Оптимизация кода
Пт, 20/03/2015 - 19:11
В программировании слабоват.
Есть вот такой кусок рабочего кода.
if(count_LAST == 2) Pos_LAST = Pos2; if(count_LAST == 3) Pos_LAST = Pos3; if(count_LAST == 4) Pos_LAST = Pos4; if(count_LAST == 5) Pos_LAST = Pos5; if(count_LAST == 6) Pos_LAST = Pos6; if(count_LAST == 7) Pos_LAST = Pos7; if(count_LAST == 8) Pos_LAST = Pos8; if(count_LAST == 9) Pos_LAST = Pos9; if(count_LAST == 10) Pos_LAST = Pos10; if(count_LAST == 11) Pos_LAST = Pos11; if(count_LAST == 12) Pos_LAST = Pos12; if(count_LAST == 13) Pos_LAST = Pos13; if(count_LAST == 14) Pos_LAST = Pos14; if(count_LAST == 15) Pos_LAST = Pos15; if(count_LAST == 16) Pos_LAST = Pos16; if(count_LAST == 17) Pos_LAST = Pos17; if(count_LAST == 18) Pos_LAST = Pos18; if(count_LAST == 19) Pos_LAST = Pos19; if(count_LAST == 20) Pos_LAST = Pos20; if(count_LAST == 21) Pos_LAST = Pos21; if(count_LAST == 22) Pos_LAST = Pos22; if(count_LAST == 23) Pos_LAST = Pos23; if(count_LAST == 24) Pos_LAST = Pos24; if(count_LAST == 25) Pos_LAST = Pos25; if(count_LAST == 26) Pos_LAST = Pos26; if(count_LAST == 27) Pos_LAST = Pos27; if(count_LAST == 28) Pos_LAST = Pos28; if(count_LAST == 29) Pos_LAST = Pos29; if(count_LAST == 30) Pos_LAST = Pos30; if(count_LAST == 31) Pos_LAST = Pos31; if(count_LAST == 32) Pos_LAST = Pos32; if(count_LAST == 33) Pos_LAST = Pos33; if(count_LAST == 34) Pos_LAST = Pos34; if(count_LAST == 35) Pos_LAST = Pos35; if(count_LAST == 36) Pos_LAST = Pos36; if(count_LAST == 37) Pos_LAST = Pos37; if(count_LAST == 38) Pos_LAST = Pos38; if(count_LAST == 39) Pos_LAST = Pos39; if(count_LAST == 40) Pos_LAST = Pos40; if(count_LAST == 41) Pos_LAST = Pos41; if(count_LAST == 42) Pos_LAST = Pos42; if(count_LAST == 43) Pos_LAST = Pos43; if(count_LAST == 44) Pos_LAST = Pos44; if(count_LAST == 45) Pos_LAST = Pos45; if(count_LAST == 46) Pos_LAST = Pos46; if(count_LAST == 47) Pos_LAST = Pos47; if(count_LAST == 48) Pos_LAST = Pos48; if(count_LAST == 49) Pos_LAST = Pos49; if(count_LAST == 50) Pos_LAST = Pos50;
Возможно ли сделать запись более короткой?
Можно конечно. Не совсем понятно, что такое эти Pos2, Pos3, и т.д - но в общем всё может выглядеть как-то так:
int Pos[ ] = { 0, 0, Pos2, Pos3, Pos4, ....... , Pos50 }; // или, по возможности, const int ..... ..... Pos_LAST = Pos[ count_LAST ];Зависит от значений Pos*, если есть зависимость, то можно упростить (формализовать) в каком то виде, если нет, то через массив, как уже сказали.
Немного не в кассу. Когда пишите несколько if, лучше писать if... else if... else if... else ; в противном случае у Вас программа будет проходить через все ифы, а оно Вам надо? (риторический). Другой вариант switch. Увы, не помню, что оптимальней, вроде какие то были отличия (switch от if else if else if ; ) или грабли, может кто подскажет.
А зачем в начале массива два нуля?
Ну у вас же вкоде сравнение начинается с двойки
поэтому для первых двух значений - 0 и 1 - оставили "пустые" ячейки.
Как вариант - можно было и без них обойтись. Тогда было бы так:
Да вряд ли тут кто подскажет. Зависит от конкретных значений в switch, и от конкретного компилятора. И даже от опций заданных при компиляции.
Иногда switch может компилиться в такую же таблицу переходов, а иногда в те же if - else. Не угадаешь. :)
С массивом попробую, а вот такие условия
Навскидку, массив структур, бинарный поиск, функция пересчета. Хотя можно и простым поиском обойтись, значений немного. Если других вариантов не будет, покажу пример.
int Pos[ ] = { Pos1, Pos2, Pos3, ....... , Pos10 }; // или, по возможности, const int int Servo[ ] = { Servo1, Servo2, Servo3, ....... , Servo9 }; // ..... ..... for( int i = 0; i < ( sizeof( Servo ) / sizeof( Servo[ 0 ] ) ); i++ ) { int Pos_L = Pos[ i ]; int Pos_H = Pos[ i + 1 ]; if( Rotor_G0 > Pos_L && Rotor_G0 <= Pos_H ) { ServoG0 = map( Rotor_G0, Pos_L, Pos_H, Servo[ i ], Servo[ i + 1 ] ); break; } }Это если так, "в лоб", по-простому. В зависимости от реального размера массивов и от требований к скорости - да, можно попробовать что-то как-то оптимизировать.
Удобней объединять в структуру, а не использовать два разных массива, будет меньше ошибок, уж поверьте
Со структурами вообще тёмный лес
Попробую поиграться с массивами
/* * Исходные значения неизвестны, ставим как попало, но в возрастающем порядке */ #define Pos1 30 #define Pos2 38 #define Pos3 49 #define Pos4 70 #define Pos5 75 #define servo1 500 #define servo2 700 #define servo3 900 #define servo4 1000 #define servo5 1300 #define NO_POS 0 #define NO_VALUE 0 typedef struct _ServoVals { int pos_start; /* Верхняя граница */ int servo_min; /* Минимум */ int servo_max; /* Максимум */ } ServoVals; const int pos_minimum = Pos1; const ServoVals array[] = { { Pos2, servo1, servo2 }, { Pos3, servo2, servo3 }, { Pos4, servo3, servo4 }, { Pos5, servo4, servo5 } }; /* Длина массива, т.е. кол-во записей */ const int array_size = sizeof(array) / sizeof(ServoVals); /* Преобразование, возвращает NO_VALUE, если значение выходит за пределы */ int getServValue(int Rotor_GO) { /* Сначала проверяем нижнюю границу, всё, что меньше - неинтересно */ int l_PrevPos = pos_minimum; if (Rotor_GO <= l_PrevPos) { return NO_VALUE; // Здесь непонятно что возвращать, потому что исходный код не полный } /* Дальше проверка по всем структурам, расположенным в массиве, начиная с первого элемента */ for (int i = 0; i < array_size; ++i) { if (Rotor_GO <= array[i].pos_start) { return map(Rotor_GO, l_PrevPos, array[i].pos_start, array[i].servo_min, array[i].servo_max); } l_PrevPos = array->pos_start; } return NO_VALUE; } void setup() { Serial.begin(57600); } int val = 40; void loop() { Serial.print("Rotor_GO = "); Serial.print(val); /* Вызываем преобразование */ int servoGO = getServValue(val); /* Проверка на наличие реального ответа */ if (servoGO != NO_VALUE) { Serial.print(", ServoGO = "); Serial.println(servoGO); } else { Serial.println(", NO_VALUE"); } delay(1000); /* Меняем исходное значение для проверки */ val += rand(); val %= 100; }Вот такой вариант со структурой. Не смотри, что много, больше кода для тестирования.
В скетче #8 есть как минимум одна ошибка, выход за пределы массива. Аккуратней.
Имеете ввиду Servo[ i + 1 ] при достижении максимального значения i
В пример со структурами попробую вникнуть...
Ну да, везде, где есть индекс+1
У меня что ли? А, ну да, есть.
Монитор потому что маленький - десятая серва перенеслась на другую строку, и я её не заметил. :)
Конечно, массивы должны быть одинакового размера, а цикл на единицу короче.
Пример рабочий, проверял. Отвечу на вопросы, если понадобится. А нет, так нет :)
Спасибо откликнувшимся.
Решил сначала разобраться с массивами, на будуще однозначно пригодится , да и простыни исписывать не хочется (код уже переделал и костыль с размером массива выскочил, но вроде обошёл его).
Потом полезу в структуры.
Эту простыню записал так
for(int i=0; i <= 9; i++ ) { if( Rotor_GO > Pos[i] && Rotor_GO <= Pos[i + 1] ) { servoGO = map(Rotor_GO, Pos[i], Pos[i + 1], servo[i], servo[i + 1]); break; } }Вроде получилось.
Но есть и такая запись.
if ( BUTTON_SAVEState == HIGH && count == 0) { count = 1; Pos[0] = number; Pos_LAST = Pos[0]; servo[0] = valPot; BUTTON_SAVEState = LOW; } if ( BUTTON_SAVEState == HIGH && count == 1) { count = 2; Pos[1] = number; Pos_LAST = Pos[1]; servo[1] = valPot; BUTTON_SAVEState = LOW; } if ( BUTTON_SAVEState == HIGH && count == 2) { count = 3; Pos[2] = number; Pos_LAST = Pos[2]; servo[2] = valPot; BUTTON_SAVEState = LOW; } if ( BUTTON_SAVEState == HIGH && count == 3) { count = 4; Pos[3] = number; Pos_LAST = Pos[3]; servo[3] = valPot; BUTTON_SAVEState = LOW; } if ( BUTTON_SAVEState == HIGH && count == 4) { count = 5; Pos[4] = number; Pos_LAST = Pos[4]; servo[4] = valPot; BUTTON_SAVEState = LOW; } if ( BUTTON_SAVEState == HIGH && count == 5) { count = 6; Pos[5] = number; Pos_LAST = Pos[5]; servo[5] = valPot; BUTTON_SAVEState = LOW; } if ( BUTTON_SAVEState == HIGH && count == 6) { count = 7; Pos[6] = number; Pos_LAST = Pos[6]; servo[6] = valPot; BUTTON_SAVEState = LOW; } if ( BUTTON_SAVEState == HIGH && count == 7) { count = 8; Pos[7] = number; Pos_LAST = Pos[7]; servo[7] = valPot; BUTTON_SAVEState = LOW; } if ( BUTTON_SAVEState == HIGH && count == 8) { count = 9; Pos[8] = number; Pos_LAST = Pos[8]; servo[8] = valPot; BUTTON_SAVEState = LOW; } if ( BUTTON_SAVEState == HIGH && count == 9) { count = 10; Pos[9] = number; Pos_LAST = Pos[9]; servo[9] = valPot; BUTTON_SAVEState = LOW; } if ( BUTTON_SAVEState == HIGH && count == 10) { count = 11; Pos[10] = number; Pos_LAST = Pos[10]; servo[10] = valPot; BUTTON_SAVEState = LOW; }Условия работают при разных режимах. Вот их увязать и не получается.
Конечно не катастрофа, но хотелось бы узнать как в данном случае правильно записать.
Пока сложновато, но мне интересно, буду ковыряться...
Сделать одной функцией: sorry, я с мобилы, форматировать сложно, главное - смысл:
addNewPoint()
if ( BUTTON_SAVEState == HIGH )
Pos[count] = number;
Pos_LAST = Pos[count];
servo[count] = valPot;
count++;
Спасибо за идею.
А вот как эту функцию теперь запускать?
Получается условие в самой функции
Это уж тебе видней, потому что любая задача решается комплексно, а ты даёшь нам кусочки, потому сложно сделать оптимально задачу вцелом.
А вызывать нужно где то в loop, плюс добавить проверку на длину массива, а то count не ограничен. Плюс здесь используются глобальные переменные, что не очень хорошо, плюс это можно не делать функцией, а просто вписать этот код в нужном месте.
На счёт условия внутри функции, вариант от телепата, возвращать условие из функции
