Ошибка: a function-definition is not allowed here before '{' token
Втр, 30/11/2021 - 23:40
Дорогие люди, помогите решить проблему. Создаю дистанционный пульсоксиметр. Работаю врачом в ковидном госпитале. Очень нужна ваша помощь!
Код взял с сайта https://create.arduino.cc/projecthub/1NextPCB/iot-based-pulse-oximeter-using-esp32-549166
[code]
## Hardware Connections (ESP32 <- OLED <- MAX 30102):
-VIN = 3.3V
-GND = GND
-SDA = 21 (or SDA)
-SCL = 22 (or SCL)
char auth[] = "ijM8wv52vur7GH90ku66YjcaYz-tJgHO";
char ssid[] = "noname"; // Your WiFi Name (SSID) (**case sensitive).
char pass[] = "gera0001"; // Your WiFi Password.
//DiY Projects Lab
#define BLYNK_PRINT Serial
#include <WiFi.h>
#include <BlynkSimpleEsp32.h>
#include <Wire.h>
#include <Adafruit_GFX.h> //OLED libraries
#include <Adafruit_SSD1306.h>
#include <SimpleTimer.h>
#include "MAX30105.h" //sparkfun MAX3010X library
//#include "heartRate.h"
SimpleTimer timer;
MAX30105 particleSensor;
#define INTERVAL_MESSAGE2 60000
unsigned long time_2 = 0;
int period = 2000;
unsigned long time_now = 0;
double avered = 0;
double aveir = 0;
double sumirrms = 0;
double sumredrms = 0;
int i = 0;
int Num = 100; //calculate SpO2 by this sampling interval
int oxygen;
double ESpO2 = 95.0; //initial value of estimated SpO2
double FSpO2 = 0.7; //filter factor for estimated SpO2
double frate = 0.95; //low pass filter for IR/red LED value to eliminate AC component
#define TIMETOBOOT 3000 // wait for this time(msec) to output SpO2
#define SCALE 88.0 //adjust to display heart beat and SpO2 in the same scale
#define SAMPLING 5 //if you want to see heart beat more precisely , set SAMPLING to 1
#define FINGER_ON 3000 // if red signal is lower than this , it indicates your finger is not on the sensor
#define MINIMUM_SPO2 0.0
const byte RATE_SIZE = 4; //Increase this for more averaging. 4 is good.
byte rates[RATE_SIZE]; //Array of heart rates
byte rateSpot = 0;
long lastBeat = 0; //Time at which the last beat occurred
float beatsPerMinute;
int beatAvg;
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET); //Declaring the display name (display)
//Logo2 and Logo3 are two bmp pictures that display on the OLED if called
static const unsigned char PROGMEM logo2_bmp[] =
{ 0x03, 0xC0, 0xF0, 0x06, 0x71, 0x8C, 0x0C, 0x1B, 0x06, 0x18, 0x0E, 0x02, 0x10, 0x0C, 0x03, 0x10,
0x04, 0x01, 0x10, 0x04, 0x01, 0x10, 0x40, 0x01, 0x10, 0x40, 0x01, 0x10, 0xC0, 0x03, 0x08, 0x88,
0x02, 0x08, 0xB8, 0x04, 0xFF, 0x37, 0x08, 0x01, 0x30, 0x18, 0x01, 0x90, 0x30, 0x00, 0xC0, 0x60,
0x00, 0x60, 0xC0, 0x00, 0x31, 0x80, 0x00, 0x1B, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x04, 0x00,
static const unsigned char PROGMEM logo3_bmp[] =
{ 0x01, 0xF0, 0x0F, 0x80, 0x06, 0x1C, 0x38, 0x60, 0x18, 0x06, 0x60, 0x18, 0x10, 0x01, 0x80, 0x08,
0x20, 0x01, 0x80, 0x04, 0x40, 0x00, 0x00, 0x02, 0x40, 0x00, 0x00, 0x02, 0xC0, 0x00, 0x08, 0x03,
0x80, 0x00, 0x08, 0x01, 0x80, 0x00, 0x18, 0x01, 0x80, 0x00, 0x1C, 0x01, 0x80, 0x00, 0x14, 0x00,
0x80, 0x00, 0x14, 0x00, 0x80, 0x00, 0x14, 0x00, 0x40, 0x10, 0x12, 0x00, 0x40, 0x10, 0x12, 0x00,
0x7E, 0x1F, 0x23, 0xFE, 0x03, 0x31, 0xA0, 0x04, 0x01, 0xA0, 0xA0, 0x0C, 0x00, 0xA0, 0xA0, 0x08,
0x00, 0x60, 0xE0, 0x10, 0x00, 0x20, 0x60, 0x20, 0x06, 0x00, 0x40, 0x60, 0x03, 0x00, 0x40, 0xC0,
0x01, 0x80, 0x01, 0x80, 0x00, 0xC0, 0x03, 0x00, 0x00, 0x60, 0x06, 0x00, 0x00, 0x30, 0x0C, 0x00,
0x00, 0x08, 0x10, 0x00, 0x00, 0x06, 0x60, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x01, 0x80, 0x00
#define USEFIFO
Serial.begin(115200);
// Start I2C Communication SDA = 5 and SCL = 4 on Wemos Lolin32 ESP32 with built-in SSD1306 OLED
Wire.begin(5, 4);
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C, false, false)) {
Serial.println("Initializing...");
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); //Start the OLED display
display.display();
display.clearDisplay();
Blynk.begin(auth, ssid, pass);
// Initialize sensor
while (!particleSensor.begin(Wire, I2C_SPEED_FAST)) //Use default I2C port, 400kHz speed
Serial.println("MAX30102 was not found. Please check wiring/power/solder jumper at MH-ET LIVE MAX30102 board. ");
//while (1);
Serial.println("Place your index finger on the sensor with steady pressure.");
void sendUptime()
Blynk.virtualWrite(V4, oxygen);
//Blynk.virtualWrite(V5, beatAvg);
//Setup to sense a nice looking saw tooth on the plotter
byte ledBrightness = 255; // 0x7F Options: 0=Off to 255=50mA
byte sampleAverage = 4; //Options: 1, 2, 4, 8, 16, 32
byte ledMode = 2; //Options: 1 = Red only, 2 = Red + IR, 3 = Red + IR + Green
int sampleRate = 400; //1000 is best but needs processing power//Options: 50, 100, 200, 400, 800, 1000, 1600, 3200
int pulseWidth = 411; //Options: 69, 118, 215, 411
int adcRange = 16384; //Options: 2048, 4096, 8192, 16384
// Set up the wanted parameters
particleSensor.setup(ledBrightness, sampleAverage, ledMode, sampleRate, pulseWidth, adcRange); //Configure sensor with these settings
particleSensor.enableDIETEMPRDY();
timer.setInterval(500, sendUptime);
Blynk.run();
timer.run(); // Initiates SimpleTimer
uint32_t ir, red, green;
double fred, fir;
double SpO2 = 0; //raw SpO2 before low pass filtered
#ifdef USEFIFO
particleSensor.check(); //Check the sensor, read up to 3 samples
while (particleSensor.available())
{ //do we have new data
#ifdef MAX30105
red = particleSensor.getFIFORed(); //Sparkfun's MAX30105
ir = particleSensor.getFIFOIR(); //Sparkfun's MAX30105
#else
red = particleSensor.getFIFOIR(); //why getFOFOIR output Red data by MAX30102 on MH-ET LIVE breakout board
ir = particleSensor.getFIFORed(); //why getFIFORed output IR data by MAX30102 on MH-ET LIVE breakout board
#endif
i++;
fred = (double)red;
fir = (double)ir;
avered = avered * frate + (double)red * (1.0 - frate); //average red level by low pass filter
aveir = aveir * frate + (double)ir * (1.0 - frate); //average IR level by low pass filter
sumredrms += (fred - avered) * (fred - avered); //square sum of alternate component of red level
sumirrms += (fir - aveir) * (fir - aveir); //square sum of alternate component of IR level
if ((i % SAMPLING) == 0)
{ //slow down graph plotting speed for arduino Serial plotter by thin out
if (millis() > TIMETOBOOT)
if (ir < FINGER_ON)
ESpO2 = MINIMUM_SPO2; //indicator for finger detached
//float temperature = particleSensor.readTemperatureF();
if (ESpO2 <= -1)
ESpO2 = 0;
if (ESpO2 > 100)
ESpO2 = 100;
oxygen = ESpO2;
Serial.print(" Oxygen % = ");
Serial.println(oxygen);
if ((i % Num) == 0)
double R = (sqrt(sumredrms) / avered) / (sqrt(sumirrms) / aveir);
// Serial.println(R);
SpO2 = -23.3 * (R - 0.4) + 100; //http://ww1.microchip.com/downloads/jp/AppNotes/00001525B_JP.pdf
ESpO2 = FSpO2 * ESpO2 + (1.0 - FSpO2) * SpO2; //low pass filter
//Serial.print(SpO2); Serial.print(","); Serial.println(ESpO2);
sumredrms = 0.0;
sumirrms = 0.0;
i = 0;
particleSensor.nextSample(); //We're finished with this sample so move to next sample
//Serial.println(SpO2);
long irValue = particleSensor.getIR();
//Serial.println(irValue);
if (irValue > 7000)
{ //If a finger is detected
display.clearDisplay(); //Clear the display
display.drawBitmap(5, 5, logo2_bmp, 24, 21, WHITE); //Draw the first bmp picture (little heart)
display.setTextSize(2); //Near it display the average BPM you can display the BPM if you want
display.setTextColor(WHITE);
display.setCursor(50, 15);
display.println("SpO2");
display.setCursor(50, 50);
//display.println(beatAvg);
display.print(oxygen);
display.println("%");
display.display();
if (irValue == true)
display.drawBitmap(0, 0, logo3_bmp, 32, 32, WHITE); //Draw the second picture (bigger heart)
display.setTextSize(2); //And still displays the average BPM
display.display();
if (irValue < 7000)
{ //If no finger is detected it inform the user and put the average BPM to 0 or it will be stored for the next measure
//beatAvg=0;
display.setTextSize(1);
display.setCursor(30, 10);
display.println("WiFi Connected ");
display.setCursor(30, 25);
display.println("Please Place ");
display.setCursor(30, 4
0);
display.println("your Finger ");
display.display();
if (millis() > time_2 + INTERVAL_MESSAGE2 && oxygen < 93)
time_2 = millis();
Blynk.notify("Alert! Oxygen Saturation below 93% Detected");
Serial.print("Alert called");
#endif
[/code]
Ошибка: Arduino: 1.8.16 (Windows 10), Плата:"WEMOS LOLIN32, 80MHz, Default, 240MHz (WiFi/BT), 921600"
In file included from C:\Users\User\Documents\Arduino\libraries\blynk-library-master\src/Blynk/BlynkApi.h:37:0,
from C:\Users\User\Documents\Arduino\libraries\blynk-library-master\src/BlynkApiArduino.h:14,
from C:\Users\User\Documents\Arduino\libraries\blynk-library-master\src/BlynkSimpleEsp32.h:20,
from C:\Users\User\Desktop\Бизнес\123\123.ino:32:
C:\Users\User\Documents\Arduino\libraries\blynk-library-master\src/Blynk/BlynkTimer.h:36:21: error: redefinition of 'class BlynkTimer'
#define SimpleTimer BlynkTimer
C:\Users\User\Documents\Arduino\libraries\SimpleTimer/SimpleTimer.h:10:7: note: in expansion of macro 'SimpleTimer'
class SimpleTimer {
C:\Users\User\Documents\Arduino\libraries\blynk-library-master\src/Blynk/BlynkTimer.h:36:21: error: previous definition of 'class BlynkTimer'
C:\Users\User\Documents\Arduino\libraries\blynk-library-master\src/Blynk/BlynkTimer.h:41:7: note: in expansion of macro 'SimpleTimer'
class SimpleTimer {
C:\Users\User\Desktop\Бизнес\123\123.ino: In function 'void setup()':
123:119:1: error: a function-definition is not allowed here before '{' token
123:133:26: error: 'sendUptime' was not declared in this scope
123:139:1: error: a function-definition is not allowed here before '{' token
123:272:1: error: expected '}' at end of input
Несколько библиотек найдено для "WiFi.h"
Используется: C:\Users\User\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5\libraries\WiFi
Не используется: D:\Arduino\libraries\WiFi
Несколько библиотек найдено для "Adafruit_SSD1306.h"
Используется: C:\Users\User\Documents\Arduino\libraries\Adafruit_SSD1306
Не используется: C:\Users\User\Documents\Arduino\libraries\Adafruit_SSD1306_Wemos_Mini_OLED
exit status 1
Буду очень благодарен
А в свободное от работы время занимаетесь
Правильно?
Ну, как Вам помочь. В тексте написан чистый, ничем не замутнённый бред. Спросите у своего коллеги-психиатра что это слово означает и как людям с таким анамнезом помогают.
Конкретно то сообщение, что Вас смутило означает, что в строка №№120-124 у Вас определяется функция, а её в этом месте определять нельзя. Только эта информация Вам ничем не поможет, т.к. во-первых, Вы не знаете где и как можно, а во-вторых, это далеко не единственная ошибка.
Помочь Вам невозможно, т.к. Вы не имеете ни малейшего понятия о том как это делается, можно только сделать вместо Вас.
Если Вам для
бизнесаработы в госпитале нужен код, закажите его в коммерческом разделе. Вам за нормальные деньги сделают.Спасибо за ответ, а свободного времени у меня очень мало. Да, папка Бизнес.
Подскажите пожалуйста, где можно найти коммерческий раздел?
здесь: Ищу исполнителя
