Ошибка ==> no matching function for call to 'ICMPPing::ICMPPing(SOCKET&, uint16_t)'
Heres_M
Пытаюсь залить скетч для пинга IP адреса в сети.
#define BLYNK_PRINT Serial
#include <LiquidCrystal.h>
#include <SPI.h>
#include <Ethernet.h>
#include <ICMPPing.h>
#include <BlynkSimpleEthernet.h>
LiquidCrystal lcd(8, 3, 9, 4, 5, 6, 7); // these are the pins used on the shield for this sketch
unsigned long start, finished, elapsed;
//byte mac[] = {0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED}; // max address for ethernet shield
//byte ip[] = {10, 10, 0, 75}; // ip address for ethernet shield
IPAddress pingAddr(45,55,195,102); // ip address to ping
char auth[] = "9d13cddba3d8450ca7e8badf586f4ee3";
SOCKET pingSocket = 0;
char buffer [256];
ICMPPing ping(pingSocket, (uint16_t)random(0, 255));
const unsigned long interval = 300;
const unsigned long interval1 = 200;
const unsigned long interval2 = 100;
unsigned long timer;
unsigned long timer1;
unsigned long timer2;
IPAddress server_ip (45,55,195,102);
// Mac address should be different for each device in your LAN
byte arduino_mac[] = { 0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
IPAddress arduino_ip ( 10,   0,   0,  75);
IPAddress dns_ip     (  8,   8,   8,   8);
IPAddress gateway_ip ( 10,   10,   0,   1);
IPAddress subnet_mask(255, 255, 255,   0);
  Blynk.begin(auth);
  lcd.begin(16, 2);
  //Print default title.
  clearPrintTitle();
  delay(2000);
  //Call the main menu.
  if ( (millis () - timer) >= interval)
    Blynk.run();
    uptime();
  if ( (millis () - timer1) >= interval1)
   pingss();
 // if ( (millis () - timer2) >= interval2)
 // uptime();
//Print a basic header on Row 1.
void clearPrintTitle() {
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print(" HACKSHED.CO.UK ");
  lcd.setCursor(0, 1);
  lcd.clear();
void pingss()
  ICMPEchoReply echoReply = ping(pingAddr, 4);
  if (echoReply.status == SUCCESS)
    lcd.print("Ping: ");
    lcd.print(millis() - echoReply.data.time);
    lcd.print("ms");
    lcd.print(echoReply.status);
void uptime()
  finished = millis(); // saves stop time to calculate the elapsed time
  //delay(200); // for debounce
  //  lcd.setCursor(0,0); // NOT needed
  displayResult(); // display the results on the function}
void displayResult()
  // declare variables
  float h, m, s ;
  unsigned long over;
  // MATH time!!!
  elapsed = finished - start;
  h = int(elapsed / 3600000);
  over = elapsed % 3600000;
  m    = int(over / 60000);
  over = over % 60000;
  s    = int(over / 1000);
  // display variable 'h' - the 0 after it is the number of algorithms after a comma
  //(ex: lcd.print(h, 2); would print 0,00
  lcd.print("Up  : ");
  lcd.print(h, 0);
  lcd.print("h "); // and the letter 'h' after it
  lcd.print(m, 0);
  lcd.print("m ");
  lcd.print(s, 0);
  lcd.print("s ");
______________________________________________________________________________________
Выдает ошибку:
Arduino: 1.6.12 (Windows 7), Плата:"Arduino/Genuino Uno"
sketch_feb10a:18: error: no matching function for call to 'ICMPPing::ICMPPing(SOCKET&, uint16_t)'
C:\Users\1\AppData\Local\Temp\arduino_modified_sketch_371941\sketch_feb10a.ino:18:51: note: candidates are:
In file included from C:\Users\1\AppData\Local\Temp\arduino_modified_sketch_371941\sketch_feb10a.ino:5:0:
C:\Program Files (x86)\Arduino\libraries\ICMPPing/ICMPPing.h:28:2: note: ICMPPing::ICMPPing(SOCKET)
  ICMPPing(SOCKET s); // construct an ICMPPing object for socket s
C:\Program Files (x86)\Arduino\libraries\ICMPPing/ICMPPing.h:28:2: note:   candidate expects 1 argument, 2 provided
C:\Program Files (x86)\Arduino\libraries\ICMPPing/ICMPPing.h:25:7: note: constexpr ICMPPing::ICMPPing(const ICMPPing&)
 class ICMPPing
C:\Program Files (x86)\Arduino\libraries\ICMPPing/ICMPPing.h:25:7: note:   candidate expects 1 argument, 2 provided
C:\Program Files (x86)\Arduino\libraries\ICMPPing/ICMPPing.h:25:7: note: constexpr ICMPPing::ICMPPing(ICMPPing&&)
C:\Users\1\AppData\Local\Temp\arduino_modified_sketch_371941\sketch_feb10a.ino: In function 'void pingss()':
sketch_feb10a:66: error: 'ICMPEchoReply' was not declared in this scope
sketch_feb10a:67: error: 'echoReply' was not declared in this scope
sketch_feb10a:67: error: 'SUCCESS' was not declared in this scope
Несколько библиотек найдено для "Ethernet.h"
 Используется: C:\Users\1\Documents\Arduino\libraries\Ethernet
Не используется: C:\Program Files (x86)\Arduino\libraries\Ethernet
Несколько библиотек найдено для "ICMPPing.h"
 Используется: C:\Program Files (x86)\Arduino\libraries\ICMPPing
Не используется: C:\Program Files (x86)\Arduino\libraries\icmp_ping
exit status 1
_______________________________________________________________________________________
Помогите разобраться в чем проблема?????
Библиотека ICMPPing.h не та. Попробуйте вот эту.
