#include <SPI.h>
#include <SdFat.h>
#include <SdFatUtil.h>
#include <Ethernet.h>
/************ ETHERNET STUFF ************/
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 177 };
char rootFileName[] = "index.htm";
EthernetServer server(80);
/************ SDCARD STUFF ************/
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
// store error strings in flash to save RAM
#define error(s) error_P(PSTR(s))
void error_P(const char* str) {
PgmPrint("error: ");
SerialPrintln_P(str);
if (card.errorCode()) {
PgmPrint("SD error: ");
Serial.print(card.errorCode(), HEX);
Serial.print(',');
Serial.println(card.errorData(), HEX);
while(1);
Serial.begin(115200);
PgmPrint("Free RAM: ");
Serial.println(FreeRam());
// initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
// breadboards. use SPI_FULL_SPEED for better performance.
pinMode(10, OUTPUT); // set the SS pin as an output (necessary!)
digitalWrite(10, HIGH); // but turn off the W5100 chip!
if (!card.init(SPI_HALF_SPEED, 4)) error("card.init failed!");
// initialize a FAT volume
if (!volume.init(&card)) error("vol.init failed!");
PgmPrint("Volume is FAT");
Serial.println(volume.fatType(),DEC);
Serial.println();
if (!root.openRoot(&volume)) error("openRoot failed");
// list file in root with date and size
PgmPrintln("Files found in root:");
root.ls(LS_DATE | LS_SIZE);
Serial.println();
// Recursive list of all directories
PgmPrintln("Files found in all dirs:");
root.ls(LS_R);
Serial.println();
PgmPrintln("Done");
// Debugging complete, we start the server!
Ethernet.begin(mac, ip);
server.begin();
// How big our line buffer should be. 100 is plenty!
#define BUFSIZ 100
char clientline[BUFSIZ];
char *filename;
int index = 0;
int image = 0;
EthernetClient client = server.available();
if (client) {
// an http request ends with a blank line
boolean current_line_is_blank = true;
// reset the input buffer
index = 0;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// If it isn't a new line, add the character to the buffer
if (c != '\n' && c != '\r') {
clientline[index] = c;
index++;
// are we too big for the buffer? start tossing out data
if (index >= BUFSIZ)
index = BUFSIZ -1;
// continue to read more data!
continue;
// got a \n or \r new line, which means the string is done
clientline[index] = 0;
filename = 0;
// Print it out for debugging
Serial.println(clientline);
// Look for substring such as a request to get the root file
if (strstr(clientline, "GET / ") != 0) {
filename = rootFileName;
if (strstr(clientline, "GET /") != 0) {
// this time no space after the /, so a sub-file
if (!filename) filename = clientline + 5; // look after the "GET /" (5 chars)
// a little trick, look for the " HTTP/1.1" string and
// turn the first character of the substring into a 0 to clear it out.
(strstr(clientline, " HTTP"))[0] = 0;
// print the file we want
Serial.println(filename);
if (! file.open(&root, filename, O_READ)) {
client.println("HTTP/1.1 404 Not Found");
client.println("Content-Type: text/html");
client.println();
client.println("<h2>File Not Found!</h2>");
Serial.println("Opened!");
client.println("HTTP/1.1 200 OK");
if (strstr(filename, ".htm") != 0)
else if (strstr(filename, ".css") != 0)
client.println("Content-Type: text/css");
else if (strstr(filename, ".png") != 0)
client.println("Content-Type: image/png");
else if (strstr(filename, ".jpg") != 0)
client.println("Content-Type: image/jpeg");
else if (strstr(filename, ".gif") != 0)
client.println("Content-Type: image/gif");
else if (strstr(filename, ".3gp") != 0)
client.println("Content-Type: video/mpeg");
else if (strstr(filename, ".pdf") != 0)
client.println("Content-Type: application/pdf");
else if (strstr(filename, ".js") != 0)
client.println("Content-Type: application/x-javascript");
else if (strstr(filename, ".xml") != 0)
client.println("Content-Type: application/xml");
client.println("Content-Type: text");
client.println();
int16_t c;
while ((c = file.read()) >= 0) {
// uncomment the serial to debug (slow!)
//Serial.print((char)c);
client.print((char)c);
file.close();
} else {
// everything else is a 404
client.println();
// give the web browser time to receive the data
delay(1);
client.stop();
D:\arduino-1.0.1\hardware\arduino\cores\arduino\Print.cpp: In member function 'virtual size_t Print::write(const uint8_t*, size_t)':
D:\arduino-1.0.1\hardware\arduino\cores\arduino\Print.cpp:37: error: invalid conversion from 'const unsigned char' to 'const char*'
D:\arduino-1.0.1\hardware\arduino\cores\arduino\Print.cpp:37: error: initializing argument 1 of 'size_t Print::write(const char*)'
D:\arduino-1.0.1\hardware\arduino\cores\arduino\Print.cpp: In member function 'size_t Print::print(const __FlashStringHelper*)':
D:\arduino-1.0.1\hardware\arduino\cores\arduino\Print.cpp:49: error: invalid conversion from 'unsigned char' to 'const char*'
D:\arduino-1.0.1\hardware\arduino\cores\arduino\Print.cpp:49: error: initializing argument 1 of 'size_t Print::write(const char*)'
D:\arduino-1.0.1\hardware\arduino\cores\arduino\Print.cpp: In member function 'size_t Print::print(const String&)':
D:\arduino-1.0.1\hardware\arduino\cores\arduino\Print.cpp:58: error: invalid conversion from 'char' to 'const char*'
D:\arduino-1.0.1\hardware\arduino\cores\arduino\Print.cpp:58: error: initializing argument 1 of 'size_t Print::write(const char*)'
D:\arduino-1.0.1\hardware\arduino\cores\arduino\Print.cpp: In member function 'size_t Print::print(char)':
D:\arduino-1.0.1\hardware\arduino\cores\arduino\Print.cpp:70: error: invalid conversion from 'char' to 'const char*'
D:\arduino-1.0.1\hardware\arduino\cores\arduino\Print.cpp:70: error: initializing argument 1 of 'size_t Print::write(const char*)'
D:\arduino-1.0.1\hardware\arduino\cores\arduino\Print.cpp: In member function 'size_t Print::print(long int, int)':
D:\arduino-1.0.1\hardware\arduino\cores\arduino\Print.cpp:91: error: invalid conversion from 'long int' to 'const char*'
D:\arduino-1.0.1\hardware\arduino\cores\arduino\Print.cpp:91: error: initializing argument 1 of 'size_t Print::write(const char*)'
D:\arduino-1.0.1\hardware\arduino\cores\arduino\Print.cpp: In member function 'size_t Print::print(long unsigned int, int)':
D:\arduino-1.0.1\hardware\arduino\cores\arduino\Print.cpp:106: error: invalid conversion from 'long unsigned int' to 'const char*'
D:\arduino-1.0.1\hardware\arduino\cores\arduino\Print.cpp:106: error: initializing argument 1 of 'size_t Print::write(const char*)'
Вот код
#include <SPI.h> #include <SdFat.h> #include <SdFatUtil.h> #include <Ethernet.h> /************ ETHERNET STUFF ************/ byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; byte ip[] = { 192, 168, 1, 177 }; char rootFileName[] = "index.htm"; EthernetServer server(80); /************ SDCARD STUFF ************/ Sd2Card card; SdVolume volume; SdFile root; SdFile file; // store error strings in flash to save RAM #define error(s) error_P(PSTR(s)) void error_P(const char* str) { PgmPrint("error: "); SerialPrintln_P(str); if (card.errorCode()) { PgmPrint("SD error: "); Serial.print(card.errorCode(), HEX); Serial.print(','); Serial.println(card.errorData(), HEX); } while(1); } void setup() { Serial.begin(115200); PgmPrint("Free RAM: "); Serial.println(FreeRam()); // initialize the SD card at SPI_HALF_SPEED to avoid bus errors with // breadboards. use SPI_FULL_SPEED for better performance. pinMode(10, OUTPUT); // set the SS pin as an output (necessary!) digitalWrite(10, HIGH); // but turn off the W5100 chip! if (!card.init(SPI_HALF_SPEED, 4)) error("card.init failed!"); // initialize a FAT volume if (!volume.init(&card)) error("vol.init failed!"); PgmPrint("Volume is FAT"); Serial.println(volume.fatType(),DEC); Serial.println(); if (!root.openRoot(&volume)) error("openRoot failed"); // list file in root with date and size PgmPrintln("Files found in root:"); root.ls(LS_DATE | LS_SIZE); Serial.println(); // Recursive list of all directories PgmPrintln("Files found in all dirs:"); root.ls(LS_R); Serial.println(); PgmPrintln("Done"); // Debugging complete, we start the server! Ethernet.begin(mac, ip); server.begin(); } // How big our line buffer should be. 100 is plenty! #define BUFSIZ 100 void loop() { char clientline[BUFSIZ]; char *filename; int index = 0; int image = 0; EthernetClient client = server.available(); if (client) { // an http request ends with a blank line boolean current_line_is_blank = true; // reset the input buffer index = 0; while (client.connected()) { if (client.available()) { char c = client.read(); // If it isn't a new line, add the character to the buffer if (c != '\n' && c != '\r') { clientline[index] = c; index++; // are we too big for the buffer? start tossing out data if (index >= BUFSIZ) index = BUFSIZ -1; // continue to read more data! continue; } // got a \n or \r new line, which means the string is done clientline[index] = 0; filename = 0; // Print it out for debugging Serial.println(clientline); // Look for substring such as a request to get the root file if (strstr(clientline, "GET / ") != 0) { filename = rootFileName; } if (strstr(clientline, "GET /") != 0) { // this time no space after the /, so a sub-file if (!filename) filename = clientline + 5; // look after the "GET /" (5 chars) // a little trick, look for the " HTTP/1.1" string and // turn the first character of the substring into a 0 to clear it out. (strstr(clientline, " HTTP"))[0] = 0; // print the file we want Serial.println(filename); if (! file.open(&root, filename, O_READ)) { client.println("HTTP/1.1 404 Not Found"); client.println("Content-Type: text/html"); client.println(); client.println("<h2>File Not Found!</h2>"); break; } Serial.println("Opened!"); client.println("HTTP/1.1 200 OK"); if (strstr(filename, ".htm") != 0) client.println("Content-Type: text/html"); else if (strstr(filename, ".css") != 0) client.println("Content-Type: text/css"); else if (strstr(filename, ".png") != 0) client.println("Content-Type: image/png"); else if (strstr(filename, ".jpg") != 0) client.println("Content-Type: image/jpeg"); else if (strstr(filename, ".gif") != 0) client.println("Content-Type: image/gif"); else if (strstr(filename, ".3gp") != 0) client.println("Content-Type: video/mpeg"); else if (strstr(filename, ".pdf") != 0) client.println("Content-Type: application/pdf"); else if (strstr(filename, ".js") != 0) client.println("Content-Type: application/x-javascript"); else if (strstr(filename, ".xml") != 0) client.println("Content-Type: application/xml"); else client.println("Content-Type: text"); client.println(); int16_t c; while ((c = file.read()) >= 0) { // uncomment the serial to debug (slow!) //Serial.print((char)c); client.print((char)c); } file.close(); } else { // everything else is a 404 client.println("HTTP/1.1 404 Not Found"); client.println("Content-Type: text/html"); client.println(); client.println("<h2>File Not Found!</h2>"); } break; } } // give the web browser time to receive the data delay(1); client.stop(); } }Вот ошибка
У меня что-то такое было... Какая-то библиотека (кажется, ethernrt) была старая.
