sonar.ping_cm(); //Check values if (window==HIGH){ alarmFunction(); //Call alarm! } if (door==HIGH){ unlockPassword(); //Disarm the system with correct password } //Ultrasonic sensor code if (curr_distanse < (distance -5)){ //Check distanse (minus 5 for safety) with current distanse alarmFunction(); } } } //Door is opend, unlcok the system! void unlockPassword() { int count=21; //20 sec for alarm! retry: //label for goto, retry in case of wrong password tempPassword=""; //reset temp password (typing...) lcd.clear(); //clear lcd i=6; //variable to put * while typing pass unsigned long previousMillis = 0; const long interval = 1000; boolean buzzerState = false; //variable to help us make a beep NewTone while(!checkPassword){ //While waiting for correct password do... unsigned long currentMillis = millis(); if (currentMillis - previousMillis >= interval) { previousMillis = currentMillis; //play beep NewTone every 1 sec if (!buzzerState){ NewTone(buzzer, 700); buzzerState=true; } else{ noNewTone(buzzer); buzzerState=false; } if (count>0){ //Screen counter 20sec count--; } else{ alarmFunction(); //Times is up, ALARM! break; } } keypressed = myKeypad.getKey(); lcd.setCursor(0,0); lcd.print("ALARM IN: "); //For screen counter - 20sec if (count>=10){ lcd.setCursor(14,0); lcd.print(count); //print countdown timer at lcd } else{ //catch '0'bellow 10 (eg 09) lcd.setCursor(14,0); lcd.print(" "); lcd.print(count); } lcd.setCursor(0,1); lcd.print("PASS>"); if (keypressed != NO_KEY){ //Accept only numbers and * from keypad if (keypressed == '0' || keypressed == '1' || keypressed == '2' || keypressed == '3' || keypressed == '4' || keypressed == '5' || keypressed == '6' || keypressed == '7' || keypressed == '8' || keypressed == '9' ){ tempPassword += keypressed; lcd.setCursor(i,1); lcd.print("*"); //Put * on lcd i++; NewTone(buzzer,500,200); //Button NewTone } else if (keypressed == '*'){ //Check for password if (password==tempPassword){//If it's correct unarmed the system armed=false; NewTone(buzzer,700,500); break; } else{ //if it's false, retry tempPassword=""; NewTone(buzzer,200,200); delay(300); NewTone(buzzer,200,200); delay(300); goto retry; } } } } } //Alarm void alarmFunction(){ retry: //label for goto tempPassword=""; lcd.clear(); i=6; unsigned long previousMillis = 0; const long interval = 500; boolean buzzerState = false; while(!checkPassword){ //Waiting for password to deactivate the alarm... unsigned long currentMillis = millis(); if (currentMillis - previousMillis >= interval) { previousMillis = currentMillis; //Play a beep NewTone every 0.5 second if (!buzzerState){ NewTone(buzzer, 700); buzzerState=true; } else{ noNewTone(buzzer); buzzerState=false; } } keypressed = myKeypad.getKey(); lcd.setCursor(0,0); lcd.print(" !!! ALARM !!! "); lcd.setCursor(0,1); lcd.print("PASS>"); if (keypressed != NO_KEY){ //Accept only numbers and * if (keypressed == '0' || keypressed == '1' || keypressed == '2' || keypressed == '3' || keypressed == '4' || keypressed == '5' || keypressed == '6' || keypressed == '7' || keypressed == '8' || keypressed == '9' ){ tempPassword += keypressed; lcd.setCursor(i,1); lcd.print("*"); i++; } else if (keypressed == '*'){ if (password==tempPassword){ armed=false; NewTone(buzzer,700,500); break; } else{ tempPassword=""; NewTone(buzzer,200,200); delay(300); NewTone(buzzer,200,200); delay(300); goto retry; } } } } } //Change current password void changePassword(){ retry: //label for goto tempPassword=""; lcd.clear(); i=1; while(!changedPassword){ //Waiting for current password keypressed = myKeypad.getKey(); //Read pressed keys lcd.setCursor(0,0); lcd.print("CURRENT PASSWORD"); lcd.setCursor(0,1); lcd.print(">"); if (keypressed != NO_KEY){ if (keypressed == '0' || keypressed == '1' || keypressed == '2' || keypressed == '3' || keypressed == '4' || keypressed == '5' || keypressed == '6' || keypressed == '7' || keypressed == '8' || keypressed == '9' ){ tempPassword += keypressed; lcd.setCursor(i,1); lcd.print("*"); i++; NewTone(buzzer,800,200); } else if (keypressed=='#'){ break; } else if (keypressed == '*'){ i=1; if (password==tempPassword){ storedPassword=false; NewTone(buzzer,500,200); newPassword(); //Password is corrent, so call the newPassword function break; } else{ //Try again tempPassword=""; NewTone(buzzer,500,200); delay(300); NewTone(buzzer,500,200); delay(300); goto retry; } } } } } String firstpass; //Setup new password void newPassword(){ tempPassword=""; changedPassword=false; lcd.clear(); i=1; while(!storedPassword){ keypressed = myKeypad.getKey(); //Read pressed keys if (doublecheck==0){ lcd.setCursor(0,0); lcd.print("SET NEW PASSWORD"); lcd.setCursor(0,1); lcd.print(">"); } else{ lcd.setCursor(0,0); lcd.print("One more time..."); lcd.setCursor(0,1); lcd.print(">"); } if (keypressed != NO_KEY){ if (keypressed == '0' || keypressed == '1' || keypressed == '2' || keypressed == '3' || keypressed == '4' || keypressed == '5' || keypressed == '6' || keypressed == '7' || keypressed == '8' || keypressed == '9' ){ tempPassword += keypressed; lcd.setCursor(i,1); lcd.print("*"); i++; NewTone(buzzer,800,200); } else if (keypressed=='#'){ break; } else if (keypressed == '*'){ if (doublecheck == 0){ firstpass=tempPassword; doublecheck=1; newPassword(); } if (doublecheck==1){ doublecheck=0; if (firstpass==tempPassword){ i=1; firstpass=""; password = tempPassword; // New password saved tempPassword="";//erase temp password lcd.setCursor(0,0); lcd.print("PASSWORD CHANGED"); lcd.setCursor(0,1); lcd.print("----------------"); storedPassword=true; NewTone(buzzer,500,400); delay(2000); lcd.clear(); break; } else{ firstpass=""; newPassword(); } } } } } }А по-моему так всё ОК.
+1
ТС, если вас что-то не устравивает - пишите конкретно, что именно, желательно с примерами - типа "вводим А, ожидаем Б. а получем -Х"
А без конкретики сильно сомневаюсь, что кто-то захочет разбираться в этой портянке
Включатеся система защиты- идет отсчет 10 секунд до срабатывания датчиков гиркона и ультразвукового - далее система включает звуковое оповещение
Хотя датчики гиркона находятся в закрытом положении и не размыкаются. При таком расположении датчиков гиркона звуковое оповещение включаться не должно.
