Нужна помощь в переделке кода с оптик энкодерами
Вс, 26/03/2017 - 19:47
Всем доброго времени суток.
Изобретаю станок ЧПУ с DC моторами и оптическими энкодерами.
имеется такой код:
//CNC router // //Code to run on the command computer see: //commands-plotter.c // //Source & info: www.HomoFaciens.de //#include <avr/io.h> //#include <util/delay.h> #include <Servo.h> //Change values below to adapt your motor #define STEP_MARGIN 1L //10 - 1000 (2) #define MIN_DUTYCYCLE 120 //0 - 255 (125) #define MAX_DUTYCYCLE 255 //0 - 255 (255) #define MX_S1 A0 //Sensor input 1 #define MX_S2 A1 //Sensor input 2 #define MX_DIR 2 //Direction output motor #define MX_PWM 3 //PWM output motor #define MY_S1 A2 //Sensor input 1 #define MY_S2 A3 //Sensor input 2 #define MY_DIR 4 //Direction output motor #define MY_PWM 5 //PWM output motor #define MZ_S1 A4 //Sensor input 1 #define MZ_S2 A5 //Sensor input 2 #define MZ_DIR 7 //Direction output motor #define MZ_PWM 6 //PWM output motor #define RELAY 9 //Relay used to turn on milling machine int MxSensorRead2 = 0; int MxSensorRead1 = 0; int MxDutyCycle = 100; // 10 - 255 unsigned long MxSetPoint = 0; unsigned long MxActualPoint = 0; byte MxStep = 0; byte MxStepDone = 0; int MySensorRead2 = 0; int MySensorRead1 = 0; int MyDutyCycle = 100; // 10 - 255 unsigned long MySetPoint = 0; unsigned long MyActualPoint = 0; byte MyStep = 0; byte MyStepDone = 0; int MzSensorRead2 = 0; int MzSensorRead1 = 0; int MzDutyCycle = 100; // 10 - 255 unsigned long MzSetPoint = 0; unsigned long MzActualPoint = 0; byte MzStep = 0; byte MzStepDone = 0; byte readByte = 0; unsigned long stepTime = 1; unsigned long millisStart = 0; void establishContact() { while (Serial.available() <= 0) { Serial.print('X'); // send a capital X delay(300); } } void printValues() { Serial.print(MxActualPoint); Serial.print(", "); Serial.print(MxSetPoint); Serial.print(", "); Serial.print(MxStep); } void setup(){ pinMode(RELAY, OUTPUT); digitalWrite(RELAY, 0); pinMode(MX_DIR, OUTPUT); pinMode(MX_PWM, OUTPUT); analogWrite(MX_PWM, 0); digitalWrite(MX_DIR, 0); pinMode(MX_S1, INPUT); pinMode(MX_S2, INPUT); pinMode(MY_DIR, OUTPUT); pinMode(MY_PWM, OUTPUT); analogWrite(MY_PWM, 0); digitalWrite(MY_DIR, 0); pinMode(MY_S1, INPUT); pinMode(MY_S2, INPUT); pinMode(MZ_DIR, OUTPUT); pinMode(MZ_PWM, OUTPUT); analogWrite(MZ_PWM, 0); digitalWrite(MZ_DIR, 0); pinMode(MZ_S1, INPUT); pinMode(MZ_S2, INPUT); stepTime = 1; readByte = 0; MxStep = 0; MyStep = 0; MzStep = 0; MxStepDone = 1; MyStepDone = 1; MzStepDone = 1; MxSetPoint = 300000; MxActualPoint = 300000; MySetPoint = 300000; MyActualPoint = 300000; MzSetPoint = 300000; MzActualPoint = 300000; // start serial port at 115200 bps: Serial.begin(115200); establishContact(); // send a byte to establish contact until receiver responds } void loop(){ millisStart = millis(); while(millis() - millisStart < stepTime){ do{ MzSensorRead1 = digitalRead(MZ_S1); MzSensorRead2 = digitalRead(MZ_S2); if(MzSensorRead2 == 0 && MzSensorRead1 == 0){ if(MzStep == 3){ MzActualPoint++; } if(MzStep == 1){ MzActualPoint--; } MzStep = 0; } if(MzSensorRead2 == 1 && MzSensorRead1 == 0){ if(MzStep == 0){ MzActualPoint++; } if(MzStep == 2){ MzActualPoint--; } MzStep = 1; } if(MzSensorRead2 == 1 && MzSensorRead1 == 1){ if(MzStep == 1){ MzActualPoint++; } if(MzStep == 3){ MzActualPoint--; } MzStep = 2; } if(MzSensorRead2 == 0 && MzSensorRead1 == 1){ if(MzStep == 2){ MzActualPoint++; } if(MzStep == 0){ MzActualPoint--; } MzStep = 3; } if(abs(MzSetPoint - MzActualPoint) < STEP_MARGIN){ analogWrite(MZ_PWM, 0); digitalWrite(MZ_DIR, 0); MzStepDone = 1; MzDutyCycle = MIN_DUTYCYCLE; } else{ if(MzActualPoint < MzSetPoint){ digitalWrite(MZ_DIR, 1); analogWrite(MZ_PWM, 255 - MzDutyCycle); } if(MzActualPoint > MzSetPoint){ digitalWrite(MZ_DIR, 0); analogWrite(MZ_PWM, MzDutyCycle); } } MySensorRead1 = digitalRead(MY_S1); MySensorRead2 = digitalRead(MY_S2); if(MySensorRead2 == 0 && MySensorRead1 == 0){ if(MyStep == 3){ MyActualPoint++; } if(MyStep == 1){ MyActualPoint--; } MyStep = 0; } if(MySensorRead2 == 1 && MySensorRead1 == 0){ if(MyStep == 0){ MyActualPoint++; } if(MyStep == 2){ MyActualPoint--; } MyStep = 1; } if(MySensorRead2 == 1 && MySensorRead1 == 1){ if(MyStep == 1){ MyActualPoint++; } if(MyStep == 3){ MyActualPoint--; } MyStep = 2; } if(MySensorRead2 == 0 && MySensorRead1 == 1){ if(MyStep == 2){ MyActualPoint++; } if(MyStep == 0){ MyActualPoint--; } MyStep = 3; } if(abs(MySetPoint - MyActualPoint) < STEP_MARGIN){ analogWrite(MY_PWM, 0); digitalWrite(MY_DIR, 0); MyStepDone = 1; MyDutyCycle = MIN_DUTYCYCLE; } else{ if(MyActualPoint < MySetPoint){ digitalWrite(MY_DIR, 1); analogWrite(MY_PWM, 255 - MyDutyCycle); } if(MyActualPoint > MySetPoint){ digitalWrite(MY_DIR, 0); analogWrite(MY_PWM, MyDutyCycle); } } MxSensorRead1 = digitalRead(MX_S1); MxSensorRead2 = digitalRead(MX_S2); if(MxSensorRead2 == 0 && MxSensorRead1 == 0){ if(MxStep == 3){ MxActualPoint++; printValues(); } if(MxStep == 1){ MxActualPoint--; printValues(); } MxStep = 0; } if(MxSensorRead2 == 1 && MxSensorRead1 == 0){ if(MxStep == 0){ MxActualPoint++; printValues(); } if(MxStep == 2){ MxActualPoint--; printValues(); } MxStep = 1; } if(MxSensorRead2 == 1 && MxSensorRead1 == 1){ if(MxStep == 1){ MxActualPoint++; printValues(); } if(MxStep == 3){ MxActualPoint--; printValues(); } MxStep = 2; } if(MxSensorRead2 == 0 && MxSensorRead1 == 1){ if(MxStep == 2){ MxActualPoint++; printValues(); } if(MxStep == 0){ MxActualPoint--; printValues(); } MxStep = 3; } if(abs(MxSetPoint - MxActualPoint) < STEP_MARGIN){ analogWrite(MX_PWM, 0); digitalWrite(MX_DIR, 0); MxStepDone = 1; MxDutyCycle = MIN_DUTYCYCLE; } else{ if(MxActualPoint < MxSetPoint){ digitalWrite(MX_DIR, 1); analogWrite(MX_PWM, 255 - MxDutyCycle); } if(MxActualPoint > MxSetPoint){ digitalWrite(MX_DIR, 0); analogWrite(MX_PWM, MxDutyCycle); } } }while(MzStepDone == 0 || MyStepDone == 0 || MxStepDone == 0 ); if(readByte == 0){ millisStart = 0L; } }//while(millis() - millisStart < stepTime){ readByte = 0; if (Serial.available() > 0){//if we get a valid byte, read from serial: //get incoming byte: readByte = Serial.read(); Serial.print('r'); // send a 'r' to initiate next data from computer }//if (Serial.available() > 0){ if(readByte > 0){ if(readByte == 'a'){ MxSetPoint++; MxDutyCycle = MAX_DUTYCYCLE; MxStepDone = 0; } if(readByte == 'b'){ MxSetPoint--; MxDutyCycle = MAX_DUTYCYCLE; MxStepDone = 0; } if(readByte == 'c'){ MySetPoint++; MyDutyCycle = MAX_DUTYCYCLE; MyStepDone = 0; } if(readByte == 'd'){ MySetPoint--; MyDutyCycle = MAX_DUTYCYCLE; MyStepDone = 0; } if(readByte == 'e'){ MzSetPoint++; MzDutyCycle = MAX_DUTYCYCLE; MzStepDone = 0; } if(readByte == 'f'){ MzSetPoint--; MzDutyCycle = MAX_DUTYCYCLE; MzStepDone = 0; } if(readByte == 'R'){ digitalWrite(RELAY, 1); readByte = 0; } if(readByte == 'r'){ digitalWrite(RELAY, 0); readByte = 0; } if(readByte == 'S'){ if(stepTime < 1000){ stepTime+=10; } } if(readByte == 's'){ if(stepTime > 10){ stepTime-=10; } } }//if(readByte > 0){ }
В этом коде идет работа со сдвоенными Оптическими энкодерами, хочу переделать для работы с одинарными, типа такого ( http://www.conrad.com/ce/en/product/184250/Vishay-TCST-2103-CNY-37-Photoelectric-Fork-Sensor )
обработка сигналов идет тут:
if(MzStep == 3){
MzActualPoint++;
if(MzStep == 1){
MzActualPoint--;
MzStep = 0;
if(MzStep == 0){
MzActualPoint++;
if(MzStep == 2){
MzActualPoint--;
MzStep = 1;
if(MzStep == 1){
MzActualPoint++;
if(MzStep == 3){
MzActualPoint--;
MzStep = 2;
if(MzStep == 2){
MzActualPoint++;
if(MzStep == 0){
MzActualPoint--;
MzStep = 3;
MzStepDone = 1;
else{
Подскажите как можно переписать код для ардуино, чтоб шаги считались с одинарными энкодерами? Разумеется без учета направления?...
Заранее всем откликнувшимся - спасибо!!!
Сам станок уже гоов, и работает: http://www.cnc-club.ru/forum/viewtopic.php?f=40&t=15148&p=347947#p347947
Но не нравится управляющая программа.. Потому и хотелось бы переделать. Но к сожалению, достать нужные энкодеры, нет возможности.
Этот код Вы сами писали? Или скачали где-нибудь?
Код взят с сайта: http://www.homofaciens.de/technics-machines-cnc-v2_en.htm
Сейчас станок работает с проекта ecnc.ru, но код переписал для работы с DC моторами и энкодерами (одинарными)
#include <AFMotor.h> int motorPins[3][4] = {{2, 3, 4, 5},{7, 8, 6, 9},{10, 11, 12, 13}}; int count; int count2[3] = {0,0,0}; int delayTime; int val = 0; int rot=0; int incomingByte = 0; int sign=1; int P1,P2,P3, s = 0; AF_DCMotor motor1(3, MOTOR12_64KHZ); AF_DCMotor motor2(2, MOTOR12_64KHZ); AF_DCMotor motor3(4, MOTOR12_64KHZ); void blink1() { P1++; } void blink2() { P2++; } void blink3() { P3++; } //Процедура настройки прошивки void setup() { motor1.setSpeed(255); motor2.setSpeed(255); motor3.setSpeed(255); int i; Serial.begin(9600); attachInterrupt(3, blink1, CHANGE); attachInterrupt(2, blink2, CHANGE); attachInterrupt(4, blink3, CHANGE); delayTime=4; //задержка между шагами 3 мс (2 мс - время реакции ШД на подачу напряжения) } void moveBackward(int sm) { if (sm == 0) { while (P1 < 1){ motor1.run(FORWARD); } motor1.run(RELEASE); P1 = 0; } else if (sm == 1) { while (P2 < 1){ motor2.run(FORWARD); } motor2.run(RELEASE); P2 = 0; } else if (sm == 2) { while (P3 < 1){ motor3.run(FORWARD); } motor3.run(RELEASE); motor3.run(BACKWARD); delay(5); motor3.run(RELEASE); P3 = 0; } } void moveForward(int sm) { if (sm == 0) { while (P1 < 1){ motor1.run(BACKWARD); } motor1.run(RELEASE); P1 = 0; } else if (sm == 1) { while (P2 < 1){ motor2.run(BACKWARD); } motor2.run(RELEASE); P2 = 0; } else if (sm == 2) { while (P3 < 1){ motor3.run(BACKWARD); } motor3.run(RELEASE); motor3.run(FORWARD); delay(5); motor3.run(RELEASE); P3 = 0; } } //Одновременный поворот двигателей 0, 1, 2 на x, y, z шагов соответственно void MoveSM(long x, long y, long z) { long c[3], c2[3]; double c1[3], d[3]; long m, i; boolean flg; c[0] = x; c[1] = y; c[2] = z; m = 1; for (i=0; i<3; i++) { if (m < abs(c[i])) m = abs(c[i]); } for (i=0; i<3; i++) { c1[i] = 0; d[i] = 1.0 * c[i] / m; c2[i] = 0; } flg = false; for (i=0; i<3; i++) { if (abs(c1[i]) < abs(c[i])) flg=true; } while (flg) { flg=false; for (i=0; i<3; i++) { if (abs(c1[i]) < abs(c[i])) c1[i] += d[i]; if (abs(c1[i]) - abs(c2[i]) >= 0.5) { if (c[i]>0) { c2[i]++; moveForward(i); } else { c2[i]--; moveBackward(i); } } if (abs(c1[i]) < abs(c[i])) flg=true; } delay(delayTime); } } //Основной цикл void loop() { if (Serial.available() > 0) { //Пришла команда long c[4]={0,0,0,0}; int i; sign=1; i=0; incomingByte = Serial.read(); while (incomingByte!=';') { //Читаем входящую строку, признак конца строки знак "точка с запятой" if (c[i]==0) { if (incomingByte=='-') sign=-1; } if (incomingByte==',') { c[i]*=sign; sign=1; i++; } else if (incomingByte>='0' && incomingByte<='9') { c[i]=c[i]*10+incomingByte-'0'; } while (Serial.available() == 0) { delay(2); } incomingByte = Serial.read(); } c[i]*=sign; MoveSM(c[0],c[1],c[2]); //Вращаем двигатели на заданное число шагов Serial.println("OK"); //Отправляем компьютеру сообщение "OK", значит можно высылать новую команду } else delay(100); //Если ничего не пришло, ждём 1/10 секуды. }Т.е. Вы скачали код, а сейчас хотите его модифицировать, правильно?
Лучше всего Вам обратиться к автору кода. Если такой возможности нет, то попробуйте обратиться в раздел "Ищу исполнителя". не думаю, что что в этом разделе Вам помогут. Всё может быть, но вероятность невелика.
Правильно. К автору обратится нет возможности.
Знаю что можно модифицировать код, но уже всю голову сломал. запутался в алгоритме работы данного исходника. вот и подумал, может кто свежим взглядом гланет, да и поможет. :)
Ну, попробуйте в "Ищу исполнителя"
